74AHC1G14-Q100;
74AHCT1G14-Q100
Inverting Schmitt trigger
Rev. 2 — 18 January 2016
Product data sheet
1. General description
74AHC1G14-Q100 and 74AHCT1G14-Q100 are high-speed Si-gate CMOS devices.
They provide an inverting buffer function with Schmitt-trigger action. These devices can
transform slowly changing input signals into sharply defined, jitter-free output signals.
The AHC device has CMOS input switching levels and supply voltage range 2 V to 5.5 V.
The AHCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Symmetrical output impedance
High noise immunity
Low power dissipation
Balanced propagation delays
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
SOT353-1 and SOT753 package options
3. Applications
Wave and pulse shapers
Astable multivibrators
Monostable multivibrators
74AHC1G14-Q100; 74AHCT1G14-Q100
Nexperia
4. Ordering information
Table 1.
Type number
Package
74AHC1G14GW-Q100
Temperature range Name
Description
Version
40 C to +125 C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
40 C to +125 C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74AHCT1G14GW-Q100
74AHC1G14GV-Q100
74AHCT1G14GV-Q100
5. Marking
Table 2.
Marking codes
Marking code[1]
Type number
74AHC1G14GW-Q100
AF
74AHCT1G14GW-Q100
CF
74AHC1G14GV-Q100
A14
74AHCT1G14GV-Q100
C14
[1]
The pin 1 indicator is on the lower left corner of the device, below the marking code.
6. Functional diagram
PQD
Fig 1.
Logic symbol
PQD
PQD
Fig 2.
IEC logic symbol
Fig 3.
Logic diagram
7. Pinning information
7.1 Pinning
$+&*4
$+&7*4
QF
*1'
9&&
DDD
Fig 4.
Pin configuration
74AHC_AHCT1G14_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
2 of 17
Nexperia B.V. 2017. All rights reserved
Nexperia
7.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
n.c.
1
not connected
A
2
data input
GND
3
ground (0 V)
Y
4
data output
VCC
5
supply voltage
8. Functional description
Table 4.
Function table
H = HIGH voltage level; L = LOW voltage level
Input
Output
A
Y
L
H
H
L
9. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Min
Max
Unit
VCC
supply voltage
Conditions
0.5
+7.0
V
VI
input voltage
0.5
+7.0
V
IIK
input clamping current
VI < 0.5 V
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
IO
output current
0.5 V < VO < VCC + 0.5 V
ICC
mA
mA
25
mA
supply current
75
mA
IGND
ground current
75
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
250
mW
Tamb = 40 C to +125 C
[1]
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For both TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
74AHC_AHCT1G14_Q100
Product data sheet
3 of 17
Nexperia
10. Recommended operating conditions
Table 6.
Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
74AHC1G14-Q100
74AHCT1G14-Q100
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
5.5
4.5
5.0
5.5
V
input voltage
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
40
+25
+125
40
+25
+125
C
VCC
supply voltage
VI
11. Static characteristics
Table 7.
Symbol Parameter
25 C
Conditions
40 C to +85 C 40 C to +125 C Unit
Min
Typ
Max
Min
Max
Min
Max
HIGH-level
VI = VT+ or VT
output voltage
IO = 50 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 50 A; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = 50 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
For type 74AHC1G14-Q100
VOH
VOL
IO = 4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = 8.0 mA; VCC = 4.5 V
3.94
3.8
3.70
V
LOW-level
VI = VT+ or VT
output voltage
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.36
0.44
0.55
V
0.36
0.44
0.55
V
0.1
1.0
2.0
A
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
1.0
10
40
A
CI
input
capacitance
1.5
10
10
10
pF
For type 74AHCT1G14-Q100
VOH
HIGH-level
VI = VT+ or VT; VCC = 4.5 V
output voltage
IO = 50 A
IO = 8.0 mA
VOL
LOW-level
output voltage
IO = 50 A
IO = 8.0 mA
II
input leakage
current
74AHC_AHCT1G14_Q100
Product data sheet
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
4.4
4.5
4.4
4.4
V
3.94
3.8
3.70
V
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
A
4 of 17
Nexperia
Table 7.
Static characteristics …continued
Symbol Parameter
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
ICC
VCC = 5.5 V
1.0
10
40
A
ICC
additional
per input pin; VI = 3.4 V;
supply current other inputs at VCC or GND;
IO = 0 A; VCC = 5.5 V
1.35
1.5
1.5
mA
CI
input
capacitance
1.5
10
10
10
pF
11.1 Transfer characteristics
Table 8.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V). See Figure 7 and Figure 8.
Symbol Parameter
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
VCC = 3.0 V
2.2
2.2
2.2
V
VCC = 4.5 V
3.15
3.15
3.15
V
VT+
VT
VH
positive-going
threshold
voltage
negative-going
threshold
voltage
hysteresis
voltage
VCC = 5.5 V
3.85
3.85
3.85
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 4.5 V
1.35
1.35
1.35
V
VCC = 5.5 V
1.65
1.65
1.65
V
VCC = 3.0 V
0.3
1.2
0.3
1.2
0.25
1.2
V
VCC = 4.5 V
0.4
1.4
0.4
1.4
0.35
1.4
V
VCC = 5.5 V
0.5
1.6
0.5
1.6
0.45
1.6
V
VT+
VT
VH
positive-going
threshold
voltage
VCC = 4.5 V
2.0
2.0
2.0
V
VCC = 5.5 V
2.0
2.0
2.0
V
negative-going
threshold
voltage
VCC = 4.5 V
0.5
0.5
0.5
V
VCC = 5.5 V
0.6
0.6
0.6
V
hysteresis
voltage
VCC = 4.5 V
0.4
1.4
0.4
1.4
0.35
1.4
V
VCC = 5.5 V
0.4
1.6
0.4
1.6
0.35
1.6
V
74AHC_AHCT1G14_Q100
Product data sheet
5 of 17
Nexperia
12. Dynamic characteristics
Table 9.
GND = 0 V; tr = tf 3.0 ns. For waveform see Figure 5. For test circuit see Figure 6.
Symbol Parameter
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
CL = 15 pF
4.2
12.8
1.0
15.0
1.0
16.5
ns
CL = 50 pF
6.0
16.3
1.0
18.5
1.0
20.5
ns
3.2
8.6
1.0
10.0
1.0
11.0
ns
4.6
10.6
1.0
12.0
1.0
13.5
ns
12
pF
4.1
7.0
1.0
8.0
1.0
9.0
ns
5.9
8.5
1.0
10.0
1.0
11.0
ns
13
pF
tpd
propagation
delay
[1]
A to Y;
VCC = 3.0 V to 3.6 V
VCC = 4.5 V to 5.5 V
[2]
[3]
CL = 15 pF
CL = 50 pF
CPD
power
dissipation
capacitance
per buffer;
CL = 50 pF; f = 1 MHz;
VI = GND to VCC
[4]
tpd
propagation
delay
A to Y;
[1]
[3]
CL = 15 pF
CL = 50 pF
CPD
power
dissipation
capacitance
[4]
per buffer;
VI = GND to VCC
[1]
tpd is the same as tPLH and tPHL.
[2]
Typical values are measured at VCC = 3.3 V.
[3]
Typical values are measured at VCC = 5.0 V.
[4]
CPD is used to determine the dynamic power dissipation PD (W).
PD = CPD VCC2 fi + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts.
74AHC_AHCT1G14_Q100
Product data sheet
6 of 17
Nexperia
13. Waveforms
90
$LQSXW
9&&
W3+/
W3/+
9,
38/6(
*(1(5$725
90
很抱歉,暂时无法提供与“74AHC1G14GW-Q100,1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+0.571633000+0.06934
- 6000+0.497096000+0.06030
- 15000+0.4225215000+0.05126
- 30000+0.3976730000+0.04824
- 75000+0.3728175000+0.04523
- 150000+0.32311150000+0.03920
