A1254H-2P
A1254H-2P
    CJT(长江连接器)
    Housings
    间距P=1.25mm 胶壳 2pin 125V 1A
A1254H-2P 数据手册
A1254 SERIES 1.25mm pitch wire to board connector Specifications Current rating:1A AC,DC Voltage rating:125V AC,DC Temperature range:-40°C~+105°C Contact resistance:20mΩMax. Insulation resistance:100MΩMin. Withstanding voltage:500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 1.95 7.30 REF CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-60 A1254 SERIES A1254-T 1.25mm pitch wire to board connector 1.25mm pitch Crimp Terminal Reference Informations: *Used in CJT A1254H-XP series Housing 0.15 1.45±0.25 0.50 1.20±0.25 SEC:A-A 2.75±0.25 1.05±0.25 0.90 SEC:B-B 1.04±0.25 3.00±0.25 B 0.73 B 0.25 0.70 A 5.50±0.25 A 0.40 Ordering information & Specifications: Unit:mm Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A1254-TP AWG#28-#32 0.90mm(max) Phosphor Bronze Tin over Nickel 10,000 PCS AWG#28-#32 0.90mm(max) Phosphor Bronze Gold over Nickel 10,000 PCS A1254-GP Optional Gold plating available but MOQ requested A1254H-XP 1.25mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A1254-T series Terminal *Mates with CJT A1254WR-S-XP series Wafer *Color:White Ordering Information: A1254H-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ Circuit 1 1.25±0.10 A±0.20 1.00 C±0.25 1.30±0.25 6.20±0.25 B±0.25 1.00 Ordering Information & Dimensions: 1.80±0.25 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P Dimensions A B C 1.25 5.72 2.72 2.50 3.97 6.97 3.75 5.22 8.22 5.00 6.47 9.47 6.25 7.72 10.72 7.50 8.97 11.97 8.75 10.22 13.22 10.00 11.47 14.47 11.25 12.72 15.72 12.50 13.97 16.97 13.75 15.22 18.22 15.00 16.47 19.47 16.25 17.72 20.72 17.50 18.97 21.97 18.75 20.22 23.22 PART NO. 17P 18P 19P 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P Dimensions A B C 20.00 21.47 24.47 21.25 22.72 25.72 22.50 23.97 26.97 23.75 25.22 28.22 25.00 26.47 29.47 26.25 27.72 30.72 27.50 28.97 31.97 28.75 30.22 33.22 30.00 31.47 34.47 31.25 32.72 35.72 32.50 33.97 36.97 33.75 35.22 38.22 35.00 36.47 39.47 36.25 37.72 40.72 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-61 A1254 SERIES A1254HA-XP 1.25mm pitch wire to board connector 1.25mm pitch Housing Ordering Information: A1254HA-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ 1.64±0.20 9.10±0.25 4.20±0.20 1.20±0.20 1.20±0.20 6.60±0.25 8.60±0.25 11.10±0.25 (9.64)±0.30 (12.14)±0.30 3.75±0.20 1.25±0.10 Circuit 1 6.20±0.25 Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A1254-T series Terminal *Color:White 2.15±0.25 6.25±0.20 Circuit 1 1.25±0.10 A1254HA-4P A1254HA-6P Unit: mm 1.25mm pitch 90° Wafer-SMT TYPE Reference Informations: *Material:Pin:Brass/Tin over Nickel on solder area Gold over Nickel on contact area Solder Tabs:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A1254H-XP series Housing *Color:Beige A±0.10 2.25±0.10 0.40 1.30±0.10 P.C.B. LAYOUT 3.35±0.10 0.80±0.05 A±0.20 1.25±0.10 1.25±0.10 2.20±0.10 1.90±0.10 A1254WR-S-XP Ordering Information: A1254WR-S-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT :Nylon 6T,UL94V-0 GWT 750 ℃ Ordering Information & Dimensions: 2.67±0.25 PART NO. 0.76 5.50±0.25 1.00 1.85 B±0.25 Circuit 1 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P Dimensions A B 1.25 7.65 2.50 8.90 3.75 10.15 5.00 11.40 6.25 12.65 7.50 13.90 8.75 15.15 10.00 16.40 11.25 17.65 12.50 18.90 13.75 20.15 15.00 21.40 16.25 22.65 17.50 23.90 18.75 25.15 PART NO. 17P 18P 19P 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P Dimensions A B 20.00 26.40 21.25 27.65 22.50 28.90 23.75 30.15 25.00 31.40 26.25 32.65 27.50 33.90 28.75 35.15 30.00 36.40 31.25 37.65 32.50 38.90 33.75 40.15 35.00 41.40 36.25 42.65 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-62
A1254H-2P 价格&库存
很抱歉,暂时无法提供与“A1254H-2P”相匹配的价格&库存,您可以联系我们找货
A1254H-2P
    • 1+0.10260
    库存:57
