74AHC1G04; 74AHCT1G04
Inverter
Rev. 10 — 24 September 2019
Product data sheet
1. General description
74AHC1G04 and 74AHCT1G04 are high-speed Si-gate CMOS devices. They provide an inverting
buffer.
The AHC device has CMOS input switching levels and supply voltage range 2 V to 5.5 V.
The AHCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V.
2. Features and benefits
Symmetrical output impedance
High noise immunity
Low power dissipation
Balanced propagation delays
Multiple package options
ESD protection:
• HBM JESD22-A114E: exceeds 2 000 V
• MM JESD22-A115-A: exceeds 200 V
• CDM JESD22-C101C: exceeds 1 000 V
Specified from -40 °C to +125 °C
3. Ordering information
Table 1. Ordering information
Type number
Package
74AHC1G04GW
Temperature range
Name
Description
Version
-40 °C to +125 °C
TSSOP5
plastic thin shrink small outline package;
5 leads; body width 1.25 mm
SOT353-1
-40 °C to +125 °C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
-40 °C to +125 °C
XSON6
plastic extremely thin small outline
package; no leads; 6 terminals;
body 1 × 1.45 × 0.5 mm
SOT886
74AHCT1G04GW
74AHC1G04GV
74AHCT1G04GV
74AHC1G04GM
74AHCT1G04GM
Nexperia
Inverter
4. Marking
Table 2. Marking codes
Type number
Marking [1]
74AHC1G04GW
AC
74AHCT1G04GW
CC
74AHC1G04GV
A04
74AHCT1G04GV
C04
74AHC1G04GM
AC
74AHCT1G04GM
CC
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
A
Y
1
Y
A
mna109
mna108
Fig. 1.
Logic symbol
Fig. 2.
mna110
IEC logic symbol
Fig. 3.
Logic diagram
6. Pinning information
6.1. Pinning
74AHC1G04
74AHCT1G04
74AHC1G04
74AHCT1G04
n.c.
1
A
2
GND
3
5
4
n.c.
1
6
VCC
A
2
5
n.c.
GND
3
4
Y
VCC
Y
aaa-017113
001aaf093
Fig. 4.
Pin configuration SOT353-1 (TSSOP5) and
SOT753 (SC-74A)
74AHC_AHCT1G04
Product data sheet
Transparent top view
Fig. 5.
Pin configuration SOT886 (XSON6)
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 12
Nexperia
Inverter
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
SOT353-1 and SOT753
SOT886
n.c.
1
1
not connected
A
2
2
data input
GND
3
3
ground (0 V)
Y
4
4
data output
n.c.
5
not connected
VCC
5
6
supply voltage
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level
Input
Output
A
Y
L
H
H
L
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
-0.5
+7.0
V
VI
input voltage
-0.5
+7.0
V
IIK
input clamping current
VI < -0.5 V
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
IO
output current
-0.5 V < VO < VCC + 0.5 V
ICC
-20
mA
±20
mA
±25
mA
supply current
75
mA
IGND
ground current
-75
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
[1]
[2]
Tamb = -40 °C to +125 °C
[1]
[2]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SOT353-1 (TSSOP5) packages: Ptot derates linearly with 3.3 mW/K above 74 °C.
For SOT753 (SC-74A5) packages: Ptot derates linearly with 3.8 mW/K above 85 °C.
For SOT886 (XSON6) packages: Ptot derates linearly with 3.3 mW/K above 74 °C.
74AHC_AHCT1G04
Product data sheet
3 / 12
Nexperia
Inverter
9. Recommended operating conditions
Table 6. Recommended operating conditions
Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
74AHC1G04
74AHCT1G04
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
5.5
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise and
fall rate
VCC = 3.3 V ± 0.3 V
100
ns/V
VCC = 5.0 V ± 0.5 V
ns/V
10. Static characteristics
Table 7. Static characteristics
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
IO = -50 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -50 μA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = -50 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = -8.0 mA; VCC = 4.5 V
3.94
3.8
3.70
V
IO = 50 μA; VCC = 2.0 V
0.1
0.1
V
IO = 50 μA; VCC = 3.0 V
0.1
0.1
V
IO = 50 μA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
74AHC1G04
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
VI = VIH or VIL
VI = VIH or VIL
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1.0
2.0
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
1.0
10
40
μA
CI
input
capacitance
1.5
10
10
10
pF
74AHC_AHCT1G04
Product data sheet
4 / 12
Nexperia
Inverter
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Min
Typ
Max
Min
Max
Min
Max
Unit
74AHCT1G04
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = -50 μA
4.4
4.5
4.4
4.4
V
IO = -8.0 mA
3.94
3.8
3.70
V
IO = 50 μA
0.1
0.1
V
IO = 8.0 mA
0.36
0.44
0.55
V
VOL
LOW-level
output voltage
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1.0
2.0
μA
ICC
supply current
VCC = 5.5 V
1.0
10
40
μA
ΔICC
additional
supply current
per input pin; VI = 3.4 V;
other inputs at VCC or GND;
IO = 0 A; VCC = 5.5 V
1.35
1.5
1.5
mA
CI
input
capacitance
1.5
10
10
10
pF
11. Dynamic characteristics
Table 8. Dynamic characteristics
GND = 0 V; tr = tf = ≤ 3.0 ns. For test circuit see Fig. 7.
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 3.0 V to 3.6 V; CL = 15 pF [2]
4.3
7.1
1.0
8.5
1.0
11.0 ns
VCC = 3.0 V to 3.6 V; CL = 50 pF [2]
6.1
10.6
1.0
12
1.0
14.5 ns
VCC = 4.5 V to 5.5 V; CL = 15 pF [3]
3.1
5.5
1.0
6.5
1.0
7.0
ns
VCC = 4.5 V to 5.5 V; CL = 50 pF [3]
4.5
7.5
1.0
8.5
1.0
9.5
ns
15
pF
74AHC1G04
tpd
CPD
propagation
delay
power
dissipation
capacitance
74AHC_AHCT1G04
Product data sheet
A to Y; see Fig. 6
[1]
per buffer; CL = 50 pF; f = 1 MHz;
VI = GND to VCC
[4]
5 / 12
Nexperia
Inverter
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
3.4
6.7
1.0
7.5
1.0
8.5
4.9
7.7
1.0
8.5
1.0
10.0 ns
16
74AHCT1G04
tpd
propagation
delay
CPD
[1]
[2]
[3]
[4]
power
dissipation
capacitance
A to Y; see Fig. 6
[1]
VI = GND to VCC
[4]
ns
pF
tpd is the same as tPLH and tPHL.
Typical values are measured at VCC = 3.3 V.
Typical values are measured at VCC = 5.0 V.
CPD is used to determine the dynamic power dissipation PD (μW).
2
2
PD = CPD × VCC × fi + Σ (CL × VCC × fo) where:
fi = input frequency in MHz; fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts;
N = total load switching outputs;
2
Σ(CL × VCC × fo) = sum of outputs.
12. Waveforms and test circuit
VM
A input
tPHL
tPLH
VM
Y output
mna111
Measurement points are given in Table 9.
Fig. 6.
Input (A) to output (Y) propagation delays
Table 9. Measurement point
Input
Type
Input
Output
VI
VM
VM
74AHC1G04
GND to VCC
0.5 × VCC
0.5 × VCC
74AHCT1G04
GND to 3.0 V
1.5 V
0.5 × VCC
VCC
PULSE
GENERATOR
VI
DUT
VO
RT
CL
mna101
Test data is given in Table 8. Definitions for test circuit:
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Fig. 7.
Test circuit for measuring switching times
74AHC_AHCT1G04
Product data sheet
6 / 12
Nexperia
Inverter
13. Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
D
E
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
e
e1
L
w M
bp
detail X
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
Fig. 8.
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Package outline SOT353-1 (TSSOP5)
74AHC_AHCT1G04
Product data sheet
7 / 12
Nexperia
Inverter
Plastic surface-mounted package; 5 leads
SOT753
D
B
E
y
A
X
HE
5
v M A
4
Q
A
A1
c
1
2
3
Lp
detail X
bp
e
w M B
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.100
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT753
Fig. 9.
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-04-16
06-03-16
SC-74A
Package outline SOT753 (SC-74A)
74AHC_AHCT1G04
Product data sheet
8 / 12
Nexperia
Inverter
SOT886
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm
b
1
2
3
4x
(2)
L
L1
e
6
5
e1
4
e1
6x
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A(1)
0.5
A1
b
D
E
0.04 0.25 1.50 1.05
0.20 1.45 1.00
0.17 1.40 0.95
e
e1
L
0.6
0.5
L1
0.35 0.40
0.30 0.35
0.27 0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
Outline
version
SOT886
sot886_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
04-07-22
12-01-05
MO-252
Fig. 10. Package outline SOT886 (XSON6)
74AHC_AHCT1G04
Product data sheet
9 / 12
Nexperia
Inverter
14. Abbreviations
Table 10. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
15. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74AHC_AHCT1G04 v.10
20190924
Product data sheet
Modifications:
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Table 5: Derating values for Ptot total power dissipation have been updated.
74AHC_AHCT1G04 v.9
20150310
Modifications:
74AHC_AHCT1G04 v.8
20141106
Modifications:
74AHC_AHCT1G04 v.7
20070531
Modifications:
74AHC_AHCT1G04 v.9
Product data sheet
74AHC_AHCT1G04 v.8
Added type numbers 74AHC1G04GM and 74AHCT1G04GM.
Product data sheet
74AHC_AHCT1G04 v.7
74AHC_AHCT1G04 v.6
Section 4: table note added.
Product data sheet
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Package SOT353 changed to SOT353-1 in Table 1 and Section 13.
Quick reference data and Soldering sections removed.
74AHC_AHCT1G04 v.6
20030904
Product specification
74AHC_AHCT1G04 v.5
74AHC_AHCT1G04 v.5
20020527
74AHC_AHCT1G04 v.4
74AHC_AHCT1G04 v.4
20020215
74AHC_AHCT1G04 v.3
74AHC_AHCT1G04 v.3
20010131
74AHC_AHCT1G04 v.2
74AHC_AHCT1G04 v.2
19990127
74AHC_AHCT1G04_N v.1
19981125
Preliminary specification -
74AHC_AHCT1G04
Product data sheet
10 / 12
Nexperia
Inverter
16. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74AHC_AHCT1G04
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
11 / 12
Nexperia
Inverter
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Marking.......................................................................... 2
5. Functional diagram.......................................................2
6. Pinning information......................................................2
6.1. Pinning.........................................................................2
6.2. Pin description............................................................. 3
7. Functional description................................................. 3
8. Limiting values............................................................. 3
9. Recommended operating conditions..........................4
10. Static characteristics..................................................4
11. Dynamic characteristics.............................................5
12. Waveforms and test circuit........................................6
13. Package outline.......................................................... 7
14. Abbreviations............................................................ 10
15. Revision history........................................................10
16. Legal information......................................................11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 24 September 2019
74AHC_AHCT1G04
Product data sheet
12 / 12
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AHC1G04GV,125 74AHC1G04GW,125 74AHC1G04GW,165 74AHCT1G04GV,125 74AHCT1G04GW,125
74AHCT1G04GW,165 74AHC1G04GV-Q100H 74AHC1G04GW-Q100H 74AHCT1G04GM,132 74AHCT1G04GM,115
74AHC1G04GM,132 74AHC1G04GM,115
