74LVC2G126-Q100
Bus buffer/line driver; 3-state
Rev. 3 — 10 January 2019
Product data sheet
1. General description
The 74LVC2G126-Q100 is a dual non-inverting buffer/line driver with 3-state outputs. An output
enable input (pin nOE) controls each 3-state output. A LOW-level at pin nOE causes the output to
assume a high-impedance OFF-state. Schmitt trigger action at all inputs makes the circuit highly
tolerant of slower input rise and fall times.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of the
74LVC2G126-Q100 as a translator in a mixed 3.3 V and 5 V environment.
It is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the
output, preventing a damaging backflow current through the device when it is powered down.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant input/output for interfacing with 5 V logic
High noise immunity
Complies with JEDEC standard:
• JESD8-7 (1.65 V to 1.95 V)
• JESD8-5 (2.3 V to 2.7 V)
• JESD8-B/JESD36 (2.7 V to 3.6 V)
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
±24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74LVC2G126DP-Q100
-40 °C to +125 °C
TSSOP8
plastic thin shrink small outline package; 8 leads; SOT505-2
body width 3 mm; lead length 0.5 mm
74LVC2G126DC-Q100
-40 °C to +125 °C
VSSOP8
plastic very thin shrink small outline package;
8 leads; body width 2.3 mm
SOT765-1
74LVC2G126-Q100
Nexperia
4. Marking
Table 2. Marking codes
Type number
Marking code [1]
74LVC2G126DP-Q100
V26
74LVC2G126DC-Q100
V26
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
1Y
1A
1OE
nY
nA
2Y
2A
2OE
nOE
001aah787
Fig. 1.
Logic symbol
Fig. 2.
mna234
Logic diagram (one gate)
6. Pinning information
6.1. Pinning
74LVC2G126-Q100
1OE
1
8
VCC
1A
2
7
2OE
2Y
3
6
1Y
GND
4
5
2A
aaa-017813
Fig. 3.
Pin configuration SOT505-2 (TSSOP8) and SOT765-1 (VSSOP8)
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
1OE, 2OE
1, 7
output enable input (active HIGH)
1A, 2A
2, 5
data input
1Y, 2Y
6, 3
data output
GND
4
ground (0 V)
VCC
8
supply voltage
74LVC2G126_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 12
74LVC2G126-Q100
Nexperia
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
Input
Output
nOE
nA
nY
H
L
L
H
H
H
L
X
Z
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+6.5
V
-50
-0.5
+6.5
V
±50
mA
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO > VCC or VO < 0 V
VO
output voltage
Active mode
[1]
-0.5
VCC + 0.5
V
Power-down mode; VCC = 0 V
[1]
-0.5
+6.5
V
IO
output current
±50
mA
ICC
supply current
+100
mA
IGND
ground current
-100
mA
Ptot
total power dissipation
300
mW
Tstg
storage temperature
-65
+150
°C
[1]
[2]
VI < 0 V
[1]
VO = 0 V to VCC
Tamb = -40 °C to +125 °C
[2]
mA
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For TSSOP8 packages: above 55 °C the value of Ptot derates linearly at 2.5 mW/K.
For VSSOP8 packages: above 110 °C the value of Ptot derates linearly at 8.0 mW/K.
9. Recommended operating conditions
Table 6. Operating conditions
Symbol Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
74LVC2G126_Q100
Product data sheet
Conditions
Min
Max
Unit
1.65
5.5
V
V
Active mode
VCC
V
VCC = 0 V; Power-down mode
V
-40
+125
°C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
3 / 12
74LVC2G126-Q100
Nexperia
10. Static characteristics
Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VIH
HIGH-level
input voltage
Conditions
Tamb = -40 °C to +85 °C
VCC = 1.65 V to 1.95 V
VOL
LOW-level
output voltage
VOH
HIGH-level
output voltage
Min
Typ [1]
Max
Min
Max
0.65VCC
0.65VCC
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
VCC = 2.7 V to 3.6 V
2.0
2.0
V
VCC = 4.5 V to 5.5 V
0.7VCC
0.7VCC
V
0.35VCC
LOW-level input VCC = 1.65 V to 1.95 V
voltage
VIL
Tamb =
Unit
-40 °C to +125 °C
0.35VCC V
0.7
0.7
V
0.8
0.8
V
0.3VCC
IO = 100 μA;
VCC = 1.65 V to 5.5 V
0.1
0.1
V
IO = 4 mA; VCC = 1.65 V
0.45
0.70
V
IO = 8 mA; VCC = 2.3 V
0.3
0.45
V
IO = 12 mA; VCC = 2.7 V
0.4
0.60
V
IO = 24 mA; VCC = 3.0 V
0.55
0.80
V
IO = 32 mA; VCC = 4.5 V
0.55
0.80
V
VCC - 0.1
VCC - 0.1
V
IO = -4 mA; VCC = 1.65 V
1.2
0.95
V
IO = -8 mA; VCC = 2.3 V
1.9
1.7
V
IO = -12 mA; VCC = 2.7 V
2.2
1.9
V
IO = -24 mA; VCC = 3.0 V
2.3
2.0
V
IO = -32 mA; VCC = 4.5 V
3.8
3.4
V
0.3VCC V
VI = VIH or VIL
VI = VIH or VIL
IO = -100 μA;
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
±0.1
±1
±1
μA
IOZ
OFF-state
output current
VI = VIH or VIL;
VO = 5.5 V or GND; VCC = 3.6 V
±0.1
±2
±2
μA
IOFF
power-off
VI or VO = 5.5 V; VCC = 0 V
leakage current
±0.1
±2
±2
μA
ICC
supply current
VI = 5.5 V or GND;
VCC = 1.65 V to 5.5 V; IO = 0 A
0.1
4
4
μA
ΔICC
additional
supply current
per pin; VI = VCC - 0.6 V; IO = 0 A;
VCC = 2.3 V to 5.5 V
5
500
500
μA
CI
input
capacitance
2
pF
[1]
Typical values are measured at VCC = 3.3 V and Tamb = 25 °C.
74LVC2G126_Q100
Product data sheet
4 / 12
74LVC2G126-Q100
Nexperia
11. Dynamic characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 6.
Symbol Parameter
tpd
propagation delay
Conditions
Min
Typ [1]
Max
Min
Max
1.0
3.9
9.8
1.0
12.3
ns
0.5
2.6
4.9
0.5
6.3
ns
VCC = 2.7 V
1.0
2.8
4.7
1.0
5.9
ns
VCC = 3.0 V to 3.6 V
0.5
2.4
4.3
0.5
5.4
ns
0.5
1.9
3.2
0.5
4.0
ns
1.0
4.1
10.0
1.0
12.5
ns
1.0
2.6
5.0
1.0
6.3
ns
VCC = 2.7 V
1.0
2.8
4.7
1.0
5.9
ns
1.0
2.4
4.1
1.0
5.1
ns
0.5
1.8
3.1
0.5
3.9
ns
1.0
3.3
12.6
1.0
15.4
ns
0.5
1.9
5.7
0.5
7.5
ns
VCC = 2.7 V
1.5
3.0
4.8
1.5
6.2
ns
1.0
2.5
4.4
1.0
5.7
ns
0.5
1.8
3.3
0.5
4.4
ns
output enabled
17
pF
output disabled
5
pF
nA to nY; see Fig. 4
[2]
ten
tdis
CPD
[1]
[2]
[3]
[4]
[5]
enable time
disable time
power dissipation
capacitance
Tamb =
Unit
-40 °C to +125 °C
nOE to nY; see Fig. 5
per buffer; VI = GND to VCC
[3]
[4]
[5]
Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
tpd is the same as tPLH and tPHL
ten is the same as tPZH and tPZL
tdis is the same as tPLZ and tPHZ
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL × VCC × fo) = sum of outputs.
74LVC2G126_Q100
Product data sheet
5 / 12
74LVC2G126-Q100
Nexperia
11.1. Waveforms and test circuit
VI
VM
nA input
GND
tPHL
tPLH
VOH
VM
nY output
VOL
mna230
Measurement points are given in Table 9.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 4.
The data input (nA) to output (nY) propagation delays
VI
nOE input
VM
GND
t PLZ
output
LOW-to-OFF
OFF-to-LOW
t PZL
VCC
VM
VX
VOL
t PHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
t PZH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
mna949
Fig. 5.
3-state enable and disable times
Table 9. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
VX
VY
1.65 V to 1.95 V
0.5 × VCC
0.5 × VCC
VOL + 0.15 V
VOH - 0.15 V
2.3 V to 2.7 V
0.5 × VCC
0.5 × VCC
VOL + 0.15 V
VOH - 0.15 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
3.0 V to 3.6 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
4.5 V to 5.5 V
0.5 × VCC
0.5 × VCC
VOL + 0.3 V
VOH - 0.3 V
74LVC2G126_Q100
Product data sheet
6 / 12
74LVC2G126-Q100
Nexperia
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
mna616
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 6.
Test circuit for measuring switching times
Table 10. Test data
Supply voltage
Input
VCC
VI
tr, tf
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
open
GND
2 × VCC
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
GND
2 × VCC
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
GND
6V
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
GND
6V
4.5 V to 5.5 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
GND
2 × VCC
74LVC2G126_Q100
Product data sheet
Load
VEXT
7 / 12
74LVC2G126-Q100
Nexperia
12. Package outline
TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm
D
E
A
SOT505-2
X
c
HE
y
v M A
Z
5
8
A
A2
pin 1 index
(A3)
A1
θ
Lp
L
1
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.15
0.00
0.95
0.75
0.25
0.38
0.22
0.18
0.08
3.1
2.9
3.1
2.9
0.65
4.1
3.9
0.5
0.47
0.33
0.2
0.13
0.1
0.70
0.35
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT505-2
Fig. 7.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-01-16
Package outline SOT505-2 (TSSOP8)
74LVC2G126_Q100
Product data sheet
8 / 12
74LVC2G126-Q100
Nexperia
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
SOT765-1
E
A
X
c
y
HE
v
A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
detail X
4
e
L
w
bp
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
max.
max
nom
min
1
A1
A2
0.15 0.85
0.00 0.60
A3
0.12
D(1)
E(2)
0.27 0.23
2.1
2.4
0.17 0.08
1.9
2.2
bp
c
e
HE
0.5
3.2
3.0
L
0.4
Lp
Q
0.40 0.21
0.15 0.19
v
w
y
0.2
0.08
0.1
Z(1)
θ
0.4
8°
0.1
0°
Note
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT765-1
Fig. 8.
References
IEC
JEDEC
JEITA
sot765-1_po
European
projection
Issue date
07-06-02
16-05-31
MO-187
Package outline SOT765-1 (VSSOP8)
74LVC2G126_Q100
Product data sheet
9 / 12
74LVC2G126-Q100
Nexperia
13. Abbreviations
Table 11. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74LVC2G126_Q100 v.3
20190110
Product data sheet
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
74LVC2G126_Q100 v.2
20161214
Modifications:
74LVC2G126_Q100 v.1
20150512
74LVC2G126_Q100
Product data sheet
74LVC2G126_Q100 v.2
Product data sheet
74LVC2G126_Q100 v.1
Table 7: The maximum limits for leakage current and supply current have changed.
Product data sheet
10 / 12
74LVC2G126-Q100
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74LVC2G126_Q100
Product data sheet
11 / 12
74LVC2G126-Q100
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Marking.......................................................................... 2
5. Functional diagram.......................................................2
6. Pinning information......................................................2
6.1. Pinning.........................................................................2
6.2. Pin description............................................................. 2
7. Functional description................................................. 3
8. Limiting values............................................................. 3
9. Recommended operating conditions..........................3
10. Static characteristics..................................................4
11. Dynamic characteristics.............................................5
11.1. Waveforms and test circuit........................................ 6
12. Package outline.......................................................... 8
13. Abbreviations............................................................ 10
14. Revision history........................................................10
15. Legal information......................................................11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 10 January 2019
74LVC2G126_Q100
Product data sheet
12 / 12
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVC2G126DP-Q100H 74LVC2G126DC-Q100H
