B1502H-2P
B1502H-2P
    CJT(长江连接器)
    Housings
    间距P=1.50mm 胶壳 2pin 200V 1A
B1502H-2P 数据手册
B1502 SERIES 1.50mm pitch board-in connector Specifications Current rating:1A AC,DC Voltage rating:200V AC,DC Temperature range:-40°C~+105°C Contact resistance:20mΩMax. Insulation resistance:500MΩMin. Withstanding voltage:500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 1.47 REF. 0.80 4.30±0.25 2.70±0.25 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-10 B1502 SERIES B1502-T 1.50mm pitch board-in connector 1.50mm pitch Crimp Terminal Reference Informations: *Used in CJT B1502H-XP series Housing 1.90±0.25 1.70±0.25 0.60 0.20 SEC:A-A 1.50±0.25 C C 0.90 1.50±0.25 B 0.30 3.50 B 6.15±0.25 A 0.70 A SEC:B-B 1.20±0.25 SEC:C-C 1.50±0.25 0.50±0.05 0.70±0.15 Unit:mm Ordering information & Specifications: Wire Range Part NO. B1502-TB B1502-TP B1502-GB B1502-GP AWG#28-#30 AWG#28-#30 AWG#28-#30 AWG#28-#30 Material Brass Phosphor Bronze Insulation O.D. 1.00mm(max) 1.00mm(max) 1.00mm(max) 1.00mm(max) Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 10,000 PCS 10,000 PCS 10,000 PCS 10,000 PCS Optional Gold plating available but MOQ requested B1502H-XP 1.50mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT B1502-T series Terminal *Color:White Ordering Information: B1502H-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C Circuit 1 1.50±0.05 1.50±0.10 A±0.20 +0.10 ∅0.70-0.00 Ordering Information & Dimensions: P.C.B LAYOUT PART NO. 2.70±0.25 4.30±0.25 B±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 1.50 3.70 3.00 5.20 4.50 6.70 6.00 8.20 7.50 9.70 9.00 11.20 10.50 12.70 12.00 14.20 13.50 15.70 15.00 17.20 16.50 18.70 18.00 20.20 19.50 21.70 21.00 23.20 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-11
B1502H-2P 价格&库存
很抱歉,暂时无法提供与“B1502H-2P”相匹配的价格&库存,您可以联系我们找货
B1502H-2P
    • 1+0.12560
    库存:600
    B1502H-2P
      • 1000+0.09300
      库存:19000
