PSMN1R2-30YLC
N-channel 30 V 1.25mΩ logic level MOSFET in LFPAK using
NextPower technology
Rev. 1 — 3 May 2011
Product data sheet
1. Product profile
1.1 General description
Logic level enhancement mode N-channel MOSFET in LFPAK package. This product is
designed and qualified for use in a wide range of industrial, communications and domestic
equipment.
1.2 Features and benefits
High reliability Power SO8 package,
qualified to 175°C
Optimised for 4.5V Gate drive utilising
NextPower Superjunction technology
Ultra low QG, QGD, and QOSS for
high system efficiencies at low and
high loads
Ultra low Rdson and low parasitic
inductance
1.3 Applications
DC-to-DC converters
Power OR-ing
Lithium-ion battery protection
Server power supplies
Load switching
Sync rectifier
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
25 °C ≤ Tj ≤ 175 °C
30
V
ID
drain current
Tmb = 25 °C; VGS = 10 V;
see Figure 1
100
A
Ptot
total power dissipation Tmb = 25 °C; see Figure 2
215
W
Tj
junction temperature
-55
175
°C
VGS = 4.5 V; ID = 25 A;
Tj = 25 °C;
see Figure 12
1.35
1.65
mΩ
VGS = 10 V; ID = 25 A;
Tj = 25 °C;
see Figure 12
1.05
1.25
mΩ
[1]
Static characteristics
RDSon
drain-source on-state
resistance
PSMN1R2-30YLC
Nexperia
N-channel 30 V 1.25mΩ logic level MOSFET in LFPAK using NextPower
Table 1.
Quick reference data …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Dynamic characteristics
QGD
gate-drain charge
VDS = 15 V; see Figure 14;
see Figure 15
11.6
nC
QG(tot)
total gate charge
see Figure 15
38
nC
[1]
Continuous current is limited by package.
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
S
source
2
S
source
3
S
source
4
G
gate
mb
D
mounting base;
connected to drain
Simplified outline
Graphic symbol
mb
D
G
mbb076
S
1 2 3 4
SOT669 (LFPAK;
Power-SO8)
3. Ordering information
Table 3.
Type number
PSMN1R2-30YLC
Package
Name
Description
Version
LFPAK;
Power-SO8
plastic single-ended surface-mounted package; 4 leads
SOT669
4. Marking
Table 4.
Marking codes
Type number
Marking code[1]
PSMN1R2-30YLC
1C230L
[1]
% = placeholder for manufacturing site code
PSMN1R2-30YLC
Product data sheet
All information provided in this document is subject to legal disclaimers.
Rev. 1 — 3 May 2011
Nexperia B.V. 2017. All rights reserved
2 of 15
PSMN1R2-30YLC
Nexperia
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
25 °C ≤ Tj ≤ 175 °C
30
V
VDGR
drain-gate voltage
25 °C ≤ Tj ≤ 175 °C; RGS = 20 kΩ
30
V
VGS
gate-source voltage
ID
drain current
-20
V
VGS = 10 V; Tmb = 25 °C; see Figure 1
[1]
100
A
VGS = 10 V; Tmb = 100 °C; see Figure 1
[1]
100
A
IDM
peak drain current
pulsed; tp ≤ 10 µs; Tmb = 25 °C;
see Figure 4
1237
A
Ptot
215
W
Tstg
storage temperature
-55
175
°C
Tj
-55
175
°C
Tsld(M)
peak soldering temperature
VESD
electrostatic discharge voltage
MM (JEDEC JESD22-A115)
260
°C
900
V
100
A
Source-drain diode
[1]
IS
source current
Tmb = 25 °C
ISM
peak source current
1237
A
VGS = 10 V; Tj(init) = 25 °C; ID = 100 A;
Vsup ≤ 30 V; RGS = 50 Ω; unclamped;
see Figure 3
209
mJ
Avalanche ruggedness
EDS(AL)S
[1]
non-repetitive drain-source
avalanche energy
PSMN1R2-30YLC
Product data sheet
Rev. 1 — 3 May 2011
3 of 15
PSMN1R2-30YLC
Nexperia
003a a f 553
360
03na19
120
ID
(A)
300
Pder
80
240
180
120
40
(1)
60
Fig 1.
50
100
200
Tmb ( C)
50
100
150
200
Tmb (°C)
Continuous drain current as a function of
mounting base temperature
Fig 2.
Normalized total power dissipation as a
function of mounting base temperature
003a a f 567
103
I AL
(A)
(1)
102
(2)
10
1
10-1
10-3
Fig 3.
10-2
10-1
1
tAL (ms )
10
Single pulse avalanche rating; avalanche current as a function of avalanche time
PSMN1R2-30YLC
Product data sheet
Rev. 1 — 3 May 2011
4 of 15
PSMN1R2-30YLC
Nexperia
003aaf554
104
ID
(A)
103
Limit RDSon = VDS / ID
tp =10 μ s
102
100 μ s
1 ms
10
DC
10 ms
100 ms
1
10-1
10-1
Fig 4.
1
10
102
VDS (V)
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
6. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance from
junction to mounting base
see Figure 5
0.58
0.7
K/W
003aaf555
1
Zth(j-mb)
(K/W)
δ = 0.5
0.2
10-1
0.1
0.05
0.02
10
δ=
P
-2
tp
T
single shot
t
tp
T
10-3
1e-6
Fig 5.
10-5
10-4
10-3
10-2
10-1
tp (s)
1
Transient thermal impedance from junction to mounting base as a function of pulse duration
PSMN1R2-30YLC
Product data sheet
Rev. 1 — 3 May 2011
5 of 15
PSMN1R2-30YLC
Nexperia
7. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V
V(BR)DSS
drain-source
breakdown voltage
ID = 250 µA; VGS = 0 V; Tj = 25 °C
30
ID = 250 µA; VGS = 0 V; Tj = -55 °C
27
V
VGS(th)
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 25 °C;
see Figure 10; see Figure 11
1.05
1.46
1.95
V
ID = 10 mA; VDS = VGS; Tj = 150 °C
0.5
V
IDSS
drain leakage current
IGSS
gate leakage current
RDSon
resistance
RG
gate resistance
ID = 1 mA; VDS = VGS; Tj = -55 °C
2.25
V
VDS = 30 V; VGS = 0 V; Tj = 25 °C
1
µA
VDS = 30 V; VGS = 0 V; Tj = 150 °C
100
µA
VGS = 16 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = -16 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = 4.5 V; ID = 25 A; Tj = 25 °C;
see Figure 12
1.35
1.65
mΩ
VGS = 4.5 V; ID = 25 A; Tj = 150 °C;
see Figure 13; see Figure 12
2.8
mΩ
VGS = 10 V; ID = 25 A; Tj = 25 °C;
see Figure 12
1.05
1.25
mΩ
VGS = 10 V; ID = 25 A; Tj = 150 °C;
2.05
mΩ
f = 1 MHz
1.1
2.2
Ω
ID = 25 A; VDS = 15 V; VGS = 10 V;
see Figure 14; see Figure 15
78
nC
ID = 25 A; VDS = 15 V; VGS = 4.5 V;
38
nC
ID = 0 A; VDS = 0 V; VGS = 10 V
75
nC
10.3
nC
6.7
nC
QG(tot)
total gate charge
QGS
gate-source charge
QGS(th)
pre-threshold
gate-source charge
QGS(th-pl)
post-threshold
gate-source charge
3.6
nC
QGD
gate-drain charge
11.6
nC
VGS(pl)
gate-source plateau
voltage
ID = 25 A; VDS = 15 V; see Figure 14;
see Figure 15
2.34
V
Ciss
input capacitance
Coss
output capacitance
VDS = 15 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; see Figure 16
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
tf
VDS = 15 V; RL = 0.6 Ω; VGS = 4.5 V;
RG(ext) = 4.7 Ω
5093
pF
977
pF
333
pF
36
ns
60
ns
turn-off delay time
75
ns
fall time
39
ns
PSMN1R2-30YLC
Product data sheet
Rev. 1 — 3 May 2011
6 of 15
PSMN1R2-30YLC
Nexperia
Table 7.
Characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Qoss
output charge
VGS = 0 V; VDS = 15 V; f = 1 MHz;
Tj = 25 °C
33
nC
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS = 0 V; Tj = 25 °C;
see Figure 17
0.8
1.1
V
trr
reverse recovery time
41.5
ns
Qr
recovered charge
IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 15 V
45
nC
ta
reverse recovery rise
time
VGS = 0 V; IS = 25 A; dIS/dt = -100 A/µs;
VDS = 15 V; see Figure 18
25
ns
tb
reverse recovery fall
time
16.5
ns
003a a f 556
100
2.8
ID
(A)
RDS on
(mΩ)
10
2.6
3.0
4.5
80
003a a f 557
12
10
8
60
2.4
6
40
4
VGS (V) = 2.2
Fig 6.
0.5
1
1.5
VDS (V)
2
Output characteristics; drain current as a
function of drain-source voltage; typical values
PSMN1R2-30YLC
Product data sheet
Fig 7.
8
12
VGS (V)
16
Drain-source on-state resistance as a function
of gate-source voltage; typical values
Rev. 1 — 3 May 2011
4
7 of 15
PSMN1R2-30YLC
Nexperia
003a a f 562
300
gfs
(S )
250
003a a f 564
100
ID
(A)
80
200
60
150
40
100
Tj = 150 °C
Fig 8.
Tj = 25 °C
25
50
75
I D (A)
100
Forward transconductance as a function of
drain current; typical values
003a a f 561
10-1
ID
(A)
Fig 9.
Typ
3
4
003a a f 560
Max (1mA)
I D=5mA
1mA
2
Max
VGS (V)
Transfer characteristics; drain current as a
function of gate-source voltage
VGS (th)
(V)
Min
2
3
10-2
10-3
1
10-4
1
Min (5mA)
10-5
10-6
2
VGS (V)
3
Fig 10. Sub-threshold drain current as a function of
gate-source voltage
PSMN1R2-30YLC
Product data sheet
120
Tj ( C)
180
Fig 11. Gate-source threshold voltage as a function of
Rev. 1 — 3 May 2011
8 of 15
PSMN1R2-30YLC
Nexperia
RDS on
(mΩ)
003a a f 558
6
a
2.6
5
003a a f 559
2
VGS = 4.5V
1.5
VGS (V) = 2.8
4
10V
3
1
3.0
3.5
2
0.5
1
4.5
10
50
75
I D (A)
100
120
180
Tj ( C)
Fig 12. Drain-source on-state resistance as a function
of drain current; typical values
Fig 13. Normalized drain-source on-state resistance
factor as a function of junction temperature
003a a f 565
10
VGS
(V)
8
VDS
ID
6
24V
VGS(pl)
VDS = 15V
4
VGS(th)
6V
VGS
2
QGS1
QGS2
QGS
QGD
QG(tot)
50
75
003aaa508
Fig 14. Gate charge waveform definitions
PSMN1R2-30YLC
Product data sheet
100
QG (nC)
Fig 15. Gate-source voltage as a function of gate
charge; typical values
Rev. 1 — 3 May 2011
9 of 15
PSMN1R2-30YLC
Nexperia
003a a f 563
104
C
(pF)
003a a f 566
100
IS
(A)
80
Cis s
60
3
10
Cos s
40
Crs s
102
10-1
1
10
VDS (V)
Tj = 150 °C
Tj = 25 °C
Fig 16. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
0.3
0.6
0.9
VS D (V)
1.2
Fig 17. Source current as a function of drain-source
003a a f 444
ID
(A)
trr
ta
tb
0.25 IRM
I RM
t (s )
Fig 18. Reverse recovery timing definition
PSMN1R2-30YLC
Product data sheet
Rev. 1 — 3 May 2011
10 of 15
PSMN1R2-30YLC
Nexperia
8. Package outline
Plastic single-ended surface-mounted package (LFPAK; Power-SO8); 4 leads
A2
A
E
SOT669
C
c2
b2
E1
b3
L1
mounting
base
b4
D1
D
H
L2
1
2
3
e
4
w M A
b
1/2
X
c
e
A
(A 3)
C
A1
θ
L
detail X
y C
5 mm
scale
DIMENSIONS (mm are the original dimensions)
A
UNIT
A1
A2
A3
b
b2
1.20 0.15 1.10
0.50 4.41
0.25
1.01 0.00 0.95
0.35 3.62
mm
b3
b4
2.2
2.0
0.9
0.7
c
D (1)
c2
D1(1)
E(1) E1(1)
max
0.25 0.30 4.10
4.20
0.19 0.24 3.80
5.0
4.8
3.3
3.1
e
H
L
L1
L2
w
y
θ
1.27
6.2
5.8
0.85
0.40
1.3
0.8
1.3
0.8
0.25
0.1
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT669
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
06-03-16
11-03-25
MO-235
Fig 19. Package outline SOT669 (LFPAK; Power-SO8)
PSMN1R2-30YLC
Product data sheet
Rev. 1 — 3 May 2011
11 of 15
PSMN1R2-30YLC
Nexperia
9. Revision history
Table 8.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PSMN1R2-30YLC v.1
20110503
Product data sheet
PSMN1R2-30YLC
Product data sheet
Rev. 1 — 3 May 2011
12 of 15
PSMN1R2-30YLC
Nexperia
10. Legal information
10.1 Data sheet status
Document status [1] [2]
Product status [3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
10.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
10.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
PSMN1R2-30YLC
Product data sheet
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Rev. 1 — 3 May 2011
13 of 15
PSMN1R2-30YLC
Nexperia
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
10.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
non-automotive qualified products in automotive equipment or applications.
11. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PSMN1R2-30YLC
Product data sheet
Rev. 1 — 3 May 2011
14 of 15
PSMN1R2-30YLC
Nexperia
12. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
10.1
10.2
10.3
10.4
11
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .5
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12
Legal information. . . . . . . . . . . . . . . . . . . . . . . .13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .14
Contact information. . . . . . . . . . . . . . . . . . . . . .14
Date of release: 03 May 2011
