A1255H-2P
A1255H-2P
    CJT(长江连接器)
    Housings
    间距P=1.25mm 胶壳 2pin 150V 1A
A1255H-2P 数据手册
A1255 SERIES 1.25mm pitch wire to board connector Specifications Current rating:1A AC,DC Voltage rating:150V AC,DC Temperature range:-40°C~+105°C Contact resistance:30m Max. Insulation resistance:500M Min. Withstanding voltage:500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 2.60 7.35 REF 2.60 7.35 REF E326732 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-63 A1255 SERIES A1255-T 1.25mm pitch wire to board connector 1.25mm pitch Crimp Terminal Reference Informations: *Used in CJT A1255H-XP series Housing 1.57±0.25 0.15 0.50 1.70±0.25 SEC:A-A 1.25±0.25 C SEC:B-B 1.00±0.15 0.82 0.76 1.21±0.25 C 1.08±0.15 B 2.22±0.25 B 1.05 A 5.00±0.25 A SEC:C-C Ordering information & Specifications: Unit:mm Wire Range Insulation O.D. Material Finish Qty/reel A1255-TP AWG#26-#32 1.00mm(max) Phosphor Bronze Tin over Nickel 10,000 PCS A1255-GP AWG#26-#32 1.00mm(max) Phosphor Bronze Gold over Nickel 10,000 PCS Part NO. Optional Gold plating available but MOQ requested A1255MA-T Reference Informations: *Used in CJT A1255HMA-XP series Housing 0.30 1.34±0.25 0.50 R0.30 0.90 1.24±0.25 R0.30 SEC:B-B 1.15±0.25 C 1.21 C 1.45 B 0.70 B 0.30 7.83±0.25 A SEC:A-A 1.10±0.25 3.89±0.25 A 1.75±0.25 1.25mm pitch Crimp Terminal 0.80 0.90±0.25 0.30 0.40 0.40±0.20 SEC:C-C Ordering information & Specifications: Unit:mm Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A1255MA-TP AWG#28-#32 0.90mm(max) Phosphor Bronze Tin over Nickel 15,000 PCS A1255MA-GP AWG#28-#32 0.90mm(max) Phosphor Bronze Gold over Nickel 15,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-64 A1255 SERIES A1255H-XP 1.25mm pitch wire to board connector 1.25mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitble CJT A1255-T series Terminal *Mates with CJT A1255WR-S,WR-S-F-XP series Wafer *Color:Gray Circuit 1 Ordering Information: A1255H-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ Ordering Information & Dimensions: 1.25±0.10 PART NO. A±0.20 5.80±0.25 1.55±0.25 2.35±0.25 B±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 20P 25P 30P Dimensions A B 1.25 4.35 2.50 5.60 3.75 6.85 5.00 8.10 6.25 9.35 7.50 10.60 8.75 11.85 10.00 13.10 11.25 14.35 12.50 15.60 13.75 16.85 15.00 18.10 16.25 19.35 17.50 20.60 23.75 26.85 30.00 33.10 36.25 39.35 Unit: mm A1255HA-XP 1.25mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitble CJT A1256-T series Terminal *Mates with CJT A1255HMA-XP series Housing or A1255WVA-S,WRA-S-XP series Wafer *Color:White Ordering Information: A1255HA-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ Circuit 1 Ordering Information & Dimensions: PART NO. 1.25±0.10 A±0.20 5.80±0.25 1.50±0.25 10 B±0.25 2.00±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 20P 25P 30P Dimensions A B 1.25 4.35 2.50 5.60 3.75 6.85 5.00 8.10 6.25 9.35 7.50 10.60 8.75 11.85 10.00 13.10 11.25 14.35 12.50 15.60 13.75 16.85 15.00 18.10 16.25 19.35 17.50 20.60 23.75 26.85 30.00 33.10 36.25 39.35 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-65 A1255 SERIES A1255HMA-XP 1.25mm pitch wire to board connector 1.25mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitble CJT A1255MA-T series Terminal *Mates with CJT A1255HA-XP series Housing *Color:White Ordering Information: A1255HMA-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ A±0.20 1.25±0.10 Ordering Information & Dimensions: Circuit 1 PART NO. 2.70±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 20P 25P 9.90±0.25 5.00±0.25 B±0.25 2.90±0.25 Dimensions A B 1.25 4.50 2.50 5.75 3.75 7.00 5.00 8.25 6.25 9.50 7.50 10.75 8.75 12.00 10.00 13.25 11.25 14.50 12.50 15.75 13.75 17.00 15.00 18.25 16.25 19.50 17.50 20.75 23.75 22.00 30.00 33.25 Unit: mm A1255WR-S-XP 1.25mm pitch 90° Wafer Without Boss -SMT TYPE Ordering Information: A1255WR-S-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 9T,UL94V-0 GWT:Nylon 9T,UL94V-0,GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Solder Tabs:Brass/Tin over Nickel Insulator:Nylon 9T,UL94V-0 *Mates with CJT A1255H-XP series Housing *Color:Ivory A±0.20 0.30 2.60±0.10 1.25±0.10 2.40±0.10 7.30±0.20 1.80±0.10 2.00±0.10 0.70±0.05 1.25±0.05 A±0.10 B±0.25 Circuit 1 2.50±0.25 P.C.B. LAYOUT 5.70±0.25 1.10 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 20P 25P 30P Dimensions A B 1.25 7.45 2.50 8.70 3.75 9.95 5.00 11.20 6.25 12.45 7.50 13.70 8.75 14.95 10.00 16.20 11.25 17.45 12.50 18.70 13.75 19.95 15.00 21.20 16.25 22.45 17.50 23.70 23.75 29.95 30.00 36.20 36.25 42.45 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-66 A1255 SERIES A1255WR-S-F-XP 1.25mm pitch 90° Wafer With Boss-SMT TYPE Ordering Information: A1255WR-S-F-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 9T,UL94V-0 GWT:Nylon 9T,UL94V-0,GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Solder Tabs:Brass/Tin over Nickel Insulator:Nylon 9T,UL94V-0 *Mates with CJT A1255H-XP series Housing *Color:Ivory 2.60±0.10 A±0.20 0.30 2.40±0.10 2.00±0.10 Ordering Information & Dimensions: 5.30±0.10 1.25±0.10 1.25mm pitch wire to board connector 1.80±0.10 2.00±0.10 ∅1.10+0.10 -0.00 PART NO. 2.60±0.10 0.70 1.25±0.05 A±0.10 P.C.B. LAYOUT B±0.25 5.70±0.25 1.10 2.50 Circuit 1 0.60 ∅0.90 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 20P 25P 30P Dimensions A B 1.25 7.45 2.50 8.70 3.75 9.95 5.00 11.20 6.25 12.45 7.50 13.70 8.75 14.95 10.00 16.20 11.25 17.45 12.50 18.70 13.75 19.95 15.00 21.20 16.25 22.45 17.50 23.70 23.75 29.95 30.00 36.20 36.25 42.45 Unit: mm A1255WVA-S-XP 2.50±0.20 1.25 0.70 A±0.20 Ordering Information: A1255WVA-S-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel 1.80±0.20 3.79±0.20 1.00 1.80±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Solder Tabs:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A1255HA-XP series Housing *Color:Beige 1.25mm pitch 180° Wafer Without Boss -SMT TYPE P.C.B LAYOUT A±0.20 A±0.20 1.28 0.30 Circuit 1 0.59 0.94 B±0.25 1.28 1.25±0.10 0.59 Circuit 1 0.94 0.30 Ordering Information & Dimensions: 0.75 1.25±0.10 PART NO. CAP (FOR PICK AND PLACE SYSTEMS) B±0.25 6.05±0.25 2.60 2P~15P,20P 3.35±0.20 25P,30P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 20P 25P 30P Dimensions A B 1.25 7.45 2.50 8.70 3.75 9.95 5.00 11.20 6.25 12.45 7.50 13.70 8.75 14.95 10.00 16.20 11.25 17.45 12.50 18.70 13.75 19.95 15.00 21.20 16.25 22.45 17.50 23.70 23.75 29.95 30.00 36.20 36.25 42.45 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-67 A1255 SERIES 1.25mm pitch 90° Wafer Without Boss -SMT TYPE 0.59 0.94 1.28 1.25±0.10 2.00±0.20 2.40±0.20 0.70 1.25±0.10 A±0.20 P.C.B LAYOUT Ordering Information & Dimensions: 0.30 0.59 Circuit 1 0.94 1.28 1.25±0.10 A±0.20 PART NO. 2P~15P,20P 5.70±0.20 B±0.25 5.70±0.20 1.10±0.20 A±0.20 Ordering Information: A1255WRA-S-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel 2.60±0.20 Circuit 1 0.30 2.60±0.20 7.30±0.20 2.60±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Solder Tabs:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A1255HA-XP series Housing *Color:Beige 1.80±0.20 A1255WRA-S-XP 1.25mm pitch wire to board connector B±0.20 25P,30P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 20P 25P 30P Dimensions A B 1.25 7.45 2.50 8.70 3.75 9.95 5.00 11.20 6.25 12.45 7.50 13.70 8.75 14.95 10.00 16.20 11.25 17.45 12.50 18.70 13.75 19.95 15.00 21.20 16.25 22.45 17.50 23.70 23.75 29.95 30.00 36.20 36.25 42.45 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-68
A1255H-2P 价格&库存
很抱歉,暂时无法提供与“A1255H-2P”相匹配的价格&库存,您可以联系我们找货
A1255H-2P
    • 1+0.34370
    库存:10
