74HC158D,652
74HC158D,652
    NEXPERIA(安世)
    SOIC16_150MIL
    四路2输入多路复用器;反转 SOIC16_150MIL 2~6V
74HC158D,652 数据手册
74HC158 Quad 2-input multiplexer; inverting Rev. 4 — 23 December 2015 Product data sheet 1. General description The 74HC158 is a high-speed Si-gate CMOS device and is pin compatible with low power Schottky TTL (LSTTL). The 74HC158 is specified in compliance with JEDEC standard no. 7A. The 74HC158 is a quad 2-input multiplexer which select 4 bits of data from two sources and are controlled by a common data select input (S). The four outputs present the selected data in the inverted form. The enable input (E) is active LOW. When E is HIGH, all the outputs (1Y to 4Y) are forced HIGH regardless of all other input conditions. Moving the data from two groups of registers to four common output buses is a common use of the 74HC158. The state of S determines the particular register from which the data comes. It can also be used as a function generator. The device is useful for implementing highly irregular logic by generating any four of the 16 different functions of two variables with one variable common. The 74HC158 is the logic implementation of a 4-pole, 2-position switch, where the position of the switch is determined by the logic levels applied to S. The logic equations for the output are: 1Y = E.(1l1.S  1l0.S) 2Y = E.(2l1.S  2l0.S) 3Y = E.(3l1.S  3l0.S) 4Y = E.(4l1.S  4l0.S) The 74HC158 is identical to the 74HC157 but has inverting outputs. 2. Features and benefits Low-power dissipation Inverting data path Complies with JEDEC standard no. 7A ESD protection:  HBM JESD22-A114F exceeds 2 000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from −40° C to +85 °C and −40 °C to +125 °C     74HC158 Nexperia Quad 2-input multiplexer; inverting 3. Ordering information Table 1. Ordering information Type number 74HC158D Package Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 4. Functional diagram 2 3 5 6 11 10 14 13 1I0 1I1 2I0 2I1 3I0 3I1 4I0 4I1 1 S MULTIPLEXER 15 E OUTPUTS 1Y 4 2Y 7 3Y 9 4Y 12 DDE Fig 1. Functional diagram 1 15 1 2 3 5 6 11 10 14 13 15 S 1I0 1I1 2I0 2I1 3I0 3I1 4I0 4I1 1Y 2Y 3Y 4Y 2 4 3 G1 EN 1 5 7 14 74HC158 Product data sheet 12 13 12 11 E Logic symbol 7 6 9 4 1 9 10 DDE Fig 2. MUX DDE Fig 3. IEC logic symbol All information provided in this document is subject to legal disclaimers. . Rev. 4 — 23 December 2015 2 of 16 © Nexperia B.V. 2017. All rights reserved 74HC158 Nexperia Quad 2-input multiplexer; inverting S E 1I0 1Y 1I1 2I0 2Y 2I1 3I0 3Y 3I1 4I0 4Y 4I1 DDE Fig 4. Logic diagram 5. Pinning information 5.1 Pinning S 1 16 VCC 1I0 2 15 E 1I1 3 14 4I0 1Y 4 13 4I1  2I0 5 12 4Y 2I1 6 11 3I0 2Y 7 10 3I1 GND 8 9 3Y DDE Fig 5. Pin configuration 74HC158 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 4 — 23 December 2015 3 of 16 © Nexperia B.V. 2017. All rights reserved 74HC158 Nexperia Quad 2-input multiplexer; inverting 5.2 Pin description Table 2. Pin description Symbol Pin Description S 1 common data select input 1I0 2 data input 1 from source 0 1I1 3 data input 1 from source 1 1Y 4 multiplexer output 1 2I0 5 data input 2 from source 0 2I1 6 data input 2 from source 1 2Y 7 multiplexer output 2 GND 8 ground (0 V) 3Y 9 multiplexer output 3 3I1 10 data input 3 from source 1 3I0 11 data input 3 from source 0 4Y 12 multiplexer output 4 4I1 13 data input 4 from source 1 4I0 14 data input 4 from source 0 E 15 enable input (active LOW) VCC 16 positive supply voltage 6. Functional description 6.1 Function table Table 3. Function[1] Control Input Output E S nI0 nl1 nY H X X X H L L L X H H X L X L H X H L H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 74HC158 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 4 — 23 December 2015 4 of 16 © Nexperia B.V. 2017. All rights reserved 74HC158 Nexperia Quad 2-input multiplexer; inverting 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min VCC supply voltage 0.5 +7 V IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA IO output current VO = 0.5 V to VCC + 0.5 V - 25 mA ICC supply current - +50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation Unit - 500 mW Tamb = 40 C to +125 C [1] SO16 package [1] Max Above 70 C: Ptot derates linearly with 8 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage VI VO Min Typ Max Unit 2.0 5.0 6.0 V input voltage 0 - VCC V output voltage 0 - VCC V Tamb ambient temperature t/V input transition rise and fall rate 74HC158 Product data sheet Conditions 40 - +125 C VCC = 2.0 V - - 625 ns/V VCC = 4.5 V - 1.67 139 ns/V VCC = 6.0 V - - 83 ns/V All information provided in this document is subject to legal disclaimers. . Rev. 4 — 23 December 2015 5 of 16 © Nexperia B.V. 2017. All rights reserved 74HC158 Nexperia Quad 2-input multiplexer; inverting 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit HIGH-level input voltage VCC = 2.0 V 1.5 1.2 - V VCC = 4.5 V 3.15 2.4 - V VCC = 6.0 V 4.2 3.2 - V Tamb = 25 C VIH VIL VOH VOL LOW-level input voltage VCC = 2.0 V - 0.8 0.5 V VCC = 4.5 V - 2.1 1.35 V VCC = 6.0 V - 2.8 1.8 V HIGH-level output voltage VI = VIH or VIL LOW-level output voltage IO = 20 A; VCC = 2.0 V 1.9 2.0 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - V IO = 4 mA; VCC = 4.5 V 3.98 4.32 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - V IO = 20 A; VCC = 2.0 V - 0 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 V IO =4 mA; VCC = 4.5 V - 0.15 0.26 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 V - 0.1 A VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - ICC supply current VI = VCC or GND; IO =0 A; VCC = 6.0 V - - 8.0 A CI input capacitance - 3.5 - pF VCC = 2.0 V 1.5 - - V Tamb = 40 C to +85 C VIH VIL VOH HIGH-level input voltage LOW-level input voltage VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 - - V IO = 20 A; VCC = 4.5 V 4.4 - - V IO = 20 A; VCC = 6.0 V 5.9 - - V IO = 4 mA; VCC = 4.5 V 3.84 - - V IO = 5.2 mA; VCC = 6.0 V 5.34 - - V HIGH-level output voltage VI = VIH or VIL 74HC158 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 4 — 23 December 2015 6 of 16 © Nexperia B.V. 2017. All rights reserved 74HC158 Nexperia Quad 2-input multiplexer; inverting Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VOL LOW-level output voltage VI = VIH or VIL Min Typ Max Unit IO = 20 A; VCC = 2.0 V - - 0.1 V IO = 20 A; VCC = 4.5 V - - 0.1 V IO = 20 A; VCC = 6.0 V - - 0.1 V IO =4 mA; VCC = 4.5 V - - 0.33 V IO = 5.2 mA; VCC = 6.0 V - - 0.33 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 A ICC supply current VI = VCC or GND; IO =0 A; VCC = 6.0 V - - 80 A VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 - - V IO = 20 A; VCC = 4.5 V 4.4 - - V IO = 20 A; VCC = 6.0 V 5.9 - - V IO = 4 mA; VCC = 4.5 V 3.7 - - V IO = 5.2 mA; VCC = 6.0 V 5.2 - - V IO = 20 A; VCC = 2.0 V - - 0.1 V IO = 20 A; VCC = 4.5 V - - 0.1 V IO = 20 A; VCC = 6.0 V - - 0.1 V IO =4 mA; VCC = 4.5 V - - 0.4 V IO = 5.2 mA; VCC = 6.0 V - - 0.4 V Tamb = 40 C to +125 C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VI = VIH or VIL LOW-level output voltage VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 A ICC supply current VI = VCC or GND; IO =0 A; VCC = 6.0 V - - 160 A 74HC158 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 4 — 23 December 2015 7 of 16 © Nexperia B.V. 2017. All rights reserved 74HC158 Nexperia Quad 2-input multiplexer; inverting 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; tr = tf = 6 ns; CL = 50 pF; for test circuit see Figure 8. Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V - 41 125 ns VCC = 4.5 V - 15 25 ns VCC = 6.0 V - 12 21 ns VCC =5.0 V; CL = 15 pF - 12 - ns VCC = 2.0 V - 47 145 ns VCC = 4.5 V - 17 29 ns VCC = 6.0 V - 14 25 ns - 14 - ns Tamb = 25 C tpd propagation delay nI0, nI1 to nY; see Figure 6 E to nY; see Figure 7 [1] [1] VCC =5.0 V; CL = 15 pF S to nY; see Figure 6 [1] VCC = 2.0 V - 47 145 ns VCC = 4.5 V - 17 29 ns VCC = 6.0 V - 14 25 ns - 14 - ns VCC = 2.0 V - 19 75 ns VCC = 4.5 V - 7 15 ns - 6 13 ns - 40 - pF VCC = 2.0 V - - 155 ns VCC = 4.5 V - - 31 ns VCC = 6.0 V - - 26 ns VCC = 2.0 V - - 180 ns VCC = 4.5 V - - 36 ns VCC = 6.0 V - - 31 ns VCC = 2.0 V - - 180 ns VCC = 4.5 V - - 36 ns VCC = 6.0 V - - 31 ns VCC = 2.0 V - - 95 ns VCC = 4.5 V - - 19 ns VCC = 6.0 V - - 16 ns VCC =5.0 V; CL = 15 pF tt transition time see Figure 6 and 7 [2] VCC = 6.0 V CPD power dissipation capacitance per multiplexer; VI = GND to VCC [3] nI0, nI1 to nY; see Figure 6 [1] Tamb = 40 C to +85 C tpd propagation delay E to nY; see Figure 7 S to nY; see Figure 6 tt transition time 74HC158 Product data sheet see Figure 6 and 7 [1] [1] [2] All information provided in this document is subject to legal disclaimers. . Rev. 4 — 23 December 2015 8 of 16 © Nexperia B.V. 2017. All rights reserved 74HC158 Nexperia Quad 2-input multiplexer; inverting Table 7. Dynamic characteristics …continued GND = 0 V; tr = tf = 6 ns; CL = 50 pF; for test circuit see Figure 8. Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V - - 190 ns VCC = 4.5 V - - 38 ns - - 32 ns VCC = 2.0 V - - 220 ns VCC = 4.5 V - - 44 ns - - 38 ns VCC = 2.0 V - - 220 ns VCC = 4.5 V - - 44 ns - - 38 ns VCC = 2.0 V - - 110 ns VCC = 4.5 V - - 22 ns VCC = 6.0 V - - 19 ns Tamb = 40 C to +125 C propagation delay tpd nI0, nI1 to nY; see Figure 6 [1] VCC = 6.0 V E to nY; see Figure 7 [1] VCC = 6.0 V S to nY; see Figure 6 [1] VCC = 6.0 V transition time tt [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] see Figure 6 and 7 [2] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74HC158 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 4 — 23 December 2015 9 of 16 © Nexperia B.V. 2017. All rights reserved 74HC158 Nexperia Quad 2-input multiplexer; inverting 11. Waveforms nI0, nI1, S input VM tPHL nY output tPLH VM tTHL tTLH DDE VM = 0.5VCC. Fig 6. Waveforms showing the data input (nI0, nI1) to output (nY) propagation delays and the output transition times E input VM tPHL nY output tPLH VM tTHL tTLH DDE VM = 0.5VCC. Fig 7. Waveforms showing the enable input (E) to output (nY) propagation delays and the output transition times 74HC158 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 4 — 23 December 2015 10 of 16 © Nexperia B.V. 2017. All rights reserved 74HC158 Nexperia Quad 2-input multiplexer; inverting VI negative pulse VM VI GND VM 10 % GND positive pulse tW 90 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL DDK  Test data is given in Table 8. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig 8. Table 8. Test circuit for measuring switching times Test data Type 74HC158 74HC158 Product data sheet Input Load VI tr, tf CL VCC 6.0 ns 15 pF, 50 pF Test tPLH, tPHL All information provided in this document is subject to legal disclaimers. . Rev. 4 — 23 December 2015 11 of 16 © Nexperia B.V. 2017. All rights reserved 74HC158 Nexperia Quad 2-input multiplexer; inverting 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ 8o 0o 1RWH 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 9. 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& SOT109-1 076E07 MS-012 -(,7$ (8523($1 352-(&7,21 ,668('$7( 99-12-27 03-02-19 Package outline SOT109-1 (SO16) 74HC158 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 4 — 23 December 2015 12 of 16 © Nexperia B.V. 2017. All rights reserved 74HC158 Nexperia Quad 2-input multiplexer; inverting 13. Abbreviations Table 9. Abbreviations Acronym Abbreviation CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model LSTTL Low-power Schottky Transistor-Transistor Logic MM Machine Model 14. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC158 v.4 20151223 Product data sheet - 74HC158 v.3 Modifications: 74HC158 v.3 Modifications: • Type number 74HC158N (SOT38-4) removed. 20041112 Product data sheet - 74HC_HCT158_CNV v.2 • The format of this data sheet has been redesigned to comply with the current presentation and information standard of Philips Semiconductors. • • Removed type number 74HCT158. Inserted family specification. 74HC_HCT158_CNV v.2 19970827 Product specification - 74HC_HCT158 v.1 74HC_HCT158 v.1 19901201 Product specification - - 74HC158 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 4 — 23 December 2015 13 of 16 © Nexperia B.V. 2017. All rights reserved 74HC158 Nexperia Quad 2-input multiplexer; inverting 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC158 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. . Rev. 4 — 23 December 2015 14 of 16 © Nexperia B.V. 2017. All rights reserved 74HC158 Nexperia Quad 2-input multiplexer; inverting Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC158 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 4 — 23 December 2015 15 of 16 © Nexperia B.V. 2017. All rights reserved Nexperia 74HC158 Quad 2-input multiplexer; inverting 17. Contents 1 2 3 4 5 5.1 5.2 6 6.1 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 4 Function table . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 23 December 2015 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC158D,652 74HC158D,653
74HC158D,652 价格&库存
很抱歉,暂时无法提供与“74HC158D,652”相匹配的价格&库存,您可以联系我们找货
