74LVC1G19
1-of-2 decoder/demultiplexer
Rev. 8 — 2 December 2016
Product data sheet
1. General description
The 74LVC1G19 is a 1-of-2 decoder/demultiplexer with a common output enable. This
device buffers the data on input A and passes it to the outputs 1Y (true) and 2Y
(complement) when the enable (E) input signal is LOW.
Inputs can be driven from either 3.3 V or 5 V devices. These features allow the use of
these devices in a mixed 3.3 V and 5 V environment.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the device
when it is powered down.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant inputs for interfacing with 5 V logic
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8B/JESD36 (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C.
74LVC1G19
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC1G19GW
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74LVC1G19GV
40 C to +125 C
TSOP6
plastic surface-mounted package (TSOP6); 6 leads
SOT457
74LVC1G19GM
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74LVC1G19GF
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT891
6 terminals; body 1 1 0.5 mm
74LVC1G19GN
40 C to +125 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74LVC1G19GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74LVC1G19GW
VY
74LVC1G19GV
V19
74LVC1G19GM
VY
74LVC1G19GF
VY
74LVC1G19GN
VY
74LVC1G19GS
VY
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
PQE
Fig 1.
Logic symbol
74LVC1G19
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 18
74LVC1G19
Nexperia
6. Pinning information
6.1 Pinning
/9&*
/9&*
*1'
9&&
*1'
9&&
*1'
9&&
DDE
DDI
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
DDE
Fig 2.
/9&*
Pin configuration SOT363
and SOT457
Fig 3.
Pin configuration SOT886
Fig 4.
Pin configuration SOT891,
SOT1115 and SOT1202
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
A
1
data input
GND
2
ground (0 V)
E
3
enable input (active LOW)
2Y
4
data output
VCC
5
supply voltage
1Y
6
data output
7. Functional description
Table 4.
Function table[1]
Input
Output
E
A
1Y
2Y
L
L
L
H
L
H
H
L
H
X
H
H
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care
74LVC1G19
Product data sheet
3 of 18
74LVC1G19
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VI < 0 V
[1]
IO
output current
ICC
supply current
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
Min
Max
Unit
0.5
+6.5
V
50
0.5
+6.5
V
mA
mA
50
Active mode
[1][2]
0.5
VCC + 0.5
V
Power-down mode
[1][2]
0.5
+6.5
V
50
mA
100
mA
100
mA
250
mW
65
+150
C
VO > VCC or VO < 0 V
output voltage
VO
[1]
Conditions
VO = 0 V to VCC
Tamb = 40 C to +125 C
[3]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
For SC-88 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 package: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
t/V
input transition rise and fall rate
74LVC1G19
Product data sheet
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
40
+125
C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
4 of 18
74LVC1G19
Nexperia
10. Static characteristics
Table 7.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ[1]
Max
Unit
Tamb = 40 C to +85 C
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
0.65 VCC
V
VCC = 2.3 V to 2.7 V
1.7
V
VCC = 2.7 V to 3.6 V
2.0
V
VCC = 4.5 V to 5.5 V
0.7 VCC
V
VCC = 1.65 V to 1.95 V
0.7
V
0.8
V
0.3 VCC
V
VCC 0.1
V
IO = 4 mA; VCC = 1.65 V
1.2
1.54
V
IO = 8 mA; VCC = 2.3 V
1.9
2.15
V
IO = 12 mA; VCC = 2.7 V
2.2
2.50
V
IO = 24 mA; VCC = 3.0 V
2.3
2.62
V
IO = 32 mA; VCC = 4.5 V
3.8
4.11
V
VI = VIH or VIL
IO = 100 A; VCC = 1.65 V to 5.5 V
VOL
LOW-level output voltage
0.35 VCC V
VI = VIH or VIL
0.10
V
0.07
0.45
V
0.12
0.30
V
0.17
0.40
V
0.33
0.55
V
0.39
0.55
V
II
input leakage current
VI = 5.5 V or GND; VCC = 0 V to 5.5 V
0.1
1
A
IOFF
power-off leakage current
VCC = 0 V; VI or VO = 5.5 V
0.1
2
A
ICC
supply current
VI = 5.5 V or GND;
VCC = 1.65 V to 5.5 V; IO = 0 A
0.1
4
A
ICC
additional supply current
per pin; VCC = 2.3 V to 5.5 V;
VI = VCC 0.6 V; IO = 0 A
5
500
A
CI
input capacitance
VCC = 3.3 V; VI = GND to VCC
2.5
pF
74LVC1G19
Product data sheet
5 of 18
74LVC1G19
Nexperia
Table 7.
Static characteristics …continued
Symbol Parameter
Conditions
Min
Typ[1]
Max
0.65 VCC
V
Unit
VIH
VIL
VOH
1.7
V
2.0
V
0.7 VCC
V
0.7
V
0.8
V
0.3 VCC
V
VI = VIH or VIL
VOL
0.35 VCC V
VCC 0.1
V
0.95
V
1.7
V
1.9
V
2.0
V
3.4
V
0.10
V
VI = VIH or VIL
0.70
V
0.45
V
0.60
V
0.80
V
0.80
V
II
1
A
IOFF
2
A
ICC
supply current
VI = 5.5 V or GND;
4
A
ICC
500
A
[1]
All typical values are measured at VCC = 3.3 V and Tamb = 25 C.
74LVC1G19
Product data sheet
6 of 18
74LVC1G19
Nexperia
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 6.
Symbol Parameter
40 C to +85 C
Conditions
power dissipation
capacitance
CPD
Unit
Min
Max
Min
Max
1.0
4.0
10.5
1.0
13.1
ns
0.5
2.5
6.2
0.5
7.7
ns
VCC = 2.7 V
1.0
2.8
6.5
1.0
8.1
ns
VCC = 3.0 V to 3.6 V
0.5
2.5
5.2
0.5
6.0
ns
0.5
1.8
3.9
0.5
5.0
ns
18.9
pF
[2]
propagation delay A, E to nY; see Figure 5
tpd
40 C to +125 C
Typ[1]
[3]
VI = GND to VCC; VCC = 3.3 V
[1]
Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
12. AC waveforms
9,
90
$(LQSXW
90
*1'
W 3+/
W 3/+
92+
Q
很抱歉,暂时无法提供与“74LVC1G19GW,125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+0.479683000+0.05819
- 9000+0.313749000+0.03806
- 24000+0.3110224000+0.03773
- 45000+0.3019545000+0.03663
- 国内价格 香港价格
- 3000+0.297013000+0.03603
- 9000+0.295639000+0.03587
- 15000+0.2956215000+0.03587
- 60000+0.2956160000+0.03586
- 90000+0.2956190000+0.03586
- 国内价格 香港价格
- 3000+0.549423000+0.06665
- 6000+0.494466000+0.05999
- 15000+0.4395215000+0.05332
- 30000+0.4120530000+0.04999
- 75000+0.3653575000+0.04433
- 150000+0.35162150000+0.04266
- 国内价格 香港价格
- 1+2.978851+0.36137
- 10+2.1983310+0.26669
- 25+1.9222425+0.23319
- 100+1.24406100+0.15092
- 250+1.03000250+0.12495
- 500+0.82412500+0.09998
- 1000+0.631811000+0.07665
