74HCT1G125GV,125
74HCT1G125GV,125
    NEXPERIA(安世)
    SOT23-5
    IC BUFFER NON-INVERT 5.5V SC74A
74HCT1G125GV,125 数据手册
74HC1G125; 74HCT1G125 Bus buffer/line driver; 3-state Rev. 6 — 6 September 2017 1 Product data sheet General description The 74HC1G125; 74HCT1G125 is a single buffer/line driver with 3-state output. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2 Features and benefits • Wide supply voltage range from 2.0 V to 6.0 V • Input levels: – For 74HC1G125: CMOS level – For 74HCT1G125: TTL level • Low power dissipation • Symmetrical output impedance • High noise immunity • Balanced propagation delays • ESD protection – HBM EIA/JESD22-A114-C exceeds 2000V – MM EIA/JESD22-A115-A exceeds 200V • Specified from −40 °C to 85 °C and −40 °C to 125 °C 3 Ordering information Table 1. Ordering information Type number 74HC1G125GW Package Temperature range Name Description -40 °C to +125 °C TSSOP5 plastic thin shrink small outline package; 5 leads; SOT353-1 body width 1.25 mm -40 °C to +125 °C SC-74A plastic surface mounted package; 5 leads 74HCT1G125GW 74HC1G125GV Version 74HCT1G125GV 4 Marking Table 2. Marking Type number Marking code 74HC1G125GW HM 74HCT1G125GW TM [1] SOT753 74HC1G125; 74HCT1G125 Nexperia Bus buffer/line driver; 3-state Type number Marking code 74HC1G125GV H25 74HCT1G125GV T25 [1] [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5 Functional diagram 2 A 1 OE Y 4 1 4 EN OE mna119 mna118 Figure 1. Logic symbol 6 Y A 2 mna120 Figure 2. IEC logic symbol Figure 3. Logic diagram Pinning information 6.1 Pinning 74HC1G125GV 74HCT1G125GV 74HC1G125GW 74HCT1G125GW OE 1 A 2 GND 3 5 4 VCC Y OE 1 A 2 GND 3 5 VCC 4 Y 001aad949 001aad948 Figure 4. Pin configuration TSSOP5 Figure 5. Pin configuration SC-74A 6.2 Pin description Table 3. Pin description Symbol Pin Description OE 1 output enable input (active LOW) A 2 data input GND 3 ground (0 V) Y 4 data output VCC 5 supply voltage 74HC_HCT1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 6 September 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 14 74HC1G125; 74HCT1G125 Nexperia Bus buffer/line driver; 3-state 7 Functional description Table 4. Function table [1] Control Input Output OE A Y L L L L H H H X Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 8 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Conditions supply voltage IIK input clamping current IOK output clamping current Min Max Unit -0.5 +7.0 V VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA VO = -0.5 V to (VCC + 0.5 V) [1] - ±35 mA IO output current ICC supply current - 70 mA IGND ground current -70 - mA Tstg storage temperature -65 +150 °C - 200 mW Ptot [1] [2] total power dissipation [2] Tamb = -40 °C to +125 °C The input and output voltage ratings may be exceeded if the input and output current ratings are observed. Above 55 °C the value of Ptot derates linearly with 2.5 mW/K. 9 Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74HC1G125 74HCT1G125 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 74HC_HCT1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 6 September 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 14 74HC1G125; 74HCT1G125 Nexperia Bus buffer/line driver; 3-state 10 Static characteristics Table 7. Static characteristics 74HC1G125 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH HIGH-level input voltage VIL LOW-level input voltage VOH VOL HIGH-level output voltage LOW-level output voltage Conditions Tamb = −40 °C to +85 °C Min Typ VCC = 2.0 V 1.5 VCC = 4.5 V [1] Tamb = −40 °C Unit to +125 °C Max Min Max 1.2 - 1.5 - V 3.15 2.4 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 V IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - V IO = -6.0 mA; VCC = 4.5 V 3.84 4.32 - 3.7 - V IO = -7.8 mA; VCC = 6.0 V 5.34 5.81 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.33 - 0.4 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.33 - 0.4 V VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 - 1.0 μA IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - 5 - 10 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 10 - 20 μA CI input capacitance - 1.5 - - - pF [1] All typical values are measured at Tamb = 25 °C. 74HC_HCT1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 6 September 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 14 74HC1G125; 74HCT1G125 Nexperia Bus buffer/line driver; 3-state Table 8. Static characteristics 74HCT1G125 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Tamb = −40 °C to +85 °C Min Typ [1] Tamb = −40 °C Unit to +125 °C Max Min Max VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = -20 μA 4.4 4.5 - 4.4 - V IO = -6.0 mA 3.84 4.32 - 3.7 - V IO = 20 μA - 0 0.1 - 0.1 V IO = 6.0 mA - 0.16 0.33 - 0.4 V VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 - 1.0 μA IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - - 5 - 10 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 10 - 20 μA ΔICC additional supply current VI = VCC - 2.1 V; IO = 0 A; VCC = 4.5 V to 5.5 V - - 500 - 850 μA CI input capacitance - 1.5 - - - pF [1] All typical values are measured at Tamb = 25 °C. 74HC_HCT1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 6 September 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 14 74HC1G125; 74HCT1G125 Nexperia Bus buffer/line driver; 3-state 11 Dynamic characteristics Table 9. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 8 Symbol Parameter Conditions Tamb = -40 °C to +125 °C Min [1] Typ Unit Max +85 °C Max +125 °C 74HC1G125 tpd propagation delay A to Y; see Figure 6 [2] VCC = 2.0 V - 24 125 150 ns VCC = 4.5 V - 10 25 30 ns VCC = 5 V; CL = 15 pF - 9 - - ns - 8 21 26 ns VCC = 2.0 V - 19 155 190 ns VCC = 4.5 V - 9 31 38 ns - 7 26 32 ns VCC = 2.0 V - 18 155 190 ns VCC = 4.5 V - 12 31 38 ns - 11 26 32 ns - 30 - - pF VCC = 4.5 V - 11 30 36 ns VCC = 5 V; CL = 15 pF - 10 - - ns VCC = 6.0 V ten enable time OE to Y; see Figure 7 [2] VCC = 6.0 V tdis disable time OE to Y; see Figure 7 [2] VCC = 6.0 V CPD power dissipation capacitance VI = GND to VCC [3] A to Y; see Figure 6 [2] 74HCT1G125 tpd propagation delay ten enable time tdis disable time CPD [1] [2] [3] power dissipation capacitance VCC = 4.5 V; OE to Y; see Figure 7 [2] - 10 35 42 ns VCC = 4.5 V; OE to Y; see Figure 7 [2] - 11 31 38 ns VI = GND to VCC - 1.5 V [3] - 27 - - pF All typical values are measured at Tamb = 25 °C. tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of the outputs. 74HC_HCT1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 6 September 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 14 74HC1G125; 74HCT1G125 Nexperia Bus buffer/line driver; 3-state 11.1 Waveforms and test circuit VI VM A input GND t PHL Y output t PLH VM 001aad070 Measurement points are given in Table 10. Figure 6. Propagation delay data input (A) to output (Y) VI OE input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH output HIGH-to-OFF OFF-to-HIGH tPZH VY VM GND outputs enabled outputs disabled outputs enabled mna644 Measurement points are given in Table 10. VOL and VOH are typical output voltage levels that occur with the output load. Figure 7. Enable and disable times Table 10. Measurement points Input Output VM VM VX VY 74HC1G125 0.5VCC 0.5VCC VOL + 0.3 V VOH - 0.3 V 74HCT1G125 1.3 V 1.3 V VOL + 0.3 V VOH - 0.3 V Type 74HC_HCT1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 6 September 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 14 74HC1G125; 74HCT1G125 Nexperia Bus buffer/line driver; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VCC VO RT RL S1 open CL 001aad983 Test data is given in Table 11. Definitions for test circuit: RT = Termination resistance should be equal to the output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistance S1 = Test selection switch Figure 8. Test circuit for measuring switching times Table 11. Test data Type Input Load VI tr, tf CL 74HC1G125 VCC 6 ns 74HCT1G125 3V 6 ns 74HC_HCT1G125 Product data sheet S1 position RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ 15 pF, 50 pF 1 kΩ open GND VCC 15 pF, 50 pF 1 kΩ open GND VCC All information provided in this document is subject to legal disclaimers. Rev. 6 — 6 September 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 14 74HC1G125; 74HCT1G125 Nexperia Bus buffer/line driver; 3-state 12 Package outline TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm D E SOT353-1 A X c y HE v M A Z 5 4 A2 A (A3) A1 θ 1 Lp 3 e e1 L w M bp detail X 0 1.5 3 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e e1 HE L Lp v w y Z(1) θ mm 1.1 0.1 0 1.0 0.8 0.15 0.30 0.15 0.25 0.08 2.25 1.85 1.35 1.15 0.65 1.3 2.25 2.0 0.425 0.46 0.21 0.3 0.1 0.1 0.60 0.15 7° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT353-1 REFERENCES IEC JEDEC JEITA MO-203 SC-88A EUROPEAN PROJECTION ISSUE DATE 00-09-01 03-02-19 Figure 9. Package outline SOT353-1 (TSSOP5) 74HC_HCT1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 6 September 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 14 74HC1G125; 74HCT1G125 Nexperia Bus buffer/line driver; 3-state Plastic surface-mounted package; 5 leads SOT753 D B E y A X HE 5 v M A 4 Q A A1 c 1 2 3 Lp detail X bp e w M B 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.100 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC JEITA SOT753 SC-74A EUROPEAN PROJECTION ISSUE DATE 02-04-16 06-03-16 Figure 10. Package outline SOT753 (SC-74A) 74HC_HCT1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 6 September 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 14 74HC1G125; 74HCT1G125 Nexperia Bus buffer/line driver; 3-state 13 Abbreviations Table 12. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14 Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT1G125 v.6 20170906 Product data sheet - 74HC_HCT1G125 v.5 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74HC_HCT1G125 v.5 20051223 Modifications: • The format of this data sheet has been redesigned to comply with the new presentation and information standard of Philips Semiconductors. • In Table 5 Limiting values – IO: changed max value ±12.5 into ±35 – ICC: changed max value 25 into 70 – IGND: changed max value -25 into -70 • In Table 7 Static characteristics 74HC1G125 – VOH: changed condition IO = -2.0 mA into IO = -6.0 mA and min value from 4.13 into 3.84 – VOH: changed condition IO = -2.6 mA into IO = -7.8 mA and min value from 5.63 into 5.34 – VOL: changed condition IO = 2.0 mA into IO = 6.0 mA – VOL: changed condition IO = 2.6 mA into IO = 7.8 mA – VOH: changed condition IO = -2.0 mA into IO = -6.0 mA – VOL: changed condition IO = 2.0 mA into IO = 6.0 mA • In Table 8 Static characteristics 74HCT1G125 – VOH: changed condition IO = -2.0 mA into IO = -6.0 mA and min value from 4.13 into 3.84 – VOL: changed condition IO = 2.0 mA into IO = 6.0 mA and typ value from 0.15 into 0.16 – VOH: changed condition IO = -2.0 mA into IO = -6.0 mA – VOL: changed condition IO = 2.0 mA into IO = 6.0 mA 74HC_HCT1G125 v.4 20040727 Product specification - 74HC_HCT1G125 v.3 74HC_HCT1G125 v.3 20020517 Product specification - 74HC_HCT1G125 v.2 74HC_HCT1G125 v.2 20010302 Product specification - 74HC_HCT1G125 v.1 74HC_HCT1G125 v.1 19981110 Product specification - - 74HC_HCT1G125 Product data sheet Product data sheet ECN05_085 All information provided in this document is subject to legal disclaimers. Rev. 6 — 6 September 2017 74HC_HCT1G125 v.4 © Nexperia B.V. 2017. All rights reserved. 11 / 14 74HC1G125; 74HCT1G125 Nexperia Bus buffer/line driver; 3-state 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74HC_HCT1G125 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 6 — 6 September 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 14 74HC1G125; 74HCT1G125 Nexperia Bus buffer/line driver; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74HC_HCT1G125 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 6 — 6 September 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 14 Nexperia 74HC1G125; 74HCT1G125 Bus buffer/line driver; 3-state Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Marking .................................................................1 Functional diagram ............................................. 2 Pinning information ............................................ 2 Pinning ............................................................... 2 Pin description ................................................... 2 Functional description ........................................3 Limiting values .................................................... 3 Recommended operating conditions ................ 3 Static characteristics .......................................... 4 Dynamic characteristics .....................................6 Waveforms and test circuit ................................ 7 Package outline ...................................................9 Abbreviations .................................................... 11 Revision history ................................................ 11 Legal information .............................................. 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 6 September 2017 Document identifier: 74HC_HCT1G125
74HCT1G125GV,125 价格&库存
很抱歉,暂时无法提供与“74HCT1G125GV,125”相匹配的价格&库存,您可以联系我们找货
74HCT1G125GV,125
  • 3000+0.640483000+0.07749
  • 6000+0.461916000+0.05588
  • 15000+0.4528215000+0.05478
  • 30000+0.4355430000+0.05269
  • 75000+0.4019075000+0.04862
  • 150000+0.39735150000+0.04807
库存:30000
74HCT1G125GV,125
  • 3000+0.612733000+0.07413
  • 6000+0.441906000+0.05346
  • 15000+0.4337215000+0.05247
  • 30000+0.4173530000+0.05049
  • 75000+0.3864475000+0.04675
库存:3000
