DF1B-2428SCF
DF1B-2428SCF
    HRS(广濑)
    Contacts
    端子 24-28AWG 锡
DF1B-2428SCF 数据手册
2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF1B Series ■Features 1. New Insulation Displacement and Crimping Ideas This connector is a new type to insert the ID contacts in the case. Using this method, the following merits can be gained. Cables with different current capacities can be mixed in one case ID terminal (24, 26, 28AWG) Crimping contact (20 to 30AWG) 1 By using the ID contact and crimping contact together, different current capacity cables can be mixed in one case. 2 After connection, the contact can be replaced in excellent maintainability. 3 Because the insulation displacement area is protected by the case, high reliability can be assured. 4 Since the insulation displacement process can be performed only by replacing the applicator of the existing crimping machine, no expensive machine for insulation displacement is required. 2. Potting Header Available Fig.1 Potting status The high profile header is also available, corresponding to the board potting process (sealed with resin) as waterproof measures. 3. Broad Variations The single row and double row contacts are aligned for "Board to Cable" and "In-line" series, respectively, while standard tin and gold plating products are available. (Refer to the applicable combination pattern on next page.) ■Applications Fig.2 Business equipment, particularly including the copy machine and printer B183 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) BApplicable Combination K Single Row Type Socket (Cable Side) DF1B-*S-2.5R Straight Through hole Type Pin header DF1B(Z)-*P-2.5DSA Right angle Through hole Type Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Pin header DF1B(Z)-*P-2.5DS Panel Mount Type In-line plug (Cable side) DF1BA-*EP-2.5RC K Double Row Type Socket (Cable Side) DF1B-*DS-2.5RC Straight Through hole Type Pin header DF1B(Z)-*DP-2.5DSA Right angle Through hole Type Pin header DF1B(Z)-*DP-2.5DS Panel Mount Type In-line plug (Cable side) DF1BA-*DEP-2.5RC In-line Connection Product (Cable to Cable Connection) : Full Lock Type K Single Row Type Socket (Cable Side) DF1B-*ES-2.5RC In-line plug (Cable side) DF1B-*EP-2.5RC K Double Row Type Socket (Cable Side) DF1B-*DES-2.5RC B184 In-line plug (Cable side) DF1B-*DEP-2.5RC DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■Product Specifications Current rating Rating Cable Size (Note1) Voltage rating 20 to 24AWG : 3A Operating Temperature Range -35 to +85ç (Note2) 26AWG : 2A Operating Humidity Range -40 to 80% 28AWG : 1A 30AWG : 0.5A Storage Temperature Range -10 to +60ç (Note3) Storage Humidity Range -40 to 70% (Note3) 250V AC ■UL CSA Safety File No. UL : E52653 CSA : LR95109 UL-CSA Safety Standard Standardized Value 20 to 22AWG : 3A Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Current rating Rating Cable Size (Note1) 24 to 28AWG : 1A 30AWG Voltage rating : 0.5A 30V AC Item Specification Condition 1. Insulation Resistance 1000Mø Min 500V DC 2. Withstanding voltage No flashover or insulation breakdown. 650V AC/1 minute 3. Contact Resistance 30mø Max 100mA 4. Insertor/Extraction Force MIN0.44N (45gf), MAX4.4N(450gf) Measure at the square steel pin of 0.635±0.002mm 5. Vibration No electrical discontinuity of 1μs or more 6. Humidity (Steady state) 7. Temperature Cycle 8. Operating Life 9. Resistance to Soldering heat Frequency : 10 to 55Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions. Contact resistance : 30mø max. 96 hours at temperature of 40±2ç and Insulation resistance : 1000Mø min. humidity of 90% to 95% Contact resistance : 30mø max. (-55ç : 30 minutes ➝ 5 to 35ç : 10 minutes Insulation resistance : 1000Mø min. (-85ç : 30 minutes ➝ 5 to 35ç : 10 minutes) 5 cycles Tin plating : 30 cycles Contact resistance : 30mø max. Gold plating : 50 cycles No deformation of components affecting performance. Flow : 250ç for 10 seconds Manual soldering : 300ç for 3 seconds Note 1 : Current rating of header is 3A. Note 2 : Includes temperature rise caused by current flow. Note 3 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. ■Materials / Finish Product Part Socket Insulator Polyamide White ID Contact for Socket Contact Phosphor copper Tin plated or gold plated Crimping Contact for Socket Pin Header In-line Plug Material Finish Contact Phosphor copper Tin plated or gold plated Insulator Polyamide White Contact Brass Tin plated or gold plated Insulator Polyamide White Remarks UL94V-0 –––––– –––––– UL94V-0 –––––– UL94V-0 ID Contact for In-line Plug Contact Phosphor copper Tin plated or gold plated –––––– Crimping Contact for In-line Plug Contact Phosphor copper Tin plated or gold plated –––––– B185 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. KConnector 1 q Series Name 2 3 4 5 6 r Connector Type : DF 1B w Style Symbol : Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. - * S 2.5 RC DF1B t Contact Pitch: 2.5mm y Contact Type S : Single row socket Blank : Standard type DS : Double row socket RC A : In-line Plug (Simple Lock type) P : Single row pin header DSA : Straight through hole D : Pin header (Potting type) DP : Double row pin header Z : Pin header (Standard type, Tin plated) ES : Single row in-line socket e Number of Contacts DS : ID/crimping socket (Note) : Right angle through hole Note : The single row socket DF1B-*S-2.5R DES : Double row in-line socket only adds "R" to the tail, which has Single Row : 2 to 16, 18, 20 EP : Single row in-line plug the same meaning as "RC". Double Row : 4 to 30, 34, 40 DEP : Double row in-line plug KSocket ID Contact DF1B - R 24 F A q w q 1. Connection Type e r e Packaging Type R : ID Blank : Bag w Applicable Cable Size F : Reel r Plating Type 24 : 24AWG 26 : 26AWG Blank : Tin plated 28 : 28AWG A KPlug ID Contact : Gold plated DF1B - 24 P R F q w q Applicable Cable Size e r e Connection Type R : ID 24 : 24AWG r Packaging Type 26 : 26AWG Blank : Bag 28 : 28AWG w Connector Type F : Reel P : Plug KCrimping Contact DF1B - 2428 SCF A q q Applicable Cable Size w e e Plating Type 2022 : 20 to 22AWG Blank : Tin plated 2428 : 24 to 28AWG A : Gold plated B : Gold plated (Note) 30 : 30AWG w Packaging Type Note: In case of the socket contact, SCF : Socket Contact/Reel "A" is attached to the tail of SC the product name. In case of : Socket Contact/Bag PCF : Plug Contact/Reel the plug contact, "B" is PC attached thereto. : Plug Contact/Bag Note : Product Numbers of Gold plated Plug Contact for 24 to 28 AWG cable are DF1-PD2428SCFB(Reel) and DF1-PD2428SCB(Bag). B186 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Single Row Socket Photo: Contact Inserted Unit: mm Part No. HRS No. No. of Contacts A B Part No. HRS No. No. of Contacts A DF1B- 2S-2.5R 541-0200-6 2 5 DF1B- 3S-2.5R 541-0201-9 3 7.5 2.5 DF1B-11S-2.5R 541-0209-0 11 27.5 25 5 DF1B-12S-2.5R 541-0210-0 12 30 27.5 DF1B- 4S-2.5R 541-0202-1 4 10 DF1B- 5S-2.5R 541-0203-4 5 12.5 10 7.5 DF1B-13S-2.5R 541-0211-2 13 32.5 30 DF1B-14S-2.5R 541-0212-5 14 35 32.5 DF1B- 6S-2.5R 541-0204-7 6 15 12.5 DF1B-15S-2.5R 541-0213-8 15 37.5 35 DF1B- 7S-2.5R 541-0205-0 7 17.5 15 DF1B-16S-2.5R 541-0214-0 16 40 37.5 DF1B- 8S-2.5R 541-0206-2 8 DF1B- 9S-2.5R 541-0207-5 9 20 17.5 DF1B-18S-2.5R 541-0215-3 18 45 42.5 22.5 20 DF1B-20S-2.5R 541-0216-6 20 50 47.5 DF1B-10S-2.5R 541-0208-8 10 25 22.5 RoHS Yes B RoHS Yes Note 1 : The quantity at the specific No."None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. Note 2 : The 2 contact connector contains the convex portion to prevent mis-insertion in the center at one point, which is different from the above figure. The 3 to 6 contacts connectors have the area at both ends. ■Double Row Socket Photo: Contact Inserted. Unit : mm Part No. HRS No. No. of Contacts Part No. HRS No. No. of Contacts DF1B- 4DS-2.5RC 541-0648-0 4 2.5 DF1B-22DS-2.5RC 541-0606-0 DF1B- 6DS-2.5RC 541-0649-3 6 DF1B- 8DS-2.5RC 541-0650-2 8 10 5 DF1B-24DS-2.5RC 12.5 7.5 DF1B-26DS-2.5RC DF1B-10DS-2.5RC 541-0600-4 10 15 DF1B-12DS-2.5RC 541-0601-7 12 17.5 12.5 DF1B-14DS-2.5RC 541-0602-0 14 20 DF1B-16DS-2.5RC 541-0603-2 16 22.5 17.5 DF1B-18DS-2.5RC 541-0604-5 18 25 DF1B-20DS-2.5RC 541-0605-8 20 27.5 22.5 A B 7.5 RoHS 10 15 20 Yes A B 22 30 25 541-0607-3 24 32.5 27.5 541-0608-6 26 35 30 DF1B-28DS-2.5RC 541-0609-9 28 37.5 32.5 DF1B-30DS-2.5RC 541-0610-8 30 40 35 DF1B-34DS-2.5RC 541-0612-3 34 45 40 DF1B-36DS-2.5RC 541-0613-6 36 47.5 42.5 DF1B-40DS-2.5RC 541-0615-1 40 52.5 47.5 RoHS Yes Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.) If needed, please order the product per bag. Note 2 : The 4 contact connector contains the convex portion to prevent miss-insertion in the center at one point, which is different from the above figure. B187 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ Single Row Straight Pin Header B188 +0.1 KBoard Through-hole Diameter:Ø1.1+0 Unit : mm Tin plated Gold plated Part No. HRS No. Part No. HRS No. No. of Contacts A B DF1BZ- 2P-2.5DSA 541-2000-8 DF1B- 2P-2.5DSA(01) 541-0225-7 01 2 2.5 7.5 DF1BZ- 3P-2.5DSA 541-2001-0 DF1B- 3P-2.5DSA(01) 541-0226-0 01 3 5.0 10.0 DF1BZ- 4P-2.5DSA 541-2002-3 DF1B- 4P-2.5DSA(01) 541-0227-2 01 4 7.5 12.5 DF1BZ- 5P-2.5DSA 541-2003-6 DF1B- 5P-2.5DSA(01) 541-0228-5 01 5 10.0 15.0 DF1BZ- 6P-2.5DSA 541-2004-9 DF1B- 6P-2.5DSA(01) 541-0229-8 01 6 12.5 17.5 DF1BZ- 7P-2.5DSA 541-2005-1 DF1B- 7P-2.5DSA(01) 541-0230-7 01 7 15.0 20.0 DF1BZ- 8P-2.5DSA 541-2006-4 DF1B- 8P-2.5DSA(01) 541-0231-0 01 8 17.5 22.5 DF1BZ- 9P-2.5DSA 541-2007-7 DF1B- 9P-2.5DSA(01) 541-0232-2 01 9 20.0 25.0 DF1BZ-10P-2.5DSA 541-2008-0 DF1B-10P-2.5DSA(01) 541-0233-5 01 10 22.5 27.5 Yes DF1BZ-11P-2.5DSA 541-2009-2 _________ _________ _________ DF1BZ-12P-2.5DSA 541-2010-1 DF1B-12P-2.5DSA(01) 541-0235-0 01 12 DF1BZ-13P-2.5DSA 541-2011-4 _________ _________ _________ DF1BZ-14P-2.5DSA 541-2012-7 DF1B-14P-2.5DSA(01) 541-0237-6 01 14 32.5 37.5 DF1BZ-15P-2.5DSA 541-2013-0 DF1B-15P-2.5DSA(01) 541-0238-9 01 15 35.0 40.0 DF1BZ-16P-2.5DSA 541-2014-2 DF1B-16P-2.5DSA(01) 541-0239-1 01 16 37.5 42.5 DF1BZ-18P-2.5DSA 541-2015-5 DF1B-18P-2.5DSA(01) 541-0240-0 01 18 42.5 47.5 ___ RoHS ___ 27.5 32.5 ___ ___ 20 DF1B-20P-2.5DSA(01) 541-0241-3 01 47.5 52.5 DF1BZ-20P-2.5DSA 541-2016-8 Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.) If needed, please order the product per bag. Note 2 : The 2 and 3 contact connector contains the concave portion to prevent miss-insertion in the center at one point, which is different from the above figure.In addition, the 4 to 6 contact connectors have two concave portions at both ends. DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ Single Row Right Angle Pin Header +0.1 K Board Through-hole Diameter:Ø1.1+0 Unit : mm Tin plated Gold plated Part No. HRS No. Part No. HRS No. No. of Contacts A B DF1BZ- 2P-2.5DS 541-2034-0 DF1B- 2P-2.5DS(01) 541-0225-7 01 2 2.5 7.5 DF1BZ- 3P-2.5DS 541-2035-2 DF1B- 3P-2.5DS(01) 541-0226-0 01 3 5.0 10.0 DF1BZ- 4P-2.5DS 541-2036-5 DF1B- 4P-2.5DS(01) 541-0227-2 01 4 7.5 12.5 DF1BZ- 5P-2.5DS 541-2037-8 DF1B- 5P-2.5DS(01) 541-0228-5 01 5 10.0 15.0 DF1BZ- 6P-2.5DS 541-2038-0 DF1B- 6P-2.5DS(01) 541-0229-8 01 6 12.5 17.5 DF1BZ- 7P-2.5DS 541-2039-3 DF1B- 7P-2.5DS(01) 541-0230-7 01 7 15.0 20.0 DF1BZ- 8P-2.5DS 541-2040-2 DF1B- 8P-2.5DS(01) 541-0231-0 01 8 17.5 22.5 DF1BZ- 9P-2.5DS 541-2041-5 _________ _________ _________ DF1BZ-10P-2.5DS 541-2042-8 DF1B-10P-2.5DS(01) 541-0233-5 01 10 DF1BZ-11P-2.5DS 541-2043-0 _________ _________ _________ DF1BZ-12P-2.5DS 541-2044-3 DF1B-12P-2.5DS(01) 541-0235-0 01 12 DF1BZ-13P-2.5DS 541-2045-6 _________ _________ _________ DF1BZ-14P-2.5DS 541-2046-9 DF1B-14P-2.5DS(01) 541-0237-6 01 14 32.5 37.5 DF1BZ-15P-2.5DS 541-2047-1 DF1B-15P-2.5DS(01) 541-0238-9 01 15 35.0 40.0 DF1BZ-16P-2.5DS 541-2048-4 DF1B-16P-2.5DS(01) 541-0239-1 01 16 37.5 42.5 DF1BZ-18P-2.5DS 541-2049-7 DF1B-18P-2.5DS(01) 541-0240-0 01 18 42.5 47.5 ___ RoHS ___ 22.5 27.5 Yes ___ ___ 27.5 32.5 ___ ___ 20 47.5 52.5 541-0241-3 01 Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. Note 2 : The 4 and 6 contact connector contains the concave portion to prevent miss-insertion in the center at one point, which is different from the above figure. DF1BZ-20P-2.5DS 541-2050-6 DF1B-20P-2.5DS(01) B189 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ Single Row Straight Pin Header for Potting B Tube Size Unit : mm Part No. HRS No. No. of Contacts A B 7.5 Tube Package Quantity RoHS DF1BD- 2P-2.5DSA(**) 541-0800-3 ** 2 2.5 DF1BD- 3P-2.5DSA(**) 541-0801-6 ** 3 5 10 48 DF1BD- 4P-2.5DSA(**) 541-0802-9 ** 4 7.5 12.5 38 DF1BD- 5P-2.5DSA(**) 541-0803-1 ** 5 10 15 32 DF1BD- 6P-2.5DSA(**) 541-0804-4 ** 6 12.5 17.5 27 DF1BD- 7P-2.5DSA(**) 541-0805-7 ** 7 15 20 24 DF1BD- 8P-2.5DSA(**) 541-0806-0 ** 8 17.5 22.5 21 DF1BD- 9P-2.5DSA(**) 541-0807-2 ** 9 20 25 19 DF1BD-10P-2.5DSA(**) 541-0808-5 ** 10 22.5 27.5 17 Yes [Specific No.] –* *, (* *) (05) : Tin plated (25) : Tin plated, tube packaging Note 1 : A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please order the product per pack. Note 2 : Please order the tube packaging products, multiplying the packaging quantity (pieces). Note 3 : The 2 and 3 contact connector contains the concave portion to prevent miss-insertion in the center at one point, which is different from the above figure.In addition, the 4 to 6 contacts connectors have two concave portions at both ends. BApplicable Potting Thickness : 6mm Potting status B190 64pieces +0.1 K Board Positioning Boss Hole Diameter : Ø1.1+0 +0.1 K Board Through-hole Diameter : Ø1.1+0 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ Double Row Straight Pin Header +0.1 ●Board Through-hole Diameter : Ø1.1+0 Unit : mm Tin plated Gold plated Part No. HRS No. Part No. HRS No. No. of Contacts A B DF1BZ- 4DP-2.5DSA 541-2017-0 DF1B- 4DP-2.5DSA(01) 541-0651-5 01 4 7.5 2.5 RoHS DF1BZ- 6DP-2.5DSA 541-2018-3 DF1B- 6DP-2.5DSA(01) 541-0652-8 01 6 10.0 5.0 DF1BZ- 8DP-2.5DSA 541-2019-6 DF1B- 8DP-2.5DSA(01) 541-0653-0 01 8 12.5 7.5 DF1BZ-10DP-2.5DSA 541-2020-5 DF1B-10DP-2.5DSA(01) 541-0616-4 01 10 15.0 10.0 DF1BZ-12DP-2.5DSA 541-2021-8 DF1B-12DP-2.5DSA(01) 541-0617-7 01 12 17.5 12.5 DF1BZ-14DP-2.5DSA 541-2022-0 DF1B-14DP-2.5DSA(01) 541-0618-0 01 14 20.0 15.0 DF1BZ-16DP-2.5DSA 541-2023-3 DF1B-16DP-2.5DSA(01) 541-0619-2 01 16 22.5 17.5 DF1BZ-18DP-2.5DSA 541-2024-6 DF1B-18DP-2.5DSA(01) 541-0620-1 01 18 25.0 20.0 DF1BZ-20DP-2.5DSA 541-2025-9 DF1B-20DP-2.5DSA(01) 541-0621-4 01 20 27.5 22.5 Yes DF1BZ-22DP-2.5DSA 541-2026-1 DF1B-22DP-2.5DSA(01) 541-0622-7 01 22 30.0 25.0 DF1BZ-24DP-2.5DSA 541-2027-4 DF1B-24DP-2.5DSA(01) 541-0623-0 01 24 32.5 27.5 DF1BZ-26DP-2.5DSA 541-2028-7 DF1B-26DP-2.5DSA(01) 541-0624-2 01 26 35.0 30.0 DF1BZ-28DP-2.5DSA 541-2029-0 DF1B-28DP-2.5DSA(01) 541-0625-5 01 28 37.5 32.5 DF1BZ-30DP-2.5DSA 541-2030-9 DF1B-30DP-2.5DSA(01) 541-0626-8 01 30 40.0 35.0 DF1BZ-34DP-2.5DSA 541-2031-1 DF1B-34DP-2.5DSA(01) 541-0628-3 01 34 45.0 40.0 DF1BZ-36DP-2.5DSA 541-2032-4 DF1B-36DP-2.5DSA(01) 541-0629-6 01 36 47.5 42.5 DF1BZ-40DP-2.5DSA DF1B-40DP-2.5DSA(01) 40 541-0631-8 01 541-2033-7 52.5 47.5 Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. Note 2 : The 4 and 6 contact connector contains the concave portion to prevent miss-insertion in the center area at one point, which is different from the above figure. B191 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Double Row Right Angle Pin Header B192 +0.1 K Board Through-hole Diameter : Ø1.1+0 Unit : mm Tin plated Gold plated Part No. HRS No. Part No. HRS No. No. of Contacts A B DF1BZ- 4DP-2.5DS 541-2051-9 DF1B- 4DP-2.5DS(01) 541-0654-3 01 4 7.5 2.5 RoHS DF1BZ- 6DP-2.5DS 541-2052-1 DF1B- 6DP-2.5DS(01) 541-0655-6 01 6 10.0 5.0 DF1BZ- 8DP-2.5DS 541-2053-4 DF1B- 8DP-2.5DS(01) 541-0656-9 01 8 12.5 7.5 DF1BZ-10DP-2.5DS 541-2054-7 DF1B-10DP-2.5DS(01) 541-0632-0 01 10 15.0 10.0 DF1BZ-12DP-2.5DS 541-2055-0 DF1B-12DP-2.5DS(01) 541-0633-3 01 12 17.5 12.5 DF1BZ-14DP-2.5DS 541-2056-2 DF1B-14DP-2.5DS(01) 541-0634-6 01 14 20.0 15.0 DF1BZ-16DP-2.5DS 541-2057-5 DF1B-16DP-2.5DS(01) 541-0635-9 01 16 22.5 17.5 DF1BZ-18DP-2.5DS 541-2058-8 DF1B-18DP-2.5DS(01) 541-0636-1 01 18 25.0 20.0 DF1BZ-20DP-2.5DS 541-2059-0 DF1B-20DP-2.5DS(01) 541-0637-4 01 20 27.5 22.5 Yes DF1BZ-22DP-2.5DS 541-2060-0 DF1B-22DP-2.5DS(01) 541-0638-7 01 22 30.0 25.0 DF1BZ-24DP-2.5DS 541-2061-2 DF1B-24DP-2.5DS(01) 541-0639-0 01 24 32.5 27.5 DF1BZ-26DP-2.5DS 541-2062-5 DF1B-26DP-2.5DS(01) 541-0640-9 01 26 35.0 30.0 DF1BZ-28DP-2.5DS 541-2063-8 DF1B-28DP-2.5DS(01) 541-0641-1 01 28 37.5 32.5 DF1BZ-30DP-2.5DS 541-2064-0 DF1B-30DP-2.5DS(01) 541-0642-4 01 30 40.0 35.0 DF1BZ-34DP-2.5DS 541-2065-3 DF1B-34DP-2.5DS(01) 541-0644-0 01 34 42.5 37.5 DF1BZ-36DP-2.5DS 541-2066-6 DF1B-36DP-2.5DS(01) 541-0645-2 01 36 47.5 42.5 DF1BZ-40DP-2.5DS DF1B-40DP-2.5DS(01) 40 541-0647-8 01 541-2067-9 52.5 47.5 Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. Note 2 : The 4 and 6 contact connector contains the concave portion to prevent miss-insertion in the center area at one point, which is different from the above figure. DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■ Single Row In-line Plug(Simple Lock Type) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. KApplicable Socket: DF1B-*S-2.5R Contact Inserted. Unit : mm Part No. HRS No. No. of Contacts A B Part No. HRS No. No. of Contacts A B DF1BA- 2EP-2.5RC 541-0700-9 2 2.5 7.1 DF1BA- 8EP-2.5RC 541-0706-5 8 17.5 22.1 DF1BA- 3EP-2.5RC 541-0701-1 3 5 9.6 DF1BA- 9EP-2.5RC 541-0707-8 9 20 24.6 DF1BA- 4EP-2.5RC 541-0702-4 4 7.5 12.1 DF1BA-10EP-2.5RC 541-0708-0 10 22.5 27.1 DF1BA- 5EP-2.5RC 541-0703-7 5 10 14.6 DF1BA-12EP-2.5RC 541-0710-2 12 27.5 32.1 DF1BA- 6EP-2.5RC 541-0704-0 6 12.5 17.1 DF1BA- 7EP-2.5RC 541-0705-2 7 15 19.6 RoHS Yes RoHS Yes Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. Note 2 : The 2 contacts connector contains the concave portion to prevent miss-insertion in the center area at one point, which is different from the above figure.In addition, the 3 to 6 contact connectors contain the concave portion at both sides. B Panel Cutouts Panel Unit : mm Note 3 C Applicable Plug No. of Contacts Panel Board Thickness (Note 1) D 0.5 to 1.2 1.3 to 1.6 1.7 to 2.0 DF1BA- 2EP-2.5RC 2 11.2 11.9 12.6 DF1BA- 3EP-2.5RC 3 13.7 14.4 15.1 9.8 DF1BA- 4EP-2.5RC 4 16.2 16.9 17.6 12.3 DF1BA- 5EP-2.5RC 5 18.7 19.4 20.1 14.8 DF1BA- 6EP-2.5RC 6 21.2 21.9 22.6 17.3 DF1BA- 7EP-2.5RC 7 23.7 24.4 25.1 19.8 DF1BA- 8EP-2.5RC 8 26.2 26.9 27.6 22.3 DF1BA- 9EP-2.5RC 9 28.7 29.4 30.1 24.8 DF1BA-10EP-2.5RC 10 31.2 31.9 32.6 27.3 DF1BA-12EP-2.5RC 12 36.2 36.9 37.6 32.3 7.3 Note 1 : The installation hole size C according to panel board thickness. Note 2 : Fabricate installation holes so that no burr can occur. Note 3 : At the panel tab portion, use the surface that will not be rounded. B193 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■ Double Row In-line Plug (Simple Lock Type) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. KApplicable Socket: DF1B-*DS-2.5RC Contact Inserted. Unit : mm Part No. HRS No. No. of Contacts DF1BA- 4DEP-2.5RC 541-0719-7 4 2.5 DF1BA- 6DEP-2.5RC 541-0720-6 6 5 DF1BA- 8DEP-2.5RC 541-0721-9 8 7.5 DF1BA-10DEP-2.5RC 541-0722-1 10 10 DF1BA-12DEP-2.5RC 541-0723-4 12 12.5 18.6 DF1BA-14DEP-2.5RC 541-0724-7 14 15 21.1 DF1BA-16DEP-2.5RC 541-0725-0 16 17.5 23.6 DF1BA-18DEP-2.5RC 541-0726-2 18 20 26.1 A Part No. HRS No. No. of Contacts A B 8.6 DF1BA-20DEP-2.5RC 541-0727-5 20 22.5 28.6 11.1 DF1BA-22DEP-2.5RC 541-0728-8 22 25 31.1 13.6 DF1BA-24DEP-2.5RC 541-0729-0 24 27.5 33.6 16.1 DF1BA-26DEP-2.5RC 541-0730-0 26 30 36.1 DF1BA-28DEP-2.5RC 541-0731-2 28 32.5 38.6 DF1BA-30DEP-2.5RC 541-0732-5 30 35 41.1 DF1BA-34DEP-2.5RC 541-0734-0 34 40 46.1 B RoHS Yes Yes Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. Note 2 : The 4 contacts connector contains the concave portion to prevent miss-insertion in the center at one point, which is different from the above figure. B Panel Cutouts Unit : mm C Applicable Plug No. of Contacts Panel Board Thickness (Note 1) D 0.5 to 1.2 1.3 to 1.6 1.7 to 2.0 Note 3 Panel DF1BA- 4DEP-2.5RC 4 12.7 13.4 14.1 8.8 DF1BA- 6DEP-2.5RC 6 15.2 15.9 16.6 11.3 DF1BA- 8DEP-2.5RC 8 17.7 18.4 19.1 13.8 DF1BA-10DEP-2.5RC 10 20.2 20.9 21.6 16.3 DF1BA-12DEP-2.5RC 12 22.7 23.4 24.1 18.8 DF1BA-14DEP-2.5RC 14 25.2 25.9 26.6 21.3 DF1BA-16DEP-2.5RC 16 27.7 28.4 29.1 23.8 DF1BA-18DEP-2.5RC 18 30.2 30.9 31.6 26.3 DF1BA-20DEP-2.5RC 20 32.7 33.4 34.1 28.8 DF1BA-22DEP-2.5RC 22 35.2 35.9 36.6 31.3 DF1BA-24DEP-2.5RC 24 37.7 38.4 39.1 33.8 DF1BA-26DEP-2.5RC 26 40.2 40.9 41.6 36.3 DF1BA-28DEP-2.5RC 28 42.7 43.4 44.1 38.8 DF1BA-30DEP-2.5RC 30 45.2 45.9 46.6 41.3 DF1BA-34DEP-2.5RC 34 50.2 50.9 51.6 46.3 Note 1 : The installation hole size C according to panel board thickness. Note 2 : Fabricate installation holes so that no burr can occur. Note 3 : At the panel tab portion, use the surface that will not be rounded. B194 RoHS DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■ Single Row In-line Socket (Full Lock Type) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. KApplicable Socket: DF1B-*EP-2.5RC Contact Inserted. Unit : mm Part No. HRS No. No. of Contacts A B Part No. HRS No. No. of Contacts A B DF1B- 2ES-2.5RC 541-0320-8 2 2.5 6.5 DF1B- 8ES-2.5RC 541-0326-4 8 17.5 21.5 DF1B- 3ES-2.5RC 541-0321-0 3 5 9 DF1B- 9ES-2.5RC 541-0327-7 9 20 24 DF1B- 4ES-2.5RC 541-0322-3 4 7.5 11.5 DF1B-10ES-2.5RC 541-0328-0 10 22.5 26.5 DF1B- 5ES-2.5RC 541-0323-6 5 10 14 DF1B-11ES-2.5RC 541-0329-2 11 25 29 DF1B- 6ES-2.5RC 541-0324-9 6 12.5 16.5 DF1B-12ES-2.5RC 541-0330-1 12 27.5 31.5 DF1B- 7ES-2.5RC 541-0325-1 7 15 19 DF1B-13ES-2.5RC 541-0331-4 13 30 34 RoHS Yes RoHS Yes Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. B Panel Cutouts Note 3 Panel Unit : mm E Applicable Plug No. of Contacts C D Panel Board Thickness (Note 1) 0.5 to 1.2 1.3 to 1.6 1.7 to 2.0 DF1B- 2ES-2.5RC 2 4.7 6.7 10.8 11.3 12 DF1B- 3ES-2.5RC 3 7.2 9.2 13.3 13.8 14.5 DF1B- 4ES-2.5RC 4 9.7 11.7 15.8 16.3 17 DF1B- 5ES-2.5RC 5 12.2 14.2 18.3 18.8 19.5 DF1B- 6ES-2.5RC 6 14.7 16.7 20.8 21.3 22 DF1B- 7ES-2.5RC 7 17.2 19.2 23.3 23.8 24.5 DF1B- 8ES-2.5RC 8 19.7 21.7 25.8 26.3 27 DF1B- 9ES-2.5RC 9 22.2 24.2 28.3 28.8 29.5 DF1B-10ES-2.5RC 10 24.7 26.7 30.8 31.3 32 DF1B-11ES-2.5RC 11 27.2 29.2 33.3 33.8 34.5 DF1B-12ES-2.5RC 12 29.7 31.7 35.8 36.3 37 DF1B-13ES-2.5RC 13 32.2 34.2 38.3 38.8 39.5 Note 1 : The installation hole size C will be changed according to panel board thickness. Note 2 : Fabricate installation holes so that no burr can occur. Note 3 : At the panel tab portion, use the surface that will not be rounded. B195 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■ Double Row In-line Socket (Full Lock Type) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. KApplicable Socket: DF1B-*DEP-2.5RC Contact Inserted. Unit : mm Part No. HRS No. No. of Contacts Part No. HRS No. No. of Contacts A B DF1B-10DES-2.5RC 541-0351-1 15 DF1B-24DES-2.5RC 541-0357-8 24 27.5 32.5 DF1B-12DES-2.5RC DF1B-14DES-2.5RC 12.5 17.5 DF1B-26DES-2.5RC 541-0358-0 26 30 35 15 20 DF1B-28DES-2.5RC 541-0359-3 28 32.5 37.5 16 17.5 22.5 DF1B-30DES-2.5RC 541-0360-2 30 35 40 541-0346-1 18 20 25 DF1B-32DES-2.5RC 541-0361-5 32 37.5 42.5 DF1B-20DES-2.5RC 541-0355-2 20 22.5 27.5 DF1B-34DES-2.5RC 541-0362-8 34 40 45 DF1B-22DES-2.5RC 541-0356-5 22 25 30 A B 10 10 541-0352-4 12 541-0353-7 14 DF1B-16DES-2.5RC 541-0354-0 DF1B-18DES-2.5RC RoHS Yes Yes Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. B Panel Cutouts Note 3 Panel Unit : mm C Applicable Plug No. of Contacts Panel Board Thickness (Note 1) 0.5 to 1.2 1.3 to 1.6 1.7 to 2.0 D E DF1B-10DES-2.5RC 10 19.1 19.8 20.5 15.2 3.7 DF1B-12DES-2.5RC 12 21.6 22.3 23 17.7 3.7 DF1B-14DES-2.5RC 14 24.1 24.8 25.5 20.2 3.7 DF1B-16DES-2.5RC 16 26.6 27.3 28 22.7 3.7 DF1B-18DES-2.5RC 18 29.1 29.8 30.5 25.2 3.7 DF1B-20DES-2.5RC 20 31.6 32.3 33 27.7 5.2 DF1B-22DES-2.5RC 22 34.1 34.8 35.5 30.2 5.2 DF1B-24DES-2.5RC 24 36.6 37.3 38 32.7 5.2 DF1B-26DES-2.5RC 26 39.1 39.8 40.5 35.2 5.2 DF1B-28DES-2.5RC 28 41.6 42.3 43 37.7 5.2 DF1B-30DES-2.5RC 30 44.1 44.8 45.5 40.2 5.2 DF1B-32DES-2.5RC 32 46.6 47.3 48 42.7 5.2 DF1B-34DES-2.5RC 34 49.1 49.8 50.5 45.2 5.2 Note 1 : The installation hole size C according to panel board thickness. Note 2 : Fabricate installation holes so that no burr can occur. Note 3 : At the panel tab portion, use the surface that will not be rounded. B196 RoHS DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) ■ Single Row In-line Plug (Full Lock Type) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. KApplicable Socket: DF1B-*ES-2.5RC Contact Inserted. Unit : mm Part No. HRS No. No. of Contacts A B Part No. HRS No. No. of Contacts A B DF1B- 2EP-2.5RC 541-0332-7 2 8.9 2.5 DF1B- 8EP-2.5RC 541-0338-3 8 23.9 17.5 DF1B- 3EP-2.5RC 541-0333-0 3 11.4 5 DF1B- 9EP-2.5RC 541-0339-6 9 26.4 20 DF1B- 4EP-2.5RC 541-0334-2 4 13.9 DF1B-10EP-2.5RC 541-0340-5 10 28.9 22.5 DF1B- 5EP-2.5RC 541-0335-5 5 16.4 10 DF1B-11EP-2.5RC 541-0341-8 11 31.4 25 DF1B- 6EP-2.5RC 541-0336-8 6 18.9 12.5 DF1B-12EP-2.5RC 541-0342-0 12 33.9 27.5 DF1B- 7EP-2.5RC 541-0337-0 7 21.4 15 DF1B-13EP-2.5RC 541-0343-3 13 36.4 30 7.5 RoHS Yes RoHS Yes Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. ■ Double Row In-line Plug (Full Lock Type) KApplicable Socket: DF1B-*DES-2.5RC Contact Inserted. Unit : mm Part No. HRS No. No. of Contacts A Part No. HRS No. No. of Contacts A B DF1B-10DEP-2.5RC 541-0366-9 10 17.2 DF1B-12DEP-2.5RC 541-0367-1 12 19.7 10 DF1B-24DEP-2.5RC 541-0372-1 24 34.7 27.5 12.5 DF1B-26DEP-2.5RC 541-0373-4 26 37.2 30 DF1B-14DEP-2.5RC 541-0368-4 14 22.2 15 DF1B-28DEP-2.5RC 541-0374-7 28 39.7 32.5 DF1B-16DEP-2.5RC 541-0369-7 16 24.7 17.5 DF1B-30DEP-2.5RC 541-0375-0 30 42.2 35 DF1B-18DEP-2.5RC 541-0350-9 18 27.2 20 DF1B-32DEP-2.5RC 541-0376-2 32 44.7 37.5 DF1B-20DEP-2.5RC 541-0370-6 20 29.7 22.5 DF1B-34DEP-2.5RC 541-0377-5 34 47.2 40 DF1B-22DEP-2.5RC 541-0371-9 22 32.2 25 B RoHS Yes RoHS Yes Note 1 : The quantity at the specific No. "None" is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. B197 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ ID Contact for Socket Part No. HRS No. DF1B-R24F 541-0217-9 DF1B-R24 541-0220-3 DF1B-R26F 541-0218-1 DF1B-R26 541-0221-6 DF1B-R28F 541-0219-4 DF1B-R28 541-0222-9 DF1B-R24FA(06) 541-0261-0 06 DF1B-R24A(06) 541-0264-9 06 DF1B-R26FA(06) 541-0262-3 06 DF1B-R26A(06) 541-0265-1 06 DF1B-R28FA(06) 541-0263-6 06 DF1B-R28A(06) 541-0266-4 06 Applicable Cable Applicable Cable Indication AWG UL Style Wire Construction Jacket Diameter 24 24AWG 1061 11 cores./0.16mm 0.9 to 1.39mm 26 26AWG 28 28AWG 24 24AWG 26 26AWG 28 28AWG 1007 1061 1007 1061 1061 1007 1061 1007 7 cores./0.16mm 0.9 to 1.39mm 7 cores./0.127mm 0.9 to 1.39mm 11 cores./0.16mm 0.9 to 1.39mm 7 cores./0.16mm 0.9 to 1.39mm 7 cores./0.127mm 0.9 to 1.39mm Finish RoHS 10,000/reel 100/pack 10,000/reel Tin plated 100/pack 10,000/reel 100/pack Yes 10,000/reel 100/pack 10,000/reel Gold plated 100/pack 10,000/reel 100/pack K ID Contact Extraction Tool DF-C-PO (A) Note 1 : The applicable cable conductor is the tin plated annealing copper wire. Note 2 : If other cables are used instead of the applicable cable, cotact Hirose sales department. ■ Crimping Contact for Socket K Applicable Cable (Tin Plated Annealing Copper Wire) K Recommended Cable UL1061, UL1007 Conductor Size (Wire construction) K Strip Length 20AWG (21cores/0.18mm) 2.0 to 2.5mm 22AWG (17cores/0.16mm) Note : If other cables are used instead 24AWG (11cores/0.16mm) of the applicable cable, consult 26AWG (7cores/0.16mm) Hirose sales department. 28AWG (7cores0.127mm) 30AWG (7cores/0.1mm) Applicable Part No. HRS No. DF1B-2022SCF 541-0223-1 20 DF1B-2022SC 541-0224-4 22 DF1B-2428SCF 541-0678-1 24 DF1B-2428SC 541-0679-4 28 DF1B-30SCF 541-0682-9 DF1B-30SC 541-0683-1 Cable Indication 30 DF1B-2022SCFA 541-0662-1 20 DF1B-2022SCA 541-0663-4 22 DF1B-2428SCFA 541-0680-3 24 DF1B-2428SCA 541-0681-6 28 DF1B-30SCFA 541-0684-4 DF1B-30SCA 541-0685-7 30 Applicable Cable AWG Jacket Diameter 20 to 22AWG 1.2 to 1.9mm 24 to 28AWG 0.9 to 1.5mm 30AWG 0.6 to 1.2mm 20 to 22AWG 1.2 to 1.9mm 24 to 28AWG 0.9 to 1.5mm 30AWG K Crimping Contact Extraction Tool DF-C-PO (B) B198 1061 Packaging 0.6 to 1.2mm Packaging Finish RoHS 10,000/reel 100/pack 10,000/reel 100/pack Tin plated 10,000/reel 100/pack Yes 10,000/reel 100/pack 10,000/reel 100/pack 10,000/reel 100/pack Gold plated DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ ID Contact for Plug Part No. HRS No. DF1B-24PRF 541-0666-2 DF1B-24PR 541-0667-5 DF1B-26PRF 541-0668-8 DF1B-26PR 541-0669-0 DF1B-28PRF 541-0670-0 DF1B-28PR 541-0671-2 Applicable Cable Applicable Cable Indication AWG UL Style Wire structure Jacket Diameter 24 24AWG 1061 11 pcs./0.16mm 0.9 to 1.39mm 26 26AWG 28 28AWG 1061 1007 1061 1007 Packaging Finish RoHS Tin plated Yes 10,000/reel 100/pack 10,000/reel 7 pcs./0.16mm 0.9 to 1.39mm 100/pack 10,000/reel 7 pcs./0.127mm 0.9 to 1.39mm 100/pack K ID Contact Extraction Tool DF-C-PO (C) Note 1 : The applicable cable conductor is the tin plated annealing copper wire. Note 2 : If other cables are used instead of the applicable cable, contact Hirose sales department. ■ Crimping Contact for Plug K Applicable Cable (Tin Plated Annealing Copper Wire) K Recommended Cable UL1061, UL1007 Conductor Size (Contact wire construction) K Strip Length 20AWG (21 pieces/0.18mm) 3.0 to 3.7mm 22AWG (17 pieces/0.16mm) Note : If other cables are used instead 24AWG (11 pieces/0.16mm) of the applicable cable, consult 26AWG (7 pieces/0.16mm) Hirose sales department. 28AWG (7 pieces/0.127mm) 30AWG (7 pieces/0.1mm) Part No. HRS No. Applicable cable indicator DF1B-2022PCF 541-0259-9 20 541-0260-8 22 DF1B-2428PCF 541-0664-7 24 DF1B-2428PC 541-0665-0 28 DF1B-30PCF 541-0686-0 DF1B-30PC 541-0687-2 DF1B-2022PC 30 DF1B-2022PCFB 541-0690-7 20 DF1B-2022PCB 541-0691-0 22 DF1-PD2428SCFB 541-0660-6 24 DF1-PD2428SCB 541-0661-9 28 DF1B-30PCFB 541-0688-5 DF1B-30PCB 541-0689-8 30 Applicable Cable AWG Jacket Diameter 20 to 22AWG 1.2 to 1.9mm 24 to 28AWG 0.9 to 1.5mm 30AWG 0.6 to 1.2mm 20 to 22AWG 1.2 to 1.9mm 24 to 28AWG 0.9 to 1.5mm 30AWG 0.6 to 1.2mm Packaging Treatment RoHS 10,000/reel 100/pack 10,000/reel 100/pack Tin plated 10,000/reel 100/pack Yes 10,000/reel 100/pack 10,000/reel 100/pack Gold plated 10,000/reel 100/pack K Crimping Contact Extraction Tool DF-C-PO (C) B199 DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) B Applicable Tool Connection Type Type Applicator ID Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Manual ID tool B200 Applicator Part No. HRS No. AP105-DF1B-R 901-4507-4 DF1B-R**F/FA06 **=24,26,28 Applicable Contacts AP105-DF1B-PR 901-4536-2 DF1B-**PRF**=24,26,28 DF1B-T2428HR 550-0171-0 DF1B-R**/A06**=24,26,28 DF1B-T2428PHR 550-0221-7 DF1B-**PR/PRB **=24,26,28 AP105-DF1B-2022S 901-4510-9 DF1B-2022SCF/SCFA AP105-DF1B-2428S 901-4518-0 DF1B-2428SCF/SCFA AP105-DF1B-30S 901-4517-8 DF1B-30SCF/SCFA AP105-DF1B-2022P 901-4509-0 DF1B-2022PCF/PCFB AP105-DF1B-2428P 901-4521-5 DF1B-2428PCF,DF1-PD2428SCF/SCFB AP105-DF1B-30P 901-4519-3 DF1B-30PCF/PCFB DF1B-TA2022SHC 550-0182-7 DF1B-2022SC/SCA DF1B-TA2428SHC 550-0209-1 DF1B-2428SC/SCA Manual DF1B-TA30SHC 550-0211-3 DF1B-30SC/SCA crimping tool DF1B-TA2022PHC 550-0183-0 DF1B-2022PC/PCB DF1B-TA2428PHC 550-0224-5 DF1B-2428PC,DF1-PD2428SCB DF1B-TA30PHC 550-0210-0 DF1B-30PC/PCB Crimping Press Main Unit Extraction Tool CM-105C 901-0001-0 __________________________________ DF-C-PO(A) 550-0170-8 DF1B-R**F DF-C-PO(B) 550-0179-2 DF1B-****SCF DF-C-PO(C) 550-0198-7 DF1B-****PC,DF1B-**PRF Note 1 : Please conduct crimping work according to the "Crimping quality standards" and "Crimping condition table". Note 2 : If a trouble has occurred due to tools which are not designated by Hirose, Hirose won't guarantee any product. DF1B Series●2.5mm Pitch Connector for Discrete Wire Connection (Product Compliant with UL/CSA Standard) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B Applicable Tool Powered by TCPDF (www.tcpdf.org) BPrecautions 1. Recommended Soldering Condition Flow : 250ç for 10 seconds Manual soldering : 300ç for 3 seconds 2. Cleaning Condition Refer to Wire to Board Connector Use Hand book. 3. Connection Condition Refer to Wire to Board Connector Use Hand book. 4. Cautions ■The color phase of this product is slightly different from that of the formed product according to the manufacturing lot and future storage conditions, but the difference doesn't affect the performance. 5. Precation Refer to Wire to Board Connector Use Hand book. B201
DF1B-2428SCF 价格&库存
很抱歉,暂时无法提供与“DF1B-2428SCF”相匹配的价格&库存,您可以联系我们找货
DF1B-2428SCF
    • 1+0.10081
    • 10+0.09680
    • 100+0.08480
    • 500+0.08240
    库存:38870
    DF1B-2428SCF
      • 1+0.10868
      • 5000+0.09779
      • 10000+0.07920
