74HC4075-Q100;
74HCT4075-Q100
Triple 3-input OR gate
Rev. 2 — 4 February 2019
Product data sheet
1. General description
The 74HC4075-Q100; 74HCT4075-Q100 is a triple 3-input OR gate. Inputs include clamp diodes.
This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Complies with JEDEC standard JESD7A
Input levels:
• For 74HC4075-Q100: CMOS level
• For 74HCT4075-Q100: TTL level
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
3. Ordering information
Table 1. Ordering information
Type number
Package
74HC4075D-Q100
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
-40 °C to +125 °C
TSSOP14
plastic thin shrink small outline package; 14 leads; SOT402-1
body width 4.4 mm
74HCT4075D-Q100
74HC4075PW-Q100
Nexperia
4. Functional diagram
3
1A
4
1B
5
1C
1Y
6
3
4
≥1
6
5
1
2A
2
2B
8
2C
2Y
1
9
2
≥1
9
8
11
3A
12
3B
13
3C
3Y
11
10
12
≥1
Y
B
10
13
aaa-024793
Fig. 1.
A
C
aaa-024794
Logic symbol
Fig. 2.
IEC logic symbol
aaa-024795
Fig. 3.
Logic diagram (one gate)
5. Pinning information
5.1. Pinning
74HC4075-Q100
74HCT4075-Q100
2A
1
14
VCC
2B
2
13
3C
1A
3
12
3B
1B
4
11
3A
1C
5
10
3Y
1Y
6
9
2Y
GND
7
8
2C
74HC4075-Q100
2A
1
14 VCC
2B
2
13 3C
1A
3
12 3B
1B
4
11 3A
1C
5
10 3Y
1Y
6
9
2Y
GND
7
8
2C
aaa-007624
aaa-007623
Fig. 4.
Pin configuration SOT108-1 (SO14)
Fig. 5.
Pin configuration SOT402-1 (TSSOP14)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1A, 2A, 3A
3, 1, 11
data input
1B, 2B, 3B
4, 2, 12
data input
1C, 2C, 3C
5, 8, 13
data input
1Y, 2Y, 3Y
6, 9, 10
data output
GND
7
ground (0 V)
VCC
14
supply voltage
74HC_HCT4075_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 12
Nexperia
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
Outputs
Inputs
nA
nB
nC
nY
L
L
L
L
X
X
H
H
X
H
X
H
H
X
X
H
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
-0.5
+7
V
[1]
±20
mA
[1]
±20
mA
±25
mA
supply current
50
mA
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
74HCT4075-Q100
Unit
VCC
supply voltage
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
IO
output current
-0.5 V < VO < VCC + 0.5 V
ICC
IGND
[1]
[2]
[2]
Unit
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SO14 package: Ptot derates linearly with 8 mW/K above 70 °C.
For TSSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 °C.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
74HC4075-Q100
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
74HC_HCT4075_Q100
Product data sheet
3 / 12
Nexperia
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
LOW-level input VCC = 2.0 V
voltage
VCC = 4.5 V
0.8
0.5
0.5
0.5
V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
74HC4075-Q100
VIH
VIL
VOH
VOL
HIGH-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
VI = VIH or VIL
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
VI = VIH or VIL
II
input leakage
current
VI = VCC or GND; VCC = 6.0 V
±0.1
±1.0
±1.0
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
2.0
μA
CI
input
capacitance
3.5
pF
2.0
1.6
2.0
2.0
V
1.2
0.8
0.8
0.8
V
IO = -20 μA
4.4
4.5
4.4
4.4
V
IO = -4.0 mA
3.98
4.32
3.84
3.7
V
IO = 20 μA
0.1
0.1
V
IO = 4.0 mA
0.15
0.26
0.33
0.4
V
74HCT4075-Q100
VIH
HIGH-level
input voltage
VIL
LOW-level input VCC = 4.5 V to 5.5 V
voltage
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
LOW-level
output voltage
VOL
II
input leakage
current
VI = VCC or GND; VCC = 5.5 V
±0.1
±1.0
±1.0
μA
ICC
supply current
VI = VCC or GND; VCC = 5.5 V;
IO = 0 A
2.0
μA
74HC_HCT4075_Q100
Product data sheet
4 / 12
Nexperia
Symbol Parameter
ΔICC
additional
supply current
Conditions
25 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
150
540
675
735
μA
3.5
pF
per input pin; VI = VCC - 2.1 V;
other inputs at VCC or GND;
VCC = 4.5 V to 5.5 V; IO = 0 A
nA, nB, nC inputs
CI
-40 °C to
+85 °C
input
capacitance
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Fig. 7.
Symbol Parameter
Conditions
25 °C
-40 °C to +125 °C
Unit
Min
Typ
Max
Min
Max
Max
(85 °C) (125 °C)
VCC = 2.0 V
28
100
125
150
ns
VCC = 4.5 V
10
30
ns
VCC = 5.0 V; CL = 15 pF
8
ns
VCC = 6.0 V
8
17
21
26
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
28
pF
VCC = 4.5 V
12
24
30
36
ns
10
ns
74HC4075-Q100
tpd
tt
CPD
propagation
delay
transition time
power
dissipation
capacitance
nA, nB, nC to nY; see Fig. 6
see Fig. 6
[1]
[2]
per package; VI = GND to VCC
[3]
[1]
74HCT4075-Q100
tpd
propagation
delay
tt
transition time
VCC = 4.5 V; see Fig. 6
[2]
7
15
19
22
ns
CPD
power
dissipation
capacitance
per package;
VI = GND to VCC - 1.5 V
[3]
32
pF
[1]
[2]
[3]
tpd is the same as tPHL and tPLH.
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW):
2
2
PD = CPD × VCC × fi × N + ∑ (CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑ (CL × VCC × fo) = sum of outputs.
74HC_HCT4075_Q100
Product data sheet
5 / 12
Nexperia
10.1. Waveforms and test circuit
VI
nA, nB, nC input
VM
GND
tPHL
VOH
tPLH
VY
VM
VX
nY output
VOL
tTHL
tTLH
aaa-024798
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 6.
Input (nA, nB, nC) to output (nY) propagation delays and output transition times
Table 8. Measurement points
Input
Type
Output
VM
VM
VX
VY
74HC4075-Q100
0.5VCC
0.5VCC
0.1VCC
0.9VCC
74HCT4075-Q100
1.3 V
1.3 V
0.1VCC
0.9VCC
74HC_HCT4075_Q100
Product data sheet
6 / 12
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VCC
VO
RT
RL
S1
open
CL
001aad983
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch
Fig. 7.
Test circuit for measuring switching times
Table 9. Test data
Type
Input
S1 position
Load
VI
tr, tf
CL
RL
tPHL, tPLH
74HC4075-Q100
VCC
6 ns
15 pF, 50 pF
1 kΩ
open
74HCT4075-Q100
3V
6 ns
15 pF, 50 pF
1 kΩ
open
74HC_HCT4075_Q100
Product data sheet
7 / 12
Nexperia
11. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
A2
Q
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig. 8.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT108-1 (SO14)
74HC_HCT4075_Q100
Product data sheet
8 / 12
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
D
SOT402-1
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
7
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
Fig. 9.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Package outline SOT402-1 (TSSOP14)
74HC_HCT4075_Q100
Product data sheet
9 / 12
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74HC_HCT4075_Q100 v.2
20190204
Product data sheet
Modifications:
74HC_HCT4075_Q100 v.1
74HC_HCT4075_Q100
Product data sheet
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74HCT4075PW-Q100 (SOT402-1) removed.
74HCT4075-Q100; added value for VOL at IO = 4 mA (inline with Non-Automotive
version), see Table 6.
20130522
Product data sheet
10 / 12
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
14. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74HC_HCT4075_Q100
Product data sheet
11 / 12
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................2
5.1. Pinning.........................................................................2
5.2. Pin description............................................................. 2
6. Functional description................................................. 3
7. Limiting values............................................................. 3
8. Recommended operating conditions..........................3
9. Static characteristics....................................................4
10. Dynamic characteristics............................................ 5
10.1. Waveforms and test circuit........................................ 6
11. Package outline.......................................................... 8
12. Abbreviations............................................................ 10
13. Revision history........................................................10
14. Legal information......................................................11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 4 February 2019
74HC_HCT4075_Q100
Product data sheet
12 / 12
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC4075PW-Q100J 74HC4075D-Q100J 74HCT4075D-Q100J
