74AHC14PW-Q100,118
74AHC14PW-Q100,118
    NEXPERIA(安世)
    TSSOP14_5.1X4.5MM
    IC INVERTER 6CH 6-INP 14TSSOP
74AHC14PW-Q100,118 数据手册
74AHC14-Q100; 74AHCT14-Q100 Hex inverting Schmitt trigger Rev. 1 — 9 July 2012 Product data sheet 1. General description The 74AHC14-Q100; 74AHCT14-Q100 is a high-speed Si-gate CMOS device and is pin compatible with Low-power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard No. 7A. The 74AHC14-Q100; 74AHCT14-Q100 provides six inverting buffers with Schmitt trigger action. They are capable of transforming slowly changing input signals into sharply defined, jitter-free output signals. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Balanced propagation delays  All inputs have Schmitt trigger actions  Inputs accept voltages higher than VCC  Input levels:  For 74AHC14-Q100: CMOS level  For 74AHCT14-Q100: TTL level  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pf, R = 0 )  Multiple package options 74AHC14-Q100; 74AHCT14-Q100 Nexperia Hex inverting Schmitt trigger 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AHC14D-Q100 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74AHC14PW-Q100 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74AHC14BQ-Q100 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm SOT762-1 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74AHCT14PW-Q100 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74AHCT14BQ-Q100 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm 74AHC14-Q100 74AHCT14-Q100 74AHCT14D-Q100 SOT762-1 4. Functional diagram 1 3 5 9 11 13 1A 1Y 2A 2Y 3A 3Y 4A 4Y 5A 5Y 6A 6Y Logic symbol 74AHC_AHCT14_Q100 Product data sheet 2 3 4 5 6 9 8 11 10 13 12 2 4 6 8 10 12 mna204 Fig 1. 1 A Y mna025 001aac497 Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 Fig 3. Logic diagram (one Schmitt trigger) © Nexperia B.V. 2017. All rights reserved 2 of 17 74AHC14-Q100; 74AHCT14-Q100 Nexperia Hex inverting Schmitt trigger 5. Pinning information 5.1 Pinning 1 1A terminal 1 index area 74AHC14-Q100 74AHCT14-Q100 14 VCC 74AHC14-Q100 74AHCT14-Q100 1Y 2 13 6A 1A 1 14 VCC 2A 3 12 6Y 1Y 2 13 6A 2Y 4 11 5A 2A 3 12 6Y 3A 5 2Y 4 11 5A 3Y 6 6 9 4A 7 8 4Y 8 3Y GND 9 4Y 10 5Y 7 5 GND 3A 10 5Y GND(1) 4A aaa-003136 Transparent top view aaa-003135 (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 4. Pin configuration SO14 and TSSOP14 Fig 5. Pin configuration DHVQFN14 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A 1 data input 1 1Y 2 data output 1 2A 3 data input 2 2Y 4 data output 2 3A 5 data input 3 3Y 6 data output 3 GND 7 ground (0 V) 4Y 8 data output 4 4A 9 data input 4 5Y 10 data output 5 5A 11 data input 5 6Y 12 data output 6 6A 13 data input 6 VCC 14 supply voltage 74AHC_AHCT14_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 3 of 17 74AHC14-Q100; 74AHCT14-Q100 Nexperia Hex inverting Schmitt trigger 6. Functional description Table 3. Function table[1] Input Output nA nY L H H L [1] H = HIGH voltage level; L = LOW voltage level. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage Conditions Min Max Unit 0.5 +7.0 V 0.5 +7.0 V IIK input clamping current VI < 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current VO = 0.5 V to (VCC + 0.5 V) ICC supply current - IGND ground current 75 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot Tamb = 40 C to +125 C [2] 20 - mA 20 +20 mA 25 +25 mA +75 mA [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO14 packages: above 70 C the value of Ptot derates linearly at 8 mW/K. For TSSOP14 packages: above 60 C the value of Ptot derates linearly at 5.5 mW/K. For DHVQFN14 packages: above 60 C the value of Ptot derates linearly at 4.5 mW/K. 8. Recommended operating conditions Table 5. Operating conditions Symbol Parameter Conditions Min Typ Max Unit 74AHC14-Q100 VCC supply voltage 2.0 5.0 5.5 V VI input voltage 0 - 5.5 V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C 4.5 5.0 5.5 V 74AHCT14-Q100 VCC supply voltage VI input voltage 0 - 5.5 V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C 74AHC_AHCT14_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 4 of 17 74AHC14-Q100; 74AHCT14-Q100 Nexperia Hex inverting Schmitt trigger 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max IO = 50 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 50 A; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = 50 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = 8.0 mA; VCC = 4.5 V 3.94 - - 3.80 - 3.70 - V 74AHC14-Q100 VOH VOL HIGH-level output voltage LOW-level output voltage VI = VT+ or VT VI = VT+ or VT IO = 50 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - 0.1 - 1.0 - 2.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2.0 - 20 - 40 A CI input capacitance - 3 10 - 10 - 10 pF CO output capacitance - 4 - - - - - pF IO = 50 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 8.0 mA; VCC = 4.5 V 3.94 - - 3.80 - 3.70 - V IO = 50 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V 74AHCT14-Q100 VOH VOL HIGH-level output voltage VI = VT+ or VT LOW-level output voltage VI = VT+ or VT II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - 0.1 - 1.0 - 2.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2.0 - 20 - 40 A ICC additional supply current per input pin; VI = VCC  2.1 V; other pins at VCC or GND; IO = 0 A; VCC = 4.5 V to 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 3 10 - 10 - 10 pF CO output capacitance - 4 - - - - - pF 74AHC_AHCT14_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 5 of 17 74AHC14-Q100; 74AHCT14-Q100 Nexperia Hex inverting Schmitt trigger 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max CL = 15 pF - 4.3 12.8 1.0 15.0 1.0 16.0 ns CL = 50 pF - 5.8 16.3 1.0 18.0 1.0 20.5 ns - 3.2 8.6 1.0 10.0 1.0 11.0 ns - 4.2 10.6 1.0 12.0 1.0 13.5 ns - 10 - - - - - pF - 4.0 7.0 1.0 8.0 1.0 9.0 ns - 5.4 8.0 1.0 9.0 1.0 10.0 ns - 12 - - - - - pF 74AHC14-Q100 tpd propagation delay [2] nA to nY; see Figure 6 VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF CPD power fi = 1 MHz; VI = GND to VCC dissipation capacitance [3] 74AHCT14-Q100 tpd propagation delay [2] nA to nY; see Figure 6 VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF CPD power fi = 1 MHz; VI = GND to VCC dissipation capacitance [3] [1] Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. 74AHC_AHCT14_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 6 of 17 74AHC14-Q100; 74AHCT14-Q100 Nexperia Hex inverting Schmitt trigger 11. Waveforms VI VM nA input VM GND t PHL t PLH VOH VM nY output VM VOL mna344 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. Table 8. Input to output propagation delays Measurement points Type Input Output VM VM 74AHC14-Q100 0.5  VCC 0.5  VCC 74AHCT14-Q100 1.5 V 0.5  VCC VI negative pulse tW 90 % VM VM 10 % GND tr tf tr tf VI 90 % positive pulse GND VM VM 10 % tW VCC G VI VO DUT RT CL 001aah768 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance Fig 7. Test circuit for measuring switching times 74AHC_AHCT14_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 7 of 17 74AHC14-Q100; 74AHCT14-Q100 Nexperia Hex inverting Schmitt trigger Table 9. Test data Type Input Load VI tr, tf CL Test 74AHC14-Q100 VCC  3.0 ns 50 pF, 15 pF tPLH, tPHL 74AHCT14-Q100 3.0 V  3.0 ns 50 pF, 15 pF tPLH, tPHL 12. Transfer characteristics Table 10. Transfer characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); see Figure 8 and Figure 9. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 3.0 V - - 2.2 - 2.2 - 2.2 V VCC = 4.5 V - - 3.15 - 3.15 - 3.15 V VCC = 5.5 V - - 3.85 - 3.85 - 3.85 V 74AHC14-Q100 VT+ VT VH positive-going threshold voltage negative-going VCC = 3.0 V threshold VCC = 4.5 V voltage VCC = 5.5 V 0.9 - - 0.9 - 0.9 - V 1.35 - - 1.35 - 1.35 - V 1.65 - - 1.65 - 1.65 - V VCC = 3.0 V 0.3 - 1.2 0.3 1.2 0.25 1.2 V VCC = 4.5 V 0.4 - 1.4 0.4 1.4 0.35 1.4 V VCC = 5.5 V 0.5 - 1.6 0.5 1.6 0.45 1.6 V VCC = 4.5 V - - 1.9 - 1.9 - 1.9 V VCC = 5.5 V - - 2.1 - 2.1 - 2.1 V negative-going VCC = 4.5 V threshold VCC = 5.5 V voltage 0.5 - - 0.5 - 0.5 - V 0.6 - - 0.6 - 0.6 - V hysteresis voltage VCC = 4.5 V 0.4 - 1.4 0.4 1.4 0.35 1.4 V VCC = 5.5 V 0.4 - 1.5 0.4 1.5 0.35 1.5 V hysteresis voltage 74AHCT14-Q100 VT+ VT VH positive-going threshold voltage 13. Transfer characteristics waveforms VO VT+ VI VH VT− VI VH VT− Fig 8. VT+ Transfer characteristics 74AHC_AHCT14_Q100 Product data sheet VO mna207 mna208 Fig 9. Transfer characteristics definitions All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 8 of 17 74AHC14-Q100; 74AHCT14-Q100 Nexperia Hex inverting Schmitt trigger mna411 1.5 mna412 5 I CC I CC (mA) (mA) 4 1 3 2 0.5 1 0 0 0 1 2 VI (V) 3 1 0 a. VCC = 3.0 V 2 3 4 V (V) 5 I b. VCC = 4.5 V mna413 6 I CC (mA) 4 2 0 0 2 4 VI (V) 6 c. VCC = 5.5 V Fig 10. Typical 74AHC transfer characteristics 74AHC_AHCT14_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 9 of 17 74AHC14-Q100; 74AHCT14-Q100 Nexperia Hex inverting Schmitt trigger mna414 6 mna415 8 I CC I CC (mA) (mA) 6 4 4 2 2 0 0 0 1 2 4 V (V) 5 I 3 0 a. VCC = 4.5 V 2 4 VI (V) 6 b. VCC = 5.5 V Fig 11. Typical 74AHCT transfer characteristics 14. Application information R C mna035 1 T 1 0.55  RC For 74AHC14-Q100: f = ---  ------------------------ 1 T 1 0.60  RC For 74AHCT14-Q100: f = ---  ------------------------ Fig 12. Relaxation oscillator 74AHC_AHCT14_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 10 of 17 74AHC14-Q100; 74AHCT14-Q100 Nexperia Hex inverting Schmitt trigger 15. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.010 0.057 inches 0.069 0.004 0.049 0.05 0.244 0.039 0.041 0.228 0.016 0.028 0.024 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 13. Package outline SOT108-1 (SO14) 74AHC_AHCT14_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 11 of 17 74AHC14-Q100; 74AHCT14-Q100 Nexperia Hex inverting Schmitt trigger TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 E D A X c y HE v M A Z 8 14 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 14. Package outline SOT402-1 (TSSOP14) 74AHC_AHCT14_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 12 of 17 74AHC14-Q100; 74AHCT14-Q100 Nexperia Hex inverting Schmitt trigger DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT762-1 14 terminals; body 2.5 x 3 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 6 y y1 C v M C A B w M C b L 1 7 Eh e 14 8 13 9 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT mm A(1) max. A1 b 1 0.05 0.00 0.30 0.18 c D (1) Dh E (1) Eh 0.2 3.1 2.9 1.65 1.35 2.6 2.4 1.15 0.85 e 0.5 e1 L v w y y1 2 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT762-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 15. Package outline SOT762-1 (DHVQFN14) 74AHC_AHCT14_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 13 of 17 74AHC14-Q100; 74AHCT14-Q100 Nexperia Hex inverting Schmitt trigger 16. Abbreviations Table 11. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model LSTTL Low-power Schottky Transistor-Transistor Logic MM Machine Model MIL Military 17. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AHC_AHCT14_Q100 v.1 20120709 - - 74AHC_AHCT14_Q100 Product data sheet Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 14 of 17 74AHC14-Q100; 74AHCT14-Q100 Nexperia Hex inverting Schmitt trigger 18. Legal information 18.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 18.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 18.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74AHC_AHCT14_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 15 of 17 Nexperia 74AHC14-Q100; 74AHCT14-Q100 Hex inverting Schmitt trigger No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 18.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 19. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74AHC_AHCT14_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 16 of 17 Nexperia 74AHC14-Q100; 74AHCT14-Q100 Hex inverting Schmitt trigger 20. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 16 17 18 18.1 18.2 18.3 18.4 19 20 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Transfer characteristics . . . . . . . . . . . . . . . . . . 8 Transfer characteristics waveforms. . . . . . . . . 8 Application information. . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14 Legal information. . . . . . . . . . . . . . . . . . . . . . . 15 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Contact information. . . . . . . . . . . . . . . . . . . . . 16 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 09 July 2012 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74AHCT14D 74AHC14BQ,115 74AHC14D,112 74AHC14D,118 74AHC14PW,112 74AHC14PW,118 74AHCT14BQ,115 74AHCT14D,112 74AHCT14D,118 74AHCT14PW,112 74AHCT14PW,118 74AHCT14DQ100,118 74AHC14BQ-Q100,115 74AHCT14BQ-Q100,11 74AHCT14PW-Q100,11 74AHC14D-Q100,118 74AHC14PW-Q100,118 74AHCT14APWJ
74AHC14PW-Q100,118 价格&库存
很抱歉,暂时无法提供与“74AHC14PW-Q100,118”相匹配的价格&库存,您可以联系我们找货
74AHC14PW-Q100,118
  • 1+3.276901+0.41740
  • 10+2.2624010+0.28810
  • 100+1.34110100+0.17080
  • 1000+1.007601000+0.12830
  • 2500+0.831502500+0.10590
  • 10000+0.8140010000+0.10370
  • 25000+0.7475025000+0.09520
