6A10
6A10
    MDD(辰达半导体)
    R-6
    整流二极管 VR=1000V IF=6A VF=0.95V IR=5uA
6A10 数据手册
6A05 THRU 6A10 GENERAL PURPOSE SILICON RECTIFIER Reverse Voltage - 50 to 1000 Volts R-6 Forward Current - 6.0 Amperes FEATURES The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 Construction utilizes void-free molded plastic technique Low reverse leakage High forward surge current capability High temperature soldering guaranteed: 250 C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension 1.0 (25.4) MIN. 0.360 (9.1) 0.340(8.6) DIA. 0.360(9.1) 0.340(8.6) MECHANICAL DATA 1.0 (25.4) MIN. 0.052 (1.3) 0.048 (1.2) DIA. Dimensions in inches and (millimeters) Case: R-6 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.072 ounce, 2.05 grams MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. MDD Catalog Number Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current 0.375”(9.5mm) lead length at TA=60 C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 6.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction and storage temperature range SYMBOLS 6A05 6A1 6A2 6A4 6A6 6A8 6A10 UNITS VRRM VRMS VDC 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 VOLTS VOLTS VOLTS I(AV) 6.0 Amps IFSM 400 Amps VF 0.95 Volts IR 10.0 400 µA CJ RθJA TJ,TSTG 150 10.0 -50 to +150 pF C/W C Note: 1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.Thermal resistance from junction to ambient at 0.375” (9.5mm)lead length,P.C.B. mounted FIG. 1- FORWARD CURRENT DERATING CURVE 6.0 4.8 3.6 Single Phase Half Wave 60Hz Resistive or inductive Load 2.4 1.2 0 0 25 50 75 100 125 150 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES RATINGS AND CHARACTERISTIC CURVES 6A05 THRU 6A10 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 400 320 240 160 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 80 175 0 1 10 AMBIENT TEMPERATURE, C 100 10 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 0.1 0.5 0.7 0.9 1.1 1.3 1.4 FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 200 1 1,000 TJ=150 C 100 10 0.1 TJ=25 C 0.01 0 20 40 60 80 TJ=25 C 100 TRANSIENT THERMAL IMPEDANCE, C/W 2000 FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 10 0.1 1.0 10 REVERSE VOLTAGE,VOLTS 100 PERCENT OF PEAK REVERSE VOLTAGE,% FIG. 5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE, pF TJ=100 C 1 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 1000 100 NUMBER OF CYCLES AT 60 Hz 100 t,PULSE DURATION,sec. The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)! 100
很抱歉,暂时无法提供与“6A10”相匹配的价格&库存,您可以联系我们找货
6A10
  • 1+0.33409
  • 10+0.30840
  • 30+0.30326
6A10
    • 10000+0.28820
    库存:2000000
