MYC-C7Z015-4E1D-766-I
    MYIR(米尔科技)
    Xilinx ARM Cortex A9 核心板 C7Z015 766MHz RAM 1GB 5V DDR3 4GB eMMC
MYC-C7Z015-4E1D-766-I 数据手册
MYD-C7Z015 Development Board ➢ ➢ ➢ ➢ ➢ ➢ ➢ ➢ MYC-C7Z015 CPU Module as Controller Board Two 0.8mm pitch 140-pin Connectors for Board-to-Board Connections 667MHz Xilinx XC7Z015 Dual-core ARM Cortex-A9 Processor with Xilinx 7-series FPGA logic 1GB DDR3 SDRAM (2 x 512MB, 32-bit), 4GB eMMC, 32MB QSPI Flash Serial port, 4 x USB2.0 Host, Gigabit Ethernet, CAN, RTC, HDMI, LCD, TF 1 x XADC, 3 x PMoD, 1 x FMC, 1 x SFP Transceiver Module, 1 x PCIe Optional 4.3- or 7-inch LCD/TSP Ready-to-Run Linux 4.14.0 Figure 1-1 MYD-C7Z015 Development Board The MYD-C7Z015 development board is a programmable, low-cost and high-performance board designed by MYIR. It integrates Xilinx XC7Z015 (Z-7015) Dual-core ARM Cortex-A9 Processor with Xilinx 7-series FPGA logic from Xilinx Zynq-7000 family, with one PCIe interface and one SFP transceiver module interface on the base board to allow users to expand numerous of high-speed devices. It’s typically applications ranges from Industrial Automation, Test & measurement, Medical Equipment, Aerospace to military and more others. The MYD-C7Z015 development board is using the MYC-C7Z015 CPU Module as the core controller board which integrates the core components including the Zynq-7015 processor, 1GB DDR3 SDRAM, 4GB eMMC, 32MB quad SPI Flash, a Gigabit Ethernet PHY, a USB PHY and external watchdog. The MYC-C7Z015 CPU Module is mounted on to the MYD-C7Z015 base board through two 0.8mm pitch 140-pin Board-to-Board connectors. Compared with the Zynq-7010, the processor Zynq-7015, has more logic cells, Block RAM and DSP slices, which makes the board obtain more powerful programmable function for users. The MYD-C7Z015 development board takes full features of the Zynq-7015 SoC to create a rich set of peripherals to the base board through headers and connectors including one RS232 serial port, four USB Host ports, one Gigabit Ethernet port, CAN, HDMI, LCD/Touch screen, TF card slot, RTC, one XADC header to allow you take advantage of Xilinx XADC and one low-pin count FMC connector to allow various FMC cards for custom I/O options. Especially, it has one SFP transceiver module to keep higher transmission speed and better stability during your evaluation, as well as one PCIe interface, which contributes the data transmission speed to a high frequency when customers using the board. 1 / 10 Figure 1-2 MYD-XC7Z015 Development Board The MYD-C7Z015 development board is preloaded with Linux and delivered with necessary cable accessories. It is a high-performance and low-cost development platform for evaluation and prototype based on Xilinx Zynq-7000 All Programmable SoC family. Hardware Specification The Zynq™-7000 family of devices combines the software programmability of a Processor with the hardware programmability of an FPGA, resulting in unrivaled levels of system performance, flexibility, scalability while providing system benefits in terms of power reduction, lower cost with fast time to market. Unlike traditional SoC processing solutions, the flexible programmable logic of the Zynq-7000 devices enables optimization and differentiation, allowing designers to add peripherals and accelerators to adapt to a broad base of applications. The Zynq-7000 AP SoC leverages the 28nm scalable optimized programmable logic used in Xilinx’s 7 series FPGAs. Each device is designed to meet unique requirements across many use cases and applications. The Z-7010, Z-7015, and Z-7020 leverage the Artix® -7 FPGA programmable logic and offer lower power and lower cost for high-volume applications. The Z-7030, Z-7035, Z-7045, and Z-7100 are based on the Kintex® -7 FPGA programmable logic for higher-end applications that require higher performance and high I/O throughput. 2 / 10 Z-7010 Z-7015 Processor Core Z-7020 Z-7030 Z-7035 Z-7045 Z-7100 Dual ARM® Cortex™-A9 MPCore™ with CoreSight™ Processor NEON™ & Single / Double Precision Floating Point for each processor Extensions L1 Cache 32 KB Instruction, 32 KB Data per processor L2 Cache 512 KB On-Chip 256 KB Memory Memory DDR3, DDR3L, DDR2, LPDDR2, 2x Quad-SPI, NAND, NOR Interfaces Peripherals 2x USB 2.0 (OTG), 2x Tri-mode Gigabit Ethernet, 2x SD/SDIO 28K Logic 74K Logic 85K Logic 125K Logic 275K Logic 350K Logic Cells Cells Cells Cells Cells Cells BlockRAM (Mb) 240 KB 380 KB 560 KB 1,060 KB 2,000 KB 2,180 KB 3,020 KB DSP Slices 80 160 220 400 900 900 2,020 Logic Cells Transceiver 4 (6.25 up to 4 up to 16 up to 16 Count Gb/s) (12.5 Gb/s) (12.5 Gb/s) (12.5 Gb/s) Table 1-1 ZYNQ-7000 Devices 3 / 10 444K Logic Cells up to 16 (10.3125 Gb/s) Figure 1-3 Zynq-7000 Devices Mechanical Parameters ✓ Dimensions: 190mm x 110mm (base board), 75mm x 55mm (CPU Module) ✓ PCB layers: 4-layer design (base board), 12-layer design (CPU Module) ✓ Power supply: 12V/0.5A (base board), 5V/0.5A (CPU Module) ✓ Working temp.: 0~70 Celsius (commercial grade) or -40~85 Celsius (industrial grade) The MYD-C7Z015 Controller Board (MYC-C7Z015 CPU Module) Figure 1-4 MYC-C7Z015 CPU Module Top-view Figure 1-5 MYC-C7Z015 CPU Module Bottom-view 4 / 10 SoC ✓ Xilinx XC7Z015-1CLG485C (Zynq-7015) - 667MHz ARM® dual-core Cortex™-A9 MPCore processor (up to 866MHz) - Integrated Artix-7 class FPGA subsystem with 74K logic cells, 46,200 LUTs, 160 DSP slices - NEON™ & Single / Double Precision Floating Point for each processor - Supports a Variety of Static and Dynamic Memory Interfaces - Four high-speed SerDes transceivers up to 6.25Gbps - Four PCIe Gen2 hardened, integrated IP blocks Memory ✓ 1GB DDR3 SDRAM (512MB*2) ✓ 4GB eMMC ✓ 32MB QSPI Flash (16MB is optional) Peripherals and Signals Routed to Pins ✓ One10/100/1000M Ethernet PHY ✓ One USB PHY ✓ External watchdog ✓ Three LEDs - One blue LED for power indicator - One red LED for FPGA program done indicator - One green user LED ✓ Two 0.8mm pitch 140-pin board-to-board expansion connectors bring out below signals: - One Gigabit Ethernet (PS Ethernet 0) - One USB OTG 2.0 (PS USB 0) - Up to two Serial ports (reused from PS_MIO, can also be implemented through PL pins) - Up to two I2C (reused from PS_MIO, can also be implemented through PL pins) - Up to two CAN BUS (reused from PS_MIO, can also be implemented through PL pins) - One SPI (reused from PS_MIO, can also be implemented through PL pins) - ADC (one independent differential ADC, 16-channel ADC brought out through PL pins) - One SDIO (PS SDIO 0) - Bank 13 (PL I/O configurable as up to 18 LVDS pairs and 1 single-ended I/O or 37 single-ended I/O) - Bank 34 (PL I/O configurable as up to 24 LVDS pairs and 2 single-ended I/O or 50 single-ended I/O) - Bank 35 (PL I/O configurable as up to 24 LVDS pairs and 2 single-ended I/O or 50 single-ended I/O) - Bank 112 (4 GTP serial transceivers, 2 reference clock input) 5 / 10 The MYD-C7Z015 Base Board (MYB-C7Z015) Figure 1-6 MYD-C7Z015 Base Board for MYC-C7Z015 CPU Module PS Unit ✓ Four USB 2.0 Host ports (through USB Hub) ✓ One RS232 (DB9 port) ✓ One TF card slot (bootable) ✓ One CAN interface ✓ One 10/100/1000M Ethernet ✓ One 2.54mm pitch 14-pin JTAG interface (PS, PL reused) ✓ Battery backed RTC ✓ One User Button (One I2C, can be connected to LCD and Resistive Touch Screen) ✓ Jumpers - One for booting selection from TF card or QSPI - One for JTAG selection for using PS and PL reused or independent JTAG configured through PL pins - One for selection if adding FMC module to JTAG PL Unit ✓ One XADC interface ✓ One Xilinx standard LPFMC interface ✓ One HDMI interface (16-bit YCrCb, support 1080p display, do not support audio) ✓ LCD/Touch screen interface (16-bit RGB, signals reused with HDMI, supports resistive and capacitive touch screen) ✓ Two LEDS (one for FMC module detection, one for power indicator) ✓ Three-channel PMoD ✓ One SFP transceiver module with RJ45 interface (SFP-GE-T module, up to 1000Mbps) ✓ One PCIe interface 6 / 10 Function Block Diagram Figure 1-7 MYC-C7Z015 CPU Module Function Block Diagram Figure 1-8 MYD-C7Z015 Development Board Function Block Diagram 7 / 10 Dimension Chart Figure 1-9 Dimensions of MYC-C7Z015CPU Module Figure 1-10 Dimensions of MYD-C7Z015 Development Board 8 / 10 Software Features The MYC-C7Z015CPU Module is capable of running Linux 4.14.0. MYIR provides software package in product disk along with the goods delivery. The software package features as below: Item Cross compiler Features Description Remark gcc version 4.6.1 (Sourcery CodeBench Lite gcc 4.6.1 2011.09-50) Boot BOOT.BIN First boot program including FSBL, bitstream Source code provided program u-boot Secondary boot program Source code provided Linux Kernel Linux 4.14.0 Customized kernel for MYD-C7Z015 Source code provided USB Host USB Host driver Source code provided PCI-E PCI-E driver Source code provided SFP SFP transceiver driver Source code provided Ethernet Gigabit Ethernet driver Source code provided MMC/SD/TF MMC/SD/TF card driver Source code provided CAN CAN driver Source code provided LCD Controller XYLON LCD driver Source code provided HDMI HDMI (SII902X chip) driver Source code provided Button Button driver Source code provided UART UART driver Source code provided LED LED driver Source code provided GPIO GPIO driver Source code provided QSPI QSPI Flash S25FL256S driver Source code provided RTC DS3231 RTC driver Source code provided Resistive Touch TSC2007 resistive touch screen driver Source code provided Capacitive Touch FT5X0X capacitive touch screen driver Source code provided ADC ADC driver Source code provided Ramdisk Ramdisk system image Rootfs.tar Tar file Drivers File System Table 1-2 Linux Software Package Features 9 / 10 Order Information Item MYD-C7Z015 Development Board Part No. Packing List MYD-C7Z015-4E1D-667-C - One MYD-C7Z015 board - One 1.5m cross Ethernet cable - One DB9 UART to USB cable - One HDMI cable - One 12V/1.25A Power adapter - One 16GB TF Card - One product disk (including user manual, base board schematic in PDF format, datasheets and software package) MY-LCD43TP LCD Module MY-TFT043RV2 4.3-inch LCD Module with resistive touch screen MY-LCD70TP LCD Module MY-TFT070RV2 7-inch LCD Module with resistive touch screen MY-LCD70TP-C LCD Module MY-TFT070CV2 7-inch LCD Module with capacitive touch screen MYIR Tech Limited Room 04, 6th Floor, Building No.2, Fada Road, Yunli Smart Park, Bantian, Longgang District, Shenzhen, Guangdong, China 518129 E-mail: sales@myirtech.com Phone: +86-755-22984836 Fax: +86-755-25532724 Website: http://www.myirtech.com 10 / 10
MYC-C7Z015-4E1D-766-I 价格&库存
很抱歉,暂时无法提供与“MYC-C7Z015-4E1D-766-I”相匹配的价格&库存,您可以联系我们找货
