B1501H-5P
B1501H-5P
    CJT(长江连接器)
    Housings
    间距P=1.50mm 胶壳 5pin 200V 1A
B1501H-5P 数据手册
B1501 SERIES 1.50mm pitch board-in connector Specifications Current rating:1A AC,DC Voltage rating:200V AC,DC Temperature range:-40°C~+105°C Contact resistance:20mΩMax. Insulation resistance:500MΩMin. Withstanding voltage:500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 1.30 REF. 0.80 2.70 4.30 2.85 REF. CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-8 B1501 SERIES B1501-T 1.50mm pitch board-in connector 1.50mm pitch Crimp Terminal 1.75±0.25 Reference Informations: *Used in CJT B1501H-XP series Housing 0.20 A SEC:A-A 1.68±0.25 1.20 0.80 B SEC:C-C SEC:B-B 0.95 0.75 B 4.10±0.25 4.00±0.25 0.64 0.74 C 1.50±0.25 A C 1.10±0.20 0.45 1.65±0.25 1.75 Ordering information & Specifications: Unit:mm Part NO. Wire Range Insulation O.D. Material Finish Qty/reel B1501-TP AWG#28-#30 1.00mm(max) Phosphor Bronze Tin over Nickel 15,000 PCS B1501-GP AWG#28-#30 1.00mm(max) Phosphor Bronze Gold over Nickel 15,000 PCS Optional Gold plating available but MOQ requested B1501H-XP 1.50mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT B1501-T series Terminal *Color:White Ordering Information: B1501H-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 1.50±0.05 1.50±0.10 Ordering Information & Dimensions: +0.10 ∅0.70-0.00 A±0.20 PART NO. P.C.B LAYOUT B±0.25 4.30±0.25 2.70±0.25 Circuit 1 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 1.50 3.70 3.00 5.20 4.50 6.70 6.00 8.20 7.50 9.70 9.00 11.20 10.50 12.70 12.00 14.20 13.50 15.70 15.00 17.20 16.50 18.70 18.00 20.20 19.50 21.70 21.00 23.20 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-9
B1501H-5P 价格&库存
很抱歉,暂时无法提供与“B1501H-5P”相匹配的价格&库存,您可以联系我们找货
B1501H-5P
    • 1+0.28970
    库存:280
