74HC2G16; 74HCT2G16
Dual buffer gate
Rev. 1 — 2 November 2015
Product data sheet
1. General description
The 74HC2G16; 74HCT2G16 is a high-speed Si-gate CMOS device.
The 74HC2G16; 74HCT2G16 provides two buffers.
2. Features and benefits
Wide supply voltage range from 2.0 V to 6.0 V
Complies with JEDEC standard no. 7A
High noise immunity
ESD protection:
HBM JESD22-A114-D exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Low power dissipation
Balanced propagation delays
Unlimited input rise and fall times
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74HC2G16GW
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74HC2G16GV
40 C to +125 C
SC-74
plastic surface-mounted package (TSOP6); 6 leads
SOT457
74HCT2G16GW
40 C to +125 C
SC-88
SOT363
74HCT2G16GV
40 C to +125 C
SC-74
SOT457
4. Marking
Table 2.
Marking
Type number
Marking code
74HC2G16GW
P6
74HC2G16GV
P6
74HCT2G16GW
U6
74HCT2G16GV
U6
74HC2G16; 74HCT2G16
Nexperia
Dual buffer gate
5. Functional diagram
PQE
PQE
Fig 1. Logic symbol
DDF
Fig 2. IEC logic symbol
Fig 3. Logic diagram (one gate)
6. Pinning information
6.1 Pinning
+&7*
*1'
9&&
DDD
Fig 4. Pin configuration
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
1A
1
data input
GND
2
ground (0 V)
2A
3
data input
2Y
4
data output
VCC
5
supply voltage
1Y
6
data output
74HC_HCT2G16
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
74HC2G16; 74HCT2G16
Nexperia
Dual buffer gate
7. Functional description
Table 4.
Function table[1]
Input
Output
nA
nY
L
L
H
H
[1]
H = HIGH voltage level;
L = LOW voltage level.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+7.0
V
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
mA
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
mA
IO
output current
VO = 0.5 V to VCC + 0.5 V
[1]
25
mA
supply current
[1]
+50
mA
IGND
ground current
[1]
50
mA
Tstg
storage temperature
Ptot
total power dissipation
IIK
ICC
65
[2]
[1]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SC-88 and SC-74 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
+150 C
250
mW
9. Recommended operating conditions
Table 6.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
2.0
5.0
6.0
V
Type 74HC2G16
VCC
supply voltage
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+25
+125
C
tr
rise time
VCC = 2.0 V
1000
ns
VCC = 4.5 V
500
ns
VCC = 6.0 V
400
ns
VCC = 2.0 V
1000
ns
VCC = 4.5 V
500
ns
VCC = 6.0 V
400
ns
tf
fall time
74HC_HCT2G16
Product data sheet
except for Schmitt trigger inputs
3 of 15
74HC2G16; 74HCT2G16
Nexperia
Dual buffer gate
Table 6.
Recommended operating conditions …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
4.5
5.0
5.5
V
VCC
V
Type 74HCT2G16
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
tr
rise time
VCC
V
40
+25
+125
C
500
ns
500
ns
VCC = 4.5 V
tf
fall time
VCC = 4.5 V
10. Static characteristics
Table 7.
Static characteristics for 74HC2G16
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Typ
HIGH-level input voltage
Max
Unit
VCC = 2.0 V
1.5
1.2
V
VCC = 4.5 V
3.15
2.4
V
VCC = 6.0 V
4.2
3.2
V
VCC = 2.0 V
0.8
0.5
V
Tamb = 25 C
VIH
VIL
VOH
VOL
LOW-level input voltage
HIGH-level output voltage
LOW-level output voltage
VCC = 4.5 V
2.1
1.35
V
VCC = 6.0 V
2.8
1.8
V
IO = 20 A; VCC = 2.0 V
1.9
2.0
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
V
IO = 4.0 mA; VCC = 4.5 V
4.18
4.32
V
IO = 5.2 mA; VCC = 6.0 V
5.68
5.81
V
V
V
V
0.15
0.26
V
0.16
0.26
V
VI = VIH or VIL
VI = VIH or VIL
II
input leakage current
VI = GND or VCC; VCC = 6.0 V
0.1
A
ICC
supply current
VI = GND or VCC; IO = 0 A;
1.0
A
1.5
pF
VCC = 6.0 V
CI
input capacitance
74HC_HCT2G16
Product data sheet
4 of 15
74HC2G16; 74HCT2G16
Nexperia
Dual buffer gate
Table 7.
Static characteristics for 74HC2G16 …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
1.5
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
4.13
V
5.63
V
Tamb = 40 C to +85 C
VIH
VIL
VOH
VOL
V
VI = VIH or VIL
VI = VIH or VIL
0.1
V
0.1
V
0.1
V
0.33
V
0.33
V
II
1.0
A
ICC
supply current
10.0
A
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
Tamb = 40 C to +125 C
VIH
VIL
VOH
74HC_HCT2G16
Product data sheet
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
3.7
V
5.2
V
VI = VIH or VIL
5 of 15
74HC2G16; 74HCT2G16
Nexperia
Dual buffer gate
Table 7.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VOL
VI = VIH or VIL
0.1
V
0.1
V
0.1
V
0.4
V
0.4
V
II
1.0
A
ICC
supply current
20.0
A
Max
Unit
VCC = 6.0 V
Table 8.
Static characteristics for 74HCT2G16
Symbol
Parameter
Conditions
Min
Typ
Tamb = 25 C
VIH
VCC = 4.5 V to 5.5 V
2.0
1.6
V
VIL
1.2
0.8
V
VOH
VI = VIH or VIL
4.4
4.5
V
4.18
4.32
V
V
0.15
0.26
V
VOL
VI = VIH or VIL
II
VI = GND or VCC; VCC = 5.5 V
0.1
A
ICC
supply current
VCC = 5.5 V
1.0
A
ICC
additional supply current
VI = VCC 2.1 V;
VCC = 4.5 V to 5.5 V; IO = 0 A
300
A
CI
input capacitance
1.5
pF
2.0
V
0.8
V
4.4
V
4.13
V
0.1
V
0.33
V
VIH
VIL
VOH
VI = VIH or VIL
VOL
VI = VIH or VIL
II
1.0
A
ICC
supply current
VCC = 5.5 V
10.0
A
ICC
VI = VCC 2.1 V;
375
A
74HC_HCT2G16
Product data sheet
6 of 15
74HC2G16; 74HCT2G16
Nexperia
Dual buffer gate
Table 8.
Static characteristics for 74HCT2G16 …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
2.0
V
0.8
V
4.4
V
3.7
V
0.1
V
0.4
V
VIH
VIL
VOH
VI = VIH or VIL
VOL
VI = VIH or VIL
II
1.0
A
ICC
supply current
VCC = 5.5 V
20.0
A
ICC
VI = VCC 2.1 V;
410
A
11. Dynamic characteristics
Table 9.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6.
Symbol
Parameter
25 C
Conditions
40 C to +125 C
Unit
Min
Typ
Max
Min
Max
(85 C)
Max
(125 C)
VCC = 2.0 V; CL = 50 pF
29
75
95
125
ns
VCC = 4.5 V; CL = 50 pF
9
15
19
25
ns
8
13
16
ns
18
75
95
125
ns
6
15
19
25
ns
5
13
16
ns
10
pF
74HC2G16
tpd
propagation delay
nA to nY; see Figure 5
[1]
VCC = 6.0 V; CL = 50 pF
tt
transition time
nY; see Figure 5
[2]
CPD
power dissipation
capacitance
74HC_HCT2G16
Product data sheet
VI = GND to VCC
[3]
7 of 15
74HC2G16; 74HCT2G16
Nexperia
Dual buffer gate
Table 9.
Dynamic characteristics …continued
Symbol
Parameter
25 C
Conditions
40 C to +125 C
Unit
Min
Typ
Max
Min
Max
(85 C)
Max
(125 C)
10
18
23
29
ns
6
15
19
25
ns
9
pF
74HCT2G16
propagation delay
tpd
[1]
tt
transition time
CPD
power dissipation
capacitance
[2]
nY; see Figure 5
[1]
tpd is the same as tPLH and tPHL
[2]
tt is the same as tTLH and tTHL
[3]
VI = GND to VCC 1.5 V
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of the outputs.
12. Waveforms
9,
Q$LQSXW
90
90
*1'
W3/+
92+
W3+/
Q
很抱歉,暂时无法提供与“74HCT2G16GWH”相匹配的价格&库存,您可以联系我们找货
