74LVC1GU04GV-Q100H
74LVC1GU04GV-Q100H
    NEXPERIA(安世)
    SC-74A
    电压电平转换器 1.65~5.5V 100mA SOT753-5
74LVC1GU04GV-Q100H 数据手册
74LVC1GU04-Q100 Unbuffered inverter Rev. 2 — 13 December 2016 Product data sheet 1. General description The 74LVC1GU04-Q100 is a single unbuffered inverter. The input can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device in a mixed 3.3 V and 5 V environment. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide supply voltage range from 1.65 V to 5.5 V  High noise immunity  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pf, R = 0 )  24 mA output drive (VCC = 3.0 V)  CMOS low power consumption  Latch-up performance exceeds 250 mA  Input accepts voltages up to 5 V 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1GU04GW-Q100 40 C to +125 C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74LVC1GU04GV-Q100 40 C to +125 C SC-74A plastic surface-mounted package; 5 leads SOT753 74LVC1GU04-Q100 Nexperia Unbuffered inverter 4. Marking Table 2. Marking codes Type number Marking[1] 74LVC1GU04GW-Q100 VD 74LVC1GU04GV-Q100 VU4 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram 9&& $  $ <    PQD Fig 1. Logic symbol ȍ <  PQD Fig 2. 9&& PQD IEC logic symbol Fig 3. Logic diagram 6. Pinning information 6.1 Pinning /9&*84 QF  $  *1'   9&&  < DDD Fig 4. Pin configuration SOT353-1 and SOT753 6.2 Pin description Table 3. Pin description Symbol Pin Description n.c. 1 not connected A 2 data input GND 3 ground (0 V) Y 4 data output VCC 5 supply voltage 74LVC1GU04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 13 December 2016 © Nexperia B.V. 2017. All rights reserved 2 of 14 74LVC1GU04-Q100 Nexperia Unbuffered inverter 7. Functional description Function table[1] Table 4. Input (A) Output (Y) L H H L [1] H = HIGH voltage level; L = LOW voltage level. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage Conditions Min Max Unit 0.5 +6.5 V - 50 mA [1] 0.5 +6.5 V - 50 [1][2] 0.5 VCC + 0.5 - 50 mA - +100 mA - 100 mA - 250 mW 65 +150 C VI < 0 V IOK output clamping current VO > VCC or VO < 0 V VO output voltage Active mode IO output current VO = 0 V to VCC ICC supply current IGND ground current Ptot total power dissipation Tstg storage temperature Tamb = 40 C to +125 C [3] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. [3] For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. mA V 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature t/V input transition rise and fall rate 74LVC1GU04_Q100 Product data sheet Conditions Active mode Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V 0 - VCC V 40 - +125 C VCC = 1.65 V to 2.7 V 0 - 20 ns/V VCC = 2.7 V to 5.5 V 0 - 10 ns/V All information provided in this document is subject to legal disclaimers. Rev. 2 — 13 December 2016 © Nexperia B.V. 2017. All rights reserved 3 of 14 74LVC1GU04-Q100 Nexperia Unbuffered inverter 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max Unit Tamb = 40 C to +85 C VIH HIGH-level input voltage VCC = 1.65 V to 5.5 V 0.75  VCC - - V VIL LOW-level input voltage VCC = 1.65 V to 5.5 V - - 0.25  VCC V VOH HIGH-level output voltage VI = VIH or VIL VCC 0.1 - - V IO = 4 mA; VCC = 1.65 V 1.2 - - V IO = 8 mA; VCC = 2.3 V 1.9 - - V IO = 12 mA; VCC = 2.7 V 2.2 - - V IO = 24 mA; VCC = 3.0 V 2.3 - - V IO = 32 mA; VCC = 4.5 V 3.8 - - V IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.3 V IO = 12 mA; VCC = 2.7 V - - 0.4 V IO = 24 mA; VCC = 3.0 V - - 0.55 V IO = 32 mA; VCC = 4.5 V - - 0.55 V IO = 100 A; VCC = 1.65 V to 5.5 V VOL LOW-level output voltage VI = VIH or VIL II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - 0.1 1 A ICC supply current VI = 5.5 V or GND; IO = 0 A; VCC = 1.65 V to 5.5 V - 0.1 4 A CI input capacitance VCC = 3.3 V; VI = GND to VCC - 6 - pF Tamb = 40 C to +125 C VIH HIGH-level input voltage VCC = 1.65 V to 5.5 V 0.8  VCC - - V VIL LOW-level input voltage VCC = 1.65 V to 5.5 V - - 0.2  VCC V VOH HIGH-level output voltage VI = VIH or VIL VCC 0.1 - - V IO = 4 mA; VCC = 1.65 V 0.95 - - V IO = 8 mA; VCC = 2.3 V 1.7 - - V IO = 12 mA; VCC = 2.7 V 1.9 - - V IO = 24 mA; VCC = 3.0 V 2.0 - - V IO = 32 mA; VCC = 4.5 V 3.4 - - V IO = 100 A; VCC = 1.65 V to 5.5 V 74LVC1GU04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 13 December 2016 © Nexperia B.V. 2017. All rights reserved 4 of 14 74LVC1GU04-Q100 Nexperia Unbuffered inverter Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Min Typ[1] Max Unit IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.7 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.80 V IO = 32 mA; VCC = 4.5 V - - 0.80 V Symbol Parameter Conditions VOL VI = VIH or VIL LOW-level output voltage II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - 0.1 1 A ICC supply current VI = 5.5 V or GND; IO = 0 A; VCC = 1.65 V to 5.5 V - - 4 A [1] All typical values are measured at VCC = 3.3 V and Tamb = 25 C. 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit, see Figure 8. Symbol Parameter tpd CPD 40 C to +85 C Conditions Min Max Min Max VCC = 1.65 V to 1.95 V 0.3 1.7 5.0 0.3 6.5 ns VCC = 2.3 V to 2.7 V 0.3 1.3 4.0 0.3 5.5 ns VCC = 2.7 V 0.5 1.7 5.0 0.5 6.5 ns VCC = 3.0 V to 3.6 V 0.5 1.6 3.7 0.5 5.0 ns VCC = 4.5 V to 5.5 V 0.5 1.3 3.0 0.5 4.0 ns - 14.9 - - - pF propagation delay A to Y; see Figure 5 power dissipation capacitance 40 C to +125 C Unit Typ[1] [2] [3] VI = GND to VCC; VCC = 3.3 V [1] Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74LVC1GU04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 13 December 2016 © Nexperia B.V. 2017. All rights reserved 5 of 14 74LVC1GU04-Q100 Nexperia Unbuffered inverter 12. Waveforms 9, 90 $LQSXW *1' W 3+/ W 3/+ 92+ 90
74LVC1GU04GV-Q100H 价格&库存
很抱歉,暂时无法提供与“74LVC1GU04GV-Q100H”相匹配的价格&库存,您可以联系我们找货
