74ALVC541
Octal buffer/line driver; 3-state
Rev. 3 — 20 January 2014
Product data sheet
1. General description
The 74ALVC541 is an octal non-inverting buffer/line drivers with 3-state bus compatible
outputs. The 3-state outputs are controlled by the output enable inputs OE0 and OE1.
A HIGH on OEn causes the outputs to assume a high-impedance OFF-state.
2. Features and benefits
Wide supply voltage range from 1.65 V to 3.6 V
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V )
JESD8-5 (2.3 V to 2.5 V)
JESD8B/JESD36 (2.7 V to 3.6 V)
3.6 V tolerant inputs/outputs
CMOS LOW power consumption
Direct interface with TTL levels (2.7 V to 3.6 V)
Power-down mode
Latch-up performance exceeds 250 mA
ESD protection:
HBM JESD22-A114E exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74ALVC541D
40 C to +85 C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
74ALVC541PW
40 C to +85 C
TSSOP20
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
74ALVC541BQ
40 C to +85 C
DHVQFN20
plastic dual-in-line compatible thermal enhanced
very thin quad flat package no leads; 20 terminals;
body 2.5 4.5 0.85 mm
SOT764-1
74ALVC541
Nexperia
4. Functional diagram
很抱歉,暂时无法提供与“74ALVC541BQ,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+2.428403000+0.29480
- 6000+2.417056000+0.29342
- 9000+2.417009000+0.29342
- 12000+2.4169412000+0.29341
- 15000+2.4168915000+0.29340
- 国内价格 香港价格
- 3000+2.293493000+0.27842
- 6000+2.282776000+0.27712
- 9000+2.282739000+0.27712
- 12000+2.2826712000+0.27711
- 15000+2.2826315000+0.27710
