74LVC2G02-Q100
Dual 2-input NOR gate
Rev. 2 — 13 December 2016
Product data sheet
1. General description
The 74LVC2G02-Q100 provides a 2-input NOR gate function.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these
devices as translators in a mixed 3.3 V and 5 V environment.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing a damaging backflow current through the device
when it is powered down.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant outputs for interfacing with 5 V logic
High noise immunity
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8-B/JESD36 (2.7 V to 3.6 V)
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Multiple package options
74LVC2G02-Q100
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74LVC2G02DP-Q100 40 C to +125 C
TSSOP8
plastic thin shrink small outline package; 8 leads;
body width 3 mm; lead length 0.5 mm
SOT505-2
74LVC2G02DC-Q100 40 C to +125 C
VSSOP8
plastic very thin shrink small outline package;
8 leads; body width 2.3 mm
SOT765-1
4. Marking
Table 2.
Marking codes
Type number
Marking code[1]
74LVC2G02DP-Q100
V02
74LVC2G02DC-Q100
V02
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
DDK
Fig 1.
Logic symbol
PQD
DDK
Fig 2.
IEC logic symbol
Fig 3.
Logic diagram (one gate)
6. Pinning information
6.1 Pinning
/9&*4
9&&
*1'
DDD
Fig 4.
Pin configuration SOT505-2 and SOT765-1
74LVC2G02_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 13
74LVC2G02-Q100
Nexperia
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
1A, 2A
1, 5
data input
1B, 2B
2, 6
data input
GND
4
ground (0 V)
1Y, 2Y
7, 3
data output
VCC
8
supply voltage
7. Functional description
Table 4.
Function table[1]
Input
Output
nA
nB
nY
L
L
H
X
H
L
H
X
L
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
[1]
output voltage
VO
Conditions
Min
Max
Unit
0.5
+6.5
V
0.5
+6.5
V
[1]
0.5
VCC + 0.5
V
[1][2]
0.5
+6.5
V
Active mode
Power-down mode
IIK
input clamping current
VI < 0 V
50
mA
IOK
output clamping current
VO < 0 V or VO > VCC
50
mA
IO
output current
VO = 0 V to VCC
50
mA
ICC
supply current
100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
300
mW
Tamb = 40 C to +125 C
[3]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal condition.
[3]
For TSSOP8 package: above 55 C the value of Ptot derates linearly with 2.5 mW/K.
For VSSOP8 package: above 110 C the value of Ptot derates linearly with 8 mW/K.
74LVC2G02_Q100
Product data sheet
3 of 13
74LVC2G02-Q100
Nexperia
9. Recommended operating conditions
Table 6.
Operating conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
t/V
input transition rise and fall rate
Min
Max
Unit
1.65
5.5
V
V
Active mode
VCC
V
Power-down mode
V
40
+125
C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ[1]
Max
0.65 VCC
V
Unit
Tamb = 40 C to +85 C
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
VCC = 1.65 V to 1.95 V
VCC = 2.3 V to 2.7 V
1.7
V
VCC = 2.7 V to 3.6 V
2.0
V
VCC = 4.5 V to 5.5 V
0.7 VCC
V
0.7
V
0.8
V
0.3 VCC
V
HIGH-level output voltage VI = VIH or VIL
IO = 100 A; VCC = 1.65 V to 5.5 V
VOL
0.35 VCC V
LOW-level output voltage
VCC 0.1
V
IO = 4 mA; VCC = 1.65 V
1.2
1.53
V
IO = 8 mA; VCC = 2.3 V
1.9
2.13
V
IO = 12 mA; VCC = 2.7 V
2.2
2.50
V
IO = 24 mA; VCC = 3.0 V
2.3
2.60
V
IO = 32 mA; VCC = 4.5 V
3.8
4.10
V
0.1
V
VI = VIH or VIL
74LVC2G02_Q100
Product data sheet
0.08
0.45
V
0.14
0.3
V
0.19
0.4
V
0.37
0.55
V
0.43
0.55
V
4 of 13
74LVC2G02-Q100
Nexperia
Table 7.
Static characteristics …continued
Min
Typ[1]
Max
VI = 5.5 V or GND; VCC = 0 V to 5.5 V
0.1
1
A
power-off leakage current
VI or VO = 5.5 V; VCC = 0 V
0.1
2
A
ICC
supply current
VI = 5.5 V or GND;
VCC = 1.65 V to 5.5 V; IO = 0 A
0.1
4
A
ICC
additional supply current
per pin; VI = VCC 0.6 V; IO = 0 A;
VCC = 2.3 V to 5.5 V
5
500
A
CI
input capacitance
2.5
pF
0.65 VCC
V
1.7
V
Symbol Parameter
Conditions
II
input leakage current
IOFF
Unit
VIH
VIL
VOH
2.0
V
0.7 VCC
V
0.8
V
0.3 VCC
V
VCC 0.1
V
0.7
V
VOL
0.35 VCC V
0.95
V
1.7
V
1.9
V
2.0
V
3.4
V
0.1
V
0.70
V
0.45
V
0.60
V
0.80
V
0.80
V
VI = VIH or VIL
II
1
A
IOFF
2
A
ICC
supply current
VI = 5.5 V or GND;
4
A
ICC
500
A
[1]
All typical values are measured at Tamb = 25 C.
74LVC2G02_Q100
Product data sheet
5 of 13
74LVC2G02-Q100
Nexperia
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground 0 V); for test circuit see Figure 6.
Symbol Parameter
40 C to +85 C
Conditions
Min
Max
Min
Max
1.2
3.8
8.9
1.2
11.2
ns
0.8
2.4
5.4
0.8
6.8
ns
VCC = 2.7 V
0.8
3.2
6.0
0.8
7.5
ns
VCC = 3.0 V to 3.6 V
0.6
2.4
4.9
0.6
6.2
ns
0.6
1.8
4.3
0.6
5.5
ns
14
pF
[2]
propagation delay nA, nB to nY; see Figure 5
tpd
power dissipation
capacitance
CPD
[3]
per gate; VI = GND to VCC
[1]
Typical values are measured at nominal VCC and at Tamb = 25 C.
[2]
tpd is the same as tPLH and tPHL.
[3]
40 C to +125 C Unit
Typ[1]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
12. Waveforms
9,
90
Q$Q%LQSXW
*1'
W 3+/
W 3/+
92+
Q
很抱歉,暂时无法提供与“74LVC2G02DP-Q100H”相匹配的价格&库存,您可以联系我们找货
