ASR CONNECTOR
Emboss Tape
1.0mm pitch/Disconnectable Insulation displacement connectors
Specifications –––––––––––––––––––
• Current rating: 0.7A DC
• Voltage rating: 50V DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/30m Ω max.
After environmental testing/40m Ω max.
• Insulation resistance:
100M Ω min.
• Withstanding voltage: 500V AC/minute
• Applicable wire: Conductor size/AWG #30
Conductor/7 strands,
tin-coated annealed copper
Insulation O.D./0.54 to 0.58mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
• Compact
• Twin U-slot insulation displacement section
• 3-point grip construction
• Header designed for vacuum pick and place
robotics
Standards ––––––––––––––––––––––
Recognized E60389
1Certified LR20812
PC board layout (viewed from component side) and Assembly layout
1.0
0.6
±0.05
±0.05
±0.05
3.6
0.9
±0.1
±0.1
±0.1
0.8 ±0.1
Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. The dimensions above should serve as a guideline. Contact JST for details.
1
3.5
4.6
3.4
±0.1
±0.1
1.8
0.2
±0.1
±0.1
±0.1
Header outline
ASR CONNECTOR
Socket
B 4.0
A 1.0
Circuits
Model No.
2
02ASR-30S
03ASR-30S
04ASR-30S
3
3.6
4
1.65
2.95
1.0
Dimensions (mm)
A
B
Q'ty / box
1.0
4.0
3,000
2.0
5.0
3,000
3.0
6.0
3,000
Material and Finish
Contact: Phosphor bronze, tin-plated (reflow treatment)
Housing: Glass-filled PA 66, UL94V-0, natural
RoHS compliance
2.8
Shrouded header
Circuits
Model No.
2
BM02B-ASRS-TF
BM03B-ASRS-TF
BM04B-ASRS-TF
B
A
3.4
0.7
3
1.85
4
1.5
Dimensions (mm)
A
B
Q'ty /
reel
1.0
4.4
3,500
2.0
5.4
3,500
3.0
6.4
3,500
Material and Finish
Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment)
Wafer: PA 6T, UL94V-0, natural
Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment)
RoHS compliance This product displays (LF)(SN) on a label.
Note: The products listed above are supplied on embossed-tape.
2
很抱歉,暂时无法提供与“04ASR-30S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+1.268173000+0.15395
- 6000+1.262246000+0.15323
- 9000+1.262219000+0.15323
- 12000+1.2621912000+0.15323
- 15000+1.2621615000+0.15322
- 国内价格
- 500+1.21700
- 1000+1.16410
- 国内价格
- 1+1.03605
- 30+0.99905
- 100+0.92505
- 500+0.85104
- 1000+0.81404
