74AHC02; 74AHCT02
Quad 2-input NOR gate
Rev. 04 — 21 May 2008
Product data sheet
1. General description
The 74AHC02; 74AHCT02 is a high-speed Si-gate CMOS device and is pin compatible
with Low-power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard
No. 7-A.
The 74AHC02; 74AHCT02 provides a quad 2-input NOR function.
2. Features
n
n
n
n
Balanced propagation delays
All inputs have a Schmitt-trigger action
Inputs accept voltages higher than VCC
Input levels:
u For 74AHC02: CMOS level
u For 74AHCT02: TTL level
n ESD protection:
u HBM EIA/JESD22-A114E exceeds 2000 V
u MM EIA/JESD22-A115-A exceeds 200 V
u CDM EIA/JESD22-C101C exceeds 1000 V
n Multiple package options
n Specified from −40 °C to +85 °C and from −40 °C to +125 °C
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74AHC02D
−40 °C to +125 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
74AHC02PW
−40 °C to +125 °C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74AHC02BQ
−40 °C to +125 °C
DHVQFN14
plastic dual in-line compatible thermal enhanced very SOT762-1
thin quad flat package; no leads; 14 terminals;
body 2.5 × 3 × 0.85 mm
74AHC02
74AHC02; 74AHCT02
Nexperia
Table 1.
Ordering information …continued
Type number
Package
Description
Version
74AHCT02D
−40 °C to +125 °C
SO14
body width 3.9 mm
SOT108-1
74AHCT02PW
−40 °C to +125 °C
TSSOP14
body width 4.4 mm
SOT402-1
74AHCT02BQ
−40 °C to +125 °C
DHVQFN14
74AHCT02
4. Functional diagram
2
1A
3
1B
5
2A
6
2B
8
3A
9
3B
11
4A
12
4B
2
1Y
1
2Y
4
3Y
10
3
5
6
8
9
4Y
11
13
12
≥1
1
≥1
4
≥1
10
A
≥1
Y
13
B
001aah084
mna216
Fig 1.
Logic symbol
Fig 2.
IEC logic symbol
Fig 3.
Logic diagram (one gate)
74AHC_AHCT02_4
Product data sheet
mna215
Nexperia B.V. 2017. All rights reserved
2 of 14
74AHC02; 74AHCT02
Nexperia
5. Pinning information
1
1Y
terminal 1
index area
14 VCC
5.1 Pinning
2Y
4
2A
5
2B
6
1
1A
2
14 VCC
13 4Y
1B
3
12 4B
2Y
4
2A
5
10 3Y
8
12 4B
1Y
2B
6
9
3B
3A
13 4Y
3
7
2
1B
GND
7
8
3A
GND
1A
02
11 4A
02
11 4A
GND(1)
10 3Y
9
3B
001aac920
Transparent top view
001aac919
(1) The die substrate is attached to this pad using
conductive die attach material. It can not be used as a
supply pin or input.
Fig 4.
Pin configuration SO14 and TSSOP14
Fig 5.
Pin configuration DHVQFN14
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1Y
1
data output
1A
2
data input
1B
3
data input
2Y
4
data output
2A
5
data input
2B
6
data input
GND
7
ground (0 V)
3A
8
data input
3B
9
data input
3Y
10
data output
4A
11
data input
4B
12
data input
4Y
13
data output
VCC
14
supply voltage
74AHC_AHCT02_4
Product data sheet
3 of 14
74AHC02; 74AHCT02
Nexperia
6. Functional description
Function table[1]
Table 3.
Input
Output
nA
nB
nY
L
L
H
X
H
L
H
X
L
[1]
H = HIGH voltage level;
L = LOW voltage level;
X = don’t care.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
IIK
input clamping current
VI < −0.5 V
[1]
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = −0.5 V to (VCC + 0.5 V)
ICC
IGND
Tstg
storage temperature
Min
Max
Unit
−0.5
+7.0
V
−0.5
+7.0
V
−20
mA
−20
+20
mA
−25
+25
mA
supply current
+75
mA
ground current
−75
mA
−65
+150
°C
500
mW
total power dissipation
Ptot
Conditions
Tamb = −40 °C to +125 °C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 packages: above 70 °C the value of Ptot derates linearly at 8 mW/K.
For TSSOP14 packages: above 60 °C the value of Ptot derates linearly at 5.5 mW/K.
For DHVQFN14 packages: above 60 °C the value of Ptot derates linearly at 4.5 mW/K.
8. Recommended operating conditions
Table 5.
Operating conditions
Symbol Parameter
Conditions
Min
Typ
Max
Unit
2.0
5.0
5.5
V
74AHC02
VCC
supply voltage
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
input transition rise and fall rate
VCC = 3.0 V to 3.6 V
100
ns/V
VCC = 4.5 V to 5.5 V
ns/V
74AHC_AHCT02_4
Product data sheet
4 of 14
74AHC02; 74AHCT02
Nexperia
Table 5.
Operating conditions …continued
Symbol Parameter
Conditions
Min
Typ
Max
Unit
74AHCT02
VCC
supply voltage
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 °C
Conditions
−40 °C to +85 °C −40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
HIGH-level
VI = VIH or VIL
output voltage
IO = −50 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −50 µA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = −50 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = −8.0 mA; VCC = 4.5 V
3.94
3.80
3.70
V
LOW-level
VI = VIH or VIL
output voltage
IO = 50 µA; VCC = 2.0 V
0.1
0.1
V
IO = 50 µA; VCC = 3.0 V
0.1
0.1
V
IO = 50 µA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
0.1
1.0
2.0
µA
74AHC02
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
2.0
µA
CI
input
capacitance
3
10
10
10
pF
74AHC_AHCT02_4
Product data sheet
5 of 14
74AHC02; 74AHCT02
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
Typ
Max
Min
Max
Min
Max
74AHCT02
VIH
HIGH-level
input voltage
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = −50 µA
4.4
4.5
4.4
4.4
V
3.94
3.80
3.70
V
IO = −8.0 mA
VOL
LOW-level
output voltage
IO = 50 µA
IO = 8.0 mA
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
µA
II
input leakage
current
ICC
VCC = 5.5 V
2.0
µA
∆ICC
additional
per input pin;
supply current VI = VCC − 2.1 V;
other pins at VCC or GND;
IO = 0 A; VCC = 4.5 V to 5.5 V
1.35
1.5
1.5
mA
CI
input
capacitance
3
10
10
10
pF
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7.
Symbol Parameter
25 °C
Conditions
Min
Typ[1] Max
Min
Max
Min
Max
74AHC02
tpd
propagation
delay
nA, nB to nY; see Figure 6
[2]
CL = 15 pF
3.9
7.9
1.0
9.5
1.0
10.0
ns
CL = 50 pF
5.5
11.4
1.0
13
1.0
14.5
ns
2.9
5.5
1.0
6.5
1.0
7.0
ns
4.2
7.5
1.0
8.5
1.0
9.5
ns
7.0
pF
CL = 15 pF
CL = 50 pF
CPD
power
CL = 50 pF; fi = 1 MHz;
dissipation
VI = GND to VCC
capacitance
[3]
74AHC_AHCT02_4
Product data sheet
6 of 14
74AHC02; 74AHCT02
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
3.8
5.5
1.0
6.5
1.0
7.0
ns
5.1
7.5
1.0
8.5
1.0
9.5
ns
8.0
pF
74AHCT02; VCC = 4.5 V to 5.5 V
propagation
delay
tpd
[2]
CL = 15 pF
CL = 50 pF
[3]
power
dissipation
VI = GND to VCC
capacitance
CPD
[1]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of the outputs.
11. Waveforms
VI
VM
nA, nB input
GND
tPLH
tPHL
VOH
VM
nY output
VOL
001aah085
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 6.
Input to output propagation delays
Table 8.
Measurement points
Type
Input
Output
VM
VM
74AHC02
0.5 × VCC
0.5 × VCC
74AHCT02
1.5 V
0.5 × VCC
74AHC_AHCT02_4
Product data sheet
7 of 14
74AHC02; 74AHCT02
Nexperia
VI
negative
pulse
tW
90 %
VM
VM
10 %
GND
tr
tf
tr
VI
positive
pulse
GND
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
VO
DUT
RT
CL
001aah768
Test data is given in Table 9.
Definitions test circuit:
RT = termination resistance should be equal to output impedance Zo of the pulse generator.
CL = load capacitance including jig and probe capacitance.
Fig 7.
Load circuitry for measuring switching times
Table 9.
Test data
Type
Input
Load
Test
VI
tr, tf
CL
74AHC02
VCC
≤ 3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHCT02
3.0 V
≤ 3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHC_AHCT02_4
Product data sheet
8 of 14
74AHC02; 74AHCT02
Nexperia
12. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.010 0.057
inches 0.069
0.004 0.049
0.05
0.244
0.039
0.041
0.228
0.016
0.028
0.024
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig 8.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT108-1 (SO14)
74AHC_AHCT02_4
Product data sheet
9 of 14
74AHC02; 74AHCT02
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
SOT402-1
E
D
A
X
c
y
HE
v M A
Z
8
14
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
Fig 9.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Package outline SOT402-1 (TSSOP14)
74AHC_AHCT02_4
Product data sheet
10 of 14
74AHC02; 74AHCT02
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT762-1
14 terminals; body 2.5 x 3 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
6
y
y1 C
v M C A B
w M C
b
L
1
7
Eh
e
14
8
13
9
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
mm
c
D (1)
Dh
E (1)
Eh
0.2
3.1
2.9
1.65
1.35
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
2
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT762-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 10. Package outline SOT762-1 (DHVQFN14)
74AHC_AHCT02_4
Product data sheet
11 of 14
74AHC02; 74AHCT02
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MM
Machine Model
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC_AHCT02_4
20080521
Product data sheet
74AHC_AHCT02_3
Modifications:
The format of this data sheet has been redesigned to comply with the new identity guidelines of
NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Table 6: the conditions for input leakage current have been changed.
74AHC_AHCT02_3
20080107
Product data sheet
74AHC_AHCT02_2
74AHC_AHCT02_2
19990923
Product specification
74AHC_AHCT02_1
74AHC_AHCT02_1
19981218
74AHC_AHCT02_4
Product data sheet
12 of 14
74AHC02; 74AHCT02
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
15.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AHC_AHCT02_4
Product data sheet
13 of 14
Nexperia
74AHC02; 74AHCT02
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 6
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12
Legal information. . . . . . . . . . . . . . . . . . . . . . . 13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Contact information. . . . . . . . . . . . . . . . . . . . . 13
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Date of release: 21 May 2008
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AHC02BQ,115 74AHC02D,112 74AHC02D,118 74AHC02PW,112 74AHC02PW,118 74AHCT02D,112
74AHCT02D,118 74AHCT02PW,112 74AHCT02PW,118 74AHCT02BQ,115
