74HC151PW-Q100,118
74HC151PW-Q100,118
    NEXPERIA(安世)
    TSSOP16_5X4.4MM
    8输入多路复用器 TSSOP16_5X4.4MM 2~6V
74HC151PW-Q100,118 数据手册
74HC151-Q100; 74HCT151-Q100 8-input multiplexer Rev. 3 — 26 January 2015 Product data sheet 1. General description The 74HC151-Q100; 74HCT151-Q100 are 8-bit multiplexer with eight binary inputs (I0 to I7), three select inputs (S0 to S2) and an enable input (E). One of the eight binary inputs is selected by the select inputs and routed to the complementary outputs (Y and Y). A HIGH on E forces the output Y LOW and output Y HIGH. Inputs also include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Specified in compliance with JEDEC standard no. 7A  Input levels:  For 74HC151-Q100: CMOS level  For 74HCT151-Q100: TTL level  Low-power dissipation  Non-inverting data path  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 3. Ordering information Table 1. Ordering information Type number 74HC151D-Q100 Package Temperature range Name Description 40 C to +125 C SO16 plastic small outline package; 16 leads; body width SOT109-1 3.9 mm 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; SOT403-1 body width 4.4 mm 74HCT151D-Q100 74HC151PW-Q100 74HCT151PW-Q100 Version 74HC151-Q100; 74HCT151-Q100 Nexperia 8-input multiplexer 4. Functional diagram  Fig 1.         , , , , , , , , <  <  ( 6 6 6    DDD Logic symbol , , ,   ,  ,  ,  ,  ,   , , , , 6  6  < , < , 08/7,3/(;(5 6  , , (  < < DDD  Fig 2. Functional diagram 74HC_HCT151_Q100 Product data sheet 6  Fig 3. 6 6 ( DDD Logic diagram All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 2 of 17 74HC151-Q100; 74HCT151-Q100 Nexperia 8-input multiplexer 5. Pinning information 5.1 Pinning +&4 +&74 ,  ,   9&&  , ,   , ,   , <   , <   6 (   6 *1'   6 DDD Fig 4. Pin configuration SO16 and TSSOP16 5.2 Pin description Table 2. Pin description Symbol Pin Description I0 to I7 4, 3, 2, 1, 15, 14, 13, 12 data inputs Y 5 multiplexer output Y 6 complementary multiplexer output E 7 enable input (active LOW) GND 8 ground (0 V) S0, S1, S2 11, 10, 9 common data select inputs VCC 16 supply voltage 74HC_HCT151_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 3 of 17 74HC151-Q100; 74HCT151-Q100 Nexperia 8-input multiplexer 6. Functional description Function table[1] Table 3. Input Output E S2 S1 S0 I0 I1 I2 I3 I4 I5 I6 I7 Y Y H X X X X X X X X X X X H L L L L L L X X X X X X X H L L L L L H X X X X X X X L H L L L H X L X X X X X X H L L L L H X H X X X X X X L H L L H L X X L X X X X X H L L L H L X X H X X X X X L H L L H H X X X L X X X X H L L L H H X X X H X X X X L H L H L L X X X X L X X X H L L H L L X X X X H X X X L H L H L H X X X X X L X X H L L H L H X X X X X H X X L H L H H L X X X X X X L X H L L H H L X X X X X X H X L H L H H H X X X X X X X L H L L H H H X X X X X X X H L H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current IOK Conditions Min Max Unit 0.5 +7 V VI < 0.5 V or VI > VCC + 0.5 V - 20 mA output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA VO = 0.5 V to (VCC + 0.5 V) IO output current - 25 mA ICC supply current - +50 mA IGND ground current - 50 mA Tstg storage temperature 65 +150 C 74HC_HCT151_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 4 of 17 74HC151-Q100; 74HCT151-Q100 Nexperia 8-input multiplexer Table 4. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Ptot total power dissipation Tamb = 40 C to +125 C Min Max Unit SO16 package [1] - 500 mW TSSOP16 package [2] - 500 mW [1] For SO16 package: Ptot derates linearly with 8 mW/K above 70 C. [2] For TSSOP16 package: Ptot derates linearly with 5.5 mW/K above 60 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC151-Q100 74HCT151-Q100 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V input voltage 0 - VCC 0 - VCC V output voltage 0 - VCC 0 - VCC V VCC supply voltage VI VO Tamb ambient temperature t/V input transition rise and fall rate 74HC_HCT151_Q100 Product data sheet 40 +25 +125 40 +25 +125 VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 January 2015 © C Nexperia B.V. 2017. All rights reserved 5 of 17 74HC151-Q100; 74HCT151-Q100 Nexperia 8-input multiplexer 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 25 C Conditions Min Typ VCC = 2.0 V 1.5 VCC = 4.5 V 3.15 VCC = 6.0 V 4.2 VCC = 2.0 V - VCC = 4.5 V - VCC = 6.0 V Tamb = 40 C to +85 C Tamb = 40 C to Unit +125 C Max Min Max Min Max 1.2 - 1.5 - 1.5 - V 2.4 - 3.15 - 3.15 - V 3.2 - 4.2 - 4.2 - V 0.8 0.5 - 0.5 - 0.5 V 2.1 1.35 - 1.35 - 1.35 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V 74HC151-Q100 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 A CI input capacitance - 3.5 - 74HC_HCT151_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 January 2015 pF © Nexperia B.V. 2017. All rights reserved 6 of 17 74HC151-Q100; 74HCT151-Q100 Nexperia 8-input multiplexer Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 25 C Conditions Min Typ Tamb = 40 C to +85 C Tamb = 40 C to Unit +125 C Max Min Max Min Max 74HCT151-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V IO = 4 mA 3.98 4.32 - 3.84 - 3.7 - V IO = 20 A - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA - 0.15 0.26 - 0.33 - 0.4 V VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80 - 160 A ICC additional supply current VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A - 45 162 - 203 - 221 A per input pin; In inputs CI input capacitance 74HC_HCT151_Q100 Product data sheet per input pin; E input - 30 108 - 135 - 147 A per input pin; Sn input - 150 540 - 675 - 735 A - 3.5 - All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 January 2015 pF © Nexperia B.V. 2017. All rights reserved 7 of 17 74HC151-Q100; 74HCT151-Q100 Nexperia 8-input multiplexer 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 7. Symbol Parameter Tamb = 25 C Conditions Tamb = 40 C to +85 C Tamb = 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 52 170 - 215 - 255 ns VCC = 4.5 V - 19 34 - 43 - 51 ns VCC = 5 V; CL = 15 pF - 17 - - - - - ns - 15 29 - 37 - 43 ns 74HC151-Q100 tpd propagation delay In to Y; see Figure 5 [1] VCC = 6.0 V In to Y; see Figure 5 [1] VCC = 2.0 V - 58 185 - 230 - 280 ns VCC = 4.5 V - 21 37 - 46 - 56 ns VCC = 5 V; CL = 15 pF - 17 - - - - - ns - 17 31 - 39 - 48 ns VCC = 2.0 V - 61 185 - 230 - 280 ns VCC = 4.5 V - 22 37 - 46 - 56 ns VCC = 5 V; CL = 15 pF - 19 - - - - - ns - 18 31 - 39 - 48 ns VCC = 2.0 V - 61 205 - 255 - 310 ns VCC = 4.5 V - 22 41 - 51 - 62 ns VCC = 6.0 V Sn to Y; see Figure 6 [1] VCC = 6.0 V Sn to Y; see Figure 6 [1] VCC = 5 V; CL = 15 pF - 19 - - - - - ns VCC = 6.0 V - 18 35 - 43 - 53 ns VCC = 2.0 V - 41 125 - 155 - 190 ns VCC = 4.5 V - 15 25 - 31 - 38 ns VCC = 5 V; CL = 15 pF - 12 - - - - - ns VCC = 6.0 V - 12 21 - 26 - 32 ns E to Y; see Figure 6 E to Y; see Figure 6 VCC = 2.0 V - 47 145 - 180 - 220 ns VCC = 4.5 V - 17 29 - 36 - 44 ns VCC = 5 V; CL = 15 pF - 14 - - - - - ns - 14 25 - 31 - 38 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns VCC = 6.0 V tt transition time 74HC_HCT151_Q100 Product data sheet Y, Y; see Figure 5 [2] All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 8 of 17 74HC151-Q100; 74HCT151-Q100 Nexperia 8-input multiplexer Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 7. Symbol Parameter CPD power dissipation capacitance Tamb = 25 C Conditions Tamb = 40 C to +85 C Tamb = 40 C to +125 C Unit Min Typ Max Min Max Min Max - 40 - - - - - pF - 22 38 - 48 - 57 ns - 19 - - - - - ns VCC = 4.5 V - 22 38 - 48 - 57 ns VCC = 5 V; CL = 15 pF - 19 - - - - - ns - 23 41 - 51 - 62 ns - 20 - - - - - ns - 25 43 - 54 - 65 ns - 20 - - - - - ns - 16 29 - 36 - 44 ns - 13 - - - - - ns VCC = 4.5 V - 21 36 - 45 - 54 ns VCC = 5 V; CL = 15 pF - 18 - - - - - ns - 7 15 - 19 - 22 ns - 40 - - - - - pF CL = 50 pF; f = 1 MHz; VI = GND to VCC [3] In to Y; see Figure 5 [1] 74HCT151-Q100 tpd propagation delay VCC = 4.5 V VCC = 5 V; CL = 15 pF [1] In to Y; see Figure 5 [1] Sn to Y; see Figure 6 VCC = 4.5 V VCC = 5 V; CL = 15 pF [1] Sn to Y; see Figure 6 VCC = 4.5 V VCC = 5 V; CL = 15 pF [1] E to Y; see Figure 6 VCC = 4.5 V VCC = 5 V; CL = 15 pF [1] E to Y; see Figure 6 tt CPD transition time power dissipation capacitance [2] Y, Y; see Figure 5 VCC = 4.5 V [3] CL = 50 pF; f = 1 MHz; VI = GND to VCC  1.5 V [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74HC_HCT151_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 9 of 17 74HC151-Q100; 74HCT151-Q100 Nexperia 8-input multiplexer 11. Waveforms 9, 90 ,QLQSXW 90 *1' W3+/ 92+ W3/+   90
74HC151PW-Q100,118 价格&库存
很抱歉,暂时无法提供与“74HC151PW-Q100,118”相匹配的价格&库存,您可以联系我们找货
74HC151PW-Q100,118
  • 5000+1.79305
  • 10000+1.74921
库存:25000
