74LV164-Q100
8-bit serial-in/parallel-out shift register
Rev. 2 — 18 September 2014
Product data sheet
1. General description
The 74LV164-Q100 is a low-voltage, Si-gate CMOS device and is pin and function
compatible with the 74HC164-Q100 and 74HCT164-Q100.
The 74LV164-Q100 is an 8-bit edge-triggered shift register with serial data entry and an
output from each of the eight stages. Data is entered serially through one of two inputs
(DSA or DSB). Either input can be used as an active HIGH enable for data entry through
the other input. Both inputs must be connected together or an unused input must be tied
HIGH.
Data shifts one place to the right on each LOW-to-HIGH transition of the clock input (CP).
It enters Q0, which is the logical AND-function of the two data inputs (DSA and DSB).
Data inputs DSA and DSB, existed one set-up time prior to the rising clock edge.
A LOW on the master reset input (MR) overrides all other inputs and clears the register
asynchronously, forcing all outputs LOW.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Wide operating voltage: 1.0 V to 5.5 V
Optimized for low-voltage applications: 1.0 V to 3.6 V
Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V
Typical output ground bounce < 0.8 V at VCC = 3.3 V and Tamb = 25 C
Typical HIGH-level output voltage (VOH) undershoot: > 2 V at VCC = 3.3 V and
Tamb = 25 C
Gated serial data inputs
Asynchronous master reset
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
74LV164-Q100
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
40 C to +125 C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
74LV164PW-Q100 40 C to +125 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74LV164BQ-Q100 40 C to +125 C
DHVQFN14
plastic dual in-line compatible thermal enhanced
very thin quad flat package; no leads; 14 terminals;
body 2.5 3 0.85 mm
SOT762-1
74LV164D-Q100
4. Functional diagram
65*
5
'6$
'6%
&3
05
4
4
4
4
4
4
4
4
DDF
DDF
Fig 1.
Logic symbol
Fig 2.
'6$
'6%
&3
05
IEC logic symbol
%,76(5,$/ ,13$5$//(/ 287
6+,)75(*,67(5
4 4 4 4 4 4 4 4
DDF
Fig 3.
Functional diagram
74LV164_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 19
74LV164-Q100
Nexperia
5. Pinning information
5.1 Pinning
/94
'6$
WHUPLQDO
LQGH[DUHD
9&&
/94
9&&
'6%
4
'6%
4
4
4
4
4
4
4
4
4
4
9&&
4
4
05
4
*1'
&3
&3
4
*1'
4
'6$
05
DDD
7UDQVSDUHQWWRSYLHZ
DDD
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to VCC.
Fig 4.
Pin configuration SO14 and TSSOP14
Fig 5.
Pin configuration DHVQFN14
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
DSA
1
data input SA
DSB
2
data input SB
Q0
3
output 0
Q1
4
output 1
Q2
5
output 2
Q3
6
output 3
GND
7
ground (0 V)
CP
8
clock input (edge triggered LOW-to-HIGH)
MR
9
master reset input (active LOW)
Q4
10
output 4
Q5
11
output 5
Q6
12
output 6
Q7
13
output 7
VCC
14
supply voltage
74LV164_Q100
Product data sheet
3 of 19
74LV164-Q100
Nexperia
6. Functional description
Table 3.
Function table[1]
Operating mode
Input
Output
MR
CP
DSA
DSB
Q0
Q1 to Q7
Reset (clear)
L
X
X
X
L
L to L
Shift
H
l
l
L
q0 to q6
H
l
h
L
q0 to q6
H
h
l
L
q0 to q6
H
h
h
H
q0 to q6
[1]
H = HIGH voltage level;
L = LOW voltage level;
= LOW-to-HIGH clock transition;
h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition;
l = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition;
q = lower case letter indicates the state of referenced input one set-up time prior to the LOW-to-HIGH CP transition.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
Max
Unit
0.5
+7.0
V
mA
50
mA
25
mA
IO
output current
ICC
supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
500
mW
[1]
[2]
output source or sink current,
VO = 0.5 V to (VCC + 0.5 V)
[1]
Min
Tamb = 40 C to +125 C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
SO14 package: Ptot derates linearly with 8 mW/K above 70 C.
TSSOP14 package: Ptot derates linearly with 5.5 mW/K above 60 C.
DHVQFN14 package: Ptot derates linearly with 4.5 mW/K above 60 C.
74LV164_Q100
Product data sheet
4 of 19
74LV164-Q100
Nexperia
8. Recommended operating conditions
Table 5.
Symbol
Parameter
Conditions
[1]
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
in free air
tr
rise time
input
fall time
tf
[1]
Min
Typ
Max
Unit
1.0
3.3
5.5
V
VCC
V
VCC
V
40
+125
C
VCC = 1.0 V to 2.0 V
500
ns/V
VCC = 2.0 V to 2.7 V
200
ns/V
VCC = 2.7 V to 3.6 V
100
ns/V
VCC = 3.6 V to 5.5 V
50
ns/V
input
500
ns/V
200
ns/V
100
ns/V
50
ns/V
The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V. LV devices are guaranteed to function down to VCC = 1.0 V
(with input levels GND or VCC).
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Tamb = 40 C to +85
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
74LV164_Q100
Product data sheet
Conditions
Min
Typ
Max
Unit
C[1]
VCC = 1.2 V
0.9
V
VCC = 2.0 V
1.4
V
2.0
V
VCC = 4.5 V to 5.5 V
0.7 VCC -
V
VCC = 1.2 V
0.3
V
VCC = 2.0 V
0.6
V
0.8
V
0.3 VCC V
lO = 100 A; VCC = 1.2 V
1.2
V
lO = 100 A; VCC = 2.0 V
1.8
2.0
V
lO = 100 A; VCC = 2.7 V
2.5
2.7
V
VI = VIH or VIL
lO = 100 A; VCC = 3.0 V
2.8
3.0
V
lO = 6 mA; VCC = 3.0 V
2.4
2.82
V
lO = 100 A; VCC = 4.5 V
4.3
4.5
V
lO = 12 mA; VCC = 4.5 V
3.6
4.2
V
5 of 19
74LV164-Q100
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
Conditions
VOL
VI = VIH or VIL
LOW-level output voltage
Min
Typ
Max
Unit
IO = 100 A; VCC = 1.2 V
V
IO = 100 A; VCC = 2.0 V
V
IO = 100 A; VCC = 2.7 V
V
IO = 100 A; VCC = 3.0 V
V
IO = 6 mA; VCC = 3.0 V
0.25
0.40
V
IO = 100 A; VCC = 4.5 V
V
IO = 12 mA; VCC = 4.5 V
0.35
0.55
V
II
input leakage current
VI = VCC or GND; VCC = 5.5 V
1.0
A
ICC
supply current
quiescent: VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
20.0
A
ICC
additional supply current
quiescent, per input: VI = VCC 0.6 V;
500
A
CI
input capacitance
3.5
pF
VCC = 1.2 V
0.9
V
VCC = 2.0 V
1.4
V
2.0
V
VIH
VIL
VOH
VOL
74LV164_Q100
Product data sheet
0.7 VCC -
V
VCC = 1.2 V
0.3
V
VCC = 2.0 V
0.6
V
0.8
V
0.3 VCC V
V
1.8
V
2.5
V
2.8
V
2.2
V
4.3
V
3.5
V
V
0.2
V
0.2
V
0.2
V
0.5
V
0.2
V
0.65
V
VI = VIH or VIL
VI = VIH or VIL
6 of 19
74LV164-Q100
Nexperia
Table 6.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
ILI
1.0
A
ICC
supply current
VCC = 5.5 V
160
A
ICC
850
A
[1]
All typical values are measured at Tamb = 25 C.
10. Dynamic characteristics
Table 7.
GND = 0 V; tr = tf 2.5 ns; CL = 50 pF; RL = 1 k; for test circuit, see Figure 9.
Symbol Parameter
Tamb = 40 C to +85
tpd
Conditions
Min
Typ
Max
Unit
VCC = 1.2 V
75
ns
VCC = 2.0 V
26
39
ns
VCC = 2.7 V
19
29
ns
VCC = 3.0 V to 3.6 V
14
23
ns
12
19
ns
12
ns
VCC = 2.0 V
34
9
ns
VCC = 2.7 V
25
6
ns
ns
13
4
ns
VCC = 2.0 V
34
10
ns
VCC = 2.7 V
25
8
ns
ns
13
5
ns
VCC = 1.2 V
30
ns
VCC = 2.0 V
19
10
ns
VCC = 2.7 V
14
8
ns
11
6
ns
8
5
ns
C[1]
propagation delay
CP - see Figure 6: MR - see Figure 7
[2]
VCC = 3.0 V to 3.6 V; CL = 15 pF
tW
pulse width
[3]
CP - see Figure 6
MR - see Figure 7
trem
removal time
74LV164_Q100
Product data sheet
MR to CP - see Figure 7
7 of 19
74LV164-Q100
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
Conditions
tsu
Dn to CP - see Figure 8
th
fmax
set-up time
hold time
maximum frequency
Min
Typ
Max
Unit
VCC = 1.2 V
15
ns
VCC = 2.0 V
22
5
ns
VCC = 2.7 V
16
4
ns
13
3
ns
9
2
ns
VCC = 1.2 V
10
ns
VCC = 2.0 V
5
3
ns
VCC = 2.7 V
5
2
ns
5
2
ns
5
1
ns
14
40
MHz
see Figure 6
VCC = 2.0 V
VCC = 2.7 V
19
58
MHz
24
70
MHz
36
100
MHz
78
MHz
40
pF
VCC = 1.2 V
ns
VCC = 2.0 V
49
ns
VCC = 2.7 V
36
ns
29
ns
24
ns
VCC = 2.0 V
41
ns
VCC = 2.7 V
30
ns
24
ns
16
ns
VCC = 1.2 V
ns
VCC = 2.0 V
24
ns
VCC = 2.7 V
18
ns
14
ns
10
ns
VCC = 3.3 V; CL = 15 pF
CPD
power dissipation capacitance
per gate: VCC = 3.3 V
[4][5]
tpd
tW
trem
propagation delay
pulse width
removal time
74LV164_Q100
Product data sheet
[2]
8 of 19
74LV164-Q100
Nexperia
Table 7.
Symbol Parameter
Conditions
tsu
set-up time
hold time
th
maximum frequency
fmax
[1]
Min
Typ
Max
Unit
VCC = 1.2 V
ns
VCC = 2.0 V
26
ns
VCC = 2.7 V
19
ns
15
ns
10
ns
VCC = 1.2 V
ns
VCC = 2.0 V
5
ns
VCC = 2.7 V
5
ns
5
ns
5
ns
VCC = 2.0 V
12
MHz
VCC = 2.7 V
16
MHz
MHz
30
MHz
see Figure 6
Typical values are measured at nominal VCC and Tamb = 25 C.
[2]
tpd is the same as tPLH and tPHL.
[3]
Typical values are measured at nominal supply voltage (VCC = 3.3 V).
[4]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of the outputs.
[5]
The condition is VI = GND to VCC.
74LV164_Q100
Product data sheet
9 of 19
74LV164-Q100
Nexperia
11. Waveforms
IPD[
9,
&3LQSXW
90
*1'
W:
W 3+/
W 3/+
92+
90
4QRXWSXW
DDF
92/
Measurement points are given in Table 8.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 6.
Propagation delay clock (CP) to output (Qn), clock pulse width and maximum clock frequency
9,
90
05LQSXW
*1'
W:
IUHF
9,
&3LQSXW
90
*1'
W3+/
92+
90
4QRXWSXW
92/
DDF
Fig 7.
Pulse width master reset (MR), propagation delay master reset (MR) to output (Qn) and removal time
master reset (MR) to clock (CP)
74LV164_Q100
Product data sheet
10 of 19
74LV164-Q100
Nexperia
9,
90
&3LQSXW
*1'
W VX
W VX
WK
WK
9,
90
'QLQSXW
*1'
92+
90
4QRXWSXW
92/
DDF
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig 8.
Table 8.
Data set-up and hold times inputs (Dn) to clock (CP)
Measurement points
Supply voltage
Input
Output
VCC
VM
VM
1.2 V
0.5 VCC
0.5 VCC
2.0 V
0.5 VCC
0.5 VCC
2.7 V
1.5 V
1.5 V
3.0 V to 3.6 V
1.5 V
1.5 V
4.5 V to 5.5 V
0.5 VCC
0.5 VCC
74LV164_Q100
Product data sheet
11 of 19
74LV164-Q100
Nexperia
9&&
9,
38/6(
*(1(5$725
92
'87
S)
57
5/
Nȍ
DDD
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistor.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Fig 9.
Table 9.
Test circuit for measuring switching times
Test data
Supply voltage
Input
VCC
VI
tr, tf
CL
RL
1.2 V
VCC
2.5 ns
50 pF
1 k
tPHL, tPLH
2.0 V
VCC
2.5 ns
50 pF
1 k
tPHL, tPLH
2.7 V
2.7 V
2.5 ns
50 pF
1 k
tPHL, tPLH
3.0 V to 3.6 V
2.7 V
2.5 ns
50 pF, 15 pF
1 k
tPHL, tPLH
4.5 V to 5.5 V
VCC
2.5 ns
50 pF
1 k
tPHL, tPLH
74LV164_Q100
Product data sheet
Load
Test
12 of 19
74LV164-Q100
Nexperia
12. Package outline
62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
GHWDLO;
Z 0
ES
PP
VFDOH
',0(16,216LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
PP
LQFKHV
ș
R
R
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPLQFKPD[LPXPSHUVLGHDUHQRWLQFOXGHG
5()(5(1&(6
287/,1(
9(56,21
627
06
-(,7$
(8523($1
352-(&7,21
,668('$7(
Fig 10. Package outline SOT108-1 (SO14)
74LV164_Q100
Product data sheet
13 of 19
74LV164-Q100
Nexperia
76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
GHWDLO;
Z 0
ES
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
ș
PP
R
R
1RWHV
3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
5()(5(1&(6
-(,7$
(8523($1
352-(&7,21
,668('$7(
02
Fig 11. Package outline SOT402-1 (TSSOP14)
74LV164_Q100
Product data sheet
14 of 19
74LV164-Q100
Nexperia
'+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJHQROHDGV
627
WHUPLQDOVERG\[[PP
F
GHWDLO;
WHUPLQDO
LQGH[DUHD
WHUPLQDO
LQGH[DUHD
H
H
E
Y 0 & $ %
Z 0 &
(K
H
'K
PP
VFDOH
81,7
PP
PD[
E
F
'K
(K
H
H
Y
Z
1RWH
5()(5(1&(6
287/,1(
9(56,21
-(,7$
627
02
(8523($1
352-(&7,21
,668('$7(
Fig 12. Package outline SOT762-1 (DHVQFN14)
74LV164_Q100
Product data sheet
15 of 19
74LV164-Q100
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LV164_Q100 v.2
20140918
Product data sheet
74LV164_Q100 v.1
Modifications:
74LV164_Q100 v.1
74LV164_Q100
Product data sheet
Section 2: ESD protection: MIL-STD-833 changed to MIL-STD883
20130626
Product data sheet
16 of 19
74LV164-Q100
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74LV164_Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
17 of 19
74LV164-Q100
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74LV164_Q100
Product data sheet
18 of 19
Nexperia
74LV164-Q100
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16
Legal information. . . . . . . . . . . . . . . . . . . . . . . 17
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Contact information. . . . . . . . . . . . . . . . . . . . . 18
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Date of release: 18 September 2014
