74LVC1G386GV,125
74LVC1G386GV,125
    NEXPERIA(安世)
    SOT457
    电压电平转换器 1.65~5.5V 100mA SOT457-6
74LVC1G386GV,125 数据手册
74LVC1G386 3-input EXCLUSIVE-OR gate Rev. 4 — 9 May 2017 1 Product data sheet General description The 74LVC1G386 provides a 3-input EXCLUSIVE-OR function. The input can be driven from either 3.3 or 5 V devices. This feature allows the use of these devices in a mixed 3.3 and 5 V environment. Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall time. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2 Features and benefits • Wide supply voltage range from 1.65 to 5.5 V • High noise immunity • Complies with JEDEC standard: – JESD8-7 (1.65 V to 1.95 V) – JESD8-5 (2.3 V to 2.7 V) – JESD8B/JESD36 (2.7 V to 3.6 V) • ±24 mA output drive (VCC = 3.0 V) • Latch-up performance exceeds 250 mA • CMOS low power consumption • Direct interface with TTL levels • Inputs accept voltages up to 5 V • ESD protection: – HBM EIA/JESD22-A114E exceeds 2 000 V – MM EIA/JESD22-A115-A exceeds 200 V. • SOT363 and SOT457 package • Specified from -40 to +85 °C and -40 to +125 °C. 74LVC1G386 Nexperia 3-input EXCLUSIVE-OR gate 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G386GW -40 °C to +125 °C SC-88 plastic surface-mounted package; 6 leads SOT363 74LVC1G386GV -40 °C to +125 °C SC-74A plastic surface-mounted package (TSOP6); 6 leads SOT457 4 Marking Table 2. Marking Type number Marking code 74LVC1G386GW YH 74LVC1G386GV YH [1] 5 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. Functional diagram 1 3 6 A Y B C 1 3 6 4 =1 mnb145 mnb143 Figure 1. Logic symbol 4 Figure 2. IEC logic symbol A B Y C mnb144 Figure 3. Logic diagram 74LVC1G386 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 14 74LVC1G386 Nexperia 3-input EXCLUSIVE-OR gate 6 Pinning information 6.1 Pinning 74LVC1G386 A 1 6 C GND 2 5 VCC B 3 4 Y 001aag920 Figure 4. Pin configuration 6.2 Pin description Table 3. Pin description Symbol Pin Description A 1 data input GND 2 ground (0 V) B 3 data input Y 4 data output VCC 5 supply voltage C 6 data input 7 Functional description Table 4. Function table [1] Output Input A B C Y L L L L L L H H L H L H L H H L H L L H H L H L H H L L H H H H [1] H = HIGH voltage level; L = LOW voltage level 74LVC1G386 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 14 74LVC1G386 Nexperia 3-input EXCLUSIVE-OR gate 8 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO VI < 0 V [1] output current ICC supply current IGND ground current Ptot total power dissipation Tstg storage temperature Min Max Unit -0.5 +6.5 V -50 - -0.5 +6.5 V mA VO > VCC or VO < 0 V output voltage IO [1] [2] [3] Conditions mA - ±50 Active mode [1] [2] -0.5 VCC + 0.5 V Power-down mode [1] [2] -0.5 +6.5 V - ±50 mA - 100 mA -100 - mA - 250 mW -65 +150 °C VO = 0 V to VCC Tamb = -40 °C to +125 °C [3] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. For SC-74 and SC-88 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K. 9 Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature Δt/ΔV input transition rise and fall rate 74LVC1G386 Product data sheet Min Typ Max 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - VCC VO VCC = 0 V; Power-down mode 0 - 5.5 VO -40 - +125 °C VCC = 1.65 V to 2.7 V - - 20 ns/V VCC = 2.7 V to 5.5 V - - 10 ns/V All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 May 2017 Unit © Nexperia B.V. 2017. All rights reserved. 4 / 14 74LVC1G386 Nexperia 3-input EXCLUSIVE-OR gate 10 Static characteristics Table 7. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ [1] Max Unit Tamb = -40 °C to +85 °C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VCC = 1.65 V to 1.95 V 0.65 × VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7 × VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3 × VCC V VCC - 0.1 - - V IO = -4 mA; VCC = 1.65 V 1.2 - - V IO = -8 mA; VCC = 2.3 V 1.9 - - V IO = -12 mA; VCC = 2.7 V 2.2 - - V IO = -24 mA; VCC = 3.0 V 2.3 - - V IO = -32 mA; VCC = 4.5 V 3.8 - - V IO = 100 μA; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.3 V IO = 12 mA; VCC = 2.7 V - - 0.4 V IO = 24 mA; VCC = 3.0 V - - 0.55 V IO = 32 mA; VCC = 4.5 V - - 0.55 V VI = VIH or VIL IO = -100 μA; VCC = 1.65 V to 5.5 V VOL LOW-level output voltage 0.35 × VCC V VI = VIH or VIL II input leakage current VCC = 0 V to 5.5 V; VI = 5.5 V or GND - ±0.1 ±1 μA IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - ±0.1 ±2 μA ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - 0.1 4 μA ΔICC additional supply current per pin; VCC = 2.3 V to 5.5 V; VI = VCC - 0.6 V; IO = 0 A - 5 500 μA CI input capacitance VCC = 3.3 V; VI = GND to VCC - 4 - pF 0.65 × VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V Tamb = -40 °C to +125 °C VIH HIGH-level input voltage 74LVC1G386 Product data sheet VCC = 1.65 V to 1.95 V All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 14 74LVC1G386 Nexperia 3-input EXCLUSIVE-OR gate Symbol Parameter Conditions VCC = 4.5 V to 5.5 V VIL LOW-level input voltage VOH HIGH-level output voltage LOW-level output voltage Typ [1] Max - Unit 0.7 × VCC - VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3 × VCC V V VCC - 0.1 - - V IO = -4 mA; VCC = 1.65 V 0.95 - - V IO = -8 mA; VCC = 2.3 V 1.7 - - V IO = -12 mA; VCC = 2.7 V 1.9 - - V IO = -24 mA; VCC = 3.0 V 2.0 - - V IO = -32 mA; VCC = 4.5 V 3.4 - - V IO = 100 μA; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.80 V IO = 32 mA; VCC = 4.5 V - - 0.80 V 0.35 × VCC V VI = VIH or VIL IO = -100 μA; VCC = 1.65 V to 5.5 V VOL Min VI = VIH or VIL II input leakage current VCC = 0 V to 5.5 V; VI = 5.5 V or GND - - ±1 μA IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - - ±2 μA ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - - 4 μA ΔICC additional supply current per pin; VCC = 2.3 V to 5.5 V; VI = VCC - 0.6 V; IO = 0 A - - 500 μA [1] All typical values are measured at VCC = 3.3 V and Tamb = 25 °C. 74LVC1G386 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 14 74LVC1G386 Nexperia 3-input EXCLUSIVE-OR gate 11 Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 6. Symbol Parameter Conditions -40 °C to +85 °C Min [1] [2] [3] power dissipation capacitance Max Min Max VCC = 1.65 V to 1.95 V 2.0 8.0 17.0 2.0 22.0 ns VCC = 2.3 V to 2.7 V 1.5 5.0 9.0 1.5 11.5 ns VCC = 2.7 V 1.5 5.0 8.5 1.5 11.0 ns VCC = 3.0 V to 3.6 V 1.0 4.5 7.5 1.0 9.5 ns 1.0 3.5 5.5 1.0 7.0 ns - 13 - - - pF VCC = 4.5 V to 5.5 V CPD [1] Unit [2] propagation delay A, B, C to Y; see Figure 5 tpd Typ -40 °C to +125 °C VI = GND to VCC; VCC = 3.3 V [3] Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. tpd is the same as tPLH and tPHL. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + ∑(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑(CL × VCC × fo) = sum of outputs. 11.1 Waveforms and test circuit VI A, B, C input VM GND t PHL t PLH VOH Y output in phase VM VOL t PLH tPHL VOH Y output out of phase VM VOL mnb147 Measurement points are given in Table 9. VOL and VOH are typical output voltage levels that occur with the output load. Figure 5. Input A, B, C to output Y propagation delays 74LVC1G386 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 14 74LVC1G386 Nexperia 3-input EXCLUSIVE-OR gate Table 9. Measurement points VCC VM Input VI tr = tf 1.65 V to 1.95 V 0.5 × VCC VCC ≤ 2.0 ns 2.3 V to 2.7 V 0.5 × VCC VCC ≤ 2.0 ns 2.7 V 1.5 V 2.7 V ≤ 2.5 ns 3.0 V to 3.6 V 1.5 V 2.7 V ≤ 2.5 ns 4.5 V to 5.5 V 0.5 × VCC VCC ≤ 2.5 ns VEXT VCC G VI RL VO DUT RT CL RL mna616 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Figure 6. Test circuit for measuring switching times Table 10. Test data Supply voltage Input Load VCC VI CL RL tPLH, tPHL 1.65 V to 1.95 V VCC 30 pF 1 kΩ open 2.3 V to 2.7 V VCC 30 pF 500 Ω open 2.7 V 2.7 V 50 pF 500 Ω open 3.0 V to 3.6 V 2.7 V 50 pF 500 Ω open 4.5 V to 5.5 V VCC 50 pF 500 Ω open 74LVC1G386 Product data sheet VEXT All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 14 74LVC1G386 Nexperia 3-input EXCLUSIVE-OR gate 12 Package outline Plastic surface-mounted package; 6 leads SOT363 D B E y A X HE 6 5 v M A 4 Q pin 1 index A 1 2 e1 A1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 JEITA SC-88 EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 Figure 7. Package outline SOT363 (SC-88) 74LVC1G386 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 14 74LVC1G386 Nexperia 3-input EXCLUSIVE-OR gate Plastic surface-mounted package (TSOP6); 6 leads D SOT457 B E y A HE 6 5 X v M A 4 Q pin 1 index A A1 1 2 c 3 Lp e bp w M B detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.1 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT457 JEITA SC-74 EUROPEAN PROJECTION ISSUE DATE 05-11-07 06-03-16 Figure 8. Package outline SOT457 (SC-74) 74LVC1G386 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 14 74LVC1G386 Nexperia 3-input EXCLUSIVE-OR gate 13 Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14 Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC1G386 v.4 20170509 Product data sheet - 74LVC1G386 v.3 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate 74LVC1G386 v.3 20161207 Modifications: • Table 7: The maximum limits for leakage current and supply current have changed. 74LVC1G386 v.2 20121119 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. • In Section 10 "Static characteristics", changed conditions for input leakage and supply current. 74LVC1G386 v.1 20031104 74LVC1G386 Product data sheet Product data sheet Product data sheet Product specification All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 May 2017 - 74LVC1G386 v.2 74LVC1G386 v.1 - © Nexperia B.V. 2017. All rights reserved. 11 / 14 74LVC1G386 Nexperia 3-input EXCLUSIVE-OR gate 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74LVC1G386 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 14 74LVC1G386 Nexperia 3-input EXCLUSIVE-OR gate Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74LVC1G386 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 14 74LVC1G386 Nexperia 3-input EXCLUSIVE-OR gate Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Marking .................................................................2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................3 Limiting values .................................................... 4 Recommended operating conditions ................ 4 Static characteristics .......................................... 5 Dynamic characteristics .....................................7 Waveforms and test circuit ................................ 7 Package outline ...................................................9 Abbreviations .................................................... 11 Revision history ................................................ 11 Legal information .............................................. 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 9 May 2017 Document identifier: 74LVC1G386 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC1G386GV,125 74LVC1G386GW,125
74LVC1G386GV,125 价格&库存
很抱歉,暂时无法提供与“74LVC1G386GV,125”相匹配的价格&库存,您可以联系我们找货
74LVC1G386GV,125
    • 3000+0.89236
    74LVC1G386GV,125
      • 25+0.29920
      • 100+0.23971
      • 250+0.21347
      • 500+0.18897
