B2011H-7P
B2011H-7P
    CJT(长江连接器)
    Housings
    间距P=1.50mm 胶壳 7pin 250V 1A
B2011H-7P 数据手册
B2011 SERIES 2.00mm pitch board-in connector Specifications Current rating:1A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:20mΩMax. Insulation resistance:500MΩMin. Withstanding voltage:1000V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free need to customize* *Contact CJT for details* Standards E326732 E326732 0.80 2.25 REF. 6.15 3.50 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-13 B2011 SERIES B2011-T 2.00mm pitch board-in connector 2.00mm pitch Crimp Terminal 2.35±0.25 Reference Informations: *Used in CJT B2011H-XP series Housing 1.00±0.20 2.35±0.25 0.20 1.40±0.20 SEC:A-A 1.55±0.20 1.30 0.40 1.75±0.20 1.20±0.20 9.30±0.25 SEC:B-B 1.45±0.20 0.90±0.10 SEC:C-C 0.65±0.10 Unit:mm Ordering information & Specifications: Wire Range Part NO. Insulation O.D. 1.30mm(max) AWG#24-#30 B2011-TB 1.30mm(max) B2011-TP AWG#24-#30 1.30mm(max) B2011-GB AWG#24-#30 1.30mm(max) B2011-GP AWG#24-#30 Optional Gold plating available but MOQ requested B2011-T-A Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 10,000 PCS 10,000 PCS 10,000 PCS 10,000 PCS 2.00mm pitch Crimp Terminal Reference Informations: *Used in CJT B2011HA-XP series Housing 1.90±0.20 0.50 SEC:A-A SEC:B-B 0.82±0.05 1.55±0.20 0.50 SEC:C-C 1.55±0.20 C 4.15±0.20 C 0.40 1.05 B 1.05 B 1.40±0.20 A 7.45±0.25 A 1.50±0.20 1.80±0.20 0.20 Ø1.50 Unit:mm Ordering information & Specifications: Wire Range Part NO. Insulation O.D. 1.00mm(max) AWG#28-#30 B2011-TB-A 1.00mm(max) B2011-TP-A AWG#28-#30 1.00mm(max) B2011-GB-A AWG#28-#30 1.00mm(max) B2011-GP-A AWG#28-#30 Optional Gold plating available but MOQ requested Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 10,000 PCS 10,000 PCS 10,000 PCS 10,000 PCS CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-14 B2011 SERIES B2011H-XP 2.00mm pitch board-in connector 2.00mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT B2011-T series Terminal *Color:White Ordering Information: B2011H-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 2.00±0.10 2.00±0.10 Ordering Information & Dimensions: Ø0.80 A±0.20 PART NO. P.C.B LAYOUT 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 6.15±0.25 5.75±0.20 B±0.25 3.50±0.20 Circuit 1 Dimensions A B 2.00 5.20 4.00 7.20 6.00 9.20 8.00 11.20 10.00 13.20 12.00 15.20 14.00 17.20 16.00 19.20 18.00 21.20 20.00 23.20 22.00 25.20 24.00 27.20 26.00 29.20 28.00 31.20 30.00 33.20 Unit: mm B2011HA-XP 2.00mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT B2011-T-A series Terminal *Color:White Ordering Information: B2011HA-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 2.00±0.10 Ø0.80 2.00±0.10 Ordering Information & Dimensions: P.C.B LAYOUT PART NO. A±0.20 B±0.25 4.92±0.20 2.84±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P Dimensions A B 2.00 4.40 4.00 6.40 6.00 8.40 8.00 10.40 10.00 12.40 12.00 14.40 14.00 16.40 16.00 18.40 18.00 20.40 20.00 22.40 22.00 24.40 24.00 26.40 26.00 28.40 28.00 30.40 30.00 32.40 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-15
B2011H-7P 价格&库存
很抱歉,暂时无法提供与“B2011H-7P”相匹配的价格&库存,您可以联系我们找货
