Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
PMV37EN2
30 V, N-channel Trench MOSFET
10 January 2017
Product data sheet
1. General description
N-channel enhancement mode Field-Effect Transistor (FET) in a small SOT23 (TO-236AB)
Surface-Mounted Device (SMD) plastic package using Trench MOSFET technology.
2. Features and benefits
Logic level compatible
Very fast switching
Enhanced power dissipation capability of 1115 mW
3. Applications
Relay driver
High-speed line driver
Low-side load switch
Switching circuits
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj = 25 °C
30
V
VGS
gate-source voltage
-20
V
5.6
A
31
36
mΩ
ID
drain current
VGS = 10 V; Tamb = 25 °C; t ≤ 5 s
[1]
Static characteristics
RDSon
[1]
drain-source on-state
resistance
VGS = 10 V; ID = 4.5 A; Tj = 25 °C
2
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for drain 6 cm .
PMV37EN2
NXP Semiconductors
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
1
G
gate
2
S
source
3
D
drain
Simplified outline
Graphic symbol
3
D
G
S
1
2
017aaa253
TO-236AB (SOT23)
6. Ordering information
Table 3. Ordering information
Type number
PMV37EN2
Package
Name
Description
Version
TO-236AB
plastic surface-mounted package; 3 leads
SOT23
7. Marking
Table 4. Marking codes
[1]
Type number
Marking code
PMV37EN2
%K7
[1]
% = placeholder for manufacturing site code
PMV37EN2
Product data sheet
All information provided in this document is subject to legal disclaimers.
10 January 2017
NXP Semiconductors N.V. 2017. All rights reserved
2 / 15
PMV37EN2
NXP Semiconductors
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
Tj = 25 °C
30
V
VGS
gate-source voltage
ID
drain current
IDM
peak drain current
Ptot
-20
V
[1]
5.6
A
[1]
4.5
A
VGS = 10 V; Tamb = 100 °C
[1]
2.8
A
Tamb = 25 °C; single pulse; tp ≤ 10 µs
total power dissipation
Tamb = 25 °C
16
A
[2]
510
mW
[1]
1115
mW
5000
mW
Tsp = 25 °C
Tj
junction temperature
-55
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
1
A
Source-drain diode
IS
[1]
[2]
source current
[1]
Tamb = 25 °C
2
Device mounted on an FR4 Printed Circuit Board (PCB), single-sided copper, tin-plated and standard footprint.
017aaa123
120
Pder
Ider
80
80
40
40
Fig. 1.
017aaa124
120
- 25
25
75
125
Tj (°C)
Normalized total power dissipation as a
function of junction temperature
PMV37EN2
Product data sheet
175
Fig. 2.
- 25
75
125
Tj (°C)
175
Normalized continuous drain current as a
10 January 2017
25
3 / 15
PMV37EN2
NXP Semiconductors
aaa-013395
102
lD
(A)
tp = 10 µs
10
tp = 100 µs
1
tp = 1 ms
tp = 10 ms
DC; Tamb = 25 °C; 6 cm2
DC; Tsp = 25 °C
10-1
10-2
10-1
1
tp = 100 ms
10
102
VDS (V)
IDM = single pulse
Fig. 3.
Safe operating area; junction to ambient; continuous and peak drain currents as a function of drainsource voltage
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Rth(j-a)
Rth(j-sp)
[1]
[2]
Parameter
thermal resistance
from junction to
ambient
Conditions
in free air
in free air; t ≤ 5 s
thermal resistance
from junction to solder
point
Min
Typ
Max
Unit
[1]
209
246
K/W
[2]
95
112
K/W
[2]
63
72
K/W
K/W
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint.
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for drain 6 cm .
PMV37EN2
Product data sheet
10 January 2017
4 / 15
PMV37EN2
NXP Semiconductors
aaa-013362
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
102
0.50
0.33
0.20
0.25
0.10
0.05
10
0.02
1
10-3
10-2
10-1
1
10
102
tp (s)
103
FR4 PCB, standard footprint
Fig. 4.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
aaa-013363
103
duty cycle = 1
0.75
0.50
0.33
Zth(j-a)
(K/W)
102
10
0.02
0.01
10-3
0.25
0.20
0.10
0.05
10-2
10-1
FR4 PCB, mounting pad for drain 6 cm
Fig. 5.
1
10
102
2
tp (s)
103
PMV37EN2
Product data sheet
10 January 2017
5 / 15
PMV37EN2
NXP Semiconductors
10. Characteristics
Table 7. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source
breakdown voltage
ID = 250 µA; VGS = 0 V; Tj = 25 °C
30
V
VGSth
gate-source threshold
voltage
ID = 250 µA; VDS=VGS; Tj = 25 °C
1
1.5
2
V
IDSS
drain leakage current
VDS = 30 V; VGS = 0 V; Tj = 25 °C
1
µA
IGSS
gate leakage current
VGS = 20 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
-100
nA
31
36
mΩ
VGS = 10 V; ID = 4.5 A; Tj = 150 °C
48
56
mΩ
VGS = 4.5 V; ID = 3.9 A; Tj = 25 °C
37
47
mΩ
RDSon
resistance
gfs
forward
transconductance
VDS = 10 V; ID = 2 A; Tj = 25 °C
13
S
RG
gate resistance
Tj = 25 °C; f = 1 MHz
2.3
Ω
VDS = 15 V; ID = 3.2 A; VGS = 10 V;
Tj = 25 °C
3.6
6.3
nC
0.5
nC
0.4
nC
209
pF
50
pF
17
pF
3
ns
12
ns
Dynamic characteristics
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
turn-off delay time
11
ns
tf
fall time
2
ns
0.75
1.2
V
VDS = 15 V; f = 1 MHz; VGS = 0 V;
Tj = 25 °C
RG(ext) = 6 Ω; Tj = 25 °C
Source-drain diode
VSD
source-drain voltage
PMV37EN2
Product data sheet
IS = 1 A; VGS = 0 V; Tj = 25 °C
10 January 2017
6 / 15
PMV37EN2
NXP Semiconductors
aaa-013396
16
3.8 V
4.5 V
10 V
ID
(A)
3.2 V
ID
(A)
3.0 V
12
aaa-013397
10-3
min
typ
max
10-4
2.8 V
8
10-5
2.5 V
4
VGS = 2.2 V
Fig. 6.
2
3
VDS (V)
10-6
4
1.0
1.5
2.0
2.5
VGS (V)
Tj = 25 °C
Tj = 25 °C; VDS = 5 V
Output characteristics: drain current as a
Fig. 7.
function of drain-source voltage; typical values
Sub-threshold drain current as a function of
gate-source voltage
aaa-013398
250
RDSon
(mΩ)
aaa-013399
250
2.2 V
RDSon
(mΩ)
200
200
2.5 V
2.8 V
150
150
100
100
3.2 V
Tj = 150 °C
50
VGS = 10 V
4.5 V
8
Tj = 25 °C
3.8 V
12
ID (A)
Tj = 25 °C
Fig. 8.
Product data sheet
2
4
6
8
10
VGS (V)
ID = 4 A
Drain-source on-state resistance as a function
of drain current; typical values
PMV37EN2
Fig. 9.
of gate-source voltage; typical values
10 January 2017
7 / 15
PMV37EN2
NXP Semiconductors
aaa-013400
16
aaa-009047
1.8
ID
(A)
a
12
1.5
8
1.2
Tj = 150 °C
4
0.9
Tj = 25 °C
2
3
VDS (V)
0.6
-60
4
120
Tj (°C)
180
VDS > ID × RDSon
Fig. 10. Transfer characteristics: drain current as a
function of gate-source voltage; typical values
Fig. 11. Normalized drain-source on-state resistance
as a function of junction temperature; typical
values
aaa-009048
3
aaa-009049
103
C
(pF)
VGS(th)
(V)
max
2
Ciss
102
Coss
typ
Crss
min
1
10
120
Tj (°C)
1
180
Fig. 12. Gate-source threshold voltage as a function of
Product data sheet
1
10
VDS (V)
102
ID = 0.25 mA; VDS = VGS
PMV37EN2
10-1
Fig. 13. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
10 January 2017
8 / 15
PMV37EN2
NXP Semiconductors
aaa-009050
10
VDS
VGS
(V)
ID
8
VGS(pl)
6
VGS(th)
VGS
4
QGS1
2
QGS2
2
3
QG (nC)
QGS
QGD
QG(tot)
003aaa508
Fig. 15. MOSFET transistor: Gate charge waveform
definitions
4
ID = 3.2 A; VDS = 15 V; Tamb = 25 °C
Fig. 14. Gate-source voltage as a function of gate
charge; typical values
aaa-009052
4
IS
(A)
3
Tj = 150 °C
2
Tj = 25 °C
1
0.8
VSD (V)
1.2
VGS = 0 V
Fig. 16. Source current as a function of source-drain voltage; typical values
11. Test information
P
t2
duty cycle δ =
t1
t2
t1
t
006aaa812
Fig. 17. Duty cycle definition
PMV37EN2
Product data sheet
10 January 2017
9 / 15
PMV37EN2
NXP Semiconductors
12. Package outline
Plastic surface-mounted package; 3 leads
SOT23
B
D
A
E
X
HE
v
A
3
Q
A
A1
1
c
2
e1
bp
w
B
Lp
e
detail X
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A
A1
1.1
0.1
0.9
D
E
0.48 0.15
bp
c
3.0
1.4
0.38 0.09
2.8
1.2
e
e1
1.9
0.95
HE
Lp
Q
2.5
0.45 0.55
2.1
0.15 0.45
v
w
0.2
0.1
sot023_po
Outline
version
SOT23
References
IEC
JEDEC
JEITA
European
projection
Issue date
14-06-19
14-09-22
TO-236AB
Fig. 18. Package outline TO-236AB (SOT23)
PMV37EN2
Product data sheet
10 January 2017
10 / 15
PMV37EN2
NXP Semiconductors
13. Soldering
3.3
2.9
1.9
solder lands
3
solder resist
2
1.7
solder paste
occupied area
0.6
(3×)
0.7
(3×)
Dimensions in mm
0.5
(3×)
0.6
(3×)
1
sot023_fr
Fig. 19. Reflow soldering footprint for TO-236AB (SOT23)
2.2
1.2
(2×)
1.4
(2×)
solder lands
4.6
solder resist
2.6
occupied area
Dimensions in mm
1.4
preferred transport direction during soldering
2.8
4.5
sot023_fw
Fig. 20. Wave soldering footprint for TO-236AB (SOT23)
PMV37EN2
Product data sheet
10 January 2017
11 / 15
PMV37EN2
NXP Semiconductors
14. Revision history
Table 8. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PMV37EN2 v.2
20170110
Product data sheet
PMV37EN2 v.1
Modifications:
PMV37EN2 v.1
PMV37EN2
Product data sheet
Section 10. Characteristics: values for forward transconductance and gate resistance changed
20140603
Product data sheet
10 January 2017
12 / 15
PMV37EN2
NXP Semiconductors
Notwithstanding any damages that customer might incur for any reason
whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of NXP Semiconductors.
15. Legal information
Right to make changes — NXP Semiconductors reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Data sheet status
Document
[1] [2]
status
Product
[3]
status
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors and its suppliers accept no liability for
inclusion and/or use of NXP Semiconductors products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nxp.com.
Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
NXP Semiconductors does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local NXP
Semiconductors sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
NXP Semiconductors and its customer, unless NXP Semiconductors and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the NXP Semiconductors product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, NXP Semiconductors does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. NXP Semiconductors takes no
responsibility for the content in this document if provided by an information
source outside of NXP Semiconductors.
In no event shall NXP Semiconductors be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
PMV37EN2
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes
no representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using NXP Semiconductors products, and NXP
Semiconductors accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the NXP Semiconductors product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
NXP Semiconductors does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using NXP
Semiconductors products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). NXP does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — NXP Semiconductors
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nxp.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. NXP Semiconductors hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of NXP Semiconductors products by customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific NXP Semiconductors product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor
tested in accordance with automotive testing or application requirements.
NXP Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications.
10 January 2017
13 / 15
PMV37EN2
NXP Semiconductors
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without NXP Semiconductors’ warranty
of the product for such automotive applications, use and specifications, and
(b) whenever customer uses the product for automotive applications beyond
NXP Semiconductors’ specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies NXP Semiconductors for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond NXP Semiconductors’
standard warranty and NXP Semiconductors’ product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Bitsound, CoolFlux, CoReUse, DESFire, FabKey, GreenChip,
HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE, ITEC, MIFARE,
MIFARE Plus, MIFARE Ultralight, SmartXA, STARplug, TOPFET,
TrenchMOS, TriMedia and UCODE — are trademarks of NXP
Semiconductors N.V.
HD Radio and HD Radio logo — are trademarks of iBiquity Digital
Corporation.
PMV37EN2
Product data sheet
10 January 2017
14 / 15
PMV37EN2
NXP Semiconductors
16. Contents
1. General description......................................................1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Thermal characteristics............................................... 4
10. Characteristics............................................................ 6
11. Test information......................................................... 9
12. Package outline........................................................ 10
13. Soldering................................................................... 11
14. Revision history........................................................12
15. Legal information..................................................... 13
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
Date of release: 10 January 2017
PMV37EN2
Product data sheet
10 January 2017
15 / 15
