PSMN1R1-40BS
N-channel 40 V 1.3 mΩ standard level MOSFET in D2PAK
Rev. 2 — 29 February 2012
Product data sheet
1. Product profile
1.1 General description
Standard level N-channel MOSFET in D2PAK (SOT404) package qualified to 175 °C. This
product is designed and qualified for use in a wide range of industrial, communications
and domestic equipment.
1.2 Features and benefits
High efficiency due to low switching
and conduction losses
Suitable for standard level gate drive
sources
1.3 Applications
DC-to-DC convertors
Motor control
Load switching
Server power supplies
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj ≥ 25 °C; Tj ≤ 175 °C
40
V
ID
drain current
Tmb = 25 °C; VGS = 10 V; see Figure 1
120
A
Ptot
total power dissipation
Tmb = 25 °C; see Figure 2
306
W
Tj
junction temperature
-55
175
°C
VGS = 10 V; ID = 25 A; Tj = 100 °C;
see Figure 12;see Figure 13
1.68
2
mΩ
VGS = 10 V; ID = 25 A; Tj = 25 °C;
see Figure 13
1.16
1.3
mΩ
[1]
Static characteristics
RDSon
drain-source on-state
resistance
Dynamic characteristics
QGD
gate-drain charge
QG(tot)
total gate charge
VGS = 10 V; ID = 75 A; VDS = 20 V;
see Figure 14;see Figure 15
32
nC
136
nC
1.4
J
Avalanche ruggedness
EDS(AL)S
[1]
non-repetitive
drain-source
avalanche energy
Continuous current is limited by package
VGS = 10 V; Tj(init) = 25 °C; ID = 120 A;
Vsup ≤ 40 V; unclamped; RGS = 50 Ω;
tp = 0.1 ms
PSMN1R1-40BS
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
G
gate
2
D
drain[1]
3
S
source
mb
D
drain
Simplified outline
Graphic symbol
mb
D
G
S
mbb076
2
1
3
SOT404 (D2PAK)
[1]
It is not possible to make connection to pin 2.
3. Ordering information
Table 3.
Type number
PSMN1R1-40BS
Package
Name
Description
Version
D2PAK
plastic single-ended surface-mounted package (D2PAK); 3 leads SOT404
(one lead cropped)
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
40
V
VDGR
drain-gate voltage
Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ
40
V
VGS
gate-source voltage
ID
drain current
-20
V
VGS = 10 V; Tmb = 100 °C
[1]
120
A
VGS = 10 V; Tmb = 25 °C; see Figure 1
[1]
120
A
1320 A
IDM
peak drain current
pulsed; tp ≤ 10 µs; Tmb = 25 °C; see Figure 3
Ptot
306
W
Tstg
storage temperature
-55
175
°C
Tj
-55
175
°C
Tsld(M)
peak soldering temperature
260
°C
120
A
Source-drain diode
[1]
IS
source current
Tmb = 25 °C
ISM
peak source current
1320 A
VGS = 10 V; Tj(init) = 25 °C; ID = 120 A; Vsup ≤ 40 V;
unclamped; RGS = 50 Ω; tp = 0.1 ms
1.4
EDS(AL)S
[1]
non-repetitive drain-source
avalanche energy
J
Continuous current is limited by package.
PSMN1R1-40BS
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 14
PSMN1R1-40BS
Nexperia
003a a f329
350
ID
(A)
300
03aa16
120
Pder
250
80
200
150
40
(1)
100
50
Fig 1.
50
100
150
200
Tmb (C)
Normalized continuous drain current as a
function of mounting base temperature
100
150
200
Tmb (°C)
Fig 2.
Normalized total power dissipation as a
003a a f328
104
ID
(A)
103
tp =10 s
Limit R DS on = VDS / ID
100 s
102
DC
10
1 ms
10 ms
100 ms
1
10-1
10-1
Fig 3.
1
10
102
V DS (V)
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
PSMN1R1-40BS
Product data sheet
3 of 14
PSMN1R1-40BS
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance from
junction to mounting base
see Figure 4
0.22
0.49
K/W
Rth(j-a)
junction to ambient
minimum footprint; mounted on
a printed-circuit board
50
K/W
003aag770
1
Zth(j-mb)
(K/W)
10-1
δ = 0.5
0.2
0.1
0.05
δ=
0.02
10-2
tp
T
P
single shot
t
tp
T
-3
10
10-6
Fig 4.
10-5
10-4
10-3
10-2
10-1
tp (s)
1
Transient thermal impedance from junction to mounting base as a function of pulse duration
PSMN1R1-40BS
Product data sheet
4 of 14
PSMN1R1-40BS
Nexperia
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ID = 250 µA; VGS = 0 V; Tj = -55 °C
36
V
ID = 250 µA; VGS = 0 V; Tj = 25 °C
40
V
ID = 1 mA; VDS = VGS; Tj = -55 °C;
see Figure 10
4.6
V
ID = 1 mA; VDS = VGS; Tj = 175 °C;
see Figure 10
1
V
ID = 1 mA; VDS = VGS; Tj = 25 °C;
see Figure 11;see Figure 10
2
3
4
V
VDS = 40 V; VGS = 0 V; Tj = 25 °C
0.02
10
µA
VDS = 40 V; VGS = 0 V; Tj = 175 °C
500
µA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
10
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
10
100
nA
1.68
2
mΩ
VGS = 10 V; ID = 25 A; Tj = 175 °C;
2.3
2.8
mΩ
see Figure 13
1.16
1.3
mΩ
1.1
Ω
V(BR)DSS
drain-source
breakdown voltage
VGS(th)
gate-source threshold
voltage
IDSS
drain leakage current
IGSS
gate leakage current
RDSon
RG
resistance
internal gate resistance f = 1 MHz
(AC)
QG(tot)
total gate charge
ID = 0 A; VDS = 0 V; VGS = 10 V
133
nC
136
nC
QGS
gate-source charge
ID = 75 A; VDS = 20 V; VGS = 10 V;
52
nC
QGS(th)
pre-threshold
gate-source charge
30
nC
QGS(th-pl)
post-threshold
gate-source charge
22
nC
QGD
gate-drain charge
32
nC
VGS(pl)
gate-source plateau
voltage
ID = 75 A; VDS = 20 V;see Figure 14;
see Figure 15
6.1
V
Ciss
input capacitance
9710
pF
Coss
output capacitance
VDS = 20 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C;see Figure 16
2042
pF
Crss
reverse transfer
capacitance
994
pF
td(on)
turn-on delay time
45
ns
tr
rise time
66
ns
td(off)
turn-off delay time
111
ns
tf
fall time
53
ns
PSMN1R1-40BS
Product data sheet
VDS = 20 V; RL = 0.8 Ω; VGS = 5 V;
RG(ext) = 4.7 Ω
5 of 14
PSMN1R1-40BS
Nexperia
Table 6.
Characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
0.8
1.2
V
64
ns
117
nC
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS = 0 V; Tj = 25 °C;
see Figure 17
trr
reverse recovery time
Qr
recovered charge
IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 20 V
003aaf316
200
003aaf317
75
ID
(A)
60
gfs
(S)
150
45
100
30
Tj = 175 °C
50
15
Fig 5.
Tj = 25 °C
15
30
45
ID (A)
Forward transconductance as a function of
drain current; typical values
Fig 6.
003aaf320
18000
C
(pF)
4
VGS (V)
6
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
003aag669
8
RDSon
(mΩ)
Ciss
14000
2
6
10000
4
Crss
6000
2
2000
1
Fig 7.
10
VGS (V)
Input and reverse transfer capacitances as a
PSMN1R1-40BS
Product data sheet
4
Fig 8.
8
12
16
VGS (V)
Drain-source on-state resistance as a function
6 of 14
PSMN1R1-40BS
Nexperia
003aaf319
80
10
ID
(A)
6.0 5.2
5.0
003aad280
5
VGS (V) = 4.8
VGS(th)
(V)
4
max
60
4.7
3
typ
4.6
40
2
min
4.5
Fig 9.
0.25
0.5
−60
0.75 V (V) 1
DS
Output characteristics: drain current as a
function of drain-source voltage; typical values
03aa35
10−1
ID
(A)
120
180
Tj (°C)
Fig 10. Gate-source threshold voltage as a function of
003a a f322
2.5
a
min
10−2
typ
max
2
10−3
1.5
10−4
1
10−5
0.5
10−6
4
6
120
VGS (V)
Fig 11. Sub-threshold drain current as a function of
gate-source voltage
PSMN1R1-40BS
Product data sheet
Tj (C)
180
Fig 12. Normalized drain-source on state resistance
factor as a function of junction temperature
7 of 14
PSMN1R1-40BS
Nexperia
003aag670
8
RDSon
(mΩ)
4.6
4.8
VDS
6
ID
VGS(pl)
VGS (V) = 5
4
VGS(th)
5.2
VGS
2
QGS1
10
QGS2
QGS
QGD
QG(tot)
60
ID (A)
Fig 13. Drain-source on-state resistance as a function
of drain current; typical values
003aaf323
10
VGS
(V)
003aaa508
80
Fig 14. Gate charge waveform definitions
003aaf324
105
C
(pF)
20V
8
104
VDS = 8V
Ciss
32V
6
Coss
103
Crss
4
102
2
80
120 Q (nC)160
G
Fig 15. Gate-source voltage as a function of gate
charge; typical values
PSMN1R1-40BS
Product data sheet
10
10-1
1
10
VDS (V)
102
Fig 16. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
8 of 14
PSMN1R1-40BS
Nexperia
003aaf325
75
IS
(A)
60
45
30
15
Tj = 175 °C
Tj = 25 °C
0.5
0.75
VSD (V)
1
Fig 17. Source current as a function of source-drain voltage; typical values
PSMN1R1-40BS
Product data sheet
9 of 14
PSMN1R1-40BS
Nexperia
7. Package outline
SOT404
Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped)
A
A1
E
mounting
base
D1
D
HD
2
Lp
1
3
c
b
e
e
Q
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
c
D
max.
D1
E
e
Lp
HD
Q
mm
4.50
4.10
1.40
1.27
0.85
0.60
0.64
0.46
11
1.60
1.20
10.30
9.70
2.54
2.90
2.10
15.80
14.80
2.60
2.20
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-02-11
06-03-16
SOT404
Fig 18. Package outline SOT404 (D2PAK)
PSMN1R1-40BS
Product data sheet
10 of 14
PSMN1R1-40BS
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PSMN1R1-40BS v.2
20120229
Product data sheet
PSMN1R1-40BS v.1
Modifications:
PSMN1R1-40BS v.1
PSMN1R1-40BS
Product data sheet
Status changed from objective to product.
Various changes to content.
20110929
Objective data sheet
11 of 14
PSMN1R1-40BS
Nexperia
9. Legal information
9.1
Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Preview— The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft— The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
Short data sheet— A short data sheet is an extract from a full data sheet with
the same product type number(s) and title. A short data sheet is intended for
quick reference only and should not be relied upon to contain detailed and full
information. For detailed and full information see the relevant full data sheet,
which is available on request via the local Nexperia sales office.
In case of any inconsistency or conflict with the short data sheet, the full data
sheet shall prevail.
Product specification— The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Disclaimers
Limited warranty and liability— Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with theTerms and conditions of commercial saleof Nexperia.
PSMN1R1-40BS
Product data sheet
Right to make changes— Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use— Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Quick reference data— The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications— Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values— Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
12 of 14
PSMN1R1-40BS
Nexperia
Terms and conditions of commercial sale— Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license— Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control— This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products— Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations— A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
10. Contact information
For more information, please visit:http://www.nexperia.com
For sales office addresses, please send an email to:salesaddresses@nexperia.com
PSMN1R1-40BS
Product data sheet
13 of 14
PSMN1R1-40BS
Nexperia
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . .12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Contact information. . . . . . . . . . . . . . . . . . . . . .13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 29 February 2012
