74LV08
Quad 2-input AND gate
Rev. 4 — 8 December 2015
Product data sheet
1. General description
The 74LV08 is a low-voltage Si-gate CMOS device that is pin and function compatible with
74HC08 and 74HCT08.
The 74LV08 provides a quad 2-input AND function.
2. Features and benefits
Wide operating voltage: 1.0 V to 5.5 V
Optimized for low voltage applications: 1.0 V to 3.6 V
Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V
Typical output ground bounce < 0.8 V at VCC = 3.3 V and Tamb = 25 C
Typical HIGH-level output voltage (VOH) undershoot: > 2 V at VCC = 3.3 V and
Tamb = 25 C
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C and from 40 C to +125 C
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LV08D
40 C to +125 C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
74LV08DB
40 C to +125 C
SSOP14
plastic shrink small outline package; 14 leads;
body width 5.3 mm
SOT337-1
74LV08PW
40 C to +125 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74LV08
Nexperia
4. Functional diagram
Fig 1.
PQD
PQD
PQD
Logic symbol
Fig 2.
IEC logic symbol
Fig 3.
Logic diagram (one gate)
5. Pinning information
5.1 Pinning
/9
/9
9&&
9&&
*1'
*1'
Pin configuration SO14
74LV08
Product data sheet
DDM
DDM
Fig 4.
Fig 5.
Pin configuration (T)SSOP14
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 13
74LV08
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A, 2A, 3A, 4A
1, 4, 9, 12
data input
1B, 2B, 3B, 4B
2, 5, 10, 13
data input
1Y, 2Y, 3Y, 4Y
3, 6, 8, 11
data output
GND
7
ground (0 V)
VCC
14
supply voltage
6. Functional description
Table 3.
Function selection[1]
Input
Output
nA
nB
nY
L
X
L
X
L
L
H
H
H
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VCC
supply voltage
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = 0.5 V to (VCC + 0.5 V)
Min
Max
Unit
0.5
+7.0
V
mA
50
mA
25
mA
ICC
supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
500
mW
Ptot
total power dissipation
Tamb = 40 C to +125 C
[2]
SO14, SSOP14, TSSOP14
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 packages: above 70 C the value of Ptot derates linearly with 8 mW/K.
For (T)SSOP14 packages: above 60 C the value of Ptot derates linearly with 5.5 mW/K.
74LV08
Product data sheet
3 of 13
74LV08
Nexperia
8. Recommended operating conditions
Table 5.
Symbol
Parameter
Conditions
voltage[1]
Min
Typ
Max
Unit
1.0
3.3
5.5
V
VCC
supply
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+25
+125
C
t/V
input transition rise and fall rate
VCC = 1.0 V to 2.0 V
500
ns/V
VCC = 2.0 V to 2.7 V
200
ns/V
VCC = 2.7 V to 3.6 V
100
ns/V
VCC = 3.6 V to 5.5 V
50
ns/V
[1]
The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V, but LV devices are guaranteed to function down to
VCC = 1.0 V (with input levels GND or VCC).
9. Static characteristics
Table 6.
Symbol Parameter
VIH
VIL
VOH
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level output
voltage
74LV08
Product data sheet
40 C to +85 C
Conditions
40 C to +125 C Unit
Min
Typ[1]
Max
Min
Max
VCC = 1.2 V
0.9
0.9
V
VCC = 2.0 V
1.4
1.4
V
2.0
2.0
V
VCC = 4.5 V to 5.5 V
0.7VCC
0.7VCC
V
0.3
0.3
V
VCC = 1.2 V
VCC = 2.0 V
0.6
0.6
V
0.8
0.8
V
0.3VCC
0.3VCC
V
IO = 100 A; VCC = 1.2 V
1.2
V
IO = 100 A; VCC = 2.0 V
1.8
2.0
1.8
V
IO = 100 A; VCC = 2.7 V
2.5
2.7
2.5
V
IO = 100 A; VCC = 3.0 V
2.8
3.0
2.8
V
VI = VIH or VIL
IO = 100 A; VCC = 4.5 V
4.3
4.5
4.3
V
IO = 6 mA; VCC = 3.0 V
2.4
2.82
2.2
V
IO = 12 mA; VCC = 4.5 V
3.6
4.2
3.5
V
4 of 13
74LV08
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
VOL
40 C to +85 C
Conditions
LOW-level output
voltage
Min
Typ[1]
40 C to +125 C Unit
Max
Min
Max
VI = VIH or VIL
V
0.2
V
0.2
V
0.2
V
0.2
V
0.25
0.40
0.50
V
0.35
0.55
0.65
V
II
input leakage current
VI = VCC or GND; VCC = 5.5 V
1.0
1.0
A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
20.0
40
A
ICC
additional supply
current
per input; VI = VCC 0.6 V;
500
850
A
CI
input capacitance
3.5
pF
[1]
Typical values are measured at Tamb = 25 C.
10. Dynamic characteristics
Table 7.
GND = 0 V; For test circuit see Figure 7.
Symbol Parameter
tpd
propagation delay
40 C to +85 C
Conditions
Max
Min
Max
VCC = 1.2 V
45
ns
VCC = 2.0 V
15
26
33
ns
[2]
11
17
21
ns
VCC = 3.0 V to 3.6 V; CL = 15 pF
[3]
7
ns
[3]
9.0
15
19
ns
11
14
ns
10
pF
power dissipation
capacitance
Unit
Min
nA, nB to nY; see Figure 6
VCC = 2.7 V
CPD
40 C to +125 C
Typ[1]
CL = 50 pF; fi = 1 MHz;
VI = GND to VCC
[1]
All typical values are measured at Tamb = 25 C.
[2]
tpd is the same as tPLH and tPHL.
[4]
[3]
Typical values are measured at nominal supply voltage (VCC = 3.3 V).
[4]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz, fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
(CL VCC2 fo) = sum of the outputs.
74LV08
Product data sheet
5 of 13
74LV08
Nexperia
11. Waveforms
9,
90
Q$Q%LQSXW
*1'
W 3+/
W 3/+
92+
Q
很抱歉,暂时无法提供与“74LV08PW,112”相匹配的价格&库存,您可以联系我们找货
