74AHC157PW,118
74AHC157PW,118
    NEXPERIA(安世)
    TSSOP16_5X4.4MM
    四路2输入多路复用器 TSSOP16_5X4.4MM 2~5.5V
74AHC157PW,118 数据手册
74AHC157; 74AHCT157 Quad 2-input multiplexer Rev. 02 — 9 November 2007 Product data sheet 1. General description The 74AHC/AHCT157 are high-speed Si-gate CMOS devices and are pin compatible with Low Power Schottky TTL (LSTTL). They are specified in compliance with JEDEC standard no. 7A. The 74AHC/AHCT157 are quad 2-input multiplexer which select 4 bits of data from two sources under the control of a common data select input (S). The enable input (E) is active LOW. When E is HIGH, all of the outputs (1Y to 4Y) are forced LOW regardless of all other input conditions. Moving the data from two groups of registers to four common output buses is a common use of the 74AHC/AHCT157. The state of the common data select input (S) determines the particular register from which the data comes. It can also be used as function generator. The device is useful for implementing highly irregular logic by generating any four of the 16 different functions of two variables with one variable common. The 74AHC/AHCT157 is logic implementation of a 4-pole, 2-position switch, where the position of the switch is determine by the logic levels applied to S. The logic equations are: 1Y = E × (1I1 × S + 1I0 × S) 2Y = E × (2I1 × S + 2I0 × S) 3Y = E × (3I1 × S + 3I0 × S) 4Y = E × (4I1 × S + 4I0 × S) The 74AHC/AHCT157 is identical to the 74AHC/AHCT158 but has non-inverting (true) outputs. 2. Features ■ ■ ■ ■ ■ ■ ■ ■ Balanced propagation delays All inputs have a Schmitt-trigger action Inputs accepts voltages higher than VCC Multiple input enable for easy expansion Ideal for memory chip select decoding For 74AHC157 only: operates with CMOS input levels For 74AHCT157 only: operates with TTL input levels ESD protection: ◆ HBM JESD22-A114E exceeds 2000 V ◆ MM JESD22-A115-A exceeds 200 V ◆ CDM JESD22-C101C exceeds 1000 V 74AHC157; 74AHCT157 Nexperia Quad 2-input multiplexer ■ Multiple package options ■ Specified from −40 °C to +85 °C and from −40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number 74AHC157D Package Temperature range Name Description Version −40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 −40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 −40 °C to +125 °C DHVQFN16 SOT763-1 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5 × 3.5 × 0.85 mm 74AHCT157D 74AHC157PW 74AHCT157PW 74AHC157BQ 74AHCT157BQ 4. Functional diagram S E 1I1 1Y 1I0 2I1 2Y 2I0 2 3I1 3 5 6 11 10 14 13 3Y 1I0 1I1 2I0 2I1 3I0 3I1 4I0 4I1 3I0 1 S 15 E 4I1 1Y 2Y 3Y 4Y 4 7 9 12 4Y 4I0 Fig 1. Logic diagram mna484 mna481 Fig 2. logic symbol © 74AHC_AHCT157_2 Product data sheet Rev. 02 — 9 November 2007 Nexperia B.V. 2017. All rights reserved 2 of 16 74AHC157; 74AHCT157 Nexperia Quad 2-input multiplexer 1 2 G1 1I0 3 1I1 5 2I0 6 2I1 11 3I0 10 3I1 14 4I0 13 4I1 SELECTOR 1Y 4 2Y 7 15 EN 2 1 3 MULTIPLEXER OUTPUTS 3Y MUX 4 1 5 9 7 6 11 4Y 12 9 10 14 S E 1 15 12 13 mna483 Fig 3. Logic symbol mna482 Fig 4. IEC logic symbol 5. Pinning information 1 S terminal 1 index area 74AHC157 74AHCT157 1I0 2 15 E 1I1 3 14 4I0 2 15 E 1Y 4 1I1 3 14 4I0 2I0 5 1Y 4 13 4I1 2I1 6 2I0 5 12 4Y 2Y 7 2I1 6 11 3I0 2Y 7 10 3I1 GND 8 3Y 13 4I1 157 GND(1) 12 4Y 11 3I0 10 3I1 9 1I0 3Y 16 VCC 8 1 GND S 9 16 VCC 5.1 Pinning 001aac931 Transparent top view 001aah066 (1) The die substrate is attached to this pad using conductive die attach material. It can not be used as a supply pin or input. Fig 5. Pin configuration SO16, TSSOP16 Fig 6. Pin configuration DHVQFN16 © 74AHC_AHCT157_2 Product data sheet Rev. 02 — 9 November 2007 Nexperia B.V. 2017. All rights reserved 3 of 16 74AHC157; 74AHCT157 Nexperia Quad 2-input multiplexer 5.2 Pin description Table 2. Pin description Symbol Pin Description S 1 common data select input 1I0 to 4I0 2, 5, 11, 14 data inputs from source 0 1I1 to 4I1 3, 6, 10, 13 data inputs from source 1 1Y to 4Y 4, 7, 9, 12 multiplexer outputs GND 8 ground (0 V) E 15 enable input (active LOW) VCC 16 supply voltage 6. Functional description Table 3. Function table[1] Input Output E S nI0 nI1 nY H X X X L L L L X L L L H X H L H X L L L H X H H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. © 74AHC_AHCT157_2 Product data sheet Rev. 02 — 9 November 2007 Nexperia B.V. 2017. All rights reserved 4 of 16 74AHC157; 74AHCT157 Nexperia Quad 2-input multiplexer 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage VI input voltage IIK input clamping current VI < −0.5 V [1] IOK output clamping current VO < −0.5 V or VO > VCC + 0.5 V [1] IO output current VO = −0.5 V to (VCC + 0.5 V) Min Max Unit −0.5 +7.0 V −0.5 +7.0 V −20 - mA - ±20 mA - ±25 mA ICC supply current - 75 mA IGND ground current −75 - mA Tstg storage temperature −65 +150 °C Ptot total power dissipation [1] Tamb = −40 °C to +125 °C SO16 package [2] - 500 mW TSSOP16 package [3] - 500 mW DHVQFN16 package [4] - 500 mW The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Ptot derates linearly with 8 mW/K above 70 °C. [3] Ptot derates linearly with 5.5 mW/K above 60 °C. [4] Ptot derates linearly with 4.5 mW/K above 60 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions 74AHC157 74AHCT157 Unit Min Typ Max Min Typ Max 2.0 5.0 5.5 4.5 5.0 5.5 V VI input voltage 0 - 5.5 0 - 5.5 V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature −40 +25 +125 −40 +25 +125 °C ∆t/∆V input transition rise and fall rate VCC = 3.3 V ± 0.3 V - - 100 - - - ns/V VCC = 5.0 V ± 0.5 V - - 20 - - 20 ns/V © 74AHC_AHCT157_2 Product data sheet Rev. 02 — 9 November 2007 Nexperia B.V. 2017. All rights reserved 5 of 16 74AHC157; 74AHCT157 Nexperia Quad 2-input multiplexer 9. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V HIGH-level VI = VIH or VIL output voltage IO = −50 µA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = −50 µA; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = −50 µA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = −4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = −8.0 mA; VCC = 4.5 V For type 74AHC157 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage 3.94 - - 3.8 - 3.70 - V LOW-level VI = VIH or VIL output voltage IO = 50 µA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 µA; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 µA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 µA II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 µA CI input capacitance - 3.0 10 - 10 - 10 pF CO output capacitance - 4.0 - - - - - pF For type 74AHCT157 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = −50 µA 4.4 4.5 - 4.4 - 4.4 - V 3.94 - - 3.8 - 3.70 - V - 0 0.1 - 0.1 - 0.1 V - - 0.36 - 0.44 - 0.55 V IO = −8.0 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 µA IO = 8.0 mA © 74AHC_AHCT157_2 Product data sheet Rev. 02 — 9 November 2007 Nexperia B.V. 2017. All rights reserved 6 of 16 74AHC157; 74AHCT157 Nexperia Quad 2-input multiplexer Table 6. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 °C Conditions VI = 5.5 V or GND; VCC = 0 V to 5.5 V −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max - - 0.1 - 1.0 - 2.0 µA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 µA ∆ICC additional per input pin; supply current VI = VCC − 2.1 V; IO = 0 A; other pins at VCC or GND; VCC = 4.5 V to 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 3 10 - 10 - 10 pF CO output capacitance - 4.0 - - - - - pF 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; For test circuit see Figure 9. Symbol Parameter 25 °C Conditions Min −40 °C to +85 °C Typ[1] Max −40 °C to +125 °C Min Max Min Max Unit For type 74AHC157 tpd propagation nI0, nI1 to nY; see Figure 7 delay VCC = 3.0 V to 3.6 V [2] CL = 15 pF - 4.4 9.7 1.0 11.5 1.0 12.5 ns CL = 50 pF - 6.3 13.2 1.0 15.0 1.0 16.5 ns CL = 15 pF - 3.2 6.4 1.0 7.5 1.0 8.0 ns CL = 50 pF - 4.6 8.4 1.0 9.5 1.0 10.5 ns CL = 15 pF - 4.8 13.6 1.0 16.0 1.0 17.0 ns CL = 50 pF - 6.8 17.1 1.0 19.5 1.0 21.5 ns - 3.6 8.6 1.0 10.0 1.0 11.0 ns - 5.2 10.6 1.0 12.0 1.0 13.5 ns CL = 15 pF - 5.9 13.2 1.0 15.5 1.0 16.5 ns CL = 50 pF - 8.4 16.7 1.0 19.0 1.0 21.0 ns CL = 15 pF - 4.2 8.1 1.0 9.5 1.0 10.5 ns CL = 50 pF - 6.0 10.1 1.0 11.5 1.0 13.0 ns VCC = 4.5 V to 5.5 V S to nY; see Figure 7 [2] VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF E to nY; see Figure 8 [2] VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V © 74AHC_AHCT157_2 Product data sheet Rev. 02 — 9 November 2007 Nexperia B.V. 2017. All rights reserved 7 of 16 74AHC157; 74AHCT157 Nexperia Quad 2-input multiplexer Table 7. Dynamic characteristics …continued GND = 0 V; For test circuit see Figure 9. Symbol Parameter 25 °C Conditions Min CPD power CL = 50 pF; fi = 1 MHz; dissipation VI = GND to VCC capacitance 4 outputs switching via S −40 °C to +85 °C Typ[1] Max −40 °C to +125 °C Min Max Min Max Unit [3] - 31 - - - - - pF - 13 - - - - - pF CL = 15 pF - 3.2 6.4 1.0 7.5 1.0 8.0 ns CL = 50 pF - 4.6 8.7 1.0 9.8 1.0 11.0 ns - 3.7 8.6 1.0 10.0 1.0 11.0 ns - 5.2 10.4 1.0 12.0 1.0 13.0 ns - 4.7 8.1 1.0 9.5 1.0 10.5 ns - 6.7 10.6 1.0 12.0 1.0 13.5 ns - 41 - - - - - pF - 16 - - - - - pF 1 outputs switching via I For type 74AHCT157 tpd propagation nI0, nI1 to nY; see Figure 7 delay VCC = 4.5 V to 5.5 V [2] S to nY; see Figure 7 VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF [2] E to nY; see Figure 8 VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF CPD power CL = 50 pF; fi = 1 MHz; dissipation VI = GND to VCC capacitance 4 outputs switching via S 1 outputs switching via I [3] [1] Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation PD (µW). PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts. © 74AHC_AHCT157_2 Product data sheet Rev. 02 — 9 November 2007 Nexperia B.V. 2017. All rights reserved 8 of 16 74AHC157; 74AHCT157 Nexperia Quad 2-input multiplexer 11. Waveforms VI nI0, nI1, S VM input GND t PHL t PLH VOH VM nY output mna486 VOL Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 7. Propagation delay input (nI0, nI1, S) to output (nYn) VCC VM E input GND t PHL t PLH VOH VM nY output mna485 VOL Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 8. Propagation delay input (E) to output (nY) Table 8. Measurement points Type Input Output VM VM 74AHC157 0.5VCC 0.5VCC 74AHCT157 1.5 V 0.5VCC © 74AHC_AHCT157_2 Product data sheet Rev. 02 — 9 November 2007 Nexperia B.V. 2017. All rights reserved 9 of 16 74AHC157; 74AHCT157 Nexperia Quad 2-input multiplexer VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC PULSE GENERATOR VI VO RL S1 open DUT CL RT 001aad983 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistor S1 = Test selection switch Fig 9. Load circuitry for switching times Table 9. Test data Type Input Load S1 position VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74AHC157 VCC 3.0 ns 15 pF, 50 pF 1 kΩ open GND VCC 74AHCT157 3.0 V 3.0 ns 15 pF, 50 pF 1 kΩ open GND VCC © 74AHC_AHCT157_2 Product data sheet Rev. 02 — 9 November 2007 Nexperia B.V. 2017. All rights reserved 10 of 16 74AHC157; 74AHCT157 Nexperia Quad 2-input multiplexer 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e 0 detail X w M bp 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.16 0.15 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 10. Package outline SOT109-1 (SO16) © 74AHC_AHCT157_2 Product data sheet Rev. 02 — 9 November 2007 Nexperia B.V. 2017. All rights reserved 11 of 16 74AHC157; 74AHCT157 Nexperia Quad 2-input multiplexer TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 E D A X c y HE v M A Z 9 16 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 8 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 11. Package outline SOT403-1 (TSSOP16) © 74AHC_AHCT157_2 Product data sheet Rev. 02 — 9 November 2007 Nexperia B.V. 2017. All rights reserved 12 of 16 74AHC157; 74AHCT157 Nexperia Quad 2-input multiplexer DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 7 y y1 C v M C A B w M C b L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b 1 0.05 0.00 0.30 0.18 mm c D (1) Dh E (1) Eh 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 e 0.5 e1 L v w y y1 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 12. Package outline SOT763-1 (DHVQFN16) © 74AHC_AHCT157_2 Product data sheet Rev. 02 — 9 November 2007 Nexperia B.V. 2017. All rights reserved 13 of 16 74AHC157; 74AHCT157 Nexperia Quad 2-input multiplexer 13. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged-Device Model CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AHC_AHCT157_2 20071109 Product data sheet - 74AHC_AHCT157_1 Modifications: 74AHC_AHCT157_1 • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • Legal texts have been adapted to the new company name where appropriate. Section 3: DHVQFN16 package added. Section 8: derating values added for DHVQFN16 package. Section 12: outline drawing added for DHVQFN16 package. 19990924 Product specification - © 74AHC_AHCT157_2 Product data sheet - Rev. 02 — 9 November 2007 Nexperia B.V. 2017. All rights reserved 14 of 16 74AHC157; 74AHCT157 Nexperia Quad 2-input multiplexer 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 15.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For additional information, please visit: http://www.nexperia.com For sales office addresses, send an email to: salesaddresses@nexperia.com © 74AHC_AHCT157_2 Product data sheet Rev. 02 — 9 November 2007 Nexperia B.V. 2017. All rights reserved 15 of 16 Nexperia 74AHC157; 74AHCT157 Quad 2-input multiplexer 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14 Legal information. . . . . . . . . . . . . . . . . . . . . . . 15 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 09 November 2007
74AHC157PW,118 价格&库存
很抱歉,暂时无法提供与“74AHC157PW,118”相匹配的价格&库存,您可以联系我们找货
74AHC157PW,118
    • 2500+0.795982500+0.09663
    • 7500+0.792267500+0.09618
    • 10000+0.7922410000+0.09618
    • 25000+0.7922325000+0.09618
    • 37500+0.7922137500+0.09617
    74AHC157PW,118
      • 10+1.66971
      74AHC157PW,118
        • 2500+0.791482500+0.09609
        • 7500+0.787797500+0.09564
        • 10000+0.7877710000+0.09563
        • 25000+0.7877525000+0.09563
        • 37500+0.7877337500+0.09563
