74AHC1G07-Q100
Buffer with open-drain output
Rev. 3 — 25 February 2019
Product data sheet
1. General description
74AHC1G07-Q100 is a high-speed Si-gate CMOS device. The 74AHC1G07-Q100 provides a
non-inverting buffer.
The output of this device is open-drain and can be connected to other open-drain outputs to
implement active-LOW wired-OR or active-HIGH wired-AND functions. For digital operation, this
device must have a pull-up resistor to establish a logic HIGH-level.
The AHC device has CMOS input switching levels and supply voltage range 2 V to 5.5 V.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
High noise immunity
Low power dissipation
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74AHC1G07GW-Q100
-40 °C to +125 °C
TSSOP5
plastic thin shrink small outline package;
5 leads; body width 1.25 mm
SOT353-1
74AHC1G07GV-Q100
-40 °C to +125 °C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
4. Marking
Table 2. Marking codes
Type number
Marking [1]
74AHC1G07GW-Q100
AS
74AHC1G07GV-Q100
A07
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
74AHC1G07-Q100
Nexperia
5. Functional diagram
Y
2
A
Y
4
A
2
4
A
GND
mna590
mna589
Fig. 1.
Y
Logic symbol
Fig. 2.
IEC logic symbol
Fig. 3.
mna591
Logic diagram
6. Pinning information
6.1. Pinning
74AHC1G07-Q100
n.c.
1
A
2
GND
3
5
VCC
4
Y
aaa-015067
Fig. 4.
Pin configuration SOT353-1 (TSSOP5) and SOT753 (SC-74A)
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
n.c.
1
not connected
A
2
data input
GND
3
ground (0 V)
Y
4
data output
VCC
5
supply voltage
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state
Input
Output
A
Y
L
L
H
Z
74AHC1G07_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 10
74AHC1G07-Q100
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
-0.5
+7.0
V
VI
input voltage
-0.5
+7.0
V
IIK
input clamping current
VI < -0.5 V
IOK
output clamping current
VO < -0.5 V
IO
output current
VO > -0.5 V
VO
output voltage
active mode
high-impedance mode
-20
mA
±20
mA
±25
mA
[1]
-0.5
+7.0
V
[1]
-0.5
+7.0
V
[1]
ICC
supply current
75
mA
IGND
ground current
-75
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
Min
Typ
Max
Unit
2.0
5.0
5.5
V
V
VCC
V
[1]
[2]
Tamb = -40 °C to +125 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For both TSSOP5 and SC-74A packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
9. Recommended operating conditions
Table 6. Recommended operating conditions
Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
active mode
high-impedance mode
V
-40
+25
+125
°C
VCC = 3.3 V ± 0.3 V
100
ns/V
VCC = 5.0 V ± 0.5 V
ns/V
10. Static characteristics
Table 7. Static characteristics
Symbol Parameter
VIH
VIL
HIGH-level
input voltage
LOW-level
input voltage
74AHC1G07_Q100
Product data sheet
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
3 / 10
74AHC1G07-Q100
Nexperia
Symbol Parameter
VOL
LOW-level
output voltage
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
IO = 50 μA; VCC = 2.0 V
0.1
0.1
V
IO = 50 μA; VCC = 3.0 V
0.1
0.1
V
IO = 50 μA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
VI = VIH or VIL
0.36
0.44
0.55
V
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1.0
2.0
μA
IOZ
OFF-state
output current
VI = VIH or VIL;
VO = VCC or GND; VCC = 5.5 V
±0.25
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
1.0
10
μA
CI
input
capacitance
1.5
10
10
10
pF
±2.5
±10.0 μA
11. Dynamic characteristics
Table 8. Dynamic characteristics
GND = 0 V; tr = tf = ≤ 3.0 ns. For test circuit see Fig. 6.
Symbol Parameter
tPZL
tPLZ
CPD
[1]
[2]
[3]
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Min
Typ
Max
Min
Max
Min
Max
Unit
OFF-state to LOW A to Y; see Fig. 5
propagation delay
VCC = 3.0 V to 3.6 V; CL = 15 pF
[1]
3.5
5.6
1.0
6.3
1.0
7.0
VCC = 3.0 V to 3.6 V; CL = 50 pF
[1]
5.0
8.0
1.0
9.0
1.0
10.0 ns
VCC = 4.5 V to 5.5 V; CL = 15 pF
[2]
2.5
3.9
1.0
4.6
1.0
4.9
ns
VCC = 4.5 V to 5.5 V; CL = 50 pF
[2]
3.6
5.5
1.0
6.5
1.0
7.0
ns
LOW to OFF-state A to Y; see Fig. 5
propagation delay
[1]
5.8
7.9
1.0
8.4
1.0
8.9
ns
[1]
8.3
11.5
1.0
12.0
1.0
12.5 ns
[2]
4.2
5.1
1.0
5.6
1.0
6.1
ns
[2]
6.0
7.5
1.0
8.0
1.0
8.5
ns
[3]
5
pF
power dissipation
capacitance
per buffer; CL = 50 pF; f = 1 MHz;
VI = GND to VCC
ns
Typical values are measured at VCC = 3.3 V.
Typical values are measured at VCC = 5.0 V.
CPD is used to determine the dynamic power dissipation PD (μW).
2
2
PD = CPD × VCC × fi + Σ (CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts
74AHC1G07_Q100
Product data sheet
4 / 10
74AHC1G07-Q100
Nexperia
11.1. Waveforms and test circuit
VI
VM(1)
A input
GND
t PZL
t PLZ
VCC
Y output
VM(2)
VOL + 0.3 V
VOL
mna592
Measurement points are given in Table 9.
Fig. 5.
Input (A) to output (Y) propagation delays
Table 9. Measurement point
Input
Output
VI
(1)
VM
VM
(2)
GND to VCC
0.5 × VCC
0.5 × VCC
S1
VCC
PULSE
GENERATOR
VI
RL =
1000 Ω
VO
VCC
open
GND
D.U.T.
RT
CL
mna232
Test data is given in Table 8.
Definitions for test circuit:
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
For tPLZ, tPZL, S1 = VCC
Fig. 6.
Test circuit for measuring switching times
74AHC1G07_Q100
Product data sheet
5 / 10
74AHC1G07-Q100
Nexperia
12. Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
D
E
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
e
e1
L
w M
bp
detail X
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
Fig. 7.
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Package outline SOT353-1 (TSSOP5)
74AHC1G07_Q100
Product data sheet
6 / 10
74AHC1G07-Q100
Nexperia
Plastic surface-mounted package; 5 leads
SOT753
D
B
E
y
A
X
HE
5
v M A
4
Q
A
A1
c
1
2
3
Lp
detail X
bp
e
w M B
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.100
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT753
Fig. 8.
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-04-16
06-03-16
SC-74A
Package outline SOT753 (SC-74A)
74AHC1G07_Q100
Product data sheet
7 / 10
74AHC1G07-Q100
Nexperia
13. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
14. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC1G07_Q100 v.3
20190225
Product data sheet
74AHC_AHCT1G07_Q100 v.2
Modifications:
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type numbers 74AHCT1G07GW-Q100 (SOT353-1) and
74AHCT1G07GV-Q100 (SOT753) removed.
20141118
Modifications:
74AHC_AHCT1G07_Q100 v.1
20141020
74AHC1G07_Q100
Product data sheet
Product data sheet
Section 4: table note added.
Product data sheet
8 / 10
74AHC1G07-Q100
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74AHC1G07_Q100
Product data sheet
9 / 10
74AHC1G07-Q100
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Marking.......................................................................... 1
5. Functional diagram.......................................................2
6. Pinning information......................................................2
6.1. Pinning.........................................................................2
6.2. Pin description............................................................. 2
7. Functional description................................................. 2
8. Limiting values............................................................. 3
9. Recommended operating conditions..........................3
10. Static characteristics..................................................3
11. Dynamic characteristics.............................................4
11.1. Waveforms and test circuit........................................ 5
12. Package outline.......................................................... 6
13. Abbreviations.............................................................. 8
14. Revision history..........................................................8
15. Legal information........................................................9
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 25 February 2019
74AHC1G07_Q100
Product data sheet
10 / 10
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AHC1G07GV-Q100H 74AHC1G07GW-Q100H
