74ALVC125
Quad buffer/line driver; 3-state
Rev. 02 — 10 January 2008
Product data sheet
1. General description
The 74ALVC125 is a quad non-inverting buffer/line driver with 3-state outputs. The 3-state
outputs (nY) are controlled by the output enable input (nOE). A HIGH on the nOE pin
causes the outputs to assume a high-impedance OFF-state.
2. Features
Wide supply voltage range from 1.65 V to 3.6 V
3.6 V tolerant inputs/outputs
CMOS low power consumption
Direct interface with TTL levels (2.7 V to 3.6 V)
Power-down mode
Latch-up performance exceeds 250 mA
Complies with JEDEC standards:
◆ JESD8-7 (1.65 V to 1.95 V)
◆ JESD8-5 (2.3 V to 2.7 V)
◆ JESD8B/JESD36 (2.7 V to 3.6 V)
■ ESD protection:
◆ HBM JESD22-A114E exceeds 2000 V
◆ MM JESD22-A 115-A exceeds 200 V
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74ALVC125D
−40 °C to +85 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74ALVC125PW −40 °C to +85 °C
74ALVC125BQ
−40 °C to +85 °C
DHVQFN14 plastic dual in-line compatible thermal enhanced very
thin quad flat package; no leads; 14 terminals;
body 2.5 × 3 × 0.85 mm
SOT762-1
74ALVC125
Nexperia
4. Functional diagram
2
1A
1
1OE
5
2A
4
2OE
1Y
3
2
2Y
1
1
6
3
EN1
5
6
4
9
3A
3Y
8
9
10
3OE
12
4A
13
4OE
8
10
4Y
11
12
11
13
mna229
mna228
Fig 1. Logic symbol
Fig 2. IEC logic symbol
nY
nA
nOE
mna227
Fig 3. Logic diagram (one buffer)
5. Pinning information
5.1 Pinning
1
terminal 1
index area
1A
2
13 4OE
12 4A
1Y
3
13 4OE
2OE
4
1Y
3
12 4A
2A
5
2OE
4
11 4Y
2A
5
10 3OE
2Y
6
2Y
6
9
3A
GND
7
8
3Y
11 4Y
GND(1)
10 3OE
9
8
14 VCC
2
3Y
1
1A
7
1OE
GND
74ALVC125
14 VCC
1OE
74ALVC125
3A
001aah090
Transparent top view
001aah089
(1) The die substrate is attached to this pad using
conductive die attach material. It can not be used as
a supply pin or input.
Fig 4. Pin configuration SO14 and TSSOP14
Fig 5. Pin configuration DHVQFN14
74ALVC125_2
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 13
74ALVC125
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
nA
2, 5, 9, 12
data input
nY
3, 6, 8, 11
bus output
nOE
1, 4, 10, 13
output enable (active LOW)
VCC
14
supply voltage
GND
7
ground (0 V)
6. Functional description
Table 3.
Function table[1]
Input
Output
nOE
nA
L
L
L
L
H
H
H
X
Z
[1]
nY
H = HIGH voltage level
L = LOW voltage level
X= don’t care
Z = high-impedance OFF-state
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
Conditions
Min
−0.5
+4.6
V
VI < 0 V
−50
mA
−0.5
+4.6
V
±50
mA
[1]
VO > VCC or VO < 0 V
output HIGH or LOW state
[1][2]
output 3-state
Power-down mode, VCC = 0 V
[2]
Unit
−0.5
VCC + 0.5
V
−0.5
+4.6
V
−0.5
+4.6
V
±50
mA
IO
output current
ICC
supply current
100
mA
IGND
ground current
−100
mA
Tstg
storage temperature
−65
+150
°C
500
mW
total power dissipation
Ptot
VO = 0 V to VCC
Max
Tamb = −40 °C to +85 °C
[1]
The minimum input voltage ratings may be exceeded if the input current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 3.6 V in normal operation.
[3]
For SO14 packages: above 70 °C derate linearly with 8 mW/K.
For TSSOP14 packages: above 60 °C derate linearly with 5.5 mW/K.
For DHVQFN20 packages: above 60 °C derate linearly with 4.5 mW/K.
74ALVC125_2
Product data sheet
[3]
3 of 13
74ALVC125
Nexperia
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
Conditions
Min
Max
Unit
supply voltage
1.65
3.6
V
VI
input voltage
V
VO
output voltage
Tamb
ambient temperature
∆t/∆V
input transition rise and fall rate
VCC
V
output 3-state
V
Power-down mode; VCC = 0 V
V
in free air
−40
+85
°C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 3.6 V
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
−40 °C to +85 °C
Conditions
Min
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
LOW-level output voltage
input leakage current
V
1.7
V
2.0
V
VCC = 1.65 V to 1.95 V
VCC = 2.3 V to 2.7 V
0.7
V
0.8
V
VCC − 0.2
V
0.35 × VCC V
VI = VIH or VIL
IO = −6 mA; VCC = 1.65 V
1.25
1.51
V
IO = −12 mA; VCC = 2.3 V
1.8
2.10
V
IO = −18 mA; VCC = 2.3 V
1.7
2.01
V
IO = −12 mA; VCC = 2.7 V
2.2
2.53
V
IO = −18 mA; VCC = 3.0 V
2.4
2.76
V
IO = −24 mA; VCC = 3.0 V
2.2
2.68
V
0.2
V
VI = VIH or VIL
IO = 6 mA; VCC = 1.65 V
0.11
0.3
V
IO = 12 mA; VCC = 2.3 V
0.17
0.4
V
IO = 18 mA; VCC = 2.3 V
0.25
0.6
V
IO = 12 mA; VCC = 2.7 V
0.16
0.4
V
IO = 18 mA; VCC = 3.0 V
0.23
0.4
V
IO = 24 mA; VCC = 3.0 V
0.30
0.55
V
±0.1
±5
µA
VCC = 3.6 V; VI = 3.6 V or GND
74ALVC125_2
Product data sheet
Max
0.65 × VCC
IO = 100 µA; VCC = 1.65 V to 3.6 V
II
Unit
IO = −100 µA; VCC = 1.65 V to 3.6 V
VOL
Typ[1]
4 of 13
74ALVC125
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
−40 °C to +85 °C
Conditions
Unit
Min
Typ[1]
Max
IOZ
OFF-state output current
VI = VIH or VIL; VCC = 1.65 V to 3.6 V;
VO = 3.6 V or GND;
±0.1
±10
µA
IOFF
power-off leakage current
VCC = 0 V; VI or VO = 0 V to 3.6 V
±0.1
±10
µA
ICC
supply current
VCC = 3.6 V; VI = VCC or GND;
IO = 0 A
0.2
10
µA
∆ICC
additional supply current
per input pin; VCC = 3.0 V to 3.6 V;
VI = VCC − 0.6 V; IO = 0 A
5
750
µA
CI
input capacitance
3.5
pF
[1]
All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C.
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 8.
Symbol
tpd
Parameter
propagation delay
−40 °C to +85 °C
Conditions
Min
Max
1.3
2.4
5.3
ns
1.0
1.7
3.2
ns
nA to nY; see Figure 6
[2]
VCC = 2.7 V
2.0
3.1
ns
1.1
1.8
2.8
ns
1.4
3.9
6.4
ns
1.0
2.2
4.1
ns
2.7
4.3
ns
1.0
1.9
3.5
ns
1.8
3.9
5.9
ns
1.0
2.1
3.4
ns
2.9
4.0
ns
1.4
2.7
4.0
ns
ten
enable time
nOE to nY; see Figure 7
[2]
VCC = 2.7 V
tdis
disable time
VCC = 2.7 V
[2]
74ALVC125_2
Product data sheet
Unit
Typ[1]
5 of 13
74ALVC125
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol
CPD
Parameter
−40 °C to +85 °C
Conditions
power dissipation
capacitance
Unit
Min
Typ[1]
Max
outputs HIGH or LOW state
27
pF
outputs 3-state
5
pF
per buffer; VI = GND to VCC; VCC = 3.3 V
[1]
Typical values are measured at Tamb = 25 °C
[2]
tpd is the same as tPHL and tPLH.
ten is the same as tPZH and tPZL.
tdis is the same as tPHZ and tPLZ.
[3]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz; fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
Σ(CL × VCC2 × fo) = sum of the outputs
[3]
11. Waveforms
VI
VM
nA input
GND
tPHL
tPLH
VOH
VM
nY output
VOL
mna230
Measurement points are given in Table 8.
VOL and VOH are the typical output voltage levels that occur with the output load.
Fig 6. Input nA to output nY propagation delay times
Table 8.
Measurement points
Supply voltage
Input
Output
VCC
VM
VM
VX
VY
1.65 V to 1.95 V
0.5VCC
0.5VCC
VOL + 0.15 V
VOH − 0.15 V
2.3 V to 2.7 V
0.5VCC
0.5VCC
VOL + 0.15 V
VOH − 0.15 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH − 0.3 V
3.0 V to 3.6 V
1.5 V
1.5 V
VOL + 0.3 V
VOH − 0.3 V
74ALVC125_2
Product data sheet
6 of 13
74ALVC125
Nexperia
VI
nOE input
VM
GND
tPLZ
tPZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
tPHZ
tPZH
VOH
VY
output
HIGH-to-OFF
OFF-to-HIGH
GND
VM
outputs
enabled
outputs
enabled
outputs
disabled
mna362
Fig 7. Enable and disable times
VEXT
VCC
VI
RL
VO
G
DUT
RT
CL
RL
mna616
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 8. Test circuitry for switching times
Table 9.
Test data
Supply voltage
Input
Load
VEXT
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
open
2 × VCC
GND
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2 × VCC
GND
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
6V
GND
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
6V
GND
74ALVC125_2
Product data sheet
7 of 13
74ALVC125
Nexperia
12. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.010 0.057
inches 0.069
0.004 0.049
0.05
0.244
0.039
0.041
0.228
0.016
0.028
0.024
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 9. Package outline SOT108-1 (SO14)
74ALVC125_2
Product data sheet
8 of 13
74ALVC125
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
SOT402-1
E
D
A
X
c
y
HE
v M A
Z
8
14
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 10. Package outline SOT402-1 (TSSOP14)
74ALVC125_2
Product data sheet
9 of 13
74ALVC125
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT762-1
14 terminals; body 2.5 x 3 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
6
y
y1 C
v M C A B
w M C
b
L
1
7
Eh
e
14
8
13
9
Dh
X
5 mm
scale
UNIT
mm
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
c
D (1)
Dh
E (1)
Eh
0.2
3.1
2.9
1.65
1.35
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
2
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT762-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 11. Package outline SOT762-1 (DHVQFN14)
74ALVC125_2
Product data sheet
10 of 13
74ALVC125
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged-Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74ALVC125_2
20080110
Product data sheet
74ALVC125_1
Modifications:
74ALVC125_1
The format of this data sheet has been redesigned to comply with the new identity guidelines
of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Section 3: DHVQFN14 package added.
Section 7: derating values added for DHVQFN14 package.
Section 12: outline drawing added for DHVQFN14 package.
20021118
Product specification
74ALVC125_2
Product data sheet
11 of 13
74ALVC125
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
15.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For additional information, please visit: http://www.nexperia.com
For sales office addresses, send an email to: salesaddresses@nexperia.com
74ALVC125_2
Product data sheet
12 of 13
Nexperia
74ALVC125
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Dynamic characteristics . . . . . . . . . . . . . . . . . . 5
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . 12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Contact information. . . . . . . . . . . . . . . . . . . . . 12
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 10 January 2008
很抱歉,暂时无法提供与“74ALVC125PW,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5000+1.53190
- 10000+1.42978
- 15000+1.39270
- 25000+1.35744
- 50000+1.32392
- 125000+1.29204
- 250000+1.26162
- 国内价格 香港价格
- 1+2.914701+0.35269
- 10+2.6831610+0.32467
- 100+2.36601100+0.28630
- 500+2.21888500+0.26849
- 1000+2.016291000+0.24398
- 2500+1.317252500+0.15939
- 10000+1.2354310000+0.14949
- 25000+1.2218025000+0.14784
- 50000+1.1990750000+0.14509
