74AHC3G14-Q100;
74AHCT3G14-Q100
Triple inverting Schmitt trigger
Rev. 4 — 4 December 2018
Product data sheet
1. General description
74AHC3G14-Q100 and 74AHCT3G14-Q100 are high-speed Si-gate CMOS devices. They provide
three inverting buffers with Schmitt trigger action. These devices are capable of transforming slowly
changing input signals into sharply defined, jitter-free output signals.
The AHC device has CMOS input switching levels and supply voltage range 2 V to 5.5 V.
The AHCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Symmetrical output impedance
High noise immunity
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF; R = 0 Ω)
Low power dissipation
Balanced propagation delays
Multiple package options
3. Applications
Wave and pulse shaper for highly noisy environment
Astable multivibrator
Monostable multivibrator
4. Ordering information
Table 1. Ordering information
Type number
Package
74AHC3G14DP-Q100
Temperature range Name
Description
Version
-40 °C to +125 °C
TSSOP8
plastic thin shrink small outline package; 8 leads;
body width 3 mm; lead length 0.5 mm
SOT505-2
-40 °C to +125 °C
VSSOP8
plastic very thin shrink small outline package;
8 leads; body width 2.3 mm
SOT765-1
74AHCT3G14DP-Q100
74AHC3G14DC-Q100
74AHCT3G14DC-Q100
Nexperia
74AHC3G14-Q100; 74AHCT3G14-Q100
5. Marking
Table 2. Marking codes
Type number
Marking code[1]
74AHC3G14DP-Q100
A14
74AHCT3G14DP-Q100
C14
74AHC3G14DC-Q100
A14
74AHCT3G14DC-Q100
C14
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
6. Functional diagram
1A
1Y
3Y
3A
2A
2Y
A
Y
mna025
001aah729
001aah728
Fig. 1.
Logic symbo
Fig. 2.
Fig. 3.
IEC logic symbol
Logic diagram (one Schmitt
trigger)
7. Pinning information
7.1. Pinning
74AHC3G14
74AHCT3G14
1A
1
8
VCC
3Y
2
7
1Y
2A
3
6
3A
GND
4
5
2Y
001aai259
Fig. 4.
Pin configuration SOT505-2 and SOT765-1
7.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
1A, 2A, 3A
1, 3, 6
data input
GND
4
ground (0 V)
1Y, 2Y, 3Y
7, 5, 2
data output
VCC
8
supply voltage
74AHC_AHCT3G14_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 15
Nexperia
8. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level
Input nA
Output nY
L
H
H
L
9. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VCC
Conditions
Min
Max
Unit
supply voltage
-0.5
+7.0
V
VI
input voltage
-0.5
+7.0
V
IIK
input clamping current
VI < -0.5 V
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
IO
output current
-0.5 V < VO < VCC + 0.5 V
ICC
-20
mA
±20
mA
±25
mA
supply current
75
mA
IGND
ground current
-75
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
[1]
[2]
[1]
Tamb = -40 °C to +125 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For TSSOP8 package: above 55 °C the value of Ptot derates linearly at 2.5 mW/K.
For VSSOP8 package: above 110 °C the value of Ptot derates linearly at 8 mW/K.
10. Recommended operating conditions
Table 6. Recommended operating conditions
Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
74AHC3G14-Q100
74AHCT3G14-Q100
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
5.5
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
74AHC_AHCT3G14_Q100
Product data sheet
3 / 15
Nexperia
11. Static characteristics
Table 7. Static characteristics
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
-40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
VI = VT+ or VTHIGH-level
output voltage
IO = -50 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -50 μA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = -50 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = -8.0 mA; VCC = 4.5 V
74AHC3G14-Q100
VOH
VOL
3.94
3.8
3.70
V
VI = VT+ or VTLOW-level
output voltage
IO = 50 μA; VCC = 2.0 V
0.1
0.1
V
IO = 50 μA; VCC = 3.0 V
0.1
0.1
V
IO = 50 μA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
0.1
1.0
2.0
μA
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
1.0
10
40
μA
CI
input
capacitance
1.5
10
10
10
pF
4.4
4.5
4.4
4.4
V
3.94
3.8
3.70
V
0.1
0.1
V
IO = 8.0 mA
0.36
0.44
0.55
V
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1.0
2.0
μA
74AHCT3G14-Q100
VOH
VI = VT+ or VT-; VCC = 4.5 V
HIGH-level
output voltage
IO = -50 μA
IO = -8.0 mA
VOL
LOW-level
output voltage
IO = 50 μA
II
input leakage
current
ICC
VCC = 5.5 V
1.0
10
40
μA
ΔICC
additional
per input pin; VI = 3.4 V;
supply current other inputs at VCC or GND;
IO = 0 A; VCC = 5.5 V
1.35
1.5
1.5
mA
CI
input
capacitance
1.5
10
10
10
pF
74AHC_AHCT3G14_Q100
Product data sheet
4 / 15
Nexperia
11.1. Transfer characteristics
Table 8. Transfer characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V). See Fig. 7 and Fig. 8.
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Min
Max
VCC = 3.0 V
2.2
2.2
2.2
V
VCC = 4.5 V
3.15
3.15
3.15
V
VCC = 5.5 V
3.85
3.85
3.85
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 4.5 V
1.35
1.35
1.35
V
VCC = 5.5 V
1.65
1.65
1.65
V
hysteresis voltage VCC = 3.0 V
0.3
1.2
0.3
1.2
0.25
1.2
V
VCC = 4.5 V
0.4
1.4
0.4
1.4
0.35
1.4
V
VCC = 5.5 V
0.5
1.6
0.5
1.6
0.45
1.6
V
2.0
2.0
2.0
V
74AHC3G14-Q100
VT+
VT-
VH
positive-going
threshold voltage
negative-going
threshold voltage
74AHCT3G14-Q100
VT+
positive-going
threshold voltage
VCC = 4.5 V
VCC = 5.5 V
2.0
2.0
2.0
V
VT-
negative-going
threshold voltage
VCC = 4.5 V
0.5
0.5
0.5
V
VCC = 5.5 V
0.6
0.6
0.6
V
hysteresis voltage VCC = 4.5 V
0.4
1.4
0.4
1.4
0.35
1.4
V
VCC = 5.5 V
0.4
1.6
0.4
1.6
0.35
1.6
V
VH
74AHC_AHCT3G14_Q100
Product data sheet
5 / 15
Nexperia
12. Dynamic characteristics
Table 9. Dynamic characteristics
GND = 0 V; tr = tf ≤ 3.0 ns; for test circuit see Fig. 6.
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Min
Max
CL = 15 pF
4.2
12.8
1.0
15.0
1.0
16.5
ns
CL = 50 pF
6.0
16.3
1.0
18.5
1.0
20.5
ns
CL = 15 pF
3.2
8.6
1.0
10.0
1.0
11.0
ns
CL = 50 pF
4.6
10.6
1.0
12.0
1.0
13.5
ns
10
pF
4.1
7.0
1.0
8.0
1.0
9.0
ns
5.9
8.5
1.0
10.0
1.0
11.0
ns
12
pF
74AHC3G14-Q100
tpd
propagation
delay
nA to nY; see Fig. 5
[1]
VCC = 3.0 V to 3.6 V
[2]
VCC = 4.5 V to 5.5 V
CPD
power
per buffer;
dissipation
CL = 50 pF; fi = 1 MHz;
capacitance VI = GND to VCC
[3]
[4]
74AHCT3G14-Q100
tpd
propagation
delay
[1]
[3]
CL = 15 pF
CL = 50 pF
CPD
[1]
[2]
[3]
[4]
power
per buffer;
dissipation
[4]
tpd is the same as tPLH and tPHL.
Typical values are measured at VCC = 3.3 V.
Typical values are measured at VCC = 5.0 V.
CPD is used to determine the dynamic power dissipation PD (μW).
2
2
PD = CPD x VCC x fi + Σ (CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
2
Σ(CL x VCC x fo) = sum of the outputs.
74AHC_AHCT3G14_Q100
Product data sheet
6 / 15
Nexperia
12.1. Waveform and test circuit
VCC
tPHL
mna101
The test data is given in Table 10
The input (nA) to output (nY) propagation
delays
Table 10. Test data
Type number
CL
Test data is given in Table 10.
Definitions for test circuit:
CL = Load capacitance.
RT = Termination resistance should be equal to
output impedance Zo of the pulse generator.
mna033
Fig. 5.
VO
DUT
RT
tPLH
VM
Y output
VI
PULSE
GENERATOR
VM
A input
Fig. 6.
Test circuit for measuring switching times
Output
Input
VI
VM
VM
74AHC3G14-Q100
GND to VCC
0.5 x VCC
0.5 x VCC
74AHCT3G14-Q100
GND to 3.0 V
1.5 V
0.5 x VCC
12.2. Transfer characteristic waveforms
VO
VI
VH
VT-
Fig. 7.
VI
VT+
74AHC_AHCT3G14_Q100
Product data sheet
VT+
VH
VT-
VO
mna027
mna026
Fig. 8.
The definitions of VT+, VT- and VH
7 / 15
Nexperia
mna401
1.5
ICC
(mA)
mna402
5
ICC
(mA)
4
1
3
2
0.5
1
2
VI (V)
3
VCC = 3.0 V.
Fig. 9.
2
3
4 V (V) 5
I
VCC = 4.5 V.
Typical 74AHC3G14-Q100 transfer
characteristics
Fig. 10. Typical 74AHC3G14-Q100 transfer
characteristics
mna403
8
ICC
(mA)
mna404
5
ICC
(mA)
4
6
3
4
2
2
4
VI (V)
VCC = 5.5 V.
Product data sheet
2
3
4 V (V) 5
I
VCC = 4.5 V.
Fig. 11. Typical 74AHC3G14-Q100 transfer
characteristics
74AHC_AHCT3G14_Q100
6
Fig. 12. Typical 74AHCT3G14-Q100 transfer
characteristics
8 / 15
Nexperia
mna405
8
ICC
(mA)
6
4
2
4
VI (V)
6
VCC = 5.5 V.
Fig. 13. Typical 74AHCT3G14-Q100 transfer characteristics
74AHC_AHCT3G14_Q100
Product data sheet
9 / 15
Nexperia
13. Application information
The slow input rise and fall times cause additional power dissipation, which can be calculated using
the following formula:
Padd = fi x (tr x ΔICC(AV) + tf x ΔICC(AV)) × VCC where:
Padd = additional power dissipation (μW);
fi = input frequency (MHz);
tr = input rise time (ns); 10 % to 90 %;
tf = input fall time (ns); 90 % to 10 %;
ΔICC(AV) = average additional supply current (μA).
ΔICC(AV) differs with positive or negative input transitions, as shown in Fig. 14 and Fig. 15.
For 74AHC3G14-Q100 and 74AHCT3G14-Q100 used in relaxation oscillator circuit, see Fig. 16.
Note to the application information:
1. All values given are typical unless otherwise specified.
mna036
200
mna058
200
ΔICC(AV)
(µA)
ΔICC(AV)
(µA)
150
150
positive-going
edge
positive-going
edge
100
100
50
50
negative-going
edge
4.0
VCC (V)
Linear change of VI between 0.1VCC to 0.9VCC
negative-going
edge
4
VCC (V)
6
Fig. 14. Average additional ICC for 74AHC3G14-Q100
Schmitt trigger devices
Fig. 15. Average additional ICC for 74AHCT3G14-Q100
R
C
mna035
For 74AHC3G14-Q100:
For 74AHCT3G14-Q100:
Fig. 16. Relaxation oscillator using the 74AHC3G14-Q100 and 74AHCT3G14-Q100
74AHC_AHCT3G14_Q100
Product data sheet
10 / 15
Nexperia
14. Package outline
TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm
D
E
A
SOT505-2
X
c
HE
y
v M A
Z
5
8
A
A2
pin 1 index
(A3)
A1
θ
Lp
L
1
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.15
0.00
0.95
0.75
0.25
0.38
0.22
0.18
0.08
3.1
2.9
3.1
2.9
0.65
4.1
3.9
0.5
0.47
0.33
0.2
0.13
0.1
0.70
0.35
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT505-2
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-01-16
Fig. 17. Package outline SOT505-2 (TSSOP8)
74AHC_AHCT3G14_Q100
Product data sheet
11 / 15
Nexperia
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
SOT765-1
E
A
X
c
y
HE
v
A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
detail X
4
e
L
w
bp
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
max.
max
nom
min
1
A1
A2
0.15 0.85
0.00 0.60
A3
0.12
D(1)
E(2)
0.27 0.23
2.1
2.4
0.17 0.08
1.9
2.2
bp
c
e
HE
0.5
3.2
3.0
L
0.4
Lp
Q
0.40 0.21
0.15 0.19
v
w
y
0.2
0.08
0.1
Z(1)
θ
0.4
8°
0.1
0°
Note
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT765-1
References
IEC
JEDEC
JEITA
sot765-1_po
European
projection
Issue date
07-06-02
16-05-31
MO-187
Fig. 18. Package outline SOT765-1 (VSSOP8)
74AHC_AHCT3G14_Q100
Product data sheet
12 / 15
Nexperia
15. Abbreviations
Table 11. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
16. Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status Change notice
Supersedes
74AHC_AHCT3G14_Q100 v.4
20181204
Product data sheet -
74AHC_AHCT3G14_Q100 v.3
Modifications:
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74AHC3G14GD-Q100 and 74AHCT3G14GD-Q100 (SOT996-2/
XSON8) removed.
20130916
Modifications:
74AHC_AHCT3G14_Q100 v.2
20130128
74AHC_AHCT3G14_Q100 v.1
20121001
74AHC_AHCT3G14_Q100
Product data sheet
Added type number 74AHC3G14GD-Q100 and 74AHCT3G14GD-Q100.
13 / 15
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
17. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74AHC_AHCT3G14_Q100
Product data sheet
14 / 15
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Ordering information....................................................1
5. Marking.......................................................................... 2
6. Functional diagram.......................................................2
7. Pinning information......................................................2
7.1. Pinning.........................................................................2
7.2. Pin description............................................................. 2
8. Functional description................................................. 3
9. Limiting values............................................................. 3
10. Recommended operating conditions........................3
11. Static characteristics..................................................4
11.1. Transfer characteristics..............................................5
12. Dynamic characteristics............................................ 6
12.1. Waveform and test circuit.......................................... 7
12.2. Transfer characteristic waveforms............................. 7
13. Application information........................................... 10
14. Package outline........................................................ 11
15. Abbreviations............................................................ 13
16. Revision history........................................................13
17. Legal information......................................................14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 4 December 2018
74AHC_AHCT3G14_Q100
Product data sheet
15 / 15
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AHC3G14GD-Q100H 74AHCT3G14GD-Q100H 74AHC3G14DP-Q100H 74AHC3G14DC-Q100H
74AHCT3G14DP-Q100H 74AHCT3G14DC-Q100H
