74AUP2G0604
Low-power inverting buffer with open-drain and inverter
Rev. 1 — 23 November 2012
Product data sheet
1. General description
The 74AUP2G0604 is a single inverting buffer with open-drain output and a single
inverter. It features two input pins (nA), an output pin (2Y) and an open-drain output pin
(1Y).
Schmitt trigger action at all inputs makes the circuit tolerant of slower input rise and fall
times across the entire VCC range from 0.8 V to 3.6 V.
This device ensures a very low static and dynamic power consumption across the entire
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the device
when it is powered down.
2. Features and benefits
Wide supply voltage range from 0.8 V to 3.6 V
High noise immunity
Complies with JEDEC standards:
JESD8-12 (0.8 V to 1.3 V)
JESD8-11 (0.9 V to 1.65 V)
JESD8-7 (1.2 V to 1.95 V)
JESD8-5 (1.8 V to 2.7 V)
JESD8-B (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F Class 3A exceeds 5000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Low static power consumption; ICC = 0.9 A (maximum)
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 3.6 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial power-down mode operation
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74AUP2G0604
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AUP2G0604GW
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74AUP2G0604GM
40 C to +125 C
XSON6
plastic extremely thin small outline package;
no leads; 6 terminals; body 1 1.45 0.5 mm
SOT886
74AUP2G0604GF
40 C to +125 C
XSON6
no leads; 6 terminals; body 1 1 0.5 mm
SOT891
74AUP2G0604GN
40 C to +125 C
XSON6
extremely thin small outline package; no leads; SOT1115
6 terminals; body 0.9 1.0 0.35 mm
74AUP2G0604GS
40 C to +125 C
XSON6
extremely thin small outline package; no leads; SOT1202
6 terminals; body 1.0 1.0 0.35 mm
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74AUP2G0604GW
a6
74AUP2G0604GM
a6
74AUP2G0604GF
a6
74AUP2G0604GN
a6
74AUP2G0604GS
a6
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Logic symbol
74AUP2G0604
Product data sheet
*1'
DDD
Fig 1.
DDD
DDD
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Fig 3.
Logic diagram
Nexperia B.V. 2017. All rights reserved
2 of 20
74AUP2G0604
Nexperia
6. Pinning information
6.1 Pinning
$83*
$83*
$83*
*1'
9&&
*1'
9&&
*1'
9&&
DDD
DDD
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
DDD
Fig 4.
Pin configuration SOT363
Fig 5.
Pin configuration SOT886
Fig 6.
Pin configuration SOT891,
SOT1115 and SOT1202
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
1A
1
data input
GND
2
ground (0 V)
2A
3
data input
2Y
4
data output
VCC
5
supply voltage
1Y
6
data output
7. Functional description
Table 4.
Function table[1]
Input
Output
1A
1Y
L
Z
H
L
[1]
H = HIGH voltage level; L = LOW voltage level.
Table 5.
Function table[1]
Input
Output
2A
2Y
L
H
H
L
[1]
74AUP2G0604
Product data sheet
3 of 20
74AUP2G0604
Nexperia
8. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
Min
Max
Unit
0.5
+4.6
V
50
mA
0.5
+4.6
V
50
mA
0.5
+4.6
V
1Y
mA
2Y
mA
VI < 0 V
[1]
VO < 0 V
VO
output voltage
Active mode and Power-down mode
IO
output current
VO = 0 V to VCC
[1]
ICC
supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
250
mW
total power dissipation
Ptot
Tamb = 40 C to +125 C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SC-88 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 7.
Symbol
Parameter
Min
Max
Unit
VCC
supply voltage
0.8
3.6
V
VI
input voltage
V
VO
output voltage
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
Tamb
ambient temperature
40
+125
C
t/V
input transition rise and fall rate
ns/V
74AUP2G0604
Product data sheet
Conditions
VCC = 0.8 V to 3.6 V
4 of 20
74AUP2G0604
Nexperia
10. Static characteristics
Table 8.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
VCC = 0.8 V
VCC = 0.9 V to 1.95 V
Typ
Max
Unit
0.70 VCC -
V
0.65 VCC -
V
VCC = 2.3 V to 2.7 V
1.6
V
VCC = 3.0 V to 3.6 V
2.0
V
VCC = 0.8 V
0.30 VCC V
0.35 VCC V
0.7
V
0.9
V
IO = 20 A; VCC = 0.8 V to 3.6 V
VCC 0.1
V
IO = 1.1 mA; VCC = 1.1 V
0.75 VCC -
V
IO = 1.7 mA; VCC = 1.4 V
1.11
V
Tamb = 25 C
VIH
VIL
VOH
VOL
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
LOW-level output voltage
2Y; VI = VIH or VIL
IO = 1.9 mA; VCC = 1.65 V
1.32
V
IO = 2.3 mA; VCC = 2.3 V
2.05
V
IO = 3.1 mA; VCC = 2.3 V
1.9
V
IO = 2.7 mA; VCC = 3.0 V
2.72
V
IO = 4.0 mA; VCC = 3.0 V
2.6
V
0.1
V
0.3 VCC
V
1Y, 2Y; VI = VIH or VIL
0.31
V
0.31
V
0.31
V
0.44
V
0.31
V
0.44
V
II
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
0.1
A
IOFF
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
0.2
A
IOFF
additional power-off
leakage current
VCC = 0 V to 0.2 V
0.2
A
ICC
supply current
VI = GND or VCC; IO = 0 A;
0.5
A
ICC
additional supply current
VI = VCC 0.6 V; IO = 0 A;
VCC = 3.3 V
40
A
CI
input capacitance
VCC = 0 V to 3.6 V; VI = GND or VCC
0.8
pF
74AUP2G0604
Product data sheet
5 of 20
74AUP2G0604
Nexperia
Table 8.
Static characteristics …continued
Symbol Parameter
Conditions
CO
VO = GND; VCC = 0 V
output capacitance
1Y output; enabled
Min
Typ
Max
Unit
1.7
pF
1Y output; disabled
1.1
pF
2Y output
1.7
pF
Tamb = 40 C to +85 C
VIH
VIL
VOH
VOL
VCC = 0.8 V
0.70 VCC -
V
0.65 VCC -
V
1.6
V
2.0
V
VCC = 0.8 V
0.30 VCC V
0.35 VCC V
0.7
V
0.9
V
2Y; VI = VIH or VIL
VCC 0.1
V
0.7 VCC
V
1.03
V
1.30
V
1.97
V
1.85
V
2.67
V
2.55
V
0.1
V
0.3 VCC
V
0.37
V
0.35
V
0.33
V
0.45
V
0.33
V
0.45
V
II
0.5
A
IOFF
0.5
A
IOFF
leakage current
VCC = 0 V to 0.2 V
0.6
A
ICC
supply current
0.9
A
ICC
VCC = 3.3 V
50
A
74AUP2G0604
Product data sheet
6 of 20
74AUP2G0604
Nexperia
Table 8.
Symbol Parameter
Conditions
Min
VCC = 0.8 V
Typ
Max
Unit
0.75 VCC -
V
0.70 VCC -
V
1.6
V
2.0
V
VCC = 0.8 V
0.25 VCC V
0.30 VCC V
0.7
V
0.9
V
VIH
VIL
VOH
VOL
2Y; VI = VIH or VIL
VCC 0.11 -
V
0.6 VCC
V
0.93
V
1.17
V
1.77
V
1.67
V
2.40
V
2.30
V
0.11
V
0.33 VCC V
0.41
V
0.39
V
0.36
V
0.50
V
0.36
V
0.50
V
II
0.75
A
IOFF
0.75
A
IOFF
leakage current
VCC = 0 V to 0.2 V
0.75
A
ICC
supply current
1.4
A
ICC
VCC = 3.3 V
75
A
74AUP2G0604
Product data sheet
7 of 20
74AUP2G0604
Nexperia
11. Dynamic characteristics
Table 9.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8.
Symbol Parameter
25 C
Conditions
40 C to +125 C
Unit
Min
Typ[1]
Max
Min
14.4
ns
Max
Max
(85 C) (125 C)
CL = 5 pF
tpd
propagation 1A to 1Y or 2A to 2Y; see Figure 7
delay
VCC = 0.8 V
[2]
VCC = 1.1 V to 1.3 V
2.3
4.7
10.3
2.0
11.4
12.6
ns
VCC = 1.4 V to 1.6 V
1.8
3.4
6.4
1.5
7.4
8.2
ns
VCC = 1.65 V to 1.95 V
1.5
2.9
5.0
1.2
5.9
6.5
ns
1.2
2.3
3.9
1.0
4.5
5.0
ns
1.1
2.2
3.3
0.8
3.9
4.3
ns
17.7
ns
CL = 10 pF
tpd
delay
VCC = 0.8 V
[2]
2.7
5.7
12.2
2.5
13.7
15.1
ns
2.2
4.1
7.5
2.0
8.7
9.6
ns
1.9
3.6
5.9
1.7
7.0
7.7
ns
1.7
2.9
4.6
1.4
5.4
6.0
ns
1.6
3.0
4.6
1.2
4.9
5.4
ns
21.1
ns
CL = 15 pF
tpd
delay
VCC = 0.8 V
[2]
3.2
6.6
13.0
2.9
15.8
17.4
ns
2.6
4.7
8.6
2.3
10.0
11.0
ns
2.3
4.3
6.7
2.1
8.0
8.8
ns
2.1
3.4
5.1
1.7
6.1
6.8
ns
2.0
3.6
6.0
1.5
6.5
7.2
ns
30.7
ns
CL = 30 pF
tpd
delay
VCC = 0.8 V
74AUP2G0604
Product data sheet
[2]
4.4
9.1
16.5
3.9
19.3
21.3
ns
3.6
6.6
10.8
3.2
12.9
14.2
ns
3.2
6.1
10.7
2.9
11.0
12.1
ns
2.9
4.9
7.2
2.6
7.8
8.6
ns
2.9
5.4
10.5
2.5
10.8
11.9
ns
8 of 20
74AUP2G0604
Nexperia
Table 9.
Dynamic characteristics …continued
Symbol Parameter
25 C
Conditions
40 C to +125 C
Unit
Min
Typ[1]
Max
Min
0.5
pF
0.6
pF
Max
Max
(85 C) (125 C)
CL = 5 pF, 10 pF, 15 pF and 30 pF
power
1A to 1Y; fi=1 MHz; VI = GND to VCC
dissipation
VCC = 0.8 V
capacitance
CPD
[3][4]
0.7
pF
0.7
pF
1.0
pF
1.2
pF
VCC = 0.8 V
2.5
pF
2.7
pF
2.8
pF
3.0
pF
3.5
pF
4.0
pF
2A to 2Y; fi=1 MHz; VI = GND to VCC
[1]
[3][5]
All typical values are measured at nominal VCC.
[2]
tpd is the same as tPLH and tPHL(2A to 2Y) and tPLZ and tPZL(1A to 1Y).
[3]
All specified values are the average typical values over all stated loads.
[4]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N where:
fi = input frequency in MHz;
CL = load capacitance in pF;
N = number of inputs switching;
[5]
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fo = output frequency in MHz;
VCC = supply voltage in V;
(CL VCC2 fo) = sum of the outputs.
74AUP2G0604
Product data sheet
9 of 20
74AUP2G0604
Nexperia
12. Waveforms
9,
9,
$LQSXW
90
$LQSXW
90
90
*1'
*1'
W3+/
W3=/
W3/=
9&&
W3/+
92+
很抱歉,暂时无法提供与“74AUP2G0604GWH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.236101+0.39188
- 10+2.4353710+0.29491
- 25+2.1935025+0.26562
- 100+1.51661100+0.18366
- 250+1.27698250+0.15464
- 500+1.03753500+0.12564
- 1000+0.798151000+0.09665
