74LV164BQ-Q100X
74LV164BQ-Q100X
    NEXPERIA(安世)
    DHVQFN14_3X2.5MM_EP
    8位串行输入/并行输出移位寄存器 DHVQFN14_3X2.5MM-EP 1~5.5V
74LV164BQ-Q100X 数据手册
74LV164-Q100 8-bit serial-in/parallel-out shift register Rev. 2 — 18 September 2014 Product data sheet 1. General description The 74LV164-Q100 is a low-voltage, Si-gate CMOS device and is pin and function compatible with the 74HC164-Q100 and 74HCT164-Q100. The 74LV164-Q100 is an 8-bit edge-triggered shift register with serial data entry and an output from each of the eight stages. Data is entered serially through one of two inputs (DSA or DSB). Either input can be used as an active HIGH enable for data entry through the other input. Both inputs must be connected together or an unused input must be tied HIGH. Data shifts one place to the right on each LOW-to-HIGH transition of the clock input (CP). It enters Q0, which is the logical AND-function of the two data inputs (DSA and DSB). Data inputs DSA and DSB, existed one set-up time prior to the rising clock edge. A LOW on the master reset input (MR) overrides all other inputs and clears the register asynchronously, forcing all outputs LOW. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide operating voltage: 1.0 V to 5.5 V  Optimized for low-voltage applications: 1.0 V to 3.6 V  Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V  Typical output ground bounce < 0.8 V at VCC = 3.3 V and Tamb = 25 C  Typical HIGH-level output voltage (VOH) undershoot: > 2 V at VCC = 3.3 V and Tamb = 25 C  Gated serial data inputs  Asynchronous master reset  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 ) 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74LV164PW-Q100 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74LV164BQ-Q100 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm SOT762-1 74LV164D-Q100 4. Functional diagram 65*     & 5 '   '6$ '6%   &3 05     4  4   4   4  4   4   4  4  DDF DDF Fig 1. Logic symbol Fig 2. '6$ '6% &3 05 IEC logic symbol    %,76(5,$/ ,13$5$//(/ 287 6+,)75(*,67(5          4 4 4 4 4 4 4 4 DDF Fig 3. Functional diagram 74LV164_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 © Nexperia B.V. 2017. All rights reserved 2 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register 5. Pinning information 5.1 Pinning /94 '6$ WHUPLQDO LQGH[DUHD  9&& /94   9&& '6%   4 '6%   4 4   4 4   4 4   4 4  4    4 9&&   4  4   05  4 *1'   &3 &3  4   *1' 4  '6$ 05 DDD 7UDQVSDUHQWWRSYLHZ DDD (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to VCC. Fig 4. Pin configuration SO14 and TSSOP14 Fig 5. Pin configuration DHVQFN14 5.2 Pin description Table 2. Pin description Symbol Pin Description DSA 1 data input SA DSB 2 data input SB Q0 3 output 0 Q1 4 output 1 Q2 5 output 2 Q3 6 output 3 GND 7 ground (0 V) CP 8 clock input (edge triggered LOW-to-HIGH) MR 9 master reset input (active LOW) Q4 10 output 4 Q5 11 output 5 Q6 12 output 6 Q7 13 output 7 VCC 14 supply voltage 74LV164_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 © Nexperia B.V. 2017. All rights reserved 3 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register 6. Functional description Table 3. Function table[1] Operating mode Input Output MR CP DSA DSB Q0 Q1 to Q7 Reset (clear) L X X X L L to L Shift H  l l L q0 to q6 H  l h L q0 to q6 H  h l L q0 to q6 H  h h H q0 to q6 [1] H = HIGH voltage level; L = LOW voltage level;  = LOW-to-HIGH clock transition; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition; l = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition; q = lower case letter indicates the state of referenced input one set-up time prior to the LOW-to-HIGH CP transition. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V Max Unit 0.5 +7.0 V - 20 mA - 50 mA - 25 mA IO output current ICC supply current - 50 mA IGND ground current - 50 mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 500 mW [1] [2] output source or sink current, VO = 0.5 V to (VCC + 0.5 V) [1] Min Tamb = 40 C to +125 C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. SO14 package: Ptot derates linearly with 8 mW/K above 70 C. TSSOP14 package: Ptot derates linearly with 5.5 mW/K above 60 C. DHVQFN14 package: Ptot derates linearly with 4.5 mW/K above 60 C. 74LV164_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 © Nexperia B.V. 2017. All rights reserved 4 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register 8. Recommended operating conditions Table 5. Symbol Recommended operating conditions Parameter Conditions [1] VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature in free air tr rise time input fall time tf [1] Min Typ Max Unit 1.0 3.3 5.5 V 0 - VCC V 0 - VCC V 40 - +125 C VCC = 1.0 V to 2.0 V - - 500 ns/V VCC = 2.0 V to 2.7 V - - 200 ns/V VCC = 2.7 V to 3.6 V - - 100 ns/V VCC = 3.6 V to 5.5 V - - 50 ns/V input VCC = 1.0 V to 2.0 V - - 500 ns/V VCC = 2.0 V to 2.7 V - - 200 ns/V VCC = 2.7 V to 3.6 V - - 100 ns/V VCC = 3.6 V to 5.5 V - - 50 ns/V The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V. LV devices are guaranteed to function down to VCC = 1.0 V (with input levels GND or VCC). 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 74LV164_Q100 Product data sheet Conditions Min Typ Max Unit C[1] VCC = 1.2 V 0.9 - - V VCC = 2.0 V 1.4 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.2 V - - 0.3 V VCC = 2.0 V - - 0.6 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3  VCC V lO = 100 A; VCC = 1.2 V - 1.2 - V lO = 100 A; VCC = 2.0 V 1.8 2.0 - V lO = 100 A; VCC = 2.7 V 2.5 2.7 - V VI = VIH or VIL lO = 100 A; VCC = 3.0 V 2.8 3.0 - V lO = 6 mA; VCC = 3.0 V 2.4 2.82 - V lO = 100 A; VCC = 4.5 V 4.3 4.5 - V lO = 12 mA; VCC = 4.5 V 3.6 4.2 - V All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 © Nexperia B.V. 2017. All rights reserved 5 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VOL VI = VIH or VIL LOW-level output voltage Min Typ Max Unit IO = 100 A; VCC = 1.2 V - 0 - V IO = 100 A; VCC = 2.0 V - 0 0.2 V IO = 100 A; VCC = 2.7 V - 0 0.2 V IO = 100 A; VCC = 3.0 V - 0 0.2 V IO = 6 mA; VCC = 3.0 V - 0.25 0.40 V IO = 100 A; VCC = 4.5 V - 0 0.2 V IO = 12 mA; VCC = 4.5 V - 0.35 0.55 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 A ICC supply current quiescent: VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 20.0 A ICC additional supply current quiescent, per input: VI = VCC  0.6 V; VCC = 2.7 V to 3.6 V - - 500 A CI input capacitance - 3.5 - pF VCC = 1.2 V 0.9 - - V VCC = 2.0 V 1.4 - - V VCC = 2.7 V to 3.6 V 2.0 - - V Tamb = 40 C to +125 C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage 74LV164_Q100 Product data sheet VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.2 V - - 0.3 V VCC = 2.0 V - - 0.6 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3  VCC V lO = 100 A; VCC = 1.2 V - - - V lO = 100 A; VCC = 2.0 V 1.8 - - V lO = 100 A; VCC = 2.7 V 2.5 - - V lO = 100 A; VCC = 3.0 V 2.8 - - V lO = 6 mA; VCC = 3.0 V 2.2 - - V lO = 100 A; VCC = 4.5 V 4.3 - - V lO = 12 mA; VCC = 4.5 V 3.5 - - V IO = 100 A; VCC = 1.2 V - - - V IO = 100 A; VCC = 2.0 V - - 0.2 V IO = 100 A; VCC = 2.7 V - - 0.2 V IO = 100 A; VCC = 3.0 V - - 0.2 V IO = 6 mA; VCC = 3.0 V - - 0.5 V IO = 100 A; VCC = 4.5 V - - 0.2 V IO = 12 mA; VCC = 4.5 V - - 0.65 V VI = VIH or VIL VI = VIH or VIL All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 © Nexperia B.V. 2017. All rights reserved 6 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit ILI input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 A ICC supply current quiescent: VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 160 A ICC additional supply current quiescent, per input: VI = VCC  0.6 V; VCC = 2.7 V to 3.6 V - - 850 A [1] All typical values are measured at Tamb = 25 C. 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; tr = tf  2.5 ns; CL = 50 pF; RL = 1 k; for test circuit, see Figure 9. Symbol Parameter Tamb = 40 C to +85 tpd Conditions Min Typ Max Unit VCC = 1.2 V - 75 - ns VCC = 2.0 V - 26 39 ns VCC = 2.7 V - 19 29 ns VCC = 3.0 V to 3.6 V - 14 23 ns - 12 19 ns - 12 - ns VCC = 2.0 V 34 9 - ns VCC = 2.7 V 25 6 - ns VCC = 3.0 V to 3.6 V 20 5 - ns VCC = 4.5 V to 5.5 V 13 4 - ns VCC = 2.0 V 34 10 - ns VCC = 2.7 V 25 8 - ns VCC = 3.0 V to 3.6 V 20 6 - ns VCC = 4.5 V to 5.5 V 13 5 - ns VCC = 1.2 V - 30 - ns VCC = 2.0 V 19 10 - ns VCC = 2.7 V 14 8 - ns VCC = 3.0 V to 3.6 V 11 6 - ns VCC = 4.5 V to 5.5 V 8 5 - ns C[1] propagation delay CP - see Figure 6: MR - see Figure 7 [2] VCC = 4.5 V to 5.5 V VCC = 3.0 V to 3.6 V; CL = 15 pF tW pulse width [3] CP - see Figure 6 MR - see Figure 7 trem removal time 74LV164_Q100 Product data sheet MR to CP - see Figure 7 All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 © Nexperia B.V. 2017. All rights reserved 7 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register Table 7. Dynamic characteristics …continued GND = 0 V; tr = tf  2.5 ns; CL = 50 pF; RL = 1 k; for test circuit, see Figure 9. Symbol Parameter Conditions tsu Dn to CP - see Figure 8 th fmax set-up time hold time maximum frequency Min Typ Max Unit VCC = 1.2 V - 15 - ns VCC = 2.0 V 22 5 - ns VCC = 2.7 V 16 4 - ns VCC = 3.0 V to 3.6 V 13 3 - ns VCC = 4.5 V to 5.5 V 9 2 - ns VCC = 1.2 V - 10 - ns VCC = 2.0 V 5 3 - ns VCC = 2.7 V 5 2 - ns VCC = 3.0 V to 3.6 V 5 2 - ns VCC = 4.5 V to 5.5 V 5 1 - ns 14 40 - MHz Dn to CP - see Figure 8 see Figure 6 VCC = 2.0 V VCC = 2.7 V 19 58 - MHz VCC = 3.0 V to 3.6 V 24 70 - MHz VCC = 4.5 V to 5.5 V 36 100 - MHz - 78 - MHz - 40 - pF VCC = 1.2 V - - - ns VCC = 2.0 V - - 49 ns VCC = 2.7 V - - 36 ns VCC = 3.0 V to 3.6 V - - 29 ns VCC = 4.5 V to 5.5 V - - 24 ns VCC = 2.0 V 41 - - ns VCC = 2.7 V 30 - - ns VCC = 3.0 V to 3.6 V 24 - - ns VCC = 4.5 V to 5.5 V 16 - - ns VCC = 1.2 V - - - ns VCC = 2.0 V 24 - - ns VCC = 2.7 V 18 - - ns VCC = 3.0 V to 3.6 V 14 - - ns VCC = 4.5 V to 5.5 V 10 - - ns VCC = 3.3 V; CL = 15 pF CPD power dissipation capacitance per gate: VCC = 3.3 V [4][5] Tamb = 40 C to +125 C tpd tW trem propagation delay pulse width removal time 74LV164_Q100 Product data sheet CP - see Figure 6: MR - see Figure 7 [2] CP - see Figure 6: MR - see Figure 7 MR to CP - see Figure 7 All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 © Nexperia B.V. 2017. All rights reserved 8 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register Table 7. Dynamic characteristics …continued GND = 0 V; tr = tf  2.5 ns; CL = 50 pF; RL = 1 k; for test circuit, see Figure 9. Symbol Parameter Conditions tsu Dn to CP - see Figure 8 set-up time hold time th maximum frequency fmax [1] Min Typ Max Unit VCC = 1.2 V - - - ns VCC = 2.0 V 26 - - ns VCC = 2.7 V 19 - - ns VCC = 3.0 V to 3.6 V 15 - - ns VCC = 4.5 V to 5.5 V 10 - - ns VCC = 1.2 V - - - ns VCC = 2.0 V 5 - - ns VCC = 2.7 V 5 - - ns VCC = 3.0 V to 3.6 V 5 - - ns VCC = 4.5 V to 5.5 V 5 - - ns VCC = 2.0 V 12 - - MHz VCC = 2.7 V 16 - - MHz VCC = 3.0 V to 3.6 V 20 - - MHz VCC = 4.5 V to 5.5 V 30 - - MHz Dn to CP - see Figure 8 see Figure 6 Typical values are measured at nominal VCC and Tamb = 25 C. [2] tpd is the same as tPLH and tPHL. [3] Typical values are measured at nominal supply voltage (VCC = 3.3 V). [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. [5] The condition is VI = GND to VCC. 74LV164_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 © Nexperia B.V. 2017. All rights reserved 9 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register 11. Waveforms IPD[ 9, &3LQSXW  90 *1' W: W 3+/ W 3/+ 92+ 90 4QRXWSXW DDF 92/ Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 6. Propagation delay clock (CP) to output (Qn), clock pulse width and maximum clock frequency 9, 90 05LQSXW  *1' W: IUHF 9, &3LQSXW  90 *1' W3+/ 92+ 90 4QRXWSXW 92/ DDF Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 7. Pulse width master reset (MR), propagation delay master reset (MR) to output (Qn) and removal time master reset (MR) to clock (CP) 74LV164_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 © Nexperia B.V. 2017. All rights reserved 10 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register 9, 90 &3LQSXW *1' W VX W VX WK WK 9, 90 'QLQSXW *1' 92+ 90 4QRXWSXW 92/ DDF Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. The shaded areas indicate when the input is permitted to change for predictable output performance. Fig 8. Table 8. Data set-up and hold times inputs (Dn) to clock (CP) Measurement points Supply voltage Input Output VCC VM VM 1.2 V 0.5  VCC 0.5  VCC 2.0 V 0.5  VCC 0.5  VCC 2.7 V 1.5 V 1.5 V 3.0 V to 3.6 V 1.5 V 1.5 V 4.5 V to 5.5 V 0.5  VCC 0.5  VCC 74LV164_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 © Nexperia B.V. 2017. All rights reserved 11 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register 9&& 9, 38/6( *(1(5$725 92 '87 &/ S) 57 5/ Nȍ DDD Test data is given in Table 9. Definitions for test circuit: RL = Load resistor. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig 9. Table 9. Test circuit for measuring switching times Test data Supply voltage Input VCC VI tr, tf CL RL 1.2 V VCC  2.5 ns 50 pF 1 k tPHL, tPLH 2.0 V VCC  2.5 ns 50 pF 1 k tPHL, tPLH 2.7 V 2.7 V  2.5 ns 50 pF 1 k tPHL, tPLH 3.0 V to 3.6 V 2.7 V  2.5 ns 50 pF, 15 pF 1 k tPHL, tPLH 4.5 V to 5.5 V VCC  2.5 ns 50 pF 1 k tPHL, tPLH 74LV164_Q100 Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 Test © Nexperia B.V. 2017. All rights reserved 12 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV        ș R R  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 10. Package outline SOT108-1 (SO14) 74LV164_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 © Nexperia B.V. 2017. All rights reserved 13 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 11. Package outline SOT402-1 (TSSOP14) 74LV164_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 © Nexperia B.V. 2017. All rights reserved 14 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register '+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJHQROHDGV 627 WHUPLQDOVERG\[[PP % ' $ $ ( $ F GHWDLO; WHUPLQDO LQGH[DUHD WHUPLQDO LQGH[DUHD & H H E   \ \ & Y 0 & $ % Z 0 & /   (K H     'K ;   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 PP $   PD[ $ E      F '   'K (   (K          H H / Y Z \ \         1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& -(,7$ 627  02  (8523($1 352-(&7,21 ,668('$7(   Fig 12. Package outline SOT762-1 (DHVQFN14) 74LV164_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 © Nexperia B.V. 2017. All rights reserved 15 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register 13. Abbreviations Table 10. Abbreviations Acronym Description DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LV164_Q100 v.2 20140918 Product data sheet - 74LV164_Q100 v.1 Modifications: 74LV164_Q100 v.1 74LV164_Q100 Product data sheet • Section 2: ESD protection: MIL-STD-833 changed to MIL-STD883 20130626 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 - © Nexperia B.V. 2017. All rights reserved 16 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74LV164_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 © Nexperia B.V. 2017. All rights reserved 17 of 19 74LV164-Q100 Nexperia 8-bit serial-in/parallel-out shift register No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74LV164_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 September 2014 © Nexperia B.V. 2017. All rights reserved 18 of 19 Nexperia 74LV164-Q100 8-bit serial-in/parallel-out shift register 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16 Legal information. . . . . . . . . . . . . . . . . . . . . . . 17 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Contact information. . . . . . . . . . . . . . . . . . . . . 18 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 18 September 2014
74LV164BQ-Q100X 价格&库存
很抱歉,暂时无法提供与“74LV164BQ-Q100X”相匹配的价格&库存,您可以联系我们找货
