TRANSISTOR (313)
FEATURE
Excellent hFE Linearity
SOT-23
Low noise
Complementary to &
MARKING:
1ˊBASE
2ˊEMITTER
3ˊCOLLECTOR
&6
MAXIMUM RATINGS (Ta=25Я unless otherwise noted)
Parameter
Value
Unit
V
Collector-Base Voltage
-60
VCEO
Collector-Emitter Voltage
-50
VEBO
Emitter-Base Voltage
V
ou
VCBO
r
Symbol
V
-150
mA
200
mW
Thermal Resistance From Junction To Ambient
625
Я/W
Tj
Junction Temperature
150
Я
Tstg
Storage Temperature
-55̚+150
Я
Collector Current
PC
Collector Power Dissipation
bl
u
RĬJA
ec
IC
ol
-5
ELECTRICAL CHARACTERISTICS (Ta=25Я unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Typ
Max
ax
UnLW
Collector-base breakdown voltage
V(BR)CBO
IC= -5uA,IE=0
-60
V
Collector-emitter breakdown voltage
V(BR)CEO
IC= -1mA , IB=0
-50
V
Emitter-base breakdown voltage
V(BR)EBO
IE= -50uA, IC=0
-5
V
Collector cut-off current
ICBO
VCB= -60 V ,
IE=0
-0.1
uA
Emitter cut-off current
IEBO
VEB= -5 V ,
IC=0
-0.1
uA
DC current gain
hFE
VCE= -6 V, IC= -1mA
Collector-emitter saturation voltage
VCE(sat)
Base-emitter voltage
VBE(on)
Transition frequency
fT
9CE=-6V,IC=-P$
Collector output capacitance
Cob
VCB=-10V,IE=0,f=1MHZ
Noise figure
NF
VCE=-6V,IC=-0.3mA,
Rg=10k,f=100HZ
3DJHI
IC= -100mA, IB=- 10mA
VCE=-6V,IC=-1.0mA
-0.58
4
-0.18
-0.3
V
-0.62
-0.68
V
MHz
4.5
7
pF
6
dB
5(9
7\SLFDO&KDUDFWHULVWLFV
Static Characteristic
(mA)
-4
IC
-16uA
DC CURRENT GAIN
COLLECTOR CURRENT
Ta=100ć
-18uA
-14uA
-2
-12uA
-10uA
-8uA
-6uA
-1
IC
COMMON EMITTER
VCE=-6V
hFE
-20uA
-3
hFE
300
COMMON
EMITTER
Ta=25ć
-4uA
200
Ta=25ć
100
IB=-2uA
-0
-0
-2
-4
-6
-8
COLLECTOR-EMITTER VOLTAGE
VCEsat
VCE
-3
-1
-0.3
(V)
IC
VBEsat
-1.2
r
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
-300
-0.8
Ta=100ć
Ta=25ć
-30
-100 -150
-30
IC
(mA)
IC
Ta=25ć
ou
-100
-10
COLLECTOR CURRENT
Ta=100ć
-0.4
ol
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
-500
-10
ȕ=10
ȕ=10
-3
-1
-10
-30
COLLECTOR CURRENT
IC
COMMON EMITTER
VCE=-6V
IC
—— VBE
Ta=25ć
-1
-0.3
-0.1
-0.2
-0.4
-0.6
-0.8
—— IC
(MHz)
TRANSITION FREQUENCY
fT
-3
COLLECTOR CURRENT
3DJHI
-30
-10
IC
(mA)
f=1MHz
IE=0/IC=0
Ta=25ć
3
-1
-0.3
PC
250
VCE=-6V
Ta=25ć
-1
— —VCB/ VEB
-3
REVERSE VOLTAGE
200
100
-100 -150
(mA)
Cob
1
-0.1
-1.0
COLLECTOR POWER DISSIPATION
PC (mW)
fT
IC
Cib
BASE-EMMITER VOLTAGE VBE (V)
300
-30
C
CAPACITANCE
-3
Cob/ Cib
Ta=100ć
-10
-10
COLLECTOR CURRENT
(pF)
-30
-3
-1
-0.5
(mA)
bl
u
COLLECTOR CURRENT
IC
(mA)
-150
-100
-0.0
-0.2
-100 -150
ec
-10
-0.3
V
-10
-20
(V)
—— Ta
200
150
100
50
50
75
AMBIENT TEMPERATURE
100
Ta
125
150
(ć )
5(9
3$&.$*(287/,1(
627
bl
u
ec
ol
ou
r
3ODVWLFVXUIDFHPRXQWHGSDFNDJHOHDGV
3DJHI
5(9
很抱歉,暂时无法提供与“A733”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.03168
- 50+0.02930
- 200+0.02732
- 600+0.02534
- 1500+0.02376
- 3000+0.02277
