74HC86; 74HCT86
Quad 2-input EXCLUSIVE-OR gate
Rev. 4 — 4 December 2015
Product data sheet
1. General description
The 74HC86; 74HCT86 is a quad 2-input EXCLUSIVE-OR gate. Inputs include clamp
diodes. This enables the use of current limiting resistors to interface inputs to voltages in
excess of VCC.
2. Features and benefits
Input levels:
For 74HC86: CMOS level
For 74HCT86: TTL level
Complies with JEDEC standard no. 7A
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C and from 40 C to +125 C
3. Ordering information
Table 1.
Type number
74HC86D
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO14
plastic small outline package; 14 leads; body width
3.9 mm
SOT108-1
40 C to +125 C
SSOP14
plastic shrink small outline package; 14 leads; body
width 5.3 mm
SOT337-1
40 C to +125 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74HCT86D
74HC86DB
74HCT86DB
74HC86PW
74HCT86PW
74HC86; 74HCT86
Nexperia
4. Functional diagram
PQD
Fig 1.
Logic symbol
Fig 2.
PQD
PQD
Logic diagram (one gate)
74HC_HCT86
Product data sheet
Fig 3.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
74HC86; 74HCT86
Nexperia
5. Pinning information
5.1 Pinning
9&&
*1'
DDG
Fig 4.
Pin configuration SO14 and (T)SSOP14
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A to 4A
1, 4, 9, 12
data input
1B to 4B
2, 5, 10, 13
data input
1Y to 4Y
3, 6, 8, 11
data output
GND
7
ground (0 V)
VCC
14
supply voltage
6. Functional description
Table 3.
Function table[1]
Input nA
Input nB
Output nY
L
L
L
L
H
H
H
L
H
H
H
L
[1]
H = HIGH voltage level;
L = LOW voltage level.
74HC_HCT86
Product data sheet
3 of 15
74HC86; 74HCT86
Nexperia
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+7
V
mA
mA
25
mA
50
mA
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
0.5 V < VO < VCC + 0.5 V
ICC
supply current
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
500
mW
total power dissipation
Ptot
[2]
SO14, and (T)SSOP14 packages
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 package: Ptot derates linearly with 8 mW/K above 70 C.
For (T)SSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
8. Recommended operating conditions
Table 5.
Symbol Parameter
VCC
supply voltage
Conditions
74HC86
74HCT86
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
40
+25
+125
40
+25
+125
C
t/V
input transition rise and fall rate
625
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
74HC_HCT86
Product data sheet
VCC = 2.0 V
ns/V
4 of 15
74HC86; 74HCT86
Nexperia
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 C
Conditions
40 C to +85 C 40 C to +125 C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
74HC86
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
VI = VIH or VIL
IO = 20 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = 4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = 5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
0.1
0.1
V
0.1
0.1
V
VI = VIH or VIL
0.1
0.1
V
0.15
0.26
0.33
0.4
V
0.16
0.26
0.33
0.4
V
II
input leakage
current
VI = VCC or GND;
VCC = 6.0 V
0.1
1
1
A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
2.0
A
CI
input
capacitance
3.5
pF
74HCT86
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = 20 A
4.4
4.5
4.4
4.4
V
IO = 4.0 mA
3.98
4.32
3.84
3.7
V
LOW-level
output voltage
IO = 20 A
0.1
0.1
V
IO = 5.2 mA
0.15
0.26
0.33
0.4
V
VI = VCC or GND;
VCC = 5.5 V
0.1
1
1
A
VOL
II
input leakage
current
74HC_HCT86
Product data sheet
5 of 15
74HC86; 74HCT86
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
ICC
supply current
VCC = 5.5 V
2.0
A
ICC
additional
supply current
per input pin;
VI = VCC 2.1 V; IO = 0 A;
other inputs at VCC or GND;
100
360
450
490
A
CI
input
capacitance
3.5
pF
10. Dynamic characteristics
Table 7.
GND = 0 V; CL = 50 pF; for test circuit see Figure 6.
Symbol Parameter
25 C
Conditions
40 C to +125 C Unit
Min
Typ
Max
Max
(85 C)
Max
(125 C)
VCC = 2.0 V
39
120
150
180
ns
VCC = 4.5 V
14
24
30
36
ns
VCC = 5.0 V; CL = 15 pF
11
ns
11
31
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
6
13
16
19
ns
30
pF
74HC86
tpd
propagation delay nA, nB to nY; see Figure 5
[1]
VCC = 6.0 V
tt
transition time
[2]
see Figure 5
VCC = 6.0 V
CPD
power dissipation
capacitance
74HC_HCT86
Product data sheet
per package; VI = GND to VCC
[3]
6 of 15
74HC86; 74HCT86
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
25 C
Conditions
40 C to +125 C Unit
Min
Typ
Max
Max
(85 C)
Max
(125 C)
17
32
40
48
ns
14
ns
74HCT86
[1]
tpd
VCC = 4.5 V
tt
transition time
VCC = 4.5 V; see Figure 5
[2]
CPD
power dissipation
capacitance
per package;
VI = GND to VCC 1.5 V
[3]
[1]
7
15
19
22
ns
30
pF
tpd is the same as tPHL and tPLH.
[2]
tt is the same as tTHL and tTLH.
[3]
CPD is used to determine the dynamic power dissipation (PD in W):
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
11. Waveforms
9,
Q$Q%LQSXW
90
*1'
W3+/
92+
90
9;
Q
很抱歉,暂时无法提供与“74HC86D,652”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 57+1.08825
- 114+1.06117
- 285+1.03514
- 570+1.00910
