KX122-1037
KX122-1037
    KIONIX(Kionix传感器)
    LGA12_2X2MM
    加速度传感器 LGA-12 Accelerometer, Gyroscope, 6 Axis 15~17367count/g 1.71~3.6V
KX122-1037 数据手册
AN049 Getting Started 1. Introduction This application note will help developers quickly implement proof-of-concept designs using the KX112, KX122, KX123 and KX124 tri-axis accelerometers. Please refer to the corresponding Product Specifications document for additional implementation guidelines. Kionix strives to ensure that our accelerometers will meet design expectations by default, but it is not possible to provide default setting to work in every environment. Depending on the intended application, it is very likely that some customization will be required to optimize performance. The information provided here will help the developer get the most out of these tri-axis accelerometers. 2. Circuit Schematic This section shows recommended wiring for this family of accelerometers, based on proven operation of the part. Specific applications may require modifications from these recommendations. Please refer to the corresponding Product Specifications document for all pin descriptions. Figure 1: KX123, KX124 Application Schematic 36 Thornwood Dr. — Ithaca, NY 14850 USA Tel: 607-257-1080 — Fax: 607-257-1146 www.kionix.com — info@kionix.com © Kionix 2019 All Rights Reserved 11 July 2019 Page 1 of 21 AN049 Figure 2: KX112, KX122 Application Schematic © Kionix 2019 All Rights Reserved 11 July 2019 Page 2 of 21 AN049 3. Quick Start Implementations Here we present several basic ways to initialize the part. These can vary based on desired operation, but generally the initial operations a developer wants to do are: 1) read back acceleration data asynchronously, 2) read back acceleration data when next data is ready via interrupt (synchronous data reading), 3) use of the sample buffer, 4) use the Wake-Up function, 5) activate the tilt position function, 6) activate the tap/double-tap function, and 7) activate the free-fall function. These cursory solutions are provided as a means for configuring the part to a known operational state. Note that these conditions just provide a starting point, and the values may vary as developers refine their application requirements. 4. Asynchronous Read Back Acceleration Data (Setting G-Range and ODR) - Write 0x40 to Control Register 1 (CNTL1) to set the accelerometer in stand-by mode, to set the performance mode to High Resolution (full power) and G-range to ±2g. Register Name CNTL1 - Address 0x1B Value 0x02 Write 0xC0 to Control Register 1 (CNTL1) to set the accelerometer into operating mode (PC1 = 1) Register Name CNTL1 - Value 0x40 Write 0x02 to Data Control Register (ODCNTL) to set the Output Data Rate (ODR) of the accelerometer to 50 Hz. (Note: This is also the default value.) Register Name ODCNTL - Address 0x18 Address 0x18 Value 0xC0 Acceleration data can now be read from the XOUT_L, XOUT_H, YOUT_L, YOUT_H, ZOUT_L, and ZOUT_H registers in 2’s complement format. © Kionix 2019 All Rights Reserved 11 July 2019 Page 3 of 21 AN049 5. Synchronous Hardware Interrupt Read Back Acceleration Data (Setting GRange and ODR) - Write 0x60 to Control Register 1 (CNTL1) to set the accelerometer in stand-by mode, to set the performance mode to High Resolution (full power), G-range to ±2g enable the availability of new data as an interrupt. Register Name CNTL1 - Address 0x1F Value 0x10 Address 0x1B Value 0x02 Write 0xE0 to Control Register 1 (CNTL1) to set the accelerometer into operating mode (PC1 = 1) Register Name CNTL1 - Value 0x38 Write 0x02 to Output Data Rate (ODR) Control Register (ODCNTL) to set the ODR of the accelerometer to 50 Hz. (Note: This is also the default value.) Register Name ODCNTL - Address 0x1C Write 0x10 to Interrupt Control Register 4 (INC4) to set the Data Ready interrupt to be reported on physical interrupt pin INT1. Register Name INC4 - Value 0x60 Write 0x38 to Interrupt Control Register (INC1) to enable physical interrupt pin INT1, to set the polarity of the physical interrupt to active high and to transmit interrupt pulses with a period of 0.03 to 0.05 msec. Register Name INC1 - Address 0x18 Address 0x18 Value 0xE0 Acceleration data can now be read from the XOUT_L, XOUT_H, YOUT_L, YOUT_H, ZOUT_L, and ZOUT_H registers in 2’s complement format. Also, the interrupt would be reflected in Bit4 (INT) of STATUS_REG and Bit4 (DRDY) in INS2 register. © Kionix 2019 All Rights Reserved 11 July 2019 Page 4 of 21 AN049 6. Sample Buffer Operation 6.1. Sample Buffer-Full Interrupt via Physical Hardware Interrupt - Write 0x00 to Control Register 1 (CNTL1) to set the accelerometer in stand-by mode, to set the performance mode of the accelerometer to Low Power mode, and G-range to ±2g. Register Name CNTL1 - Value 0x40 Address 0x1B Value 0x02 Address 0x3B Value 0xA0 Write 0x80 to Control Register 1 (CNTL1) to set the accelerometer into operating mode (PC1 = 1) Register Name CNTL1 - Address 0x1F Write 0xA0 to Buffer Control Register 2 (BUF_CNTL2) to activate the sample buffer, to set the resolution of the acceleration data samples collected to 8 bits, to enable report of the interrupt status in INS2, and set the operating mode of the sample buffer to FIFO. Register Name BUF_CNTL2 - Value 0x38 Write 0x02 to Output Data Rate (ODR) Control Register (ODCNTL) to set the ODR of the accelerometer to 50 Hz. (Note: This is also the default value.) Register Name ODCNTL - Address 0x1C Write 0x40 to Interrupt Control Register 4 (INC4) to set the Buffer Full interrupt to be reported on physical interrupt pin INT1. Register Name INC4 - Value 0x00 Write 0x38 to Interrupt Control Register (INC1) to enable physical interrupt pin INT1, to set the polarity of the physical interrupt to active high and to transmit interrupt pulses with a period of 0.03 to 0.05 msec. Register Name INC1 - Address 0x18 Address 0x18 Value 0x80 Once Buffer-Full Interrupt is issued on INT1 pin, acceleration data can then be read from the Buffer Read (BUF_READ) register at address 0x3F in 2’s complement format. Also, the interrupt would be reflected in Bit4 (INT) of STATUS_REG register and Bit6 (BFI) of INS2 register. Since the resolution of the samples data was set to 8-bit, only the most significant 8 bits of each sample will be stored in the buffer, and recorded in the following order: X_HIGH, Y_HIGH, Z_HIGH with the oldest data point read first as it is a FIFO buffer. The full buffer contains 2043 X, Y, Z elements, which corresponds to 681 unique acceleration data samples. © Kionix 2019 All Rights Reserved 11 July 2019 Page 5 of 21 AN049 6.2. Trigger Mode Buffer Operation - Ensure that the TRIG pin is can be controlled via hardware or software. The pin should be held low (inactive state) and be driven high to activate the internal trigger event. - Write 0x00 to Control Register 1 (CNTL1) to set the accelerometer in stand-by mode, to set the performance mode of the accelerometer to Low Power mode, and G-range to ±2g. Register Name CNTL1 - Address 0x1F Value 0x40 Address 0x1B Value 0x02 Choose desired number of samples to collect before and after a trigger event. To begin, we need to know the capacity of the buffer. The buffer has the capability of storing 2048 bytes of data. Design constraints limit the number of samples in the buffer to rounddown(2048/dataset_in_bytes)-1. Consider 16-bit data being stored into the buffer and a complete dataset_in_bytes=6 (3 axes * 2 bytes/axis). The resulting number of samples that can be stored in the buffer is rounddown(2048/6)-1=340. For this example, we will save time by only collecting a single sample after a trigger event. This means we need to set a threshold of 339 samples (340-339=1 sample of data after a trigger event). The sample threshold is stored in register space across 2 different registers BUF_CNTL1 (lower 8 bits) and BUF_CNTL2 (bits 9 and 10). The following is an illustration of what values need to be written to the buffer threshold low and high bytes: int smp_th = 339; char smp_th_l = (smp_th & 0xFF); char smp_th_h = ((smp_th >> 8) & 0xFF); - Value 0x38 Write 0x02 to Data Control Register (ODCNTL) to set the Output Data Rate (ODR) of the accelerometer to 50 Hz. (Note: This is also the default value). Register Name ODCNTL - Address 0x1C Write 0x40 to Interrupt Control Register 4 (INC4) to set the Buffer Full interrupt to be reported on physical interrupt pin INT1. Register Name INC4 - Value 0x00 Write 0x38 to Interrupt Control Register (INC1) to enable physical interrupt pin INT1, to set the polarity of the physical interrupt to active high and to transmit interrupt pulses with a period of 0.03 to 0.05 msec. Register Name INC1 - Address 0x18 // 0x53 // 0x01 Write 0x53 to Buffer Control Register 1 (BUF_CNTL1) as this is the value for BUF_TH[7:0]. Register Name BUF_CNTL1 Address 0x3A Value 0x53 © Kionix 2019 All Rights Reserved 11 July 2019 Page 6 of 21 AN049 - Read the contents of the Buffer Control Register 2 char buf_cntl2; Register Name BUF_CNTL2 - Address 0x3B Value (READ) buf_cntl2 Bit mask clear SMP_TH[9:8] from the value returned from the previous step. BITMASK_CLEAR(buf_cntl2, (0x3
KX122-1037 价格&库存
很抱歉,暂时无法提供与“KX122-1037”相匹配的价格&库存,您可以联系我们找货
KX122-1037
  • 1+5.01800
  • 10+4.63200
  • 30+4.55480
