74LVC2G06
Inverters with open-drain outputs
Rev. 8 — 12 December 2016
Product data sheet
1. General description
The 74LVC2G06 provides two inverting buffers.
The output of this device is an open drain and can be connected to other open-drain
outputs to implement active-LOW wired-OR or active-HIGH wired-AND functions.
Input can be driven from either 3.3 V or 5 V devices. This feature allows the use of this
device in a mixed 3.3 V and 5 V environment.
Schmitt trigger action at all inputs makes the circuit tolerant for slower input rise and fall
time.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the device
when it is powered down.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant input/output for interfacing with 5 V logic
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8-B/JESD36 (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74LVC2G06
Nexperia
3. Ordering information
Table 1.
Type number
74LVC2G06GW
Package
Temperature range
Name
Description
Version
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74LVC2G06GV
40 C to +125 C
TSOP6
plastic surface-mounted package (TSOP6); 6 leads
SOT457
74LVC2G06GM
40 C to +125 C
XSON6
plastic extremely thin small outline package;
no leads; 6 terminals; body 1 1.45 0.5 mm
SOT886
74LVC2G06GF
40 C to +125 C
XSON6
no leads; 6 terminals; body 1 1 0.5 mm
SOT891
74LVC2G06GN
40 C to +125 C
XSON6
extremely thin small outline package; no leads;
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74LVC2G06GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
74LVC2G06GX
40 C to +125 C
X2SON6
plastic thermal extremely thin small outline package; SOT1255
no leads; 6 terminals; body 1 0.8 0.35 mm
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74LVC2G06GW
V6
74LVC2G06GV
V06
74LVC2G06GM
V6
74LVC2G06GF
V6
74LVC2G06GN
V6
74LVC2G06GS
V6
74LVC2G06GX
V6
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
*1'
PQE
Fig 1.
Logic symbol
74LVC2G06
Product data sheet
PQD
PQE
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Fig 3.
Logic diagram (one driver)
Nexperia B.V. 2017. All rights reserved
2 of 19
74LVC2G06
Nexperia
6. Pinning information
6.1 Pinning
/9&*
/9&*
*1'
9&&
*1'
9&&
DDE
7UDQVSDUHQWWRSYLHZ
DDE
Fig 4.
Pin configuration SOT363 and SOT457
Fig 5.
Pin configuration SOT886
/9&*
/9&*
*1'
9&&
*1'
DDJ
DDD
7UDQVSDUHQWWRSYLHZ
Fig 6.
9&&
7UDQVSDUHQWWRSYLHZ
Pin configuration SOT891, SOT1115 and
SOT1202
Fig 7.
Pin configuration SOT1255 (X2SON6)
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
1A
1
data input
GND
2
ground (0 V)
2A
3
data input
2Y
4
data output
VCC
5
supply voltage
1Y
6
data output
74LVC2G06
Product data sheet
3 of 19
74LVC2G06
Nexperia
7. Functional description
Table 4.
Function table[1]
Input nA
Output nY
L
Z
H
L
[1]
H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
Conditions
input voltage
IOK
output clamping current
VO < 0 V
VO
output voltage
Active mode
Power-down mode
IO
output current
Max
Unit
+6.5
V
50
[1]
0.5
+6.5
50
[1]
0.5
+6.5
V
[1][2]
0.5
+6.5
V
50
mA
VI < 0 V
VI
Min
0.5
VO = 0 V to 6.5 V
mA
V
mA
ICC
supply current
100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
250
mW
total power dissipation
Ptot
Tamb = 40 C to +125 C
[3]
[1]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
For SC-88 and SC-74 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 and X2SON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
V
Power-down mode; VCC = 0 V
V
40
+125
ns/V
10
ns/V
Tamb
ambient temperature
t/V
input transition rise and VCC = 1.65 V to 2.7 V
fall rate
VCC = 2.7 V to 5.5 V
74LVC2G06
Product data sheet
C
4 of 19
74LVC2G06
Nexperia
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Typ[1]
Max
Unit
Tamb = 40 C to +85 C
VIH
VIL
VOL
HIGH-level input
voltage
LOW-level input
voltage
LOW-level output
voltage
0.65 VCC
V
VCC = 2.3 V to 2.7 V
1.7
V
VCC = 2.7 V to 3.6 V
2.0
V
VCC = 4.5 V to 5.5 V
0.7 VCC
V
VCC = 1.65 V to 1.95 V
0.35 VCC V
0.7
V
0.8
V
IO = 100 A; VCC = 1.65 V to 5.5 V
0.1
V
IO = 4 mA; VCC = 1.65 V
0.45
V
IO = 8 mA; VCC = 2.3 V
0.3
V
0.3 VCC V
VI = VIH or VIL
IO = 12 mA; VCC = 2.7 V
0.4
V
IO = 24 mA; VCC = 3.0 V
0.55
V
0.55
V
0.1
1
A
IO = 32 mA; VCC = 4.5 V
[2]
II
input leakage current VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
IOZ
OFF-state output
current
VI = VIH or VIL; VO = VCC or GND;
VCC = 5.5 V
0.1
2
A
IOFF
power-off leakage
current
VI or VO = 5.5 V; VCC = 0 V
0.1
2
A
ICC
supply current
VI = 5.5 V or GND; IO = 0 A;
0.1
4
A
ICC
additional supply
current
per pin; VI = VCC 0.6 V; IO = 0 A;
VCC = 2.3 V to 5.5 V
5
500
A
CI
input capacitance
2.5
pF
74LVC2G06
Product data sheet
[2]
5 of 19
74LVC2G06
Nexperia
Table 7.
Static characteristics …continued
Symbol
Parameter
Min
Typ[1]
Max
0.65 VCC
V
1.7
V
2.0
V
0.7 VCC
V
Conditions
Unit
HIGH-level input
voltage
VIH
LOW-level input
voltage
VIL
LOW-level output
voltage
VOL
0.35 VCC V
0.7
V
0.8
V
0.10
V
0.70
V
0.45
V
0.60
V
0.80
V
0.80
V
0.3 VCC V
VI = VIH or VIL
II
VCC = 0 V to 5.5 V
1
A
IOZ
OFF-state output
current
VCC = 5.5 V
2
A
IOFF
power-off leakage
current
2
A
ICC
supply current
4
A
ICC
additional supply
current
500
A
[1]
All typical values are measured at Tamb = 25 C.
[2]
These typical values are measured at VCC = 3.3 V.
74LVC2G06
Product data sheet
6 of 19
74LVC2G06
Nexperia
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 9.
Symbol Parameter
40 C to +85 C
Conditions
power dissipation
capacitance
CPD
Unit
Min
Max
Min
Max
1.0
3.2
6.5
1.0
8.2
ns
0.5
2.0
3.9
0.5
4.9
ns
VCC = 2.7 V
1.0
2.6
4.2
1.0
5.3
ns
VCC = 3.0 V to 3.6 V
0.5
2.3
3.4
0.5
4.3
ns
0.5
1.6
2.9
0.5
3.7
ns
5.9
pF
[2]
propagation delay nA to nY; see Figure 8
tpd
40 C to +125 C
Typ[1]
VI = GND to VCC; VCC = 3.3 V
[3]
[1]
Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
[2]
tpd is the same as tPLZ and tPZL.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
12. Waveforms
9,
90
Q$LQSXW
*1'
W 3=/
W 3/=
9&&
Q
很抱歉,暂时无法提供与“74LVC2G06GW,125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+0.440183000+0.05339
- 9000+0.438129000+0.05314
- 15000+0.4381115000+0.05314
- 45000+0.4381045000+0.05314
- 75000+0.4380975000+0.05314
- 国内价格 香港价格
- 3000+0.815233000+0.09889
- 6000+0.769946000+0.09339
- 15000+0.7020115000+0.08515
- 30000+0.6567230000+0.07966
- 75000+0.5887875000+0.07142
- 150000+0.56614150000+0.06867
- 国内价格 香港价格
- 3000+0.441083000+0.05350
- 9000+0.439029000+0.05325
- 15000+0.4390115000+0.05325
- 45000+0.4390045000+0.05325
- 75000+0.4389975000+0.05325
- 国内价格 香港价格
- 1+3.457951+0.41943
- 10+2.0577210+0.24959
- 100+1.09642100+0.13299
- 1000+0.826171000+0.10021
- 3000+0.662033000+0.08030
- 9000+0.506049000+0.06138
- 24000+0.4779324000+0.05797
- 45000+0.4389445000+0.05324
- 99000+0.4271599000+0.05181
