PJ78L08SQ
3-Terminal Voltage Regulator
Features
SOT-89
Input voltage:up to 30V
Output: 8V
Output current up to 100 mA, internal thermal
overload protection and short-circuit limiting.
1. OUT 2. GND 3. IN
Maximum Ratings
Ratings at TA = 25℃ ambient temperature unless otherwise specified.
Parameter
Symbols
Value
Units
Input Voltage
VI
30
V
Output Current
IO
100
mA
Power Dissipation
PD
500
mW
Junction Temperature
TJ
150
Operating Temperature Range
TOPR
-40~125
Storage Temperature Range
TSTG
-55~150
Vi
C1
0.33 µF
www.pingjingsemi.com
Revision:1.0
May-2019
3
PJ78L08SQ
2
1
Vo
C2
0.1 µF
1/4
PJ78L08SQ
Electrical Characteristics
VI=14V, Io=40mA,0℃≤ TJ≤125℃, Ci=0.33μF,Co=0.1μF,unless otherwise specified.
Parameter
Output Voltage
Symbols
VO
Test Conditions
Min
Typ
Max
Unit
TJ=25℃
7.70
8
8.30
V
IO=1mA to 40mA VI=10.5V to 23V
7.6
8
8.4
V
7.6
8
8.4
V
VI=10.5V to 23V TJ=25℃
175
mV
VI=11V to 23V TJ=25℃
125
mV
IO=1mA to 100 mA, TJ=25℃
80
mV
IO=1mA to 70 mA, TJ=25℃
40
mV
IO=1mA to 70mA
Line Regulation
Load Regulation
Vo
VO
Ripple Rejection
RR
VI=11V to 23V, TJ=25℃ f=120Hz
Output Noise Voltage
VN
Dropout Voltage
VD
Quiescent Current
IQ
Quiescent Current Change
Revision:1.0
May-2019
IQ
45
dB
f=10Hz~100KHz
49
μV
TJ=25℃
1.7
V
36
5.5
mA
VI=11V to 23V
1.5
mA
IO=1mA to 40mA
0.1
mA
2/4
PJ78L08SQ
Ratings and Characteristic Curves
Dropout Characteristics
Output Characteristics
9.0
10
TJ=25℃
IO=0mA
9
TJ=25℃
8.5
(V)
(V)
8
8.0
VO
6
OUTPUT VOLTAGE
OUTPUT VOLTAGE VO
7
5
4
3
2
7.5
7.0
IO=0、40、70、100mA
6.5
6.0
5.5
1
10
15
INPUT VOLTAGE
VIN
25
30
7
8
9
10
11
INPUT VOLTAGE
(V)
Quiescent Current vs Input Voltage
12
VIN
13
Current Cut-off Grid Voltage
4.0
9
IO=0mA
VIN=14V
TJ=25℃
3.5
TJ=25℃
Pulsed
(V)
(mA)
8
VO
IQ
3.0
OUTPUT VOLTAGE
2.5
QUIESCENT CURRENT
14
(V)
2.0
1.5
1.0
7
6
5
4
0.5
0.0
10
15
INPUT VOLTAGE
VIN
25
3
0.00
30
0.05
0.10
0.15
OUTPUT CURRENT
(V)
Output Voltage vs Junction Temperature
IO
0.20
0.25
(A)
Power Derating Curve
800
9.0
Vin=14V
IO=5mA
700
8.0
500
POWER DISSIPATION
OUTPUT VOLTAGE VO
600
PD
(V)
(mW)
8.5
7.5
7.0
6.5
400
300
200
100
6.0
-25
50
JUNCTION TEMPERATURE
Revision:1.0
May-2019
75
TJ
100
125
50
75
TJ
100
125
3/4
PJ78L08SQ
Package Outline
SOT-89
Dimensions in mm
Ordering Information
Device
Package
Shipping
PJ78L08SQ
SOT-89
1,000/ Tape & Reel (7 inches)
Revision:1.0
May-2019
4/4
很抱歉,暂时无法提供与“PJ78L08SQ”相匹配的价格&库存,您可以联系我们找货
