DS017
DS017
    EDSYN(EDSYN)
    Deluxe SOLDAPULLT with SRT12 T
DS017 数据手册
SOLDAPULLT® Portable Desoldering Tools ...bringing innovative ideas to life Length: 13"(330mm) Wt: 3.5oz (99g) DS017 “The Original” Deluxe SOLDAPULLT® s Designed for heavy duty, high volume applications s Easy one-hand loading and operation s Integral cleaning shaft self-cleans no-stick PTFE tip Length: 13"(330mm) Wt: 3.5oz (99g) AS196 SILVERSTAT® SOLDAPULLT® s The "Rolls Royce" of static safe desoldering hand tools s Identical in size and performance to the DS017 s Engineered with conductive plating s Especially designed for desoldering of static safe components DS017LS Length: 12"(304mm) Wt: 2.5oz (71g) SOLDAPULLT®III s Smooth acting, light weight spring loaded tool s Similar to the DS017 but with petite barrel for smaller hands s Locking retractable shaft guide for portability and compact storage s Integral cleaning shaft self-cleans no-stick PTFE tip PT409 Static Safe SOLDAPULLT® Successor s Static protection for sensitive devices s Precision engineered metal barrel & static safe PTFE tip s Simple single handed loading system Length: 8"(203mm) Wt: 1.9oz (54g) SS102 Micro Tip Static Safe SOLDAPULLT® Successor s Micro tip version of SS011 for heavily populated boards and precision work s Palm grip or finger touch trigger for easier handling s Precision engineered metal barrel & static safe PTFE tip s Simple single handed loading system Length: 13"(330mm) Wt: 3.5oz (99g) Static Safe Deluxe SOLDAPULLT® s Same as DS017 but molded from conductive plastic PT109 Length: 8"(203mm) Wt: 1.7oz (49g) SS011 Length: 12"(304mm) Wt: 2.5oz (71g) Length: 8.5"(216mm) Wt: 1.4oz (40g) SS343 Static Safe Pico Tip Challenger SOLDAPULLT® s New pointed pico tip for precision desoldering and high vacuum velocity for optimum performance s Precision engineered metal barrel & static safe PTFE tip s Simple single-handed loading system s Static protection for sensitive devices SS750LS Length: 8.5"(216mm) Wt: 1.2oz (34g) Economical Static Safe Challenger SOLDAPULLT® s Compact static safe barrel s Quick change tiplet for no hassle maintenance s Simple single-handed loading system Static Safe SOLDAPULLT® III s Same as PT109 but molded from conductive plastic PT209 Length: 12"(304mm) Wt: 2.5oz (71g) SS350 Length: 9"(229mm) Wt: 1.4oz (40g) Micro Tip SOLDAPULLT® III s Micro tip version of PT109 for heavily populated circuit boards and precision work s Light weight petite barrel for smaller hands s Locking retractable shaft guide for portability and compact storage s Integral cleaning shaft self-cleans no-stick micro PTFE tip Static Safe Challenger SOLDAPULLT® s Outstanding quality for the professional or hobbyist s Precision engineered metal barrel & static safe PTFE tip s Simple single-handed loading system s Adjustable loading stroke to reduce hand strain US140 US340 Length: 8.5"(216mm) Wt: 1.5oz (43g) Universal SOLDAPULLT® s Compact single-handed loading system s Adjustable loading stroke to fit individual needs s Loading and trigger release done with thumb *See page 37 for a complete list of Replacement Tips and O-Rings Length: 8.5"(216mm) Wt: 1.5oz (43g) Static Safe Universal SOLDAPULLT® s Same as US140 but molded from conductive material s Compact single-handed loading system s Adjustable loading stroke to fit individual needs s Loading and trigger release done with thumb w w w. e d s y n . c o m 0(/.%s&!83ALES &!83ERVICE s%-!),INFO EDSYNCOM 33 SOLDAPULLT® Portable Desoldering Tips & O-Rings ...bringing innovative ideas to life Portable Replacement Tips and O-Rings Tip Tip Soldapullt® Part No. Part No. Image i.d. L Replacement O-Ring Part No. AS196 LS197 .136" (3.4mm) .53" (13.5mm) ODS31 DS017 SRT12 .136" (3.4mm) .53" (13.5mm) ODS31 DS017LS LS197 .136" (3.4mm) .53" (13.5mm) ODS31 DS117 SRT12 .136" (3.4mm) .53" (13.5mm) OA193 & ODS31 DS317 LS197 .136" (3.4mm) .53" (13.5mm) OA195 & ODS31 DS517 LS561 .098" (2.5mm) .53" (13.5 mm) OA197 PT109 SRT12 .136" (3.4mm) .53" (13.5mm) OSB32 PT209 MRT16 .098" (2.5mm) .53" (13.5mm) OSB32 PT409 LS197 .136" (3.4mm) .53" (13.5mm) OSB32 SS011 LS363A .136" (3.4mm) .53" (13.5mm) OS130 SS102 LS364A .098" (2.5mm) .53" (13.5mm) OS130 SS343 LS915 .070" (1.8mm) .53" (13.5mm) OS130 SS350 LS363 .136" (3.4mm) .53" (13.5mm) OS130 SS750LS LS751 .107" (2.7mm) .50" (12.7mm) OS130 US140 SRT12 .136" (3.4mm) .53" (13.5mm) ODS31 US340 LS197 .136" (3.4mm) .53" (13.5mm) ODS31 Maintenance Tip: Use OL111 O-Ring lube for lubrication and longer tool life w w w. e d s y n . c o m 0(/.%s&!83ALES &!83ERVICE s%-!),INFO EDSYNCOM 37
DS017 价格&库存
很抱歉,暂时无法提供与“DS017”相匹配的价格&库存,您可以联系我们找货
DS017
    • 1+276.65390
    • 10+272.04300
    库存:12
