PSMN1R6-30PL,127
PSMN1R6-30PL,127
    NEXPERIA(安世)
    SOT78
    MOS管 N-channel Id=100A VDS=30V SOT78
PSMN1R6-30PL,127 数据手册
PSMN1R6-30PL N-channel 30 V 1.7 mΩ logic level MOSFET Rev. 02 — 25 June 2009 Product data sheet 1. Product profile 1.1 General description Logic level N-channel MOSFET in TO220 package qualified to 175 °C. This product is designed and qualified for use in a wide range of industrial, communications and domestic equipment. 1.2 Features and benefits „ High efficiency due to low switching and conduction losses „ Suitable for logic level gate drive sources 1.3 Applications „ DC-to-DC converters „ Motor control „ Load switiching „ Server power supplies 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1; Ptot total power dissipation Min Typ Max Unit - - 30 V - - 100 A Tmb = 25 °C; see Figure 2 - - 306 W [1] Dynamic characteristics QGD gate-drain charge VGS = 4.5 V; ID = 25 A; VDS = 15 V; see Figure 14; see Figure 15 - 27 - nC QG(tot) total gate charge VGS = 4.5 V; ID = 25 A; VDS = 15 V; see Figure 14 - 101 - nC - 1.4 1.7 mΩ Static characteristics RDSon drain-source on-state resistance VGS = 10 V; ID = 25 A; Tj = 25 °C; [1] Continuous current is limited by package. [2] Measured 3 mm from package. [2] PSMN1R6-30PL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 D drain 3 S source mb D mounting base; connected to drain Graphic symbol mb D G mbb076 S 1 2 3 SOT78 (TO-220AB; SC-46) 3. Ordering information Table 3. Ordering information Type number Package Name Description PSMN1R6-30PL TO-220AB; SC-46 plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead SOT78 TO-220AB Version © PSMN1R6-30PL_2 Product data sheet Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 2 of 13 PSMN1R6-30PL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 30 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ VGS gate-source voltage ID drain current - 30 V -20 20 V VGS = 10 V; Tmb = 100 °C; see Figure 1; [1] - 100 A VGS = 10 V; Tmb = 25 °C; see Figure 1; [1] - 100 A IDM peak drain current tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3 - 1268 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 306 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C - 100 A - 1268 A - 1.7 J Source-drain diode IS source current Tmb = 25 °C; [1] ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C Avalanche ruggedness non-repetitive VGS = 10 V; Tj(init) = 25 °C; ID = 100 A; Vsup ≤ 30 V; drain-source avalanche RGS = 50 Ω; unclamped energy EDS(AL)S [1] Continuous current is limited by package. 003aad003 400 ID (A) 03aa16 120 Pder (%) 300 80 200 40 100 (1) 0 0 0 Fig 1. 50 100 150 Tmb (°C) 200 0 100 150 200 Tmb (°C) Continuous drain current as a function of mounting base temperature Fig 2. Normalized total power dissipation as a function of mounting base temperature © PSMN1R6-30PL_2 Product data sheet 50 Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 3 of 13 PSMN1R6-30PL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET 003aad115 104 ID (A) 10 μs Limit RDSon = VDS / ID 103 100 μs 102 (1) 1 ms 10 ms 10 DC 1 10-1 Fig 3. 1 100 ms 10 102 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-mb) thermal resistance from see Figure 4 junction to mounting base Conditions Min Typ Max Unit - 0.22 0.49 K/W 003aad005 1 Zth(j-mb) (K/W) δ = 0.5 10-1 0.2 0.1 0.05 10-2 0.02 δ= P tp T 10-3 10-4 10-6 Fig 4. t tp single shot T 10-5 10-4 10-3 10-2 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration; typical values © PSMN1R6-30PL_2 Product data sheet Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 4 of 13 PSMN1R6-30PL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET 6. Characteristics Table 6. Characteristics Tested to JEDEC standards where applicable. Symbol Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS VGS(th) IDSS IGSS RDSon drain-source breakdown voltage gate-source threshold voltage drain leakage current gate leakage current drain-source on-state resistance ID = 250 µA; VGS = 0 V; Tj = 25 °C 30 - - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 27 - - V ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 11; see Figure 12 1.3 1.7 2.15 V ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 12 0.5 - - V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 12 - - 2.45 V VDS = 30 V; VGS = 0 V; Tj = 25 °C - - 5 µA VDS = 30 V; VGS = 0 V; Tj = 125 °C - - 150 µA VGS = 16 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -16 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 4.5 V; ID = 25 A; Tj = 25 °C - 1.6 2.1 mΩ VGS = 10 V; ID = 25 A; Tj = 100 °C; see Figure 13 - - 2.3 mΩ - 1.4 1.7 mΩ f = 1 MHz - 0.98 - Ω ID = 25 A; VDS = 15 V; VGS = 10 V; see Figure 14; see Figure 15 - 212 - nC ID = 0 A; VDS = 0 V; VGS = 10 V - 193 - nC ID = 25 A; VDS = 15 V; VGS = 4.5 V; see Figure 14 - 101 - nC VGS = 10 V; ID = 25 A; Tj = 25 °C; RG gate resistance [1] Dynamic characteristics QG(tot) total gate charge QGS gate-source charge ID = 25 A; VDS = 15 V; VGS = 4.5 V; see Figure 14; see Figure 15 - 33 - nC QGS(th) pre-threshold gate-source charge ID = 25 A; VDS = 15 V; VGS = 4.5 V; see Figure 14 - 20 - nC QGS(th-pl) post-threshold gate-source charge - 13 - nC QGD gate-drain charge ID = 25 A; VDS = 15 V; VGS = 4.5 V; see Figure 14; see Figure 15 - 27 - nC VGS(pl) gate-source plateau voltage VDS = 15 V; see Figure 14 - 2.5 - V Ciss input capacitance - 12493 - pF Coss output capacitance VDS = 12 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 16 - 2486 - pF Crss reverse transfer capacitance - 1034 - pF © PSMN1R6-30PL_2 Product data sheet Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 5 of 13 PSMN1R6-30PL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET Table 6. Characteristics …continued Tested to JEDEC standards where applicable. Symbol Parameter Conditions Min Typ Max Unit td(on) turn-on delay time - 104 - ns tr rise time VDS = 12 V; RL = 0.5 Ω; VGS = 4.5 V; RG(ext) = 4.7 Ω - 163 - ns td(off) turn-off delay time - 174 - ns tf fall time - 87 - ns Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 17 - 0.77 1.2 V trr reverse recovery time - 64 - ns Qr recovered charge IS = 50 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 15 V - 79 - nC [1] Measured 3 mm from package. 003aad011 300 ID (A) 250 10 3 4.5 3.5 003aad012 10 2.6 RDSon (mΩ) 8 2.8 VGS (V) = 3 200 6 2.8 150 4 100 2.6 4.5 50 VGS (V) = 2.4 10 0 0 0 Fig 5. 3.5 2 2 4 6 8 0 10 VDS (V) Output characteristics: drain current as a function of drain-source voltage; typical values Fig 6. 200 ID (A) 300 Drain-source on-state resistance as a function of drain current; typical values © PSMN1R6-30PL_2 Product data sheet 100 Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 6 of 13 PSMN1R6-30PL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET 003aad013 100 ID (A) 003aad018 400 gfs (S) 80 300 Tj = 175 °C 60 25 °C 200 40 100 20 0 0 0 Fig 7. 1 2 0 3 VGS (V) 4 Transfer characteristics: drain current as a function of gate-source voltage; typical values 003aad019 10 Fig 8. 20 40 60 80 ID (A) 100 Forward transconductance as a function of drain current; typical values 003aad017 105 RDSon (mΩ) C (pF) 8 Ciss 6 104 Crss 4 2 0 0 Fig 9. 5 10 15 VGS (V) 20 Drain-source on-state resistance as a function of gate-source voltage; typical values 103 10-1 10 VGS (V) 102 Fig 10. Input and reverse transfer capacitances as a function of gate-source voltage; typical values © PSMN1R6-30PL_2 Product data sheet 1 Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 7 of 13 PSMN1R6-30PL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET 003aab271 10-1 ID (A) 10-2 003a a c982 3 VGS (th) (V) min typ max max 2 10-3 typ min 10-4 1 10-5 10-6 0 1 2 VGS (V) 3 Fig 11. Sub-threshold drain current as a function of gate-source voltage 0 -60 0 60 120 Tj (°C) 180 Fig 12. Gate-source threshold voltage as a function of junction temperature 03aa27 2 VDS a ID 1.5 VGS(pl) VGS(th) 1 VGS QGS1 0.5 QGS2 QGS QGD QG(tot) 003aaa508 0 −60 0 60 120 Tj (°C) 180 Fig 14. Gate charge waveform definitions Fig 13. Normalized drain-source on-state resistance factor as a function of junction temperature © PSMN1R6-30PL_2 Product data sheet Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 8 of 13 PSMN1R6-30PL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET 003aad015 10 003aad016 105 VGS (V) 8 C (pF) VDS = 15 V Ciss 104 6 Coss 4 103 Crss 2 102 10-1 0 0 40 80 120 160 200 240 QG (nC) 1 2 VDS (V) 10 10 Fig 16. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values Fig 15. Gate-source voltage as a function of gate charge; typical values 003aad014 100 IS (A) 80 60 175 °C 40 20 Tj = 25 °C 0 0 0.2 0.4 0.6 0.8 1 VSD (V) Fig 17. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values © PSMN1R6-30PL_2 Product data sheet Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 9 of 13 PSMN1R6-30PL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET 7. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 E A A1 p q mounting base D1 D L1(1) L2(1) Q L b1(2) (3×) b2(2) (2×) 1 2 3 b(3×) c e e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1(2) b2(2) c D D1 E e L L1(1) L2(1) max. p q Q mm 4.7 4.1 1.40 1.25 0.9 0.6 1.6 1.0 1.3 1.0 0.7 0.4 16.0 15.2 6.6 5.9 10.3 9.7 2.54 15.0 12.8 3.30 2.79 3.0 3.8 3.5 3.0 2.7 2.6 2.2 Notes 1. Lead shoulder designs may vary. 2. Dimension includes excess dambar. OUTLINE VERSION SOT78 REFERENCES IEC JEDEC JEITA 3-lead TO-220AB SC-46 EUROPEAN PROJECTION ISSUE DATE 08-04-23 08-06-13 Fig 18. Package outline SOT78 (TO-220AB) © PSMN1R6-30PL_2 Product data sheet Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 10 of 13 PSMN1R6-30PL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PSMN1R6-30PL_2 20090625 Product data sheet - PSMN1R6-30PL_1 Modifications: PSMN1R6-30PL_1 • • Data sheet status changed from objective to product. Various content changes. 20090518 Objective data sheet - © PSMN1R6-30PL_2 Product data sheet - Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 11 of 13 PSMN1R6-30PL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET 9. Legal information 9.1 Data sheet status Document status [1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 9.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com © PSMN1R6-30PL_2 Product data sheet Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 12 of 13 Nexperia PSMN1R6-30PL N-channel 30 V 1.7 mΩ logic level MOSFET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . .12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Contact information. . . . . . . . . . . . . . . . . . . . . .12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 25 June 2009
PSMN1R6-30PL,127 价格&库存
很抱歉,暂时无法提供与“PSMN1R6-30PL,127”相匹配的价格&库存,您可以联系我们找货
