74HCT257PW,118
74HCT257PW,118
    NEXPERIA(安世)
    TSSOP16_5X4.4MM
    四路2输入多路复用器;三态 TSSOP16_5X4.4MM 4.5~5.5V
74HCT257PW,118 数据手册
74HC257; 74HCT257 Quad 2-input multiplexer; 3-state Rev. 7 — 2 February 2016 Product data sheet 1. General description The 74HC257; 74HCT257 is a quad 2-input multiplexer with 3-state outputs. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits     Non-inverting data path 3-state outputs interface directly with system bus Complies with JEDEC standard no. 7A Input levels:  For 74HC257: CMOS level  For 74HCT257: TTL level  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74HC257D Package Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74HCT257D 74HC257DB 74HCT257DB 74HC257PW 74HCT257PW 74HC257; 74HCT257 Nexperia Quad 2-input multiplexer; 3-state 4. Functional diagram     ,  ,  ,  ,  ,  ,  ,  ,  2( 6  < <   * (1      <     <     DDG Logic symbol Fig 2.   , ,  6  2( Fig 3.   PJD Fig 1. 08;   , ,  IEC logic symbol  , ,   , , 6(/(&725 67$7(08/7,3/(;(52873876 < < < <     PJU Functional diagram 74HC_HCT257 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 2 February 2016 2 of 17 © Nexperia B.V. 2017. All rights reserved 74HC257; 74HCT257 Nexperia Quad 2-input multiplexer; 3-state , < , , < , , < , , < , 2( 6 Fig 4. DDG Logic diagram 5. Pinning information 5.1 Pinning +& +&7 6   9&& ,   2( ,   , <   , ,   < ,   , <   , *1'   < DDG Fig 5. Pin configuration SO16, SSOP16 and TSSOP16 74HC_HCT257 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 2 February 2016 3 of 17 © Nexperia B.V. 2017. All rights reserved 74HC257; 74HCT257 Nexperia Quad 2-input multiplexer; 3-state 5.2 Pin description Table 2. Pin description Symbol Pin Description S 1 common data select input 1I0 to 4I0 2, 5, 11, 14 data input from source 0 1I1 to 4I1 3, 6, 10, 13 data input from source 1 1Y to 4Y 4, 7, 9, 12 3-state multiplexer output GND 8 ground (0 V) OE 15 3-state output enable input (active LOW) VCC 16 supply voltage 6. Functional description 6.1 Function table Table 3. Function table[1] Control Input OE S H X X X Z L H X L L L H X H H L L L X L L L H X H [1] nl0 Output nl1 nY H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7 V - 20 mA - 20 mA - 35 mA input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current VO = 0.5 V to VCC + 0.5 V ICC supply current - +70 mA IGND ground current 70 - mA Tstg storage temperature Ptot total power dissipation IIK 65 +150 C SO16 package [2] - 500 mW SSOP16 package [3] - 500 mW TSSOP16 package [3] - 500 mW [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO16 packages: above 70 C, Ptot derates linearly with 8 mW/K. [3] For SSOP16 and TSSOP16 packages: above 60 C, Ptot derates linearly with 5.5 mW/K. 74HC_HCT257 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 2 February 2016 4 of 17 © Nexperia B.V. 2017. All rights reserved 74HC257; 74HCT257 Nexperia Quad 2-input multiplexer; 3-state 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit 74HC257 VCC supply voltage 2.0 5.0 6.0 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V t/V input transition rise and fall rates VCC = 2.0 V - - 625 ns VCC = 4.5 V - 1.67 139 ns VCC = 6.0 V - - 83 ns ambient temperature 40 - +125 C Tamb 74HCT257 VCC supply voltage 4.5 5.0 5.5 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V t/V input transition rise and fall rates - 1.67 139 ns Tamb ambient temperature 40 - +125 C VCC = 4.5 V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 6.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 7.8 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V 74HC257 VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 74HC_HCT257 Product data sheet VI = VIH or VIL All information provided in this document is subject to legal disclaimers. . Rev. 7 — 2 February 2016 5 of 17 © Nexperia B.V. 2017. All rights reserved 74HC257; 74HCT257 Nexperia Quad 2-input multiplexer; 3-state Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VOL VI = VIH or VIL LOW-level output voltage 25 C 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1.0 - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - 0.5 - 5.0 - 10.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 A Ci input capacitance - 3.5 - - - - - pF 74HCT257 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V VOL LOW-level output voltage IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V IO = 6 mA 3.98 4.32 - 3.84 - 3.7 - V IO = 20 A - 0 0.1 - 0.33 - 0.4 V IO = 6.0 mA V VI = VIH or VIL; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1.0 - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - - 0.5 - 5.0 - 10 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80 - 160 A ICC additional supply current VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A per input pin; nI0, nI1 inputs - 40 144 - 180 - 196 A per input pin; OE input - 135 486 - 608 - 662 A per input pin; S input - 70 252 - 315 - 343 A - 3.5 - - - - - pF CI input capacitance 74HC_HCT257 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 2 February 2016 6 of 17 © Nexperia B.V. 2017. All rights reserved 74HC257; 74HCT257 Nexperia Quad 2-input multiplexer; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); For test circuit see Figure 8. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to Unit +125 C Typ Max Max Max 74HC257 tpd propagation delay nl0 to nY or nl1 to nY; see Figure 6 [1] VCC = 2.0 V 36 110 140 165 ns VCC = 4.5 V 13 22 28 33 ns VCC = 5.0 V; CL = 15 pF 11 - - - ns VCC = 6.0 V 10 19 24 28 ns VCC = 2.0 V 47 150 190 225 ns VCC = 4.5 V 17 30 38 45 ns VCC = 5.0 V; CL = 15 pF 14 - - - ns 14 26 33 38 ns VCC = 2.0 V 33 150 190 225 ns VCC = 4.5 V 12 30 38 45 ns 10 26 33 38 ns VCC = 2.0 V 41 150 190 225 ns VCC = 4.5 V 15 30 38 45 ns 12 26 33 38 ns VCC = 2.0 V 14 60 75 90 ns VCC = 4.5 V 5 12 15 18 ns S to nY; see Figure 6 VCC = 6.0 V ten enable time OE to nY; see Figure 7 [2] VCC = 6.0 V tdis disable time OE to nY; see Figure 7 [3] VCC = 6.0 V tt transition time [4] see Figure 6 VCC = 6.0 V CPD 4 10 13 15 ns 45 - - - pF VCC = 4.5 V 16 30 38 45 ns VCC = 5.0 V; CL = 15 pF 13 - - - ns VCC = 4.5 V 20 35 44 53 ns VCC = 5.0 V; CL = 15 pF 17 - - - ns OE to nY; VCC = 4.5 V; see Figure 7 [2] 15 30 38 45 ns OE to nY; VCC = 4.5 V; see Figure 7 [3] 16 30 38 45 ns VCC = 4.5 V; see Figure 6 [4] 5 12 15 18 ns power dissipation per multiplexer; VI = GND to VCC capacitance [5] 74HCT257 tpd propagation delay nl0 to nY or nl1 to nY; see Figure 6 [1] S to nY; see Figure 6 ten tdis tt enable time disable time transition time 74HC_HCT257 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 2 February 2016 7 of 17 © Nexperia B.V. 2017. All rights reserved 74HC257; 74HCT257 Nexperia Quad 2-input multiplexer; 3-state Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); For test circuit see Figure 8. Symbol Parameter power dissipation per multiplexer; VI = GND to VCC  1.5 V capacitance CPD [1] 40 C to +85 C 40 C to Unit +125 C Typ Max Max Max 45 - - - [5] pF tpd is the same as tPHL, tPLH. [2] ten is the same as tPZH, tPZL. [3] tdis is the same as tPHZ, tPLZ. [4] tt is the same as tTHL, tTLH. [5] 25 C Conditions CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 11. Waveforms 9, LQSXW 6Q,Q, 90 90 *1' W 3+/ W 3/+ 92+ RXWSXW Q<  90 90  92/ W 7+/ W 7/+ DDG Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. Propagation delays input (S, nI0, nI1) to output (nY) and output (nY) transition times 74HC_HCT257 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 2 February 2016 8 of 17 © Nexperia B.V. 2017. All rights reserved 74HC257; 74HCT257 Nexperia Quad 2-input multiplexer; 3-state WU 9, WI  2(LQSXW 90 *1'  W3/= RXWSXW W3=/ 9&& /2:WR2)) 2))WR/2: 90  92/ W3+= RXWSXW 92+ W3=+  +,*+WR2)) 2))WR+,*+ *1' 90 RXWSXWV HQDEOHG RXWSXWV HQDEOHG RXWSXWV GLVDEOHG DDF Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 7. 3-state output enable and disable times Table 8. Measurement points Type Input Output VM VM 74HC257 0.5VCC 0.5VCC 74HCT257 1.3 V 1.3 V 74HC_HCT257 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 2 February 2016 9 of 17 © Nexperia B.V. 2017. All rights reserved 74HC257; 74HCT257 Nexperia Quad 2-input multiplexer; 3-state 9, W:  QHJDWLYH SXOVH 90 9 WI WU WU WI 9,  SRVLWLYH SXOVH 9 90  90 90  W: 9&& 9&& * 9, 92 5/ 6 RSHQ '87 &/ 57 DDG Measurement points are given in Table 8 and test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. Fig 8. Test circuit for measuring switching times Table 9. Type Test data Input Load Switch position VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74HC257 VCC 6 ns 50 pF 1 k open GND VCC 74HCT257 3V 6 ns 50 pF 1 k open GND VCC 74HC_HCT257 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 2 February 2016 10 of 17 © Nexperia B.V. 2017. All rights reserved 74HC257; 74HCT257 Nexperia Quad 2-input multiplexer; 3-state 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 Fig 9. -(,7$ (8523($1 352-(&7,21 ,668('$7(   Package outline SOT109-1 (SO16) 74HC_HCT257 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 2 February 2016 11 of 17 © Nexperia B.V. 2017. All rights reserved 74HC257; 74HCT257 Nexperia Quad 2-input multiplexer; 3-state 6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S /   GHWDLO; Z 0 ES H   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 10. Package outline SOT338-1 (SSOP16) 74HC_HCT257 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 2 February 2016 12 of 17 © Nexperia B.V. 2017. All rights reserved 74HC257; 74HCT257 Nexperia Quad 2-input multiplexer; 3-state 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 11. Package outline SOT403-1 (TSSOP16) 74HC_HCT257 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 2 February 2016 13 of 17 © Nexperia B.V. 2017. All rights reserved 74HC257; 74HCT257 Nexperia Quad 2-input multiplexer; 3-state 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT257 v.7 20160202 Product data sheet - Modifications: 74HC_HCT257 v.6 Modifications: 74HC_HCT257 v.5 Modifications: • Type numbers 74HC257N and 74HCT257N (SOT38-4) removed. 20150126 • Product data sheet - 74HC_HCT257 v.5 Table 7: Power dissipation capacitance condition for 74HCT257 is corrected. 20100113 • 74HC_HCT257 v.6 Product data sheet - 74HC_HCT257 v.4 - 74HC_HCT257 v.3 Table 7: changed 3OE to OE 74HC_HCT257 v.4 20090608 Product data sheet 74HC_HCT257 v.3 20050920 Product data sheet - 74HC_HCT257_CNV v.2 74HC_HCT257_CNV v.2 19980930 Product specification - - 74HC_HCT257 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 2 February 2016 14 of 17 © Nexperia B.V. 2017. All rights reserved 74HC257; 74HCT257 Nexperia Quad 2-input multiplexer; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT257 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. . Rev. 7 — 2 February 2016 15 of 17 © Nexperia B.V. 2017. All rights reserved 74HC257; 74HCT257 Nexperia Quad 2-input multiplexer; 3-state Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT257 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 2 February 2016 16 of 17 © Nexperia B.V. 2017. All rights reserved Nexperia 74HC257; 74HCT257 Quad 2-input multiplexer; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 6.1 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 4 Function table . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14 Legal information. . . . . . . . . . . . . . . . . . . . . . . 15 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Contact information. . . . . . . . . . . . . . . . . . . . . 16 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 02 February 2016 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC257D,652 74HC257DB,112 74HC257DB,118 74HC257D,653 74HC257N,652 74HC257PW,112 74HC257PW,118 74HCT257D,652 74HCT257DB,112 74HCT257DB,118 74HCT257D,653 74HCT257N,652 74HCT257PW,112 74HCT257PW,118 74HC257D/AUJ 74HCT257D/AUJ
74HCT257PW,118 价格&库存
很抱歉,暂时无法提供与“74HCT257PW,118”相匹配的价格&库存,您可以联系我们找货
