PESDxUSB3B/C series
ESD protection for differential data lines
Rev. 2 — 29 January 2019
Product data sheet
1. Product profile
1.1. General description
ElectroStatic Discharge (ESD) protection for one, two and three differential channels.
The devices are footprint compatible to PCMFxUSB3B/C common mode filters with ESD
protection.
Diodes provide protection to downstream components from ESD voltages up to ±20 kV on each
signal line.
Table 1. Product overview
Type number
Number of channels Package Name
PESD1USB3B/C
1
WLCSP5
PESD2USB3B/C
2
WLCSP10
PESD3USB3B/C
3
WLCSP15
1.2. Features and benefits
Allows switching between PCMFxUSB3B/C common mode filters with ESD protection and
PESDxUSB3B/C ESD protection in the same footprint
TrEOS protection process for very high system-level ESD robustness: superior protection of
sensitive Systems on Chips (SoCs)
ESD protection for one, two and three differential channels up to ±20 kV contact discharge
according to IEC 61000-4-2
Industry-standard WLCSP5, 10 and 15 packages for smallest footprint
Bidirectional for audio line option
1.3. Applications
Smartphone, cellular and cordless phone
USB3.2, USB2.0, HDMI2.0, HDMI1.4
General-purpose downstream ESD protection for differential data lines
Tablet PC and Mobile Internet Device (MID)
MIPI D-PHY as used in Camera Serial Interface (CSI) and Display Serial Interface (DSI)
PESDxUSB3B/C series
Nexperia
2. Pinning information
Table 2. Pinning
Pin
Symbol
Description
Simplified outline
Graphic symbol
PESD1USB3B/C (WLCSP5_2-1-2)
A1
CH1_IN+
channel 1+, external
A2
CH1_IN-
channel 1-, external
B1
GND_CH1
ground channel 1
C1
CH1_OUT+
channel 1+, internal
C2
CH1_OUT-
channel 1-, internal
2
B1
A1
C1
A2
C2
1
A
B
C
Transparent top view
WLCSP5_2-1-2
B1
aaa-028532
PESD2USB3B/C (WLCSP10_4-2-4)
A1
CH1_IN+
A2
CH1_IN-
A3
CH2_IN+
channel 2+, external
A4
CH2_IN-
channel 2-, external
B1
GND_CH1
ground channel 1
B2
GND_CH2
ground channel 2
C1
CH1_OUT+
C2
CH1_OUT-
C3
CH2_OUT+
channel 2+, internal
C4
CH2_OUT-
channel 2-, internal
4
B2
A1, 3
C1, 3
A2, 4
C2, 4
3
2
B1
1
B1, B2 - no internal connection
A
B
C
aaa-028533
WLCSP10_4-2-4
PESD3USB3B/C (WLCSP15_6-3-6)
A1
CH1_IN+
A2
CH1_IN-
A3
CH2_IN+
A4
CH2_IN-
A5
CH3_IN+
channel 3+, external
A6
CH3_IN-
channel 3-, external
B1
GND_CH1
ground channel 1
B2
GND_CH2
ground channel 2
B3
GND_CH3
ground channel 3
C1
CH1_OUT+
C2
CH1_OUT-
C3
CH2_OUT+
C4
CH2_OUT-
C5
CH3_OUT+
channel 3+, internal
C6
CH3_OUT-
channel 3-, internal
PESDXUSB3B_C_SER
Product data sheet
6
B3
A1, 3, 5
C1, 3, 5
A2, 4, 6
C2, 4, 6
5
4
B2
3
B1, B2, B3 - no internal connection
aaa-028534
2
B1
1
A
B
C
WLCSP15_6-3-6
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 18
PESDxUSB3B/C series
Nexperia
3. Ordering information
Table 3. Ordering information
Type number
Package
Name
Description
PESD1USB3B/C
WLCSP5
wafer level chip-size package; 5 bumps (2-1-2)
PESD2USB3B/C
WLCSP10
wafer level chip-size package; 10 bumps (4-2-4)
PESD3USB3B/C
WLCSP15
wafer level chip-size package; 15 bumps (6-3-6)
4. Marking
Table 4. Marking codes
Type number
Marking code
PESD1USB3B/C
PD1B
PESD2USB3B/C
PD2B
PESD3USB3B/C
PD3B
5. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VI
input voltage
Conditions
VESD
electrostatic discharge
voltage
Min
Max
Unit
-4
4
V
IEC 61000-4-2, level 4; all
input pins to ground
contact discharge
-20
kV
air discharge
-20
kV
output pins to ground
PESDXUSB3B_C_SER
Product data sheet
contact discharge
-2
2
kV
air discharge
-2
2
kV
-9.5
9.5
A
IPPM
rated peak-pulse
current
tp = 8/20 μs
Tstg
storage temperature
-40
+125
°C
Tamb
ambient temperature
-40
+125
°C
3 / 18
PESDxUSB3B/C series
Nexperia
6. Characteristics
6.1. Channel characteristics
Table 6. Channel characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
Cd
diode capacitance
f = 1 MHz; VI = 2.5 V
IRM
reverse leakage current
per line; VI = 5 V
VBR
breakdown voltage
IR = 1 mA
VF
forward voltage
IF = 10 mA
Rdyn
dynamic resistance
TLP
Typ
Max
Unit
0.29
pF
1
100
nA
6
9
V
0.8
V
[1] -
[2]
positive transient
0.2
Ω
negative transient
0.2
Ω
surge
[1]
[2]
[3]
Min
[3]
positive transient
0.2
Ω
negative transient
0.2
Ω
Min
Typ
Max
Unit
16.1
GHz
This parameter is guaranteed by design.
100 ns Transmission Line Pulse (TLP); 50 Ω; pulser at 70 to 90 ns.
According to IEC 61000-4-5 (8/20 μs).
6.2. Frequency characteristics
Table 7. Frequency characteristics
Symbol Parameter
Conditions
Differential mode: Sdd21
f-3dB
[1]
cut-off frequency
[1] -
Normalized to attenuation at 1 MHz.
aaa-028535
Sdd21
(dB)
aaa-028537
Sdd21
(dB)
-1
-20
-2
-40
-3
-60
-4
-5
107
Fig. 1.
108
109
1010
f (Hz)
Differential mode insertion loss; typical values
PESDXUSB3B_C_SER
Product data sheet
-80
108
1011
Fig. 2.
109
f (Hz)
1010
Differential crosstalk; typical values
4 / 18
PESDxUSB3B/C series
Nexperia
aaa-028581
115
Zdif
(Ω)
105
Z reference
Z DUT
95
85
43.8
43.9
44.0
44.1
44.2
t (ns)
44.3
tr = 200 ps
Fig. 3.
Differential Time Domain Reflectometer (TDR) plot; typical values
Fig. 4.
USB 3.2 eye diagram 10 Gbps, test board with PCMFxUSB3B/C; typical values
Fig. 5.
USB 3.2 eye diagram 10 Gbps, test board without device; typical values
PESDXUSB3B_C_SER
Product data sheet
5 / 18
PESDxUSB3B/C series
Nexperia
Fig. 6.
USB 3.2 eye diagram 5 Gbps, test board with PCMFxUSB3B/C; typical values
Fig. 7.
USB 3.2 eye diagram 5 Gbps, test board without device; typical values
PESDXUSB3B_C_SER
Product data sheet
6 / 18
PESDxUSB3B/C series
Nexperia
1080p, 6 Gbps
Fig. 8.
HDMI 2.0 eye diagram TP1, test board with PCMFxUSB3B/C; typical values
1080p, 6 Gbps
Fig. 9.
HDMI 2.0 eye diagram TP1, test board without device; typical values
Fig. 10. HDMI 2.0 eye diagram TP2, test board with PCMFxUSB3B/C; typical values
PESDXUSB3B_C_SER
Product data sheet
7 / 18
PESDxUSB3B/C series
Nexperia
1080p, 6 Gbps
Fig. 11. HDMI 2.0 eye diagram TP2, test board without device; typical values
aaa-028542
25
I
(A)
aaa-028543
I
(A)
15
-10
10
-15
5
-20
10
15
VCL (V)
25
Transmission Line Pulse (TLP) = 100 ns;
Fig. 12. Dynamic resistance with positive clamping;
typical values
PESDXUSB3B_C_SER
Product data sheet
-25
-25
-20
-15
-10
-5
VCL (V)
Fig. 13. Dynamic resistance with negative clamping;
typical values
8 / 18
PESDxUSB3B/C series
Nexperia
aaa-028544
80
I
(A)
aaa-028545
I
(A)
60
-20
40
-40
60
80
VCL (V)
-80
-80
-60
-40
-20
VCL (V)
Transmission Line Pulse (TLP) = 5 ns
Fig. 14. Dynamic resistance with positive clamping;
typical values
Fig. 15. Dynamic resistance with negative clamping;
typical values
The device uses an advanced clamping structure showing a negative dynamic resistance.
This snap-back behavior strongly reduces the clamping voltage to the system behind the ESD
protection during an ESD event. Do not connect unlimited DC current sources to the data lines to
avoid keeping the ESD protection device in snap-back state after exceeding breakdown voltage
(due to an ESD pulse for instance).
aaa-028546
10
I
(A)
aaa-028547
I
(A)
8
-2
6
-4
4
-6
2
-8
4
6
8
VCL (V)
10
IEC61000-4-5; tp = 8/20 μs; positive pulse
Fig. 16. Dynamic resistance with positive clamping;
typical values
PESDXUSB3B_C_SER
Product data sheet
-10
-10
-8
-6
-4
-2
VCL (V)
IEC61000-4-5; tp = 8/20 μs; negative pulse
Fig. 17. Dynamic resistance with negative clamping;
typical values
9 / 18
PESDxUSB3B/C series
Nexperia
7. Application information
The device is designed to provide high-level ESD protection for differential high-speed data line
pairs such as:
USB 3.2
HDMI 2.0
Transition-Minimized Differential Signaling (TMDS)
DisplayPort
external Serial Advanced Technology Attachment (eSATA)
Low Voltage Differential Signaling (LVDS)
When designing the Printed-Circuit Board (PCB), give careful consideration to impedance matching
and signal coupling. Do not connect the protected signal lines to unlimited current sources like, for
example, a battery.
Fig. 18. Application diagram: protecting the differential data lines of a USB Type-C
connector evaluation dongle with PESD1USB3B/C
Since the SuperSpeed TX/RX lines are separated by GND or VBUS from the Hi-Speed lines,
PESD1USB3B/C makes it easy to achieve same signal lengths, straight routing, and optimal
positioning for ESD protection directly at the connector.
PESDXUSB3B_C_SER
Product data sheet
10 / 18
PESDxUSB3B/C series
Nexperia
8. Package outline
WLCSP5: wafer level chip-size package; 5 bumps (2-1-2)
PESD1USB3B/C
D
bump A1
index area
A1
E
A
detail X
e
1/2 e
b
C
e1
B1
B
e2
A
bump A1
index area
1
2
X
1 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
A1
b
D
E
e
e1
e2
max 0.64 0.42 0.31 0.82 1.22
nom 0.61 0.41 0.26 0.77 1.17 0.40 0.40 0.80
min 0.58 0.40 0.21 0.72 1.12
pesd1usb3b-c_po
Outline
version
References
IEC
JEDEC
JEITA
European
projection
Issue date
18-05-16
PESD1USB3B/C
Fig. 19. Package outline WLCSP5
PESDXUSB3B_C_SER
Product data sheet
11 / 18
PESDxUSB3B/C series
Nexperia
WLCSP10: wafer level chip-size package; 10 bumps (4-2-4)
PESD2USB3B/C
D
bump A1
index area
A1
E
A
detail X
e
b
C
e1
B1
B
B2
e2
A
bump A1
index area
1
2
3
4
e3
X
1/2 e
1 mm
scale
Unit
mm
A
A1
b
D
E
e
e1
e2
max 0.64 0.42 0.31 1.62 1.22
nom 0.61 0.41 0.26 1.57 1.17 0.40 0.40 0.80
min 0.58 0.40 0.21 1.52 1.12
e3
0.80
pesd2usb3b-c_po
Outline
version
References
IEC
JEDEC
JEITA
European
projection
Issue date
18-05-16
PESD2USB3B/C
Fig. 20. Package outline WLCSP10
PESDXUSB3B_C_SER
Product data sheet
12 / 18
PESDxUSB3B/C series
Nexperia
WLCSP15: wafer level chip-size package; 15 bumps (6-3-6)
PESD3USB3B/C
D
bump A1
index area
A1
E
A
detail X
e
1/2 e
b
C
B1
B
B2
e1
B3
e2
A
1
bump A1
index area
2
3
4
5
6
e3
X
1 mm
scale
Unit
mm
A
A1
b
D
E
e
e1
e2
e3
max 0.64 0.42 0.31 2.42 1.22
nom 0.61 0.41 0.26 2.37 1.17 0.40 0.40 0.80 0.80
min 0.58 0.40 0.21 2.32 1.12
pesd3usb3b-c_po
Outline
version
References
IEC
JEDEC
JEITA
European
projection
Issue date
18-05-16
PESD3USB3B/C
Fig. 21. Package outline WLCSP15
PESDXUSB3B_C_SER
Product data sheet
13 / 18
PESDxUSB3B/C series
Nexperia
9. Soldering
WLCSP5: Solder footprint and stencil aperture
PESD1USB3B/C
Hx
P
see
detail X
P
solder land (SL)
Hy
solder paste deposit (SP)
solder land plus solder paste
SL = SP
solder resist opening (SR)
SR
occupied area
detail X
Dimensions in mm
P
SL
SP
SR
Hx
recommend stencil thickness: 0.1 mm
Hy
18-05-16
0.40 0.25 0.25 0.325 1.00 1.40
pesd1usb3b-c_fr
Fig. 22. Soldering footprint WLCSP5 (PESD1USB3B/C)
WLCSP10: Solder footprint and stencil aperture
PESD2USB3B/C
Hx
P
see
detail X
P
solder land (SL)
Hy
SL = SP
SR
occupied area
P1
Dimensions in mm
P
P1
SL
SP
SR
Hx
Hy
detail X
18-05-16
0.40 0.80 0.25 0.25 0.325 1.80 1.40
pesd2usb3b-c_fr
Fig. 23. Soldering footprint WLCSP10 (PESD2USB3B/C)
PESDXUSB3B_C_SER
Product data sheet
14 / 18
PESDxUSB3B/C series
Nexperia
WLCSP15: Solder footprint and stencil aperture
PESD3USB3B/C
Hx
P
see
detail X
P
solder land (SL)
Hy
SL = SP
SR
occupied area
P1
Dimensions in mm
P
P1
SL
SP
SR
Hx
Hy
detail X
18-05-16
0.40 0.80 0.25 0.25 0.325 2.60 1.40
pesd3usb3b-c_fr
Fig. 24. Soldering footprint WLCSP15 (PESD3USB3B/C)
PESDXUSB3B_C_SER
Product data sheet
15 / 18
PESDxUSB3B/C series
Nexperia
10. Revision history
Table 8. Revision history
Document ID
Release
date
Data sheet status
Change
notice
Supersedes
PESDxUSB3B_C_SER v.2
20190129
Product data sheet
PESDxUSB3B_C_SER v.1
Modifications:
20180706
PESDXUSB3B_C_SER
Product data sheet
Limiting values: maximum value for Tamb updated
Frequency characteristics: Fig 2 removed and Fig 3 title adjusted
Product data sheet
16 / 18
PESDxUSB3B/C series
Nexperia
11. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
PESDXUSB3B_C_SER
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
17 / 18
PESDxUSB3B/C series
Nexperia
Contents
1. Product profile.............................................................. 1
1.1. General description......................................................1
1.2. Features and benefits..................................................1
1.3. Applications................................................................. 1
2. Pinning information......................................................2
3. Ordering information....................................................3
4. Marking.......................................................................... 3
5. Limiting values............................................................. 3
6. Characteristics.............................................................. 4
6.1. Channel characteristics............................................... 4
6.2. Frequency characteristics............................................4
7. Application information............................................. 10
8. Package outline.......................................................... 11
9. Soldering..................................................................... 14
10. Revision history........................................................16
11. Legal information......................................................17
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 29 January 2019
PESDXUSB3B_C_SER
Product data sheet
18 / 18
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
PESD1USB3B/CX PESD2USB3B/CX PESD3USB3B CX PESD3USB3B/CX
