74LV138PW,112
74LV138PW,112
    NEXPERIA(安世)
    TSSOP16_5X4.4MM
    3到8线解码器/解复用器;反转 TSSOP16_5X4.4MM 1~5.5V
74LV138PW,112 数据手册
74LV138 3-to-8 line decoder/demultiplexer; inverting Rev. 5 — 5 February 2018 1 Product data sheet General description The 74LV138 is a low-voltage Si-gate CMOS device that is pin and function compatible with 74HC138 and 74HCT138. The 74LV138 is a 3-to-8 line decoder/demultiplexer. It accepts three binary weighted address inputs (A0, A1 and A2) and, when enabled, provides eight mutually exclusive active LOW outputs (Y0 to Y7). There are three enable inputs: two active LOW (E1 and E2) and one active HIGH (E3). Every output will be HIGH unless E1 and E2 are LOW and E3 is HIGH. This multiple enable function allows easy parallel expansion of the device to a 1-of-32 (5 lines to 32 lines) decoder with just four 74LV138 devices and one inverter. The 74LV138 can be used as an eight output demultiplexer by using one of the active LOW enable inputs as the data input and the remaining enable inputs as strobes. Unused enable inputs must be permanently tied to their appropriate active HIGH or LOW state. 2 Features and benefits • • • • • • • • • • • • Wide operating voltage: 1.0 V to 5.5 V Optimized for low voltage applications: 1.0 V to 3.6 V Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V Typical output ground bounce < 0.8 V at VCC = 3.3 V and Tamb = 25 °C Typical HIGH-level output voltage (VOH) undershoot: > 2 V at VCC = 3.3 V and Tamb = 25 °C Demultiplexing capability Multiple input enable for easy expansion Ideal for memory chip select decoding Active LOW mutually exclusive outputs ESD protection: – HBM JESD22-A114E exceeds 2000 V – MM JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +85 °C and from -40 °C to +125 °C 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LV138D -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74LV138DB -40 °C to +125 °C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 74LV138PW -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74LV138BQ -40 °C to +125 °C DHVQFN16 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5 x 3.5 x 0.85 mm 4 SOT763-1 Functional diagram DX 1 1 A0 Y0 15 2 A1 Y1 14 3 A2 Y2 13 4 5 6 Y3 12 E1 Y4 11 E2 Y5 10 E3 Y6 9 Y7 7 0 1 2 3 0 G 0 7 2 2 3 4 4 & 5 5 6 6 7 X/Y 15 14 1 13 2 12 3 1 1 2 2 4 3 11 4 10 4 9 5 7 0 6 & 5 EN 6 7 15 14 13 12 11 10 9 7 mna371 (a) mna370 Figure 1.  Logic symbol (b) Figure 2.  IEC logic symbol Y0 15 1 A0 Y1 14 2 A1 Y2 13 3 A2 Y3 12 Y4 11 Y5 10 Y6 9 Y7 7 4 E1 5 E2 6 E3 3-to-8 DECODER ENABLE EXITING mna372 Figure 3.  Functional diagram 74LV138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 5 February 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 17 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 5 Pinning information 5.1 Pinning 1 A0 terminal 1 index area A1 2 15 Y0 A2 3 14 Y1 E1 4 13 Y2 5 2 15 Y0 E3 6 Y7 7 3 14 Y1 E1 4 E2 5 E3 6 11 Y4 Y7 7 10 Y5 GND 8 138 13 Y2 12 Y3 9 12 Y3 VCC(1) 11 Y4 10 Y5 9 E2 A1 8 16 VCC Y6 1 GND A0 A2 16 VCC 74LV138 001aah106 Transparent top view (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad.However, if it is soldered, the solder land should remain floating or be connected to VCC. Y6 001aad033 Figure 4.  Pin configuration SO16 and (T)SSOP16 Figure 5.  Pin configuration DHVQFN16 5.2 Pin description Table 2. Pin description Symbol Pin Description A0 1 address input A1 2 address input A2 3 address input E1 4 enable input (active LOW) E2 5 enable input (active LOW) E3 6 enable input (active HIGH) GND 8 ground (0 V) Y0 to Y7 15, 14, 13, 12, 11, 10, 9, 7 output VCC 16 supply voltage 74LV138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 5 February 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 17 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 6 Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care Input Output E1 E2 E3 A0 A1 A2 Y0 Y1 Y2 Y3 Y4 Y5 Y6 Y7 H X X X X X H H H H H H H H X H X X X X H H H H H H H H X X L X X X H H H H H H H H L L H L L L L H H H H H H H L L H H L L H L H H H H H H L L H L H L H H L H H H H H L L H H H L H H H L H H H H L L H L L H H H H H L H H H L L H H L H H H H H H L H H L L H L H H H H H H H H L H L L H H H H H H H H H H H L 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current Conditions Min Max Unit -0.5 +7.0 V VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA [1] - ±50 mA - ±25 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V IO output current VO = -0.5 V to (VCC + 0.5 V) ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation [1] [2] [3] [4] Tamb = -40 °C to +125 °C SO16 package [2] - 500 mW (T)SSOP16 package [3] - 500 mW DHVQFN16 package [4] - 500 mW The input and output voltage ratings may be exceeded if the input and output current ratings are observed. Ptot derates linearly with 8 mW/K above 70 °C. Ptot derates linearly with 5.5 mW/K above 60 °C. Ptot derates linearly with 4.5 mW/K above 60 °C. 74LV138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 5 February 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 17 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 8 Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions [1] Min Typ Max Unit 1.0 3.3 5.5 V VCC supply voltage VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 1.0 V to 2.0 V - - 500 ns/V VCC = 2.0 V to 2.7 V - - 200 ns/V VCC = 2.7 V to 3.6 V - - 100 ns/V VCC = 3.6 V to 5.5 V - - 50 ns/V [1] The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V, but LV devices are guaranteed to function down to VCC = 1.0 V (with input levels GND or VCC). 9 Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 74LV138 Product data sheet Conditions -40 °C to +85 °C [1] Min Typ VCC = 1.2 V 0.9 VCC = 2.0 V -40 °C to +125 °C Unit Max Min Max - - 0.9 - V 1.4 - - 1.4 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.7VCC - - 0.7VCC - V VCC = 1.2 V - - 0.3 - 0.3 V VCC = 2.0 V - - 0.6 - 0.6 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3VCC - lO = -100 μA; VCC = 1.2 V - 1.2 - - - V lO = -100 μA; VCC = 2.0 V 1.8 2.0 - 1.8 - V lO = -100 μA; VCC = 2.7 V 2.5 2.7 - 2.5 - V lO = -100 μA; VCC = 3.0 V 2.8 3.0 - 2.8 - V lO = -100 μA; VCC = 4.5 V 4.3 4.5 - 4.3 - V lO = -6 mA; VCC = 3.0 V 2.4 2.82 - 2.2 - V lO = -12 mA; VCC = 4.5 V 3.6 4.2 - 3.5 - V 0.3VCC V VI = VIH or VIL All information provided in this document is subject to legal disclaimers. Rev. 5 — 5 February 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 17 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting Symbol Parameter Conditions -40 °C to +85 °C Min VOL LOW-level output voltage [1] Typ -40 °C to +125 °C Unit Max Min Max VI = VIH or VIL IO = 100 μA; VCC = 1.2 V - 0 - - - V IO = 100 μA; VCC = 2.0 V - 0 0.2 - 0.2 V IO = 100 μA; VCC = 2.7 V - 0 0.2 - 0.2 V IO = 100 μA; VCC = 3.0 V - 0 0.2 - 0.2 V IO = 100 μA; VCC = 4.5 V - 0 0.2 - 0.2 V IO = 6 mA; VCC = 3.0 V - 0.25 0.40 - 0.50 V IO = 12 mA; VCC = 4.5 V - 0.35 0.55 - 0.65 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 - 1.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 20.0 - 160 μA ΔICC additional supply current per input; VI = VCC - 0.6 V; VCC = 2.7 V to 3.6 V - - 500 - 850 μA CI input capacitance - 3.5 - - - pF [1] Typical values are measured at Tamb = 25 °C. 74LV138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 5 February 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 17 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 10 Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; For test circuit see Figure 8. Symbol Parameter Conditions -40 °C to +85 °C Min tpd propagation delay An to Yn; see Figure 6 [1] Typ -40 °C to +125 °C Max Min Max Unit [2] VCC = 1.2 V - 75 - - - ns VCC = 2.0 V - 26 44 - 55 ns VCC = 2.7 V - 19 31 - 39 ns VCC = 3.0 V to 3.6 V; CL = 15 pF [3] - 12 - - - ns VCC = 3.0 V to 3.6 V [3] - 15 26 - 32 ns - - 17 - 22 ns VCC = 1.2 V - 75 - - - ns VCC = 2.0 V - 26 43 - 53 ns VCC = 4.5 V to 5.5 V E3, En to Yn; see Figure 6 and Figure 7 VCC = 2.7 V - 19 30 - 38 ns VCC = 3.0 V to 3.6 V; CL = 15 pF [3] - 14 - - - ns VCC = 3.0 V to 3.6 V [3] - 15 25 - 31 ns - - 19 - 24 ns - 45 - - - pF VCC = 4.5 V to 5.5 V CPD power dissipation capacitance [1] [2] [3] [4] CL = 50 pF; fi = 1 MHz; VI = GND to VCC [4] All typical values are measured at Tamb = 25 °C. tpd is the same as tPLH and tPHL. Typical values are measured at nominal supply voltage (VCC = 3.3 V). CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz, fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in V N = number of inputs switching 2 Σ(CL x VCC x fo) = sum of the outputs. 74LV138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 5 February 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 17 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 11 Waveforms and test circuit VCC An, E3 input VM GND tPHL tPLH VOH Yn output VM VOL 001aah080 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 6.  The inputs An, E3 to outputs Yn propagation delays VCC E1, E2 input VM GND tPHL tPLH VOH Yn output VM VOL 001aah081 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 7.  The inputs En to outputs Yn propagation delays Table 8. Measurement points Supply voltage Input Output VCC VM VM < 2.7 V 0.5VCC 0.5VCC 2.7 V to 3.6 V 1.5 V 1.5 V ≥ 4.5 V 0.5VCC 0.5VCC 74LV138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 5 February 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 17 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting VCC PULSE GENERATOR VI VO DUT RT CL 50 pF RL 1 kΩ 001aaa663 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. RL = Load resistance. CL = Load capacitance including jig and probe capacitance. Figure 8.  Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr, tf < 2.7 V VCC ≤ 2.5 ns 2.7 V to 3.6 V 2.7 V ≤ 2.5 ns ≥ 4.5 V VCC ≤ 2.5 ns 74LV138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 5 February 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 17 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 12 Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 9.  Package outline SOT109-1 (SO16) 74LV138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 5 February 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 17 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm D SOT338-1 E A X c y HE v M A Z 9 16 Q A2 A (A 3) A1 pin 1 index θ Lp L 8 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.00 0.55 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT338-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Figure 10.  Package outline SOT338-1 (SSOP16) 74LV138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 5 February 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 17 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Figure 11.  Package outline SOT403-1 (TSSOP16) 74LV138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 5 February 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 17 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm B D A A E A1 c detail X terminal 1 index area terminal 1 index area C e1 e b 2 y y1 C v M C A B w M C 7 L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 0.5 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Figure 12.  Package outline SOT763-1 (DHVQFN16) 74LV138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 5 February 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 17 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 13 Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LV138 v.5 20180205 Product data sheet - 74LV138 v.4 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74LV138 v.4 20160304 Modifications: • Type number 74LV138N (SOT38-4) removed. 74LV138 v.3 20071115 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. • Section 3: DHVQFN16 package added. • Section 7: derating values added for DHVQFN16 package. • Figure 12: outline drawing added for DHVQFN16 package. 74LV138 v.2 19980428 Product specification - 74LV138 v.1 74LV138 v.1 19970203 Product specification - - 74LV138 Product data sheet Product data sheet Product data sheet - 74LV138 v.3 - 74LV138 v.2 All information provided in this document is subject to legal disclaimers. Rev. 5 — 5 February 2018 © Nexperia B.V. 2018. All rights reserved. 14 / 17 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74LV138 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 5 — 5 February 2018 © Nexperia B.V. 2018. All rights reserved. 15 / 17 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74LV138 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 5 — 5 February 2018 © Nexperia B.V. 2018. All rights reserved. 16 / 17 74LV138 Nexperia 3-to-8 line decoder/demultiplexer; inverting Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................4 Limiting values .................................................... 4 Recommended operating conditions ................ 5 Static characteristics .......................................... 5 Dynamic characteristics .....................................7 Waveforms and test circuit ................................ 8 Package outline .................................................10 Abbreviations .................................................... 14 Revision history ................................................ 14 Legal information .............................................. 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 5 February 2018 Document identifier: 74LV138 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LV138BQ,115 74LV138D,112 74LV138DB,112 74LV138DB,118 74LV138D,118 74LV138N,112 74LV138PW,112 74LV138PW,118 74LV138PW/AUJ
74LV138PW,112 价格&库存
很抱歉,暂时无法提供与“74LV138PW,112”相匹配的价格&库存,您可以联系我们找货
