HEF4555BT,653
HEF4555BT,653
    NEXPERIA(安世)
    SO-16_9.9X3.9MM
    1/4解码器/多路分解器 SO16_150MIL 3~15V
HEF4555BT,653 数据手册
HEF4555B 1-of-4 decoder/demultiplexer Rev. 7 — 15 October 2018 Product data sheet 1. General description The HEF4555B contains two 1-of-4 decoders/demultiplexers. Each has two address inputs (nA0 and nA1, an active LOW enable input (nE) and four mutually exclusive outputs which are active HIGH (nY0 to nY3). When used as a decoder, nE when HIGH, forces nY0 to nY3 LOW. When used as a demultiplexer, the appropriate output is selected by the information on nA0 and nA1 with nE as data input. All unselected outputs are LOW. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2. Features and benefits • • • • • Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from -40 °C to +85 °C Complies with JEDEC standard JESD 13-B 3. Applications • • • Code conversion Address decoding Demultiplexing: when using the enable input as data input 4. Ordering information Table 1. Ordering information All types operate from -40 °C to +85 °C. Type number HEF4555BT Package Name Description Version SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4555B Nexperia 1-of-4 decoder/demultiplexer 5. Functional diagram 1Y0 4 2 1A0 nY0 1Y1 5 DECODER 3 1A1 1Y2 6 nA0 1Y3 7 nY1 1 1E 2Y0 12 14 2A0 nA1 2Y1 11 DECODER 13 2A1 nY2 2Y2 10 2Y3 9 nE 15 2E nY3 001aae751 Fig. 1. 001aae753 Functional diagram Fig. 2. Logic diagram for one decoder/multiplexer 6. Pinning information 6.1. Pinning HEF4555B 1E 1 16 VDD 1A0 2 15 2E 1A1 3 14 2A0 1Y0 4 13 2A1 1Y1 5 12 2Y0 1Y2 6 11 2Y1 1Y3 7 10 2Y2 VSS 8 9 2Y3 001aae752 Fig. 3. Pin configuration SOT109-1 (SO16) 6.2. Pin description Table 2. Pin description Symbol Pin Description 1A0, 1A1, 2A0, 2A1 2, 3, 14, 13 address input 1E, 2E 1, 15 enable input (active LOW 1Y0, 1Y1, 1Y2, 1Y3, 2Y0, 2Y1, 2Y2, 2Y3 4, 5, 6, 7, 12, 11, 10, 9 output (active HIGH) VDD 16 supply voltage VSS 8 ground (GND) HEF4555B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 2 / 10 HEF4555B Nexperia 1-of-4 decoder/demultiplexer 7. Functional description Table 3. Function selection H = HIGH voltage level; L = LOW voltage level; X = don’t care. Inputs Outputs nE nA0 nA1 nY0 nY1 nY2 nY3 L L L H L L L L H L L H L L L L H L L H L L H H L L L H H X X L L L L 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O input/output current IDD supply current Tstg Min Max Unit -0.5 +18 V - ±10 mA -0.5 VDD + 0.5 - ±10 mA - ±10 mA - 50 mA storage temperature -65 +150 °C Tamb ambient temperature -40 +85 °C Ptot total power dissipation SO16 package - 500 mW P power dissipation per output - 100 mW [1] Conditions VI < -0.5 V or VI > VDD + 0.5 V VO < -0.5 V or VO > VDD + 0.5 V [1] V For SO16 package: Ptot derates linearly with 8 mW/K above 70 °C. 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VDD supply voltage 3 - 15 V VI input voltage 0 - VDD V Tamb ambient temperature in free air -40 - +85 °C Δt/ΔV input transition rise and fall rate VDD = 5 V - - 3.75 μs/V VDD = 10 V - - 0.5 μs/V VDD = 15 V - - 0.08 μs/V HEF4555B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 3 / 10 HEF4555B Nexperia 1-of-4 decoder/demultiplexer 10. Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol Parameter VIH VIL VOH VOL IOH IOL HIGH-level input voltage LOW-level input voltage Conditions |IO| < 1 μA |IO| < 1 μA; VI = VSS or VDD Tamb = -40 °C Tamb = 25 °C Tamb = 85 °C Unit Min Max Min Max Min Max 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 V 5V |IO| < 1 μA HIGH-level output voltage |IO| < 1 μA; VI = VSS or VDD LOW-level output voltage VDD 15 V - 0.05 - 0.05 - 0.05 V HIGH-level output current VO = 2.5 V 5V - -1.7 - -1.4 - -1.1 mA VO = 4.6 V 5V - -0.52 - -0.44 - -0.36 mA VO = 9.5 V 10 V - -1.3 - -1.1 - -0.9 mA VO = 13.5 V 15 V - -3.6 - -3.0 - -2.4 mA VO = 0.4 V 5V 0.52 - 0.44 - 0.36 - mA VO = 0.5 V 10 V 1.3 - 1.1 - 0.9 - mA VO = 1.5 V 15 V 3.6 - 3.0 - 2.4 - mA LOW-level output current II input leakage current VDD = 15 V 15 V - ±0.3 - ±0.3 - ±1.0 μA IDD supply current IO = 0 A; VI = VSS or VDD 5V - 20 - 20 - 150 μA 10 V - 40 - 40 - 300 μA 15 V - 80 - 80 - 600 μA - - - - 7.5 - - pF CI input capacitance HEF4555B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 4 / 10 HEF4555B Nexperia 1-of-4 decoder/demultiplexer 11. Dynamic characteristics Table 7. Dynamic characteristics VSS = 0 V; Tamb = 25 °C; for test circuit see Fig. 5; unless otherwise specified. Symbol Parameter Conditions VDD Extrapolation formula tPHL HIGH to LOW nAn to nYn; propagation delay see Fig. 4 5V 10 V 15 V tPLH LOW to HIGH nAn to nYn; propagation delay see Fig. 4 tt [1] [2] transition time nYn; see Fig. 4 Max Unit [1] 88 ns + (0.55 ns/pF)CL - 115 230 ns 34 ns + (0.23 ns/pF)CL - 45 90 ns 22 ns + (0.16 ns/pF)CL - 30 65 ns - 125 250 ns 10 V 39 ns + (0.23 ns/pF)CL - 50 95 ns 15 V 22 ns + (0.16 ns/pF CL - 30 65 ns - 140 280 ns 5V [1] 113 ns + (0.55 ns/pF)CL 10 V 44 ns + (0.23 ns/pF)CL - 55 105 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 75 ns - 150 295 ns 5V nE to nYn; see Fig. 4 Typ [1] 98 ns + (0.55 ns/pF)CL 5V nE to nYn; see Fig. 4 Min [1] 123 ns + (0.55 ns/pF)CL 10 V 44 ns + (0.23 ns/pF)CL - 55 110 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 75 ns [1][2] 10 ns + (1.00 ns/pF)CL 5V - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF). Transition time tt is the same as the HIGH to LOW and LOW to HIGH transition times tTHL and tTLH. Table 8. Dynamic power dissipation PD PD can be calculated from the formulas shown. VSS = 0 V; tr = tf ≤ 20 ns; Tamb = 25 °C. Symbol Parameter VDD Typical formula for PD (μW) PD dynamic power dissipation 5V PD = 4500 × fi + Σ(fo × CL) × VDD HEF4555B Product data sheet 10 V PD = 18800 × fi + Σ(fo × CL) × 15 V PD = 45700 × fi + Σ(fo × CL) × Where: 2 2 VDD 2 VDD All information provided in this document is subject to legal disclaimers. Rev. 7 — 15 October 2018 fi = input frequency in MHz, fo = output frequency in MHz, CL = output load capacitance in pF, VDD = supply voltage in V, Σ(fo × CL) = sum of the outputs. © Nexperia B.V. 2018. All rights reserved 5 / 10 HEF4555B Nexperia 1-of-4 decoder/demultiplexer 11.1. Waveforms and test circuit VDD VM nAn, nE input GND tPHL VOH tPLH 90 % VM nYn output 10 % VOL tTHL tTLH 001aal114 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 4. Inputs nAn, nE to output nYn propagation delay and nYn output transition time Table 9. Measurement points Supply voltage Input Output VDD VM VM 5 V to 15 V 0.5VDD 0.5VDD VI negative pulse tW 90 % 90 % VM VM 10 % 0V 10 % tf tr VI positive pulse 0V tr VDD tf 90 % G 90 % VM VM 10 % 10 % tW VI VO DUT CL RT 001aaj781 001aag182 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance; CL = Load capacitance including jig and probe capacitance; RT = Termination resistance should be equal to the output impedance Zo of the pulse generator; VEXT = External voltage for measuring switching times. Fig. 5. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VDD VI tr = tf CL 5 V to 15 V VDD ≤ 20 ns 50 pF HEF4555B Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 7 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 6 / 10 HEF4555B Nexperia 1-of-4 decoder/demultiplexer 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 6. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT109-1 (SO16) HEF4555B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 7 / 10 HEF4555B Nexperia 1-of-4 decoder/demultiplexer 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4555B v.7 20181015 Product data sheet - HEF4555B v.6 Modifications: • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. HEF4555B v.6 20160401 Modifications: • HEF4555B v.5 20111118 Modifications: • HEF4555B v.4 20100106 Product data sheet - HEF4555B_CNV v.3 HEF4555B_CNV v.3 19950101 Product specification - HEF4555B_CNV v.2 HEF4555B_CNV v.2 19950101 Product specification - - HEF4555B Product data sheet Product data sheet - HEF4555B v.5 Type number HEF4555BP (SOT38-4) removed. Product data sheet - HEF4555B v.4 Table 6: IOH minimum values changed to maximum All information provided in this document is subject to legal disclaimers. Rev. 7 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 8 / 10 HEF4555B Nexperia 1-of-4 decoder/demultiplexer 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal HEF4555B Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 7 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 9 / 10 HEF4555B Nexperia 1-of-4 decoder/demultiplexer Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................1 5. Functional diagram.......................................................2 6. Pinning information......................................................2 6.1. Pinning.........................................................................2 6.2. Pin description............................................................. 2 7. Functional description................................................. 3 8. Limiting values............................................................. 3 9. Recommended operating conditions..........................3 10. Static characteristics..................................................4 11. Dynamic characteristics.............................................5 11.1. Waveforms and test circuit........................................ 6 12. Package outline.......................................................... 7 13. Revision history..........................................................8 14. Legal information........................................................9 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 15 October 2018 HEF4555B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 10 / 10 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: HEF4555BP,652 HEF4555BT,652 HEF4555BT,653
HEF4555BT,653 价格&库存
很抱歉,暂时无法提供与“HEF4555BT,653”相匹配的价格&库存,您可以联系我们找货
HEF4555BT,653
    • 2500+0.992562500+0.12011
    • 5000+0.987935000+0.11954
    • 10000+0.9879110000+0.11954
    • 12500+0.9878812500+0.11954
    • 37500+0.9878637500+0.11954
    库存:5000
    HEF4555BT,653
    • 1+4.699601+0.56870
    • 10+3.9416010+0.47700
    • 100+3.24190100+0.39230
    • 500+2.63550500+0.31890
    • 1000+2.192401000+0.26530
    • 2500+1.562702500+0.18910
    • 10000+1.2944010000+0.15670
    • 25000+1.2478025000+0.15100
    • 50000+1.2128050000+0.14680
    库存:2980
    HEF4555BT,653
      • 238+2.11364
      库存:238
