74HC1G32-Q100; 74HCT1G32-Q100
2-input OR gate
Rev. 1 — 8 August 2012
Product data sheet
1. General description
74HC1G32-Q100 and 74HCT1G32-Q100 are high-speed Si-gate CMOS devices. They
provide a 2-input OR function.
The standard output currents are half of those of the 74HC32-Q100 and 74HCT32-Q100.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Input levels:
For 74HC1G32-Q100: CMOS level
For 74HCT1G32-Q100: TTL level
Symmetrical output impedance
High noise immunity
Low power dissipation
Balanced propagation delays
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
SOT353-1 and SOT753 package options
3. Ordering information
Table 1.
Type number
74HC1G32GW-Q100
Package
Temperature range
Name
Description
Version
40 C to +125 C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
40 C to +125 C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74HCT1G32GW-Q100
74HC1G32GV-Q100
74HCT1G32GV-Q100
Nexperia
2-input OR gate
4. Marking
Table 2.
Marking codes
Type number
Marking code[1]
74HC1G32GW-Q100
HG
74HCT1G32GW-Q100
TG
74HC1G32GV-Q100
H32
74HCT1G32GV-Q100
T32
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
1
B
2
A
Y
1
4
≥1
4
2
mna165
mna164
Fig 1. Logic symbol
Fig 2. IEC logic symbol
B
Y
A
mna166
Fig 3. Logic diagram
6. Pinning information
6.1 Pinning
+&*4
+&7*4
*1'
9&&
DDD
Fig 4. Pin configuration
74HC_HCT1G32_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 12
Nexperia
2-input OR gate
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
B
1
data input B
A
2
data input A
GND
3
ground (0 V)
Y
4
data output Y
VCC
5
supply voltage
7. Functional description
Table 4.
Function table
H = HIGH voltage level; L = LOW voltage level
Inputs
Output
A
B
Y
L
L
L
L
H
H
H
L
H
H
H
H
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). [1]
Symbol
Parameter
Conditions
VCC
supply voltage
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
Min
Max
Unit
0.5
+7.0
V
mA
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
mA
IO
output current
0.5 V < VO < VCC + 0.5 V
12.5
mA
ICC
supply current
25
mA
IGND
ground current
25
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
200
mW
Tamb = 40 C to +125 C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
Above 55 C the value of Ptot derates linearly with 2.5 mW/K.
74HC_HCT1G32_Q100
Product data sheet
3 of 12
Nexperia
2-input OR gate
9. Recommended operating conditions
Table 6.
Symbol Parameter
Conditions
74HC1G32-Q100
Min
Typ
74HCT1G32-Q100
Max
Min
Typ
Unit
Max
VCC
supply voltage
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
40
+25
+125
40
+25
+125
C
t/V
input transition rise
and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
139
139
ns/V
VCC = 6.0 V
83
ns/V
10. Static characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 C.
Symbol
Parameter
40 C to +85 C
Conditions
40 C to +125 C
Unit
Min
Typ
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
V
74HC1G32-Q100
VIH
VIL
VOH
VOL
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level output
voltage
LOW-level output
voltage
VCC = 6.0 V
4.2
3.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
V
IO = 20 A; VCC = 2.0 V
1.9
2.0
1.9
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
4.4
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
5.9
V
IO = 2.0 mA; VCC = 4.5 V
4.13
4.32
3.7
V
IO = 2.6 mA; VCC = 6.0 V
5.63
5.81
5.2
V
0.1
V
0.1
V
0.1
V
0.15
0.33
0.4
V
0.16
0.33
0.4
V
VI = VIH or VIL
VI = VIH or VIL
II
input leakage current
VI = VCC or GND; VCC = 6.0 V
1.0
1.0
A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
10
A
CI
input capacitance
1.5
pF
74HC_HCT1G32_Q100
Product data sheet
4 of 12
Nexperia
2-input OR gate
Table 7.
Static characteristics …continued
Symbol
Parameter
40 C to +85 C
Conditions
40 C to +125 C
Min
Typ
Max
Min
Max
Unit
74HCT1G32-Q100
VIH
HIGH-level input
voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
V
VIL
LOW-level input
voltage
1.2
0.8
0.8
V
VOH
HIGH-level output
voltage
VI = VIH or VIL; VCC = 4.5 V
IO = 20 A
4.4
4.5
4.4
V
IO = 2.0 mA
4.13
4.32
3.7
V
VOL
LOW-level output
voltage
IO = 20 A
0.1
V
IO = 2.0 mA
0.15
0.33
0.4
V
II
VI = VCC or GND; VCC = 5.5 V
1.0
1.0
A
ICC
supply current
VCC = 5.5 V
10
A
ICC
additional supply
current
per input; VCC = 4.5 V to 5.5 V;
VI = VCC 2.1 V; IO = 0 A
500
850
A
CI
input capacitance
1.5
pF
11. Dynamic characteristics
Table 8.
GND = 0 V; tr = tf 6.0 ns. All typical values are measured at Tamb = 25 C. For test circuit see Figure 6
Symbol Parameter
40 C to +85 C
Conditions
40 C to +125 C Unit
Min
Typ
Max
Min
Max
74HC1G32-Q100
tpd
propagation delay A and B to Y; see Figure 5
[1]
VCC = 2.0 V; CL = 50 pF
18
115
135
ns
VCC = 4.5 V; CL = 50 pF
8
23
27
ns
VCC = 5.0 V; CL = 15 pF
8
ns
7
ns
19
pF
VCC = 6.0 V; CL = 50 pF
CPD
power dissipation VI = GND to VCC
capacitance
74HC_HCT1G32_Q100
Product data sheet
[2]
5 of 12
Nexperia
2-input OR gate
Table 8.
Dynamic characteristics …continued
Symbol Parameter
40 C to +85 C
Conditions
40 C to +125 C Unit
Min
Typ
Max
Min
Max
10
24
27
ns
10
ns
pF
74HCT1G32-Q100
tpd
[1]
CPD
[1]
[2]
power dissipation VI = GND to VCC 1.5 V
capacitance
[2]
tpd is the same as tPLH and tPHL.
CPD is used to determine the dynamic power dissipation PD (W).
PD = CPD VCC2 fi + (CL VCC2 fo) where:
fi = input frequency in MHz
fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in V
(CL VCC2 fo) = sum of outputs
12. Waveforms
VM
A, B input
tPLH
tPHL
VM
Y output
mna167
For 74HC1G32-Q100: VM = 0.5 VCC; VI = GND to VCC
For 74HCT1G32-Q100: VM = 1.3 V; VI = GND to 3.0 V
Fig 5. The input (A and B) to output (Y) propagation delays
VCC
PULSE
GENERATOR
VI
VO
DUT
RT
CL
mna101
Measurement points are given in Table 8. Definitions for test circuit:
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Fig 6. Load circuitry for switching times
74HC_HCT1G32_Q100
Product data sheet
6 of 12
Nexperia
2-input OR gate
13. Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
E
D
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
L
e
w M
bp
detail X
e1
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Fig 7. Package outline SOT353-1 (TSSOP5)
74HC_HCT1G32_Q100
Product data sheet
7 of 12
Nexperia
2-input OR gate
Plastic surface-mounted package; 5 leads
SOT753
D
E
B
y
A
X
HE
5
v M A
4
Q
A
A1
c
1
2
3
Lp
detail X
bp
e
w M B
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.100
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT753
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-04-16
06-03-16
SC-74A
Fig 8. Package outline SOT753 (SC-74A)
74HC_HCT1G32_Q100
Product data sheet
8 of 12
Nexperia
2-input OR gate
14. Abbreviations
Table 9.
Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
TTL
Transistor-Transistor Logic
HBM
Human Body Model
ESD
ElectroStatic Discharge
MM
Machine Model
DUT
Device Under Test
MIL
Military
15. Revision history
Table 10.
Revision history
Document ID
Release date
74HC_HCT1G32_Q100 v.1 20120808
74HC_HCT1G32_Q100
Product data sheet
Data sheet status
Change notice
Supersedes
Product data sheet
9 of 12
Nexperia
2-input OR gate
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74HC_HCT1G32_Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
10 of 12
Nexperia
2-input OR gate
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74HC_HCT1G32_Q100
Product data sheet
11 of 12
Nexperia
2-input OR gate
18. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Dynamic characteristics . . . . . . . . . . . . . . . . . . 5
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9
Legal information. . . . . . . . . . . . . . . . . . . . . . . 10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . 11
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Date of release: 08 August 2012
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC1G32GV-Q100H 74HC1G32GW-Q100H 74HCT1G32GW-Q100H 74HCT1G32GV-Q100H
很抱歉,暂时无法提供与“74HC1G32GV-Q100H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.82882
- 50+0.67994
- 150+0.60551
- 500+0.54967
- 3000+0.50501
- 6000+0.48268
