ES1AG THRU ES1JG
Reverse Voltage - 50 to 600 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER
Features
DO-214AC/SMA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Low reverse leakage
Built-in strain relief,ideal for automated
placement High forward surge current capability
High temperature soldering guaranteed:
0.110(2.80)
0.094(2.40)
0.067 (1.70)
0.051 (1.30)
0.177(4.50)
0.157(3.99)
0.012(0.305)
0.006(0.152)
250°C/10 seconds at terminals
Glass passivated chip junction
0.096(2.42)
0.078(1.98)
0.060(1.52)
0.030(0.76)
Mechanical Data
0.008(0.203)MAX.
0.208(5.30)
0.188(4.80)
Case : JEDEC DO-214AC/SMA Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.002 ounce, 0.055 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
ES1AG ES1BG ES1CG ES1DG ES1EG ES1GG ES1JG
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=55℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
at rated DCblocking voltage
TA=25℃
VRMM
VRMS
VDC
I(AV)
MDD
ES1A
MDD
ES1B
MDD
ES1C
MDD
ES1D
MDD
ES1E
MDD
ES1G
MDD
ES1J
50
35
50
100
70
100
150
105
150
200
140
200
300
210
300
400
280
400
600
420
600
IFSM
VF
IR
TA=125℃
UNITS
V
V
V
1.0
A
30
A
0.95
1.25
5.0
100.0
1.7
V
μA
trr
35
ns
CJ
15.0
pF
Typical thermal resistance (NOTE 3)
RJA
75.0
℃/W
Operating junction and storage temperature range
TJ,TSTG
-55 to +150
Maximum reverse recovery time
(NOTE 1)
Typical junction capacitance (NOTE 2)
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.P.C.B. mounted with 1.0x1.0”(2.54x2.54cm) copper pad areas.
3.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
4.The typical data above is for referenceonly.
DN:T19704A0
https://www.microdiode.com
Rev:2019A0
Page :1
ES1AG THRU ES1JG
Ratings And Characteristic Curves
10 ohm
Noninductive
50 ohm
Noninductive
t rr
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
OSCILLOSCOPE
Note 1
NonInductive
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
300
1.2
1.0
I R - Reverse Current (μA)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
0.8
0.6
0.4
0.2
Single phase half wave resistive or inductive
0.0
25
50
75
100
125
150
175
100
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
Case Temperature (°C)
Junction Capacitance (pF)
Instaneous Forward Current (A)
30
T J =25°C
ES1A~ES1D
ES1E/ES1G
0.1
ES1J
0.01
100
Fig.5 Typical Junction Capacitance
1.0
0.001
80
60
% of PIV.VOLTS
Fig.4 Typical Forward Characteristics
10
40
1.0
2.0
2.5
Instaneous Forward Voltage (V)
25
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
05
0.1
1
10
100
Reverse Voltage (V)
Peak Forward Surge Current (A)
Fig.6 Maximum Non-Repetitive Peak
35
30
25
10
05
00
8.3 ms Single Half Sine Wave
(JEDEC Method)
10
1
100
Number of Cycles
The curve above is for reference only.
Rev:2019A0
Page :2
ES1AG THRU ES1JG
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SMA
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.80
5.33
2.36
1.50
330.00
50.00
178.00
62.00
13.00
1.75
5.50
4.00
4.00
2.00
0.28
12.00
18.00
E
F
B
A
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
2,000
4.0
4,000
183*155*183
178
CARTON
SIZE
(m/m)
CARTON
(pcs)
APPROX.
GROSS WEIGHT
(kg)
SMA
7"
SMA
11"
5,000
4.0
10,000
290*290*38
330
310*310*360
80,000
11.0
SMA
13"
7,500
4.0
15,000
335*335*38
330
350*330*360
120,000
14.5
382*356*392
160,000
16.0
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
1.68
0.066
B
1.52
0.060
C
3.90
0.154
D
2.41
0.095
E
5.45
0.215
Important Notice and Disclaimer
Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the latest product information and
specifications before final design,purchase or use.
Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its
products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application
assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with
products which are purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode
Electronics (Jiangsu).
Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support
devices or systems without express written approval of Microdiode Electronics (Jiangsu).
Rev:2019A0
Page :3
很抱歉,暂时无法提供与“ES1D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.04799
- 30+0.04618
- 100+0.04258
- 500+0.03897
- 1000+0.03716
- 国内价格
- 10+0.04998
- 50+0.04623
- 200+0.04311
- 600+0.03999
- 1500+0.03749
- 3000+0.03592
