74AHC1G86; 74AHCT1G86
2-input EXCLUSIVE-OR gate
Rev. 05 — 4 July 2007
Product data sheet
1. General description
74AHC1G86 and 74AHCT1G86 are high-speed Si-gate CMOS devices. They provide a
2-input EXCLUSIVE-OR function.
The AHC device has CMOS input switching levels and supply voltage range 2 V to 5.5 V.
The AHCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V.
2. Features
n Symmetrical output impedance
n High noise immunity
n ESD protection:
u HBM JESD22-A114E: exceeds 2000 V
u MM JESD22-A115-A: exceeds 200 V
u CDM JESD22-C101C: exceeds 1000 V
n Low power dissipation
n Balanced propagation delays
n SOT353-1 and SOT753 package options
n Specified from −40 °C to +125 °C
3. Ordering information
Table 1.
Type number
74AHC1G86GW
Package
Temperature range
Name
Description
Version
−40 °C to +125 °C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
−40 °C to +125 °C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74AHCT1G86GW
74AHC1G86GV
74AHCT1G86GV
Nexperia
4. Marking
Table 2.
Marking codes
Type number
Marking code
74AHC1G86GW
AH
74AHCT1G86GW
CH
74AHC1G86GV
A86
74AHCT1G86GV
C86
5. Functional diagram
1
2
B
A
Y
1
4
=1
4
2
mna039
mna038
Fig 1. Logic symbol
Fig 2. IEC logic symbol
B
Y
A
mna040
Fig 3. Logic diagram
6. Pinning information
6.1 Pinning
74AHC1G86
B
1
A
2
GND
3
5
VCC
4
Y
001aaf054
Fig 4. Pin configuration
74AHC_AHCT1G86_5
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 12
Nexperia
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
B
1
data input
A
2
data input
GND
3
ground (0 V)
Y
4
data output
VCC
5
supply voltage
7. Functional description
Table 4.
Function table
H = HIGH voltage level; L = LOW voltage level
Inputs
Output
A
B
Y
L
L
L
L
H
H
H
L
H
H
H
L
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
Conditions
Min
Max
Unit
supply voltage
−0.5
+7.0
V
VI
input voltage
−0.5
+7.0
V
IIK
input clamping current
VI < −0.5 V
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
IO
output current
−0.5 V < VO < VCC + 0.5 V
ICC
−20
mA
±20
mA
±25
mA
supply current
75
mA
IGND
ground current
−75
mA
Tstg
storage temperature
−65
+150
°C
250
mW
total power dissipation
Ptot
Tamb = −40 °C to +125 °C
[1]
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For both TSSOP5 and SC-74A packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
74AHC_AHCT1G86_5
Product data sheet
3 of 12
Nexperia
9. Recommended operating conditions
Table 6.
Symbol Parameter
Conditions
74AHC1G86
Min
Typ
74AHCT1G86
Max
Min
Typ
Unit
Max
VCC
supply voltage
2.0
5.0
5.5
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
−40
+25
+125
−40
+25
+125
°C
∆t/∆V
input transition rise
and fall rate
VCC = 3.3 V ± 0.3 V
100
ns/V
VCC = 5.0 V ± 0.5 V
ns/V
10. Static characteristics
Table 7.
Symbol Parameter
25 °C
Conditions
−40 °C to +85 °C −40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
For type 74AHC1G86
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
HIGH-level
VI = VIH or VIL
output voltage
IO = −50 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −50 µA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = −50 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = −8.0 mA; VCC = 4.5 V
3.94
3.8
3.70
V
LOW-level
VI = VIH or VIL
output voltage
IO = 50 µA; VCC = 2.0 V
0.1
0.1
V
IO = 50 µA; VCC = 3.0 V
0.1
0.1
V
IO = 50 µA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
0.1
1.0
2.0
µA
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
1.0
10
40
µA
CI
input
capacitance
1.5
10
10
10
pF
74AHC_AHCT1G86_5
Product data sheet
4 of 12
Nexperia
Table 7.
Static characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
Typ
Max
Min
Max
Min
Max
For type 74AHCT1G86
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = −50 µA
4.4
4.5
4.4
4.4
V
3.94
3.8
3.70
V
IO = −8.0 mA
VOL
LOW-level
output voltage
IO = 50 µA
IO = 8.0 mA
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
µA
II
input leakage
current
ICC
VCC = 5.5 V
1.0
10
40
µA
∆ICC
additional
per input pin; VI = 3.4 V;
supply current other inputs at VCC or GND;
IO = 0 A; VCC = 5.5 V
1.35
1.5
1.5
mA
CI
input
capacitance
1.5
10
10
10
pF
11. Dynamic characteristics
Table 8.
GND = 0 V; tr = tf = ≤ 3.0 ns. For waveform see Figure 5. For test circuit see Figure 6.
Symbol Parameter
25 °C
Conditions
Min
Typ
Max
Min
Max
Min
Max
CL = 15 pF
4.0
11.0
1.0
13.0
1.0
14.0
ns
CL = 50 pF
5.8
14.5
1.0
16.5
1.0
18.5
ns
3.4
6.8
1.0
8.0
1.0
8.5
ns
4.9
8.8
1.0
10.0
1.0
11.5
ns
9
pF
For type 74AHC1G86
tpd
propagation
delay
A and B to Y
VCC = 3.0 V to 3.6 V
[1]
[2]
[3]
CL = 15 pF
CL = 50 pF
CPD
power
per buffer;
dissipation
CL = 50 pF; f = 1 MHz;
capacitance VI = GND to VCC
[4]
74AHC_AHCT1G86_5
Product data sheet
5 of 12
Nexperia
Table 8.
Dynamic characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
Typ
Max
Min
Max
Min
Max
3.5
6.9
1.0
8.0
1.0
9.0
ns
5.0
7.9
1.0
9.0
1.0
10.5
ns
11
pF
For type 74AHCT1G86
propagation
delay
tpd
[1]
A and B to Y
[3]
CL = 15 pF
CL = 50 pF
power
per buffer;
dissipation
CPD
[4]
[1]
tpd is the same as tPLH and tPHL.
[2]
Typical values are measured at VCC = 3.3 V.
[3]
Typical values are measured at VCC = 5.0 V.
[4]
CPD is used to determine the dynamic power dissipation PD (µW).
PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts.
12. Waveforms
A, B input
VM
tPHL
Y output
tPLH
VM
mna041
Measurement points are given in Table 9.
Fig 5. The input (A and B) to output (Y) propagation delays
Table 9.
Measurement points
Type
Input
Output
VI
VM
VM
74AHC1G86
GND to VCC
0.5 × VCC
0.5 × VCC
74AHCT1G86
GND to 3.0 V
1.5 V
0.5 × VCC
74AHC_AHCT1G86_5
Product data sheet
6 of 12
Nexperia
VCC
PULSE
GENERATOR
VI
VO
DUT
RT
CL
50 pF
mna034
Test data is given in Table 8. Definitions for test circuit:
CL = load capacitance including jig and probe capacitance.
RT = termination resistance should be equal to the output impedance Zo of the pulse generator.
Fig 6. Load circuitry for switching times
74AHC_AHCT1G86_5
Product data sheet
7 of 12
Nexperia
13. Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
E
D
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
L
e
w M
bp
detail X
e1
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Fig 7. Package outline SOT353-1 (TSSOP5)
74AHC_AHCT1G86_5
Product data sheet
8 of 12
Nexperia
Plastic surface-mounted package; 5 leads
SOT753
D
E
B
y
A
X
HE
5
v M A
4
Q
A
A1
c
1
2
3
Lp
detail X
bp
e
w M B
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.100
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT753
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-04-16
06-03-16
SC-74A
Fig 8. Package outline SOT753 (SC-74A)
74AHC_AHCT1G86_5
Product data sheet
9 of 12
Nexperia
14. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
15. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC_AHCT1G86_5
20070704
Product data sheet
74AHC_AHCT1G86_4
Modifications:
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors
Legal texts have been adapted to the new company name where appropriate.
Package SOT353 changed to SOT353-1 in Section 3 and Section 13.
Quick reference data and Soldering sections removed.
74AHC_AHCT1G86_4
20020606
Product specification
74AHC_AHCT1G86_3
74AHC_AHCT1G86_3
20020218
74AHC_AHCT1G86_2
74AHC_AHCT1G86_2
20010406
74AHC1G_AHCT1G86_1
74AHC1G_AHCT1G86_1 19990920
74AHC_AHCT1G86_5
Product data sheet
10 of 12
Nexperia
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
16.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected to
result in personal injury, death or severe property or environmental damage.
Nexperia accepts no liability for inclusion and/or use of Nexperia
products in such equipment or applications and therefore
such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For additional information, please visit: http://www.nexperia.com
For sales office addresses, send an email to: salesaddresses@nexperia.com
74AHC_AHCT1G86_5
Product data sheet
11 of 12
Nexperia
18. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Dynamic characteristics . . . . . . . . . . . . . . . . . . 5
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10
Legal information. . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . 11
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 04 July 2007
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AHC1G86GV,125 74AHC1G86GW,125 74AHCT1G86GV,125 74AHCT1G86GW,125
很抱歉,暂时无法提供与“74AHC1G86GW,125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.05484
- 10+1.03216
- 30+1.01704
- 100+1.00192
