74HCT245PW-Q100J
74HCT245PW-Q100J
    NEXPERIA(安世)
    TSSOP20_6.5X4.4MM
    安世 74HC_HCT245_Q100 TSSOP20 4.5-5.5V
74HCT245PW-Q100J 数据手册
74HC245-Q100; 74HCT245-Q100 Octal bus tranceiver; 3-state Rev. 1 — 22 July 2013 Product data sheet 1. General description The 74HC245-Q100; 74HCT245-Q100 is an 8-bit transceiver with 3-state outputs. The device features an output enable (OE) and send/receive (DIR) for direction control. A HIGH on OE causes the outputs to assume a high-impedance OFF-state. Inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Octal bidirectional bus interface  Non-inverting 3-state outputs  Multiple package options  Complies with JEDEC standard no. 7A  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 ) 3. Ordering information Table 1. Ordering information Type number 74HC245D-Q100 Package Temperature range Name Description Version 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; SOT360-1 body width 4.4 mm 40 C to +125 C DHVQFN20 plastic dual-in-line compatible thermal enhanced SOT764-1 very thin quad flat package no leads; 20 terminals; body 2.5  4.5  0.85 mm 74HCT245D-Q100 74HC245PW-Q100 74HCT245PW-Q100 74HC245BQ-Q100 74HCT245BQ-Q100 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state 4. Functional diagram 1 DIR OE 2 B0 3 16 15 14 A5 13 A6 18 2 3 17 4 16 5 15 6 14 7 13 8 12 9 B6 9 2 A4 B5 8 3EN1 3EN2 17 A3 B4 7 G3 1 B3 6 1 A2 B2 5 19 18 A1 B1 4 19 A0 11 mna175 12 A7 B7 11 mna174 Fig 1. Logic symbol 74HC_HCT245_Q100 Product data sheet Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 2 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state 5. Pinning information 5.1 Pinning ',5  WHUPLQDO LQGH[DUHD +&4 +&74  9&& +&4 +&74 $   2( $   % $   % ',5  $   9&&  2( $   % $   % $   % $   % $   % $  $   % $  $   % $   % $  $   % *1'   %  % *1'   % %  *1'   % DDD 7UDQVSDUHQWWRSYLHZ DDD (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 3. Pin configuration SO20 and TSSOP20 Fig 4. Pin configuration DHVQFN20 5.2 Pin description Table 2. Pin description Symbol Pin Description DIR 1 direction control A0, A1, A2, A3, A4, A5, A6, A7 2, 3, 4, 5, 6, 7, 8, 9 data input/output GND 10 ground (0 V) B0, B1, B2, B3, B4, B5, B6, B7 18, 17, 16, 15, 14, 13, 12, 11 data input/output OE 19 output enable input (active LOW) VCC 20 supply voltage 74HC_HCT245_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 3 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state 6. Functional description Table 3. Function table[1] Input Input/output OE DIR An Bn L L A=B input L H input B=A H X Z Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7 V IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA IO output current VO = 0.5 V to VCC + 0.5 V - 35 mA ICC supply current - +70 mA IGND ground current 70 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot [1] SO20, TSSOP20 and DHVQFN20 packages [1] For SO20 package: above 70 C, Ptot derates linearly with 8 mW/K. For TSSOP20 package: above 60 C, Ptot derates linearly with 5.5 mW/K. For DHVQFN20 package: above 60 C, Ptot derates linearly with 4.5 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature t/V input transition rise and fall rate 74HC_HCT245_Q100 Product data sheet Conditions 74HC245-Q100 74HCT245-Q100 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V 0 - VCC 0 - VCC V 0 - VCC 0 - VCC V 40 +25 +125 40 +25 +125 C VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 4 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state 9. Static characteristics Table 6. Static characteristics type 74HC245-Q100 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit Tamb = 25 C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VCC = 2.0 V 1.5 1.2 - V VCC = 4.5 V 3.15 2.4 - V VCC = 6.0 V 4.2 3.2 - V VCC = 2.0 V - 0.8 0.5 V VCC = 4.5 V - 2.1 1.35 V VCC = 6.0 V - 2.8 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - V IO = 6.0 mA; VCC = 4.5 V 3.98 4.32 - V IO = 7.8 mA; VCC = 6.0 V 5.48 5.81 - V IO = 20 A; VCC = 2.0 V - 0 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.26 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.26 V VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - 0.5 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 A CI input capacitance - 3.5 - pF CI/O input/output capacitance - 10 - pF VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V Tamb = 40 C to +85 C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 74HC_HCT245_Q100 Product data sheet VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 - - V IO = 20 A; VCC = 4.5 V 4.4 - - V IO = 20 A; VCC = 6.0 V 5.9 - - V IO = 6.0 mA; VCC = 4.5 V 3.84 - - V IO = 7.8 mA; VCC = 6.0 V 5.34 - - V VI = VIH or VIL All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 5 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state Table 6. Static characteristics type 74HC245-Q100 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VOL LOW-level output voltage VI = VIH or VIL IO = 20 A; VCC = 2.0 V - - 0.1 V IO = 20 A; VCC = 4.5 V - - 0.1 V IO = 20 A; VCC = 6.0 V - - 0.1 V IO = 6.0 mA; VCC = 4.5 V - - 0.33 V IO = 7.8 mA; VCC = 6.0 V - - 0.33 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - 5.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 80 A VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V Tamb = 40 C to +125 C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V VI = VIH or VIL - IO = 20 A; VCC = 2.0 V 1.9 - - V IO = 20 A; VCC = 4.5 V 4.4 - - V IO = 20 A; VCC = 6.0 V 5.9 - - V IO = 6.0 mA; VCC = 4.5 V 3.7 - - V IO = 7.8 mA; VCC = 6.0 V 5.2 - - V VI = VIH or VIL - IO = 20 A; VCC = 2.0 V - - 0.1 V IO = 20 A; VCC = 4.5 V - - 0.1 V IO = 20 A; VCC = 6.0 V - - 0.1 V IO = 6.0 mA; VCC = 4.5 V - - 0.4 V IO = 7.8 mA; VCC = 6.0 V - - 0.4 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - 10.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 160 A 74HC_HCT245_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 6 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state Table 7. Static characteristics type 74HCT245-Q100 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit Tamb = 25 C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V VOL LOW-level output voltage IO = 20 A 4.4 4.5 - V IO = 6 mA 3.98 4.32 - V IO = 20 A - 0 0.1 V IO = 6.0 mA VI = VIH or VIL; VCC = 4.5 V - 0.15 0.26 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 A IOZ OFF-state output current VI = VIH or VIL; VCC = 5.5 V; VO = VCC or GND per input pin; other inputs at VCC or GND; IO = 0 A - - 0.5 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 A ICC additional supply current per input pin; VI = VCC  2.1 V; other inputs at VI = VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A An or Bn inputs - 40 144 A OE input - 150 540 A DIR input - 90 324 A CI input capacitance - 3.5 - pF CI/O input/output capacitance - 10 - pF Tamb = 40 C to +85 C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 - - V IO = 6 mA 3.84 - - V IO = 20 A - - 0.1 V IO = 6.0 mA - - 0.33 V VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VCC = 5.5 V; VO = VCC or GND per input pin; other inputs at VCC or GND; IO = 0 A - - 5.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 80 A 74HC_HCT245_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 7 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state Table 7. Static characteristics type 74HCT245-Q100 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit ICC additional supply current per input pin; VI = VCC  2.1 V; other inputs at VI = VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A An or Bn inputs - - 180 A OE input - - 675 A DIR input - - 405 A Tamb = 40 C to +125 C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V VOL LOW-level output voltage IO = 20 A 4.4 - - V IO = 6 mA 3.7 - - V - - 0.1 V VI = VIH or VIL; VCC = 4.5 V IO = 20 A - - 0.4 V II input leakage current VI = VCC or GND; VCC = 5.5 V IO = 6.0 mA - - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VCC = 5.5 V; VO = VCC or GND per input pin; other inputs at VCC or GND; IO = 0 A - - 10 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 160 A ICC additional supply current per input pin; VI = VCC  2.1 V; other inputs at VI = VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A An or Bn inputs - - 196 A OE input - - 735 A DIR input - - 441 A 74HC_HCT245_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 8 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state 10. Dynamic characteristics Table 8. Dynamic characteristics type 74HC245-Q100 GND = 0 V; for test circuit, see Figure 7. Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V - 25 90 ns VCC = 4.5 V - 9 18 ns VCC = 5.0 V; CL = 15 pF - 7 - ns VCC = 6.0 V - 7 15 ns VCC = 2.0 V - 30 150 ns VCC = 4.5 V - 11 30 ns - 9 26 ns VCC = 2.0 V - 41 150 ns VCC = 4.5 V - 15 30 ns - 12 26 ns VCC = 2.0 V - 14 60 ns VCC = 4.5 V - 5 12 ns - 4 10 ns - 30 - pF VCC = 2.0 V - - 115 ns VCC = 4.5 V - - 23 ns - - 20 ns VCC = 2.0 V - - 190 ns VCC = 4.5 V - - 38 ns - - 33 ns VCC = 2.0 V - - 190 ns VCC = 4.5 V - - 38 ns VCC = 6.0 V - - 33 ns Tamb = 25 C tpd ten propagation delay An to Bn or Bn to An; see Figure 5 enable time OE to An or OE to Bn; see Figure 6 [1] [2] VCC = 6.0 V tdis disable time OE to An or OE to Bn; see Figure 6 [3] VCC = 6.0 V tt transition time An, Bn; see Figure 5 [4] VCC = 6.0 V CPD power dissipation capacitance VI = GND to VCC [5] An to Bn or Bn to An; see Figure 5 [1] Tamb = 40 C to +85 C tpd propagation delay VCC = 6.0 V ten enable time OE to An or OE to Bn; see Figure 6 [2] VCC = 6.0 V tdis disable time 74HC_HCT245_Q100 Product data sheet OE to An or OE to Bn; see Figure 6 All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 [3] © Nexperia B.V. 2017. All rights reserved 9 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state Table 8. Dynamic characteristics type 74HC245-Q100 …continued GND = 0 V; for test circuit, see Figure 7. Symbol tt Parameter transition time Conditions Min Typ Max Unit VCC = 2.0 V - - 75 ns VCC = 4.5 V - - 15 ns VCC = 6.0 V - - 13 ns VCC = 2.0 V - - 135 ns VCC = 4.5 V - - 27 ns - - 23 ns VCC = 2.0 V - - 225 ns VCC = 4.5 V - - 45 ns - - 38 ns VCC = 2.0 V - - 225 ns VCC = 4.5 V - - 45 ns VCC = 6.0 V - - 38 ns VCC = 2.0 V - - 90 ns VCC = 4.5 V - - 18 ns VCC = 6.0 V - - 15 ns An, Bn; see Figure 5 [4] Tamb = 40 C to +125 C propagation delay tpd An to Bn or Bn to An; see Figure 5 [1] VCC = 6.0 V enable time ten OE to An or OE to Bn; see Figure 6 [2] VCC = 6.0 V disable time tdis transition time tt [1] OE to An or OE to Bn; see Figure 6 An, Bn; see Figure 5 [3] [4] tpd is the same as tPLH and tPHL. [2] ten is the same as tPZH and tPZL. [3] tdis is the same as tPLZ and tPHZ. [4] tt is the same as tTHL and tTLH. [5] CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD  VCC2  fi  N +  (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching;  (CL  VCC2  fo) = sum of outputs. 74HC_HCT245_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 10 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state Table 9. Dynamic characteristics type 74HCT245-Q100 GND = 0 V; for test circuit, see Figure 7. Symbol Parameter Conditions Min Typ Max Unit - 12 22 ns Tamb = 25 C propagation delay tpd An to Bn or Bn to An; see Figure 5 [1] VCC = 4.5 V - 10 - ns ten enable time OE to An or OE to Bn; VCC = 4.5 V; see Figure 6 VCC = 5.0 V; CL = 15 pF [2] - 16 30 ns tdis disable time OE to An or OE to Bn; VCC = 4.5 V; see Figure 6 [3] - 16 30 ns tt transition time An, Bn; VCC = 4.5 V; see Figure 5 [4] - 5 12 ns CPD power dissipation capacitance VI = GND to VCC  1.5 V [5] - 30 - pF VCC = 4.5 V; see Figure 5 [1] - - 28 ns - - 38 ns Tamb = 40 C to +85 C propagation delay tpd ten enable time OE to An or OE to Bn; VCC = 4.5 V; see Figure 6 [2] tdis disable time OE to An or OE to Bn; VCC = 4.5 V; see Figure 6 [3] - - 38 ns tt transition time An, Bn; VCC = 4.5 V; see Figure 5 [4] - - 15 ns VCC = 4.5 V; see Figure 5 [1] - - 33 ns - - 45 ns Tamb = 40 C to +125 C propagation delay tpd ten enable time OE to An or OE to Bn; VCC = 4.5 V; see Figure 6 [2] tdis disable time OE to An or OE to Bn; VCC = 4.5 V; see Figure 6 [3] - - 45 ns tt transition time An, Bn; VCC = 4.5 V; see Figure 5 [4] - - 18 ns [1] tpd is the same as tPLH and tPHL. [2] ten is the same as tPZH and tPZL. [3] tdis is the same as tPLZ and tPHZ. [4] tt is the same as tTHL and tTLH. [5] CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD  VCC2  fi  N +  (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching;  (CL  VCC2  fo) = sum of outputs. 74HC_HCT245_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 11 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state 11. Waveforms VI VM An, Bn input VM GND t PHL t PLH VOH 90 % VM VM Bn, An output 10 % VOL t THL t TLH 001aac433 Measurement points are given in Table 10. VOL and VOH are typical voltage output levels that occur with the output load. Fig 5. Input (An, Bn) to output (Bn, An) propagation delays and output transition times tr VI tf 90 % OE input VM GND 10 % tPLZ output tPZL VCC LOW-to-OFF OFF-to-LOW VM 10 % VOL tPHZ output VOH tPZH 90 % HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs enabled outputs disabled 001aac479 Measurement points are given in Table 10. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. Table 10. 3-state output enable and disable times Measurement points Type Input Output VM VM 74HC245-Q100 0.5VCC 0.5VCC 74HCT245-Q100 1.3 V 1.3 V 74HC_HCT245_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 12 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC G VI VO RL S1 open DUT CL RT 001aad983 Test data is given in Table 11. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig 7. Table 11. Test circuit for measuring switching times Test data Type Input VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74HC245-Q100 VCC 6 ns 15 pF, 50 pF 1 k open GND VCC 74HCT245-Q100 3V 6 ns 15 pF, 50 pF 1 k open GND VCC 74HC_HCT245_Q100 Product data sheet Load S1 position All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 13 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state 12. Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c HE y v M A Z 20 11 Q A2 A (A 3) A1 pin 1 index θ Lp L 10 1 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 inches 0.1 0.012 0.096 0.004 0.089 0.043 0.039 0.01 0.01 Z (1) 0.9 0.4 0.035 0.004 0.016 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 8. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT163-1 (SO20) 74HC_HCT245_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 14 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 E D A X c HE y v M A Z 11 20 Q A2 (A 3) A1 pin 1 index A θ Lp L 1 10 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 Fig 9. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Package outline SOT360-1 (TSSOP20) 74HC_HCT245_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 15 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT764-1 20 terminals; body 2.5 x 4.5 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 9 y y1 C v M C A B w M C b L 1 10 Eh e 20 11 19 12 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 4.6 4.4 3.15 2.85 2.6 2.4 1.15 0.85 0.5 3.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT764-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 10. Package outline SOT764-1 (DHVQFN20) 74HC_HCT245_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 16 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state 13. Abbreviations Table 12. Abbreviations Acronym Description DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model MIL Military 14. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT245_Q100 v.1 20130722 Product data sheet - - 74HC_HCT245_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 17 of 20 74HC245-Q100; 74HCT245-Q100 Nexperia Octal bus tranceiver; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT245_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 18 of 20 Nexperia 74HC245-Q100; 74HCT245-Q100 Octal bus tranceiver; 3-state No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT245_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 July 2013 © Nexperia B.V. 2017. All rights reserved 19 of 20 Nexperia 74HC245-Q100; 74HCT245-Q100 Octal bus tranceiver; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 9 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 14 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 17 Legal information. . . . . . . . . . . . . . . . . . . . . . . 18 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 18 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Contact information. . . . . . . . . . . . . . . . . . . . . 19 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 22 July 2013
74HCT245PW-Q100J 价格&库存
很抱歉,暂时无法提供与“74HCT245PW-Q100J”相匹配的价格&库存,您可以联系我们找货
